[U-Boot] [PATCH v3 0/5] MIPS: Refactoring and cleanup of CPU and SoC code
All current Mips CPUs and SoCs except Purple are based on Mips32 arch. The complete code resides in the global arch/mips/cpu directory. All SoC specific code resides in this directory too. This is not suitable if other Mips architectures like Mips64 or Octeon or new SoCs should be supported in the future.
This patch series refactors the Mips CPU directory and put all current code into an own mips32 subdirectory. Furthermore the SoC specific code of IncaIP and Au1x00 is moved to separate SoC subdirectories. The support for Purple is dropped because not actively maintained anymore.
Changes since RFC/v1: - drop Purple supported as agreed with Wolfgang Denk - use MIPS rather than Mips in patch subject - fixed Cc lines in all patches
Changes since v2: - reverted patch for endianess flag setup - always use -march=mips32r2 as default CPU optimization for all MIPS32 CPU cores
Daniel Schwierzeck (5): MIPS: Purple: Remove Purple support MIPS: Move content of arch/mips/cpu to arch/mips/cpu/mips32 MIPS: Optimize the setup of CPU optimization flags MIPS: IncaIP: Move all IncaIP specific code to separate subdirectory MIPS: Au1x00: Move all Au1x00 specific code to separate subdirectory
MAINTAINERS | 1 - MAKEALL | 4 +- arch/mips/cpu/asc_serial.c | 368 ------------ arch/mips/cpu/{ => mips32}/Makefile | 5 - .../mips/cpu/mips32/au1x00}/Makefile | 15 +- arch/mips/cpu/{ => mips32/au1x00}/au1x00_eth.c | 0 arch/mips/cpu/{ => mips32/au1x00}/au1x00_serial.c | 0 .../mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.c | 0 .../mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.h | 0 .../mips/cpu/mips32/au1x00}/config.mk | 12 +- arch/mips/cpu/{ => mips32}/cache.S | 4 - arch/mips/cpu/{ => mips32}/config.mk | 15 +- arch/mips/cpu/{ => mips32}/cpu.c | 0 .../mips/cpu/mips32/incaip}/Makefile | 16 +- arch/mips/cpu/mips32/incaip/asc_serial.c | 285 ++++++++++ arch/mips/cpu/{ => mips32/incaip}/asc_serial.h | 0 .../mips/cpu/mips32/incaip}/config.mk | 12 +- arch/mips/cpu/{ => mips32/incaip}/incaip_clock.c | 0 arch/mips/cpu/{ => mips32/incaip}/incaip_wdt.S | 0 arch/mips/cpu/{ => mips32}/interrupts.c | 0 arch/mips/cpu/{ => mips32}/start.S | 32 - arch/mips/include/asm/inca-ip.h | 10 - arch/mips/lib/board.c | 10 - board/purple/flash.c | 595 -------------------- board/purple/lowlevel_init.S | 36 -- board/purple/purple.c | 284 ---------- board/purple/sconsole.c | 125 ---- board/purple/sconsole.h | 46 -- board/purple/u-boot.lds | 75 --- boards.cfg | 51 +- doc/README.Purple | 84 --- include/configs/purple.h | 173 ------ 32 files changed, 338 insertions(+), 1920 deletions(-) delete mode 100644 arch/mips/cpu/asc_serial.c rename arch/mips/cpu/{ => mips32}/Makefile (87%) copy {board/purple => arch/mips/cpu/mips32/au1x00}/Makefile (83%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_eth.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_serial.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.h (100%) copy {board/purple => arch/mips/cpu/mips32/au1x00}/config.mk (83%) rename arch/mips/cpu/{ => mips32}/cache.S (98%) rename arch/mips/cpu/{ => mips32}/config.mk (83%) rename arch/mips/cpu/{ => mips32}/cpu.c (100%) rename {board/purple => arch/mips/cpu/mips32/incaip}/Makefile (83%) create mode 100644 arch/mips/cpu/mips32/incaip/asc_serial.c rename arch/mips/cpu/{ => mips32/incaip}/asc_serial.h (100%) rename {board/purple => arch/mips/cpu/mips32/incaip}/config.mk (83%) rename arch/mips/cpu/{ => mips32/incaip}/incaip_clock.c (100%) rename arch/mips/cpu/{ => mips32/incaip}/incaip_wdt.S (100%) rename arch/mips/cpu/{ => mips32}/interrupts.c (100%) rename arch/mips/cpu/{ => mips32}/start.S (92%) delete mode 100644 board/purple/flash.c delete mode 100644 board/purple/lowlevel_init.S delete mode 100644 board/purple/purple.c delete mode 100644 board/purple/sconsole.c delete mode 100644 board/purple/sconsole.h delete mode 100644 board/purple/u-boot.lds delete mode 100644 doc/README.Purple delete mode 100644 include/configs/purple.h
-- 1.7.4.1
