[U-Boot] [PATCH 0/3] STM32: Remove STMMAC clock setup from board
As STMMAC designware driver is now able to get and enable STMMAC clocks, we can remove code related to STMMAC clock setup in board and in clk_stm32f driver.
Set SYSCFG clock directly in configure_clocks()
Add missing STMMAC clocks in stm32f746 dts file.
Patrice Chotard (3): ARM: dts: stm32: Add STMMAC clocks for stm32f746 clk: clk_stm32f: Remove STMMAC clock setup clk: clk_stm32f: Move SYSCFG clock setup into configure_clocks()
arch/arm/dts/stm32f746.dtsi | 3 +++ arch/arm/include/asm/arch-stm32f7/stm32_periph.h | 2 -- board/st/stm32f746-disco/stm32f746-disco.c | 20 ++++++-------------- drivers/clk/clk_stm32f.c | 16 ++++------------ 4 files changed, 13 insertions(+), 28 deletions(-)
Add ETHMAC, ETHMACRX and ETHMACTX clocks for STMMAC.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/dts/stm32f746.dtsi | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 929bf82..46d148e 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -65,6 +65,9 @@ compatible = "st,stm32-dwmac"; reg = <0x40028000 0x8000>; reg-names = "stmmaceth"; + clocks = <&rcc 0 STM32F7_AHB1_CLOCK(ETHMAC)>, + <&rcc 0 STM32F7_AHB1_CLOCK(ETHMACTX)>, + <&rcc 0 STM32F7_AHB1_CLOCK(ETHMACRX)>; interrupts = <61>, <62>; interrupt-names = "macirq", "eth_wake_irq"; snps,pbl = <8>;
Reviewed-by: Vikas Manocha vikas.manocha@st.com
Cheers, Vikas
Thanks to 'commit ba1f96672522 ("net: designware: add clock support")' we don't need anymore to setup the STMMAC clock in board.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f7/stm32_periph.h | 1 - board/st/stm32f746-disco/stm32f746-disco.c | 1 - drivers/clk/clk_stm32f.c | 6 ------ 3 files changed, 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h b/arch/arm/include/asm/arch-stm32f7/stm32_periph.h index ae0faef..13f9c9b 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32_periph.h @@ -23,7 +23,6 @@ enum periph_id { enum periph_clock { SYSCFG_CLOCK_CFG, TIMER2_CLOCK_CFG, - STMMAC_CLOCK_CFG, };
#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 2e8aa86..58a5ef0 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -75,7 +75,6 @@ static int stmmac_setup(void) clock_setup(SYSCFG_CLOCK_CFG); /* Set >RMII mode */ STM32_SYSCFG->pmc |= SYSCFG_PMC_MII_RMII_SEL; - clock_setup(STMMAC_CLOCK_CFG);
return 0; } diff --git a/drivers/clk/clk_stm32f.c b/drivers/clk/clk_stm32f.c index 63116e0..d0c7a90 100644 --- a/drivers/clk/clk_stm32f.c +++ b/drivers/clk/clk_stm32f.c @@ -90,7 +90,6 @@ enum periph_clock { SYSCFG_CLOCK_CFG, TIMER2_CLOCK_CFG, - STMMAC_CLOCK_CFG, };
struct stm32_clk_info stm32f4_clk_info = { @@ -359,11 +358,6 @@ void clock_setup(int peripheral) case TIMER2_CLOCK_CFG: setbits_le32(&STM32_RCC->apb1enr, RCC_APB1ENR_TIM2EN); break; - case STMMAC_CLOCK_CFG: - setbits_le32(&STM32_RCC->ahb1enr, RCC_AHB1ENR_ETHMAC_EN); - setbits_le32(&STM32_RCC->ahb1enr, RCC_AHB1ENR_ETHMAC_RX_EN); - setbits_le32(&STM32_RCC->ahb1enr, RCC_AHB1ENR_ETHMAC_TX_EN); - break; default: break; }
Cheers, Vikas
- STMMAC_CLOCK_CFG,
- STMMAC_CLOCK_CFG,
default: break; }break;
Move SYSCFG clock setup into configure_clocks() instead of calling clock_setup() from drivers. Move the RMII setup from board_early_init_f() to board_init() to insure that RMII bit is set only when clock driver is initialized.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f7/stm32_periph.h | 1 - board/st/stm32f746-disco/stm32f746-disco.c | 19 ++++++------------- drivers/clk/clk_stm32f.c | 10 ++++------ 3 files changed, 10 insertions(+), 20 deletions(-)
