[U-Boot] [PATCH] net/phy: Fix the phy id mask of AR8031
The both AR8031 and AR8035 belong to Atheros 803x serial PHY. So the phy id mask of AR8031 is the same to the phy id mask of AR8035. The right mask value is 0x4fffff.
This patch has been tested on the P1010 and P1023.
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com Cc: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/phy/atheros.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 0f2dfd6..466988e 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -50,7 +50,7 @@ static struct phy_driver AR8021_driver = { static struct phy_driver AR8031_driver = { .name = "AR8031", .uid = 0x4dd074, - .mask = 0xfffff0, + .mask = 0x4fffff, .features = PHY_GBIT_FEATURES, .config = genphy_config, .startup = genphy_startup,
Chunhe Lan