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Wolfgang Denk wd@denx.de --- MAINTAINERS | 1 - MAKEALL | 4 +- arch/mips/cpu/Makefile | 1 - arch/mips/cpu/asc_serial.c | 83 ------ arch/mips/cpu/cache.S | 4 - arch/mips/cpu/start.S | 32 -- arch/mips/include/asm/inca-ip.h | 10 - arch/mips/lib/board.c | 10 - board/purple/Makefile | 46 --- board/purple/config.mk | 32 -- board/purple/flash.c | 595 --------------------------------------- board/purple/lowlevel_init.S | 36 --- board/purple/purple.c | 284 ------------------- board/purple/sconsole.c | 125 -------- board/purple/sconsole.h | 46 --- board/purple/u-boot.lds | 75 ----- boards.cfg | 1 - doc/README.Purple | 84 ------ include/configs/purple.h | 173 ------------ 19 files changed, 1 insertions(+), 1641 deletions(-) delete mode 100644 board/purple/Makefile delete mode 100644 board/purple/config.mk delete mode 100644 board/purple/flash.c delete mode 100644 board/purple/lowlevel_init.S delete mode 100644 board/purple/purple.c delete mode 100644 board/purple/sconsole.c delete mode 100644 board/purple/sconsole.h delete mode 100644 board/purple/u-boot.lds delete mode 100644 doc/README.Purple delete mode 100644 include/configs/purple.h
diff --git a/MAINTAINERS b/MAINTAINERS index 4756f14..1d7e1f4 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -919,7 +919,6 @@ Daniel Engstr Wolfgang Denk wd@denx.de
incaip MIPS32 4Kc - purple MIPS64 5Kc
Thomas Lange thomas@corelatus.se dbau1x00 MIPS32 Au1000 diff --git a/MAKEALL b/MAKEALL index a732e6a..e1b928f 100755 --- a/MAKEALL +++ b/MAKEALL @@ -507,9 +507,7 @@ LIST_mips4kc=" \ vct_premium_onenand_small \ "
-LIST_mips5kc=" \ - purple \ -" +LIST_mips5kc=""
LIST_au1xx0=" \ dbau1000 \ diff --git a/arch/mips/cpu/Makefile b/arch/mips/cpu/Makefile index 06df8d1..816b76c 100644 --- a/arch/mips/cpu/Makefile +++ b/arch/mips/cpu/Makefile @@ -31,7 +31,6 @@ COBJS-y = cpu.o interrupts.o
SOBJS-$(CONFIG_INCA_IP) += incaip_wdt.o COBJS-$(CONFIG_INCA_IP) += asc_serial.o incaip_clock.o -COBJS-$(CONFIG_PURPLE) += asc_serial.o COBJS-$(CONFIG_SOC_AU1X00) += au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/mips/cpu/asc_serial.c b/arch/mips/cpu/asc_serial.c index be686c2..7239804 100644 --- a/arch/mips/cpu/asc_serial.c +++ b/arch/mips/cpu/asc_serial.c @@ -3,47 +3,10 @@ */
#include <config.h> - -#ifdef CONFIG_PURPLE -#define serial_init asc_serial_init -#define serial_putc asc_serial_putc -#define serial_puts asc_serial_puts -#define serial_getc asc_serial_getc -#define serial_tstc asc_serial_tstc -#define serial_setbrg asc_serial_setbrg -#endif - #include <common.h> #include <asm/inca-ip.h> #include "asc_serial.h"
-#ifdef CONFIG_PURPLE - -#undef ASC_FIFO_PRESENT -#define TOUT_LOOP 100000 - -/* Set base address for second FPI interrupt control register bank */ -#define SFPI_INTCON_BASEADDR 0xBF0F0000 - -/* Register offset from base address */ -#define FBS_ISR 0x00000000 /* Interrupt status register */ -#define FBS_IMR 0x00000008 /* Interrupt mask register */ -#define FBS_IDIS 0x00000010 /* Interrupt disable register */ - -/* Interrupt status register bits */ -#define FBS_ISR_AT 0x00000040 /* ASC transmit interrupt */ -#define FBS_ISR_AR 0x00000020 /* ASC receive interrupt */ -#define FBS_ISR_AE 0x00000010 /* ASC error interrupt */ -#define FBS_ISR_AB 0x00000008 /* ASC transmit buffer interrupt */ -#define FBS_ISR_AS 0x00000004 /* ASC start of autobaud detection interrupt */ -#define FBS_ISR_AF 0x00000002 /* ASC end of autobaud detection interrupt */ - -#else - -#define ASC_FIFO_PRESENT - -#endif -
#define SET_BIT(reg, mask) reg |= (mask) #define CLEAR_BIT(reg, mask) reg &= (~mask) @@ -71,10 +34,8 @@ static volatile incaAsc_t *pAsc = (incaAsc_t *)INCA_IP_ASC;
int serial_init (void) { -#ifdef CONFIG_INCA_IP /* we have to set PMU.EN13 bit to enable an ASC device*/ INCAASC_PMU_ENABLE(13); -#endif
/* and we have to set CLC register*/ CLEAR_BIT(pAsc->asc_clc, ASCCLC_DISS); @@ -86,7 +47,6 @@ int serial_init (void) /* select input port */ pAsc->asc_pisel = (CONSOLE_TTY & 0x1);
-#ifdef ASC_FIFO_PRESENT /* TXFIFO's filling level */ SET_BITFIELD(pAsc->asc_txfcon, ASCTXFCON_TXFITLMASK, ASCTXFCON_TXFITLOFF, INCAASC_TXFIFO_FL); @@ -98,25 +58,20 @@ int serial_init (void) ASCRXFCON_RXFITLOFF, INCAASC_RXFIFO_FL); /* enable RXFIFO */ SET_BIT(pAsc->asc_rxfcon, ASCRXFCON_RXFEN); -#endif