diff --git a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h b/arch/arm/include/asm/arch-stm32f7/stm32_periph.h index 13f9c9b..7b8f66a 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32_periph.h @@ -21,7 +21,6 @@ enum periph_id { };
enum periph_clock { - SYSCFG_CLOCK_CFG, TIMER2_CLOCK_CFG, };
diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 58a5ef0..8da7028 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -69,23 +69,10 @@ int dram_init_banksize(void) return 0; }
-#ifdef CONFIG_ETH_DESIGNWARE -static int stmmac_setup(void) -{ - clock_setup(SYSCFG_CLOCK_CFG); - /* Set >RMII mode */ - STM32_SYSCFG->pmc |= SYSCFG_PMC_MII_RMII_SEL; - - return 0; -} - int board_early_init_f(void) { - stmmac_setup(); - return 0; } -#endif
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_SPL_OS_BOOT @@ -162,5 +149,11 @@ int board_late_init(void) int board_init(void) { gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + +#ifdef CONFIG_ETH_DESIGNWARE + /* Set >RMII mode */ + STM32_SYSCFG->pmc |= SYSCFG_PMC_MII_RMII_SEL; +#endif + return 0; } diff --git a/drivers/clk/clk_stm32f.c b/drivers/clk/clk_stm32f.c index d0c7a90..1ae5b70 100644 --- a/drivers/clk/clk_stm32f.c +++ b/drivers/clk/clk_stm32f.c @@ -67,8 +67,6 @@ #define RCC_DCKCFGRX_SDMMC1SEL BIT(28) #define RCC_DCKCFGR2_SDMMC2SEL BIT(29)
-#define RCC_APB2ENR_SAI1EN BIT(22) - /* * RCC AHB1ENR specific definitions */ @@ -86,9 +84,9 @@ * RCC APB2ENR specific definitions */ #define RCC_APB2ENR_SYSCFGEN BIT(14) +#define RCC_APB2ENR_SAI1EN BIT(22)
@@ -227,6 +225,9 @@ static int configure_clocks(struct udevice *dev) /* gate the SAI clock, needed for MMC 1&2 clocks */ setbits_le32(®s->apb2enr, RCC_APB2ENR_SAI1EN);
+ /* gate the SYSCFG clock, needed to set RMII ethernet interface */ + setbits_le32(®s->apb2enr, RCC_APB2ENR_SYSCFGEN); + return 0; }
@@ -352,9 +353,6 @@ static int stm32_clk_enable(struct clk *clk) void clock_setup(int peripheral) { switch (peripheral) { - case SYSCFG_CLOCK_CFG: - setbits_le32(&STM32_RCC->apb2enr, RCC_APB2ENR_SYSCFGEN); - break; case TIMER2_CLOCK_CFG: setbits_le32(&STM32_RCC->apb1enr, RCC_APB1ENR_TIM2EN); break;
Hi Patrice,
It is in board configuration.
enum periph_clock {
- stmmac_setup();
} -#endif
- RCC AHB1ENR specific definitions
- RCC APB2ENR specific definitions
enum periph_clock {
- /* gate the SYSCFG clock, needed to set RMII ethernet interface */
RMII interface only required for f746 disco board.
- setbits_le32(®s->apb2enr, RCC_APB2ENR_SYSCFGEN);
RMII & Syscfg is board specific requirement, here it will configure it for all stm32f devices.
Cheers, Vikas
case TIMER2_CLOCK_CFG: setbits_le32(&STM32_RCC->apb1enr, RCC_APB1ENR_TIM2EN); break;break;
Hi Vikas
On 01/17/2018 08:55 PM, Vikas Manocha wrote:
Hi Patrice,
Yes, my comment is badly formulated.
The idea is to remove clock_setup() from clock driver.
enum periph_clock {
- stmmac_setup();
- return 0; }
-#endif
- return 0; }
@@ -86,9 +84,9 @@
enum periph_clock {
You are right, i will update this. As it is currently only needed for ethernet, i will add the CONFIG_ETH_DESIGNWARE flag around.
For information, i will add new stm32f429-evaluation board (already supported in kernel) which provide ethernet connection.
Thanks for reviewing
Patrice
Cheers, Vikas
- return 0; }
Patrice CHOTARD
Vikas Manocha
