[U-Boot] [PATCH 1/5] mx7dsabresd: Staticize when possible
Make the internal symbols static when possible.
This prevents sparse build warnings.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index d163bee..6bd47df 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -44,7 +44,7 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SYS_I2C_MXC #define PC MUX_PAD_CTRL(I2C_PAD_CTRL) /* I2C1 for PMIC */ -struct i2c_pads_info i2c_pad_info1 = { +static struct i2c_pads_info i2c_pad_info1 = { .scl = { .i2c_mode = MX7D_PAD_I2C1_SCL__I2C1_SCL | PC, .gpio_mode = MX7D_PAD_I2C1_SCL__GPIO4_IO8 | PC, @@ -156,7 +156,7 @@ static enum qn_func qn_output[8] = { qn_enable };
-void iox74lv_init(void) +static void iox74lv_init(void) { int i;
@@ -527,11 +527,11 @@ int checkboard(void) }
#ifdef CONFIG_USB_EHCI_MX7 -iomux_v3_cfg_t const usb_otg1_pads[] = { +static iomux_v3_cfg_t const usb_otg1_pads[] = { MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), };
-iomux_v3_cfg_t const usb_otg2_pads[] = { +static iomux_v3_cfg_t const usb_otg2_pads[] = { MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), };
iox74lv_set() is not used anywhere, so let's remove it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 38 ------------------------------- 1 file changed, 38 deletions(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 6bd47df..6c2fc98 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -190,44 +190,6 @@ static void iox74lv_init(void) gpio_direction_output(IOX_STCP, 1); };
-void iox74lv_set(int index) -{ - int i; - for (i = 7; i >= 0; i--) { - gpio_direction_output(IOX_SHCP, 0); - - if (i == index) - gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); - else - gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); - udelay(500); - gpio_direction_output(IOX_SHCP, 1); - udelay(500); - } - - gpio_direction_output(IOX_STCP, 0); - udelay(500); - /* - * shift register will be output to pins - */ - gpio_direction_output(IOX_STCP, 1); - - for (i = 7; i >= 0; i--) { - gpio_direction_output(IOX_SHCP, 0); - gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); - udelay(500); - gpio_direction_output(IOX_SHCP, 1); - udelay(500); - } - - gpio_direction_output(IOX_STCP, 0); - udelay(500); - /* - * shift register will be output to pins - */ - gpio_direction_output(IOX_STCP, 1); -}; - #ifdef CONFIG_FEC_MXC static iomux_v3_cfg_t const fec1_pads[] = { MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_RX_PAD_CTRL),
Best regards, Stefano Babic
Include <usb/ehci-fsl.h> in order to fix the following sparse warning:
board/freescale/mx7dsabresd/mx7dsabresd.c:538:5: warning: symbol 'board_ehci_hcd_init' was not declared. Should it be static?
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 6c2fc98..4c18b5a 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -24,6 +24,7 @@ #include <i2c.h> #include <asm/imx-common/mxc_i2c.h> #include <asm/arch/crm_regs.h> +#include <usb/ehci-fsl.h>
get_board_rev() is not actually providing the board revision.
It just returns the CPU revision instead.
As the CPU revision is already printed on boot, there is no reason to have get_board_rev(), so let's remove it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 4c18b5a..5c37df5 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -477,11 +477,6 @@ int board_late_init(void) return 0; }
-u32 get_board_rev(void) -{ - return get_cpu_rev(); -} - int checkboard(void) { puts("Board: i.MX7D SABRESD\n");
CONFIG_FEC_DMA_MINALIGN is not used anywhere, so let's remove it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx7dsabresd.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index ec6e0a6..2a736c4 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -24,7 +24,6 @@
#define CONFIG_PHYLIB #define CONFIG_PHY_BROADCOM -#define CONFIG_FEC_DMA_MINALIGN 64 /* ENET1 */ #define IMX_FEC_BASE ENET_IPS_BASE_ADDR
Fabio Estevam
Stefano Babic