/* enable error signals */ SET_BIT(pAsc->asc_con, ASCCON_FEN); SET_BIT(pAsc->asc_con, ASCCON_OEN);
-#ifdef CONFIG_INCA_IP /* acknowledge ASC interrupts */ ASC_INTERRUPTS_CLEAR(INCAASC_IRQ_LINE_ALL);
/* disable ASC interrupts */ ASC_INTERRUPTS_DISABLE(INCAASC_IRQ_LINE_ALL); -#endif
-#ifdef ASC_FIFO_PRESENT /* set FIFOs into the transparent mode */ SET_BIT(pAsc->asc_txfcon, ASCTXFCON_TXTMEN); SET_BIT(pAsc->asc_rxfcon, ASCRXFCON_RXTMEN); -#endif
/* set baud rate */ serial_setbrg(); @@ -132,11 +87,7 @@ void serial_setbrg (void) ulong uiReloadValue, fdv; ulong f_ASC;
-#ifdef CONFIG_INCA_IP f_ASC = incaip_get_fpiclk(); -#else - f_ASC = ASC_CLOCK_RATE; -#endif
#ifndef INCAASC_USE_FDV fdv = 2; @@ -261,15 +212,10 @@ static int serial_setopt (void)
void serial_putc (const char c) { -#ifdef ASC_FIFO_PRESENT uint txFl = 0; -#else - uint timeout = 0; -#endif
if (c == '\n') serial_putc ('\r');
-#ifdef ASC_FIFO_PRESENT /* check do we have a free space in the TX FIFO */ /* get current filling level */ do @@ -277,25 +223,9 @@ void serial_putc (const char c) txFl = ( pAsc->asc_fstat & ASCFSTAT_TXFFLMASK ) >> ASCFSTAT_TXFFLOFF; } while ( txFl == INCAASC_TXFIFO_FULL ); -#else - - while(!(*(volatile unsigned long*)(SFPI_INTCON_BASEADDR + FBS_ISR) & - FBS_ISR_AB)) - { - if (timeout++ > TOUT_LOOP) - { - break; - } - } -#endif
pAsc->asc_tbuf = c; /* write char to Transmit Buffer Register */
-#ifndef ASC_FIFO_PRESENT - *(volatile unsigned long*)(SFPI_INTCON_BASEADDR + FBS_ISR) = FBS_ISR_AB | - FBS_ISR_AT; -#endif - /* check for errors */ if ( pAsc->asc_con & ASCCON_OE ) { @@ -324,10 +254,6 @@ int serial_getc (void)
c = (char)(pAsc->asc_rbuf & symbol_mask);
-#ifndef ASC_FIFO_PRESENT - *(volatile unsigned long*)(SFPI_INTCON_BASEADDR + FBS_ISR) = FBS_ISR_AR; -#endif - return c; }
@@ -335,19 +261,10 @@ int serial_tstc (void) { int res = 1;
-#ifdef ASC_FIFO_PRESENT if ( (pAsc->asc_fstat & ASCFSTAT_RXFFLMASK) == 0 ) { res = 0; } -#else - if (!(*(volatile unsigned long*)(SFPI_INTCON_BASEADDR + FBS_ISR) & - FBS_ISR_AR)) - - { - res = 0; - } -#endif else if ( pAsc->asc_con & ASCCON_FE ) { SET_BIT(pAsc->asc_whbcon, ASCWHBCON_CLRFE); diff --git a/arch/mips/cpu/cache.S b/arch/mips/cpu/cache.S index 4b30c89..2965938 100644 --- a/arch/mips/cpu/cache.S +++ b/arch/mips/cpu/cache.S @@ -311,11 +311,7 @@ LEAF(dcache_enable) * RETURNS: N/A * */ -#if defined(CONFIG_PURPLE) -# define CACHE_LOCK_SIZE (CONFIG_SYS_DCACHE_SIZE/2) -#else # define CACHE_LOCK_SIZE (CONFIG_SYS_DCACHE_SIZE) -#endif .globl mips_cache_lock .ent mips_cache_lock mips_cache_lock: diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index d6bcef6..e661d46 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -67,9 +67,6 @@ _start: #if defined(CONFIG_INCA_IP) .word INFINEON_EBU_BOOTCFG /* EBU init code, fetched during booting */ .word 0x00000000 /* phase of the flash */ -#elif defined(CONFIG_PURPLE) - .word INFINEON_EBU_BOOTCFG /* EBU init code, fetched during booting */ - .word INFINEON_EBU_BOOTCFG /* EBU init code, fetched during booting */ #else RVECENT(romReserved,2) #endif @@ -203,30 +200,6 @@ _start: * 128 * 8 == 1024 == 0x400 * so this is address R_VEC+0x400 == 0xbfc00400 */ -#ifdef CONFIG_PURPLE -/* 0xbfc00400 */ - .word 0xdc870000 - .word 0xfca70000 - .word 0x20840008 - .word 0x20a50008 - .word 0x20c6ffff - .word 0x14c0fffa - .word 0x00000000 - .word 0x03e00008 - .word 0x00000000 - .word 0x00000000 -/* 0xbfc00428 */ - .word 0xdc870000 - .word 0xfca70000 - .word 0x20840008 - .word 0x20a50008 - .word 0x20c6ffff - .word 0x14c0fffa - .word 0x00000000 - .word 0x03e00008 - .word 0x00000000 - .word 0x00000000 -#endif /* CONFIG_PURPLE */ .align 4 reset:
@@ -337,17 +310,12 @@ relocate_code: move a0, t1 /* a0 <-- destination addr */ sub a1, t2, t0 /* a1 <-- size */
- /* On the purple board we copy the code earlier in a special way - * in order to solve flash problems - */ -#ifndef CONFIG_PURPLE 1: lw t3, 0(t0) sw t3, 0(t1) addu t0, 4 ble t0, t2, 1b addu t1, 4 /* delay slot */ -#endif
/* If caches were enabled, we would have to flush them here. */ diff --git a/arch/mips/include/asm/inca-ip.h b/arch/mips/include/asm/inca-ip.h index e787a1d..26f1002 100644 --- a/arch/mips/include/asm/inca-ip.h +++ b/arch/mips/include/asm/inca-ip.h @@ -894,12 +894,7 @@ /* Module : EBU register address and bits */ /***********************************************************************/
