Fwd: New Defects reported by Coverity Scan for Das U-Boot
________________________________________________________________________________________________________ *** CID 478333: Error handling issues (CHECKED_RETURN) /lib/efi_loader/efi_firmware.c: 413 in efi_firmware_set_fmp_state_var() 407 /* 408 * GetVariable may fail, EFI_NOT_FOUND is returned if FmpState 409 * variable has not been set yet. 410 * Ignore the error here since the correct FmpState variable 411 * is set later. 412 */
CID 478333: Error handling issues (CHECKED_RETURN) Calling "efi_get_variable_int" without checking return value (as is done elsewhere 29 out of 33 times).
413 efi_get_variable_int(varname, image_type_id, NULL, &size, var_state, 414 NULL); 415 416 /* 417 * Only the fw_version is set here. 418 * lowest_supported_version in FmpState variable is ignored since
There are a lot of different return values that may occur when calling efi_get_variable_int, e.g.
* EFI_BUFFER_TOO_SMALL * EFI_DEVICE_ERROR
Should we overwrite the variable in these cases with NUL values except for var_state[update_bank].fw_version?
Best regards
Heinrich
Hi Heinrich,
- EFI_BUFFER_TOO_SMALL
- EFI_DEVICE_ERROR
The var_state buffer is allocated by calloc(), and efi_get_variable_int() will not update the buffer in case of error. But it is better to set NUL values to var_state, I will send a fix.
Thanks, Masahisa Kojima
Best regards
Heinrich
Masahisa Kojima
