[PATCH] mx6: Use imx6_src_get_boot_mode() to check boot device
Use imx6_src_get_boot_mode() instead of manually reading SBMR1. The existing function has proper handling for software overrides of the bootdevice which can happen, for example, when booting from an alternate source using `bmode`.
Signed-off-by: Harald Seiler hws@denx.de --- arch/arm/mach-imx/mx6/soc.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index aacfc854a2f8..bc56ef2b0b20 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -498,8 +498,7 @@ __weak int board_mmc_get_env_dev(int devno)
static int mmc_get_boot_dev(void) { - struct src *src_regs = (struct src *)SRC_BASE_ADDR; - u32 soc_sbmr = readl(&src_regs->sbmr1); + u32 soc_sbmr = imx6_src_get_boot_mode(); u32 bootsel; int devno;
Reviewed-by: Fabio Estevam festevam@gmail.com
Use imx6_src_get_boot_mode() instead of manually reading SBMR1. The existing function has proper handling for software overrides of the bootdevice which can happen, for example, when booting from an alternate source using `bmode`. Signed-off-by: Harald Seiler hws@denx.de Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Harald Seiler
sbabic@denx.de