-#if defined(CONFIG_INCA_IP) #define INCA_IP_EBU (0xB8000200) -#elif defined(CONFIG_PURPLE) -#define INCA_IP_EBU (0xB800D800) -#endif - /***********************************************************************/
@@ -1495,12 +1490,7 @@ If set and clear bit are written concurrently with 1, the associated bit is not /* Module : ASC register address and bits */ /***********************************************************************/
-#if defined(CONFIG_INCA_IP) #define INCA_IP_ASC (0xB8000400) -#elif defined(CONFIG_PURPLE) -#define INCA_IP_ASC (0xBE500000) -#endif - /***********************************************************************/
diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index f317124..623c4d7 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -162,9 +162,6 @@ void board_init_f(ulong bootflag) init_fnc_t **init_fnc_ptr; ulong addr, addr_sp, len = (ulong)&uboot_end - CONFIG_SYS_MONITOR_BASE; ulong *s; -#ifdef CONFIG_PURPLE - void copy_code (ulong); -#endif
/* Pointer is writable since we allocated a register for it. */ @@ -253,13 +250,6 @@ void board_init_f(ulong bootflag)
memcpy (id, (void *)gd, sizeof (gd_t));
- /* On the purple board we copy the code in a special way - * in order to solve flash problems - */ -#ifdef CONFIG_PURPLE - copy_code(addr); -#endif - relocate_code (addr_sp, id, addr);
/* NOTREACHED - relocate_code() does not return */ diff --git a/board/purple/Makefile b/board/purple/Makefile deleted file mode 100644 index 10e566d..0000000 --- a/board/purple/Makefile +++ /dev/null @@ -1,46 +0,0 @@ - -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o sconsole.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/purple/config.mk b/board/purple/config.mk deleted file mode 100644 index 404c3fb..0000000 --- a/board/purple/config.mk +++ /dev/null @@ -1,32 +0,0 @@ -# -# (C) Copyright 2003 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -# -# Purple board with MIPS 5Kc CPU core -# - -# ROM version -CONFIG_SYS_TEXT_BASE = 0xB0000000 - -# RAM version -#CONFIG_SYS_TEXT_BASE = 0x80100000 diff --git a/board/purple/flash.c b/board/purple/flash.c deleted file mode 100644 index 5cee35e..0000000 --- a/board/purple/flash.c +++ /dev/null @@ -1,595 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/inca-ip.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -typedef unsigned long FLASH_PORT_WIDTH; -typedef volatile unsigned long FLASH_PORT_WIDTHV; - -#define FLASH_ID_MASK 0xFFFFFFFF - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -#define ORMASK(size) ((-size) & OR_AM_MSK) - -#define FLASH29_REG_ADRS(reg) ((FPWV *)PHYS_FLASH_1 + (reg)) - -/* FLASH29 command register addresses */ - -#define FLASH29_REG_FIRST_CYCLE FLASH29_REG_ADRS (0x1555) -#define FLASH29_REG_SECOND_CYCLE FLASH29_REG_ADRS (0x2aaa) -#define FLASH29_REG_THIRD_CYCLE FLASH29_REG_ADRS (0x3555) -#define FLASH29_REG_FOURTH_CYCLE FLASH29_REG_ADRS (0x4555) -#define FLASH29_REG_FIFTH_CYCLE FLASH29_REG_ADRS (0x5aaa) -#define FLASH29_REG_SIXTH_CYCLE FLASH29_REG_ADRS (0x6555) - -/* FLASH29 command definitions */ - -#define FLASH29_CMD_FIRST 0xaaaaaaaa -#define FLASH29_CMD_SECOND 0x55555555 -#define FLASH29_CMD_FOURTH 0xaaaaaaaa -#define FLASH29_CMD_FIFTH 0x55555555 -#define FLASH29_CMD_SIXTH 0x10101010 - -#define FLASH29_CMD_SECTOR 0x30303030 -#define FLASH29_CMD_PROGRAM 0xa0a0a0a0 -#define FLASH29_CMD_CHIP_ERASE 0x80808080 -#define FLASH29_CMD_READ_RESET 0xf0f0f0f0 -#define FLASH29_CMD_AUTOSELECT 0x90909090 -#define FLASH29_CMD_READ 0x70707070 - -#define IN_RAM_CMD_READ 0x1 -#define IN_RAM_CMD_WRITE 0x2 - -#define FLASH_WRITE_CMD ((ulong)(flash_write_cmd) & 0x7)+0xbf008000 -#define FLASH_READ_CMD ((ulong)(flash_read_cmd) & 0x7)+0xbf008000 - -typedef void (*FUNCPTR_CP)(ulong *source, ulong *destination, ulong nlongs); -typedef void (*FUNCPTR_RD)(int cmd, FPWV * pFA, char * string, int strLen); -typedef void (*FUNCPTR_WR)(int cmd, FPWV * pFA, FPW value); - -static ulong flash_get_size(FPWV *addr, flash_info_t *info); -static int write_word(flash_info_t *info, FPWV *dest, FPW