[U-Boot] [PATCH] board/ls2085rdb: Export functions for standalone AQ FW load apps
Export functions required by Aquntia PHY firmware load application. functions are memset, strcpy, mdelay, mdio_get_current_dev, phy_find_by_mask, mdio_phydev_for_ethname and miiphy_set_current_dev
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- board/freescale/ls2085ardb/eth_ls2085rdb.c | 15 +++++++++++++++ common/exports.c | 7 +++++++ include/_exports.h | 13 +++++++++++++ include/configs/ls2085ardb.h | 1 + include/exports.h | 13 ++++++++++++- 5 files changed, 48 insertions(+), 1 deletion(-)
diff --git a/board/freescale/ls2085ardb/eth_ls2085rdb.c b/board/freescale/ls2085ardb/eth_ls2085rdb.c index 60af079..0a1163a 100644 --- a/board/freescale/ls2085ardb/eth_ls2085rdb.c +++ b/board/freescale/ls2085ardb/eth_ls2085rdb.c @@ -14,10 +14,13 @@ #include <phy.h> #include <fm_eth.h> #include <asm/io.h> +#include <exports.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch-fsl-lsch3/immap_lsch3.h> #include <fsl-mc/ldpaa_wriop.h>
+DECLARE_GLOBAL_DATA_PTR; + int load_firmware_cortina(struct phy_device *phy_dev) { if (phy_dev->drv->config) @@ -129,5 +132,17 @@ int board_eth_init(bd_t *bis) cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
+#ifdef CONFIG_PHY_AQUANTIA + /* + * Export functions to be used by AQ firmware + * upload application + */ + gd->jt->strcpy = strcpy; + gd->jt->mdelay = mdelay; + gd->jt->mdio_get_current_dev = mdio_get_current_dev; + gd->jt->phy_find_by_mask = phy_find_by_mask; + gd->jt->mdio_phydev_for_ethname = mdio_phydev_for_ethname; + gd->jt->miiphy_set_current_dev = miiphy_set_current_dev; +#endif return pci_eth_init(bis); } diff --git a/common/exports.c b/common/exports.c index 333107c..b4f1f7a 100644 --- a/common/exports.c +++ b/common/exports.c @@ -16,6 +16,13 @@ unsigned long get_version(void)
#define EXPORT_FUNC(f, a, x, ...) gd->jt->x = f;
+#ifndef CONFIG_PHY_AQUANTIA +# define mdio_get_current_dev dummy +# define phy_find_by_mask dummy +# define mdio_phydev_for_ethname dummy +# define miiphy_set_current_dev dummy +#endif + void jumptable_init(void) { gd->jt = malloc(sizeof(struct jt_funcs)); diff --git a/include/_exports.h b/include/_exports.h index 279017e..74a882a 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -73,3 +73,16 @@ const char *, char **, unsigned int) EXPORT_FUNC(ustrtoull, unsigned long long, ustrtoull, const char *, char **, unsigned int) + EXPORT_FUNC(strcpy, char *, strcpy, char *dest, const char *src) + EXPORT_FUNC(mdelay, void, mdelay, unsigned long msec) +#ifdef CONFIG_PHY_AQUANTIA + EXPORT_FUNC(mdio_get_current_dev, struct mii_dev *, + mdio_get_current_dev, void) + EXPORT_FUNC(phy_find_by_mask, struct phy_device *, phy_find_by_mask, + struct mii_dev *bus, unsigned phy_mask, + phy_interface_t interface) + EXPORT_FUNC(mdio_phydev_for_ethname, struct phy_device *, + mdio_phydev_for_ethname, const char *ethname) + EXPORT_FUNC(miiphy_set_current_dev, int, miiphy_set_current_dev, + const char *devname) +#endif diff --git a/include/configs/ls2085ardb.h b/include/configs/ls2085ardb.h index 9f0a96f..b5f2d39 100644 --- a/include/configs/ls2085ardb.h +++ b/include/configs/ls2085ardb.h @@ -325,6 +325,7 @@ unsigned long get_board_sys_clk(void); #define CONFIG_MII #define CONFIG_ETHPRIME "DPNI1" #define CONFIG_PHY_GIGE +#define CONFIG_PHY_AQUANTIA #endif
#endif /* __LS2_RDB_H */ diff --git a/include/exports.h b/include/exports.h index 1a01e43..a3e0469 100644 --- a/include/exports.h +++ b/include/exports.h @@ -2,6 +2,10 @@ #define __EXPORTS_H__
#ifndef __ASSEMBLY__ +#ifdef CONFIG_PHY_AQUANTIA +#include <miiphy.h> +#include <phy.h> +#endif
struct spi_slave;
@@ -34,6 +38,13 @@ unsigned long long ustrtoull(const char *cp, char **endp, unsigned int base); int i2c_write (uchar, uint, int , uchar* , int); int i2c_read (uchar, uint, int , uchar* , int); #endif +#ifdef CONFIG_PHY_AQUANTIA +struct mii_dev *mdio_get_current_dev(void); +struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask, + phy_interface_t interface); +struct phy_device *mdio_phydev_for_ethname(const char *ethname); +int miiphy_set_current_dev(const char *devname); +#endif
void app_startup(char * const *);
@@ -46,7 +57,7 @@ struct jt_funcs { };
-#define XF_VERSION 7 +#define XF_VERSION 8
#if defined(CONFIG_X86) extern gd_t *global_data;
Prabhakar Kushwaha
