[U-Boot] [PATCH] cmd_mem: localize state variables
These "last" variables aren't used outside of this file, so add static.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_mem.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index f7a442a..f03233c 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -48,9 +48,9 @@ static int mod_mem(cmd_tbl_t *, int, int, int, char * const []); /* Display values from last command. * Memory modify remembered values are different from display memory. */ -uint dp_last_addr, dp_last_size; -uint dp_last_length = 0x40; -uint mm_last_addr, mm_last_size; +static uint dp_last_addr, dp_last_size; +static uint dp_last_length = 0x40; +static uint mm_last_addr, mm_last_size;
static ulong base_address = 0;
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