data); -static void flash_get_offsets(ulong base, flash_info_t *info); -static flash_info_t *flash_get_info(ulong base); - -static void load_cmd(ulong cmd); -static ulong in_ram_cmd = 0; - - -/****************************************************************************** -* -* Don't change the program architecture -* This architecture assure the program -* can be relocated to scratch ram -*/ -static void flash_read_cmd(int cmd, FPWV * pFA, char * string, int strLen) -{ - int i,j; - FPW temp,temp1; - FPWV *str; - - str = (FPWV *)string; - - j= strLen/4; - - if(cmd == FLASH29_CMD_AUTOSELECT) - { - *(FLASH29_REG_FIRST_CYCLE) = FLASH29_CMD_FIRST; - *(FLASH29_REG_SECOND_CYCLE) = FLASH29_CMD_SECOND; - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_AUTOSELECT; - } - - if(cmd == FLASH29_CMD_READ) - { - i = 0; - while(i<j) - { - temp = *pFA++; - temp1 = *(int *)0xa0000000; - *(int *)0xbf0081f8 = temp1 + temp; - *str++ = temp; - i++; - } - } - - if(cmd == FLASH29_CMD_READ_RESET) - { - *(FLASH29_REG_FIRST_CYCLE) = FLASH29_CMD_FIRST; - *(FLASH29_REG_SECOND_CYCLE) = FLASH29_CMD_SECOND; - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_READ_RESET; - } - - *(int *)0xbf0081f8 = *(int *)0xa0000000; /* dummy read switch back to sdram interface */ -} - -/****************************************************************************** -* -* Don't change the program architecture -* This architecture assure the program -* can be relocated to scratch ram -*/ -static void flash_write_cmd(int cmd, FPWV * pFA, FPW value) -{ - *(FLASH29_REG_FIRST_CYCLE) = FLASH29_CMD_FIRST; - *(FLASH29_REG_SECOND_CYCLE) = FLASH29_CMD_SECOND; - - if (cmd == FLASH29_CMD_SECTOR) - { - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_CHIP_ERASE; - *(FLASH29_REG_FOURTH_CYCLE) = FLASH29_CMD_FOURTH; - *(FLASH29_REG_FIFTH_CYCLE) = FLASH29_CMD_FIFTH; - *pFA = FLASH29_CMD_SECTOR; - } - - if (cmd == FLASH29_CMD_SIXTH) - { - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_CHIP_ERASE; - *(FLASH29_REG_FOURTH_CYCLE) = FLASH29_CMD_FOURTH; - *(FLASH29_REG_FIFTH_CYCLE) = FLASH29_CMD_FIFTH; - *(FLASH29_REG_SIXTH_CYCLE) = FLASH29_CMD_SIXTH; - } - - if (cmd == FLASH29_CMD_PROGRAM) - { - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_PROGRAM; - *pFA = value; - } - - if (cmd == FLASH29_CMD_READ_RESET) - { - *(FLASH29_REG_THIRD_CYCLE) = FLASH29_CMD_READ_RESET; - } - - *(int *)0xbf0081f8 = *(int *)0xa0000000; /* dummy read switch back to sdram interface */ -} - -static void load_cmd(ulong cmd) -{ - ulong *src; - ulong *dst; - FUNCPTR_CP absEntry; - ulong func; - - if (in_ram_cmd & cmd) return; - - if (cmd == IN_RAM_CMD_READ) - { - func = (ulong)flash_read_cmd; - } - else - { - func = (ulong)flash_write_cmd; - } - - src = (ulong *)(func & 0xfffffff8); - dst = (ulong *)0xbf008000; - absEntry = (FUNCPTR_CP)(0xbf0081d0); - absEntry(src,dst,0x38); - - in_ram_cmd = cmd; -} - -/*----------------------------------------------------------------------- - * flash_init() - * - * sets up flash_info and returns size of FLASH (bytes) - */ -unsigned long flash_init (void) -{ - unsigned long size = 0; - int i; - - load_cmd(IN_RAM_CMD_READ); - - /* Init: no FLASHes known */ - for (i=0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - ulong flashbase = PHYS_FLASH_1; - ulong * buscon = (ulong *) INCA_IP_EBU_EBU_BUSCON0; - - /* Disable write protection */ - *buscon &= ~INCA_IP_EBU_EBU_BUSCON1_WRDIS; - -#if 1 - memset(&flash_info[i], 0, sizeof(flash_info_t)); -#endif - - flash_info[i].size = - flash_get_size((FPW *)flashbase, &flash_info[i]); - - if (flash_info[i].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx\n", - i, flash_info[i].size); - } - - size += flash_info[i].size; - } - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - flash_get_info(CONFIG_SYS_MONITOR_BASE)); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - flash_get_info(CONFIG_ENV_ADDR)); -#endif - - return size; -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_AMD - && (info->flash_id & FLASH_TYPEMASK) == FLASH_AM160B) { - - int bootsect_size[4]; /* number of bytes/boot sector */ - int sect_size; /* number of bytes/regular sector */ - - bootsect_size[0] = 0x00008000; - bootsect_size[1] = 0x00004000; - bootsect_size[2] = 0x00004000; - bootsect_size[3] = 0x00010000; - sect_size = 0x00020000; - - /* set sector offsets for bottom boot block type */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += i < 4 ? bootsect_size[i] : sect_size; - } - } -} - -/*----------------------------------------------------------------------- - */ - -static flash_info_t *flash_get_info(ulong base) -{ - int i; - flash_info_t * info; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i ++) { - info = & flash_info[i]; - if (info->start[0] <= base && base < info->start[0] + info->size) - break; - } - - return i == CONFIG_SYS_MAX_FLASH_BANKS ? 0 : info; -} - -/*----------------------------------------------------------------------- - */ - -void flash_print_info (flash_info_t *info) -{ - int i; - uchar *boottype; - uchar *bootletter; - char *fmt; - uchar botbootletter[] = "B"; - uchar topbootletter[] = "T"; - uchar botboottype[] = "bottom boot sector"; - uchar topboottype[] = "top boot sector"; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_BM: printf ("BRIGHT MICRO "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_SST: printf ("SST "); break; - case FLASH_MAN_STM: printf ("STM "); break; - case FLASH_MAN_INTEL: printf ("INTEL "); break; - default: printf ("Unknown Vendor "); break; - } - - /* check for top or bottom boot, if it applies */ - if (info->flash_id & FLASH_BTYPE) { - boottype = botboottype; - bootletter = botbootletter; - } - else { - boottype = topboottype; - bootletter = topbootletter; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM160B: - fmt = "29LV160B%s (16 Mbit, %s)\n"; - break; - case FLASH_28F800C3B: - case FLASH_28F800C3T: - fmt = "28F800C3%s (8 Mbit, %s)\n"; - break; - case FLASH_INTEL800B: - case FLASH_INTEL800T: - fmt = "28F800B3%s (8 Mbit, %s)\n"; - break; - case FLASH_28F160C3B: - case FLASH_28F160C3T: - fmt = "28F160C3%s (16 Mbit, %s)\n"; - break; - case FLASH_INTEL160B: - case FLASH_INTEL160T: - fmt = "28F160B3%s (16 Mbit, %s)\n"; - break; - case FLASH_28F320C3B: - case FLASH_28F320C3T: - fmt = "28F320C3%s (32 Mbit, %s)\n"; - break; - case FLASH_INTEL320B: - case FLASH_INTEL320T: - fmt = "28F320B3%s (32 Mbit, %s)\n"; - break; - case FLASH_28F640C3B: - case FLASH_28F640C3T: - fmt = "28F640C3%s (64 Mbit, %s)\n"; - break; - case FLASH_INTEL640B: - case FLASH_INTEL640T: - fmt = "28F640B3%s (64 Mbit, %s)\n"; - break; - default: - fmt = "Unknown Chip Type\n"; - break; - } - - printf (fmt, bootletter, boottype); - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, - info->sector_count); - - printf (" Sector Start Addresses:"); - - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) { - printf ("\n "); - } - - printf (" %08lX%s", info->start[i], - info->protect[i] ? " (RO)" : " "); - } - - printf ("\n"); -} - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -ulong flash_get_size (FPWV *addr, flash_info_t *info) -{ - FUNCPTR_RD absEntry; - FPW retValue; - int flag; - - load_cmd(IN_RAM_CMD_READ); - absEntry = (FUNCPTR_RD)FLASH_READ_CMD; - - flag = disable_interrupts(); - absEntry(FLASH29_CMD_AUTOSELECT,0,0,0); - if (flag) enable_interrupts(); - - udelay(100); - - flag = disable_interrupts(); - absEntry(FLASH29_CMD_READ, addr + 1, (char *)&retValue, sizeof(retValue)); - absEntry(FLASH29_CMD_READ_RESET,0,0,0); - if (flag) enable_interrupts(); - - udelay(100); - - switch (retValue) { - - case (FPW)AMD_ID_LV160B: - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 8 or 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* => no or unknown flash */ - } - - flash_get_offsets((ulong)addr, info); - - return (info->size); -} - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - FPWV *addr; - int flag, prot, sect; - ulong start, now, last; - FUNCPTR_WR absEntry; - - load_cmd(IN_RAM_CMD_WRITE); - absEntry = (FUNCPTR_WR)FLASH_WRITE_CMD; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM160B: - break; - case FLASH_UNKNOWN: - default: - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - last = get_timer(0); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - - if (info->protect[sect] != 0) /* protected, skip it */ - continue; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr = (FPWV *)(info->start[sect]); - absEntry(FLASH29_CMD_SECTOR, addr, 0); - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - start = get_timer(0); - - while ((now = get_timer(start)) <= CONFIG_SYS_FLASH_ERASE_TOUT) { - - /* show that we're waiting */ - if ((get_timer(last)) > CONFIG_SYS_HZ) {/* every second */ - putc ('.'); - last = get_timer(0); - } - } - - flag = disable_interrupts(); - absEntry(FLASH29_CMD_READ_RESET,0,0); - if (flag) - enable_interrupts(); - } - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - FPW data = 0; /* 16 or 32 bit word, matches flash bus width on MPC8XX */ - int bytes; /* number of bytes to program in current word */ - int left; /* number of bytes left to program */ - int i, res; - - for (left = cnt, res = 0; - left > 0 && res == 0; - addr += sizeof(data), left -= sizeof(data) - bytes) { - - bytes = addr & (sizeof(data) - 1); - addr &= ~(sizeof(data) - 1); - - /* combine source and destination data so can program - * an entire word of 16 or 32 bits - */ - for (i = 0; i < sizeof(data); i++) { - data <<= 8; - if (i < bytes || i - bytes >= left ) - data += *((uchar *)addr + i); - else - data += *src++; - } - - res = write_word(info, (FPWV *)addr, data); - } - - return (res); -} - -static int write_word (flash_info_t *info, FPWV *dest, FPW data) -{ - int res = 0; /* result, assume success */ - FUNCPTR_WR absEntry; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*dest & data) != data) { - return (2); - } - - if (info->start[0] != PHYS_FLASH_1) - { - return (3); - } - - load_cmd(IN_RAM_CMD_WRITE); - absEntry = (FUNCPTR_WR)FLASH_WRITE_CMD; - - flag = disable_interrupts(); - absEntry(FLASH29_CMD_PROGRAM,dest,data); - if (flag) enable_interrupts(); - - udelay(100); - - flag = disable_interrupts(); - absEntry(FLASH29_CMD_READ_RESET,0,0); - if (flag) enable_interrupts(); - - return (res); -} diff --git a/board/purple/lowlevel_init.S b/board/purple/lowlevel_init.S deleted file mode 100644 index 1bd3edb..0000000 --- a/board/purple/lowlevel_init.S +++ /dev/null @@ -1,36 +0,0 @@ -/* - * Memory sub-system initialization code for PURPLE development board. - * - * Copyright (c) 2003 Wolfgang Denk wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <asm/regdef.h> - -#define MC_IOGP 0xBF800800 - - .globl lowlevel_init -lowlevel_init: - li t0, MC_IOGP - li t1, 0xf24 - sw t1, 0(t0) - jr ra - nop diff --git a/board/purple/purple.c b/board/purple/purple.c deleted file mode 100644 index 4e9e700..0000000 --- a/board/purple/purple.c +++ /dev/null @@ -1,284 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <netdev.h> -#include <asm/inca-ip.h> -#include <asm/regdef.h> -#include <asm/mipsregs.h> -#include <asm/io.h> -#include <asm/addrspace.h> -#include <asm/cacheops.h> -#include <asm/reboot.h> - -#include "sconsole.h" - -#define cache_unroll(base,op) \ - __asm__ __volatile__(" \ - .set noreorder; \ - .set mips3; \ - cache %1, (%0); \ - .set mips0; \ - .set reorder" \ - : \ - : "r" (base), \ - "i" (op)); - -typedef void (*FUNCPTR)(ulong *source, ulong *destination, ulong nlongs); - -extern void asc_serial_init (void); -extern void asc_serial_putc (char); -extern void asc_serial_puts (const char *); -extern int asc_serial_getc (void); -extern int asc_serial_tstc (void); -extern void asc_serial_setbrg (void); - -void _machine_restart(void) -{ - void (*f)(void) = (void *) 0xbfc00000; - - f(); -} - -static void sdram_timing_init (ulong size) -{ - register uint pass; - register uint done; - register uint count; - register uint p0, p1, p2, p3, p4; - register uint addr; - -#define WRITE_MC_IOGP_1 *(uint *)0xbf800800 = (p1<<14)+(p2<<13)+(p4<<8)+(p0<<4)+p3; -#define WRITE_MC_IOGP_2 *(uint *)0xbf800800 = (p1<<14)+(p2<<13)+((p4-16)<<8)+(p0<<4)+p3; - - done = 0; - p0 = 2; - while (p0 < 4 && done == 0) { - p1 = 0; - while (p1 < 2 && done == 0) { - p2 = 0; - while (p2 < 2 && done == 0) { - p3 = 0; - while (p3 < 16 && done == 0) { - count = 0; - p4 = 0; - while (p4 < 32 && done == 0) { - WRITE_MC_IOGP_1; - - for (addr = CKSEG1 + 0x4000; - addr < CKSEG1ADDR (size); - addr = addr + 4) { - *(uint *) addr = 0xaa55aa55; - } - - pass = 1; - - for (addr = CKSEG1 + 0x4000; - addr < CKSEG1ADDR (size) && pass == 1; - addr = addr + 4) { - if (*(uint *) addr != 0xaa55aa55) - pass = 0; - } - - if (pass == 1) { - count++; - } else { - count = 0; - } - - if (count == 32) { - WRITE_MC_IOGP_2; - done = 1; - } - p4++; - } - p3++; - } - p2++; - } - p1++; - } - p0++; - if (p0 == 1) - p0++; - } -} - -phys_size_t initdram(int board_type) -{ - /* The only supported number of SDRAM banks is 4. - */ -#define CONFIG_SYS_NB 4 - - ulong cfgpb0 = *INCA_IP_SDRAM_MC_CFGPB0; - ulong cfgdw = *INCA_IP_SDRAM_MC_CFGDW; - int cols = cfgpb0 & 0xF; - int rows = (cfgpb0 & 0xF0) >> 4; - int dw = cfgdw & 0xF; - ulong size = (1 << (rows + cols)) * (1 << (dw - 1)) * CONFIG_SYS_NB; - void (* sdram_init) (ulong); - - sdram_init = (void (*)(ulong)) CKSEG0ADDR(&sdram_timing_init); - - sdram_init(0x10000); - - return size; -} - -int checkboard (void) -{ - - unsigned long chipid = *(unsigned long *)0xB800C800; - - printf ("Board: Purple PLB 2800 chip version %ld, ", chipid & 0xF); - - printf("CPU Speed %d MHz\n", CPU_CLOCK_RATE/1000000); - - set_io_port_base(0); - - return 0; -} - -int misc_init_r (void) -{ - asc_serial_init (); - - sconsole_putc = asc_serial_putc; - sconsole_puts = asc_serial_puts; - sconsole_getc = asc_serial_getc; - sconsole_tstc = asc_serial_tstc; - sconsole_setbrg = asc_serial_setbrg; - - sconsole_flush (); - return (0); -} - -/******************************************************************************* -* -* copydwords - copy one buffer to another a long at a time -* -* This routine copies the first <nlongs> longs from <source> to <destination>. -*/ -static void copydwords (ulong *source, ulong *destination, ulong nlongs) -{ - ulong temp,temp1; - ulong *dstend = destination + nlongs; - - while (destination < dstend) { - temp = *source++; - /* dummy read from sdram */ - temp1 = *(ulong *)0xa0000000; - /* avoid optimization from compliler */ - *(ulong *)0xbf0081f8 = temp1 + temp; - *destination++ = temp; - - } -} - -/******************************************************************************* -* -* copyLongs - copy one buffer to another a long at a time -* -* This routine copies the first <nlongs> longs from <source> to <destination>. -*/ -static void copyLongs (ulong *source, ulong *destination, ulong nlongs) -{ - FUNCPTR absEntry; - - absEntry = (FUNCPTR)(0xbf008000+((ulong)copydwords & 0x7)); - absEntry(source, destination, nlongs); -} - -/******************************************************************************* -* -* programLoad - load program into ram -* -* This routine load copydwords into ram -* -*/ -static void programLoad(void) -{ - FUNCPTR absEntry; - ulong *src,*dst; - - src = (ulong *)(CONFIG_SYS_TEXT_BASE + 0x428); - dst = (ulong *)0xbf0081d0; - - absEntry = (FUNCPTR)(CONFIG_SYS_TEXT_BASE + 0x400); - absEntry(src,dst,0x6); - - src = (ulong *)((ulong)copydwords & 0xfffffff8); - dst = (ulong *)0xbf008000; - - absEntry(src,dst,0x38); -} - -/******************************************************************************* -* -* copy_code - copy u-boot image from flash to RAM -* -* This routine is needed to solve flash problems on this board -* -*/ -void copy_code (ulong dest_addr) -{ - extern long uboot_end_data; - unsigned long start; - unsigned long end; - - /* load copydwords into ram - */ - programLoad(); - - /* copy u-boot code - */ - copyLongs((ulong *)CONFIG_SYS_MONITOR_BASE, - (ulong *)dest_addr, - ((ulong)&uboot_end_data - CONFIG_SYS_MONITOR_BASE + 3) / 4); - - - /* flush caches - */ - - start = CKSEG0; - end = start + CONFIG_SYS_DCACHE_SIZE; - while(start < end) { - cache_unroll(start,Index_Writeback_Inv_D); - start += CONFIG_SYS_CACHELINE_SIZE; - } - - start = CKSEG0; - end = start + CONFIG_SYS_ICACHE_SIZE; - while(start < end) { - cache_unroll(start,Index_Invalidate_I); - start += CONFIG_SYS_CACHELINE_SIZE; - } -} - -#ifdef CONFIG_PLB2800_ETHER -int board_eth_init(bd_t *bis) -{ - return plb2800_eth_initialize(bis); -} -#endif diff --git a/board/purple/sconsole.c b/board/purple/sconsole.c deleted file mode 100644 index cd9d871..0000000 --- a/board/purple/sconsole.c +++ /dev/null @@ -1,125 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> - -#include "sconsole.h" - -void (*sconsole_putc) (char) = 0; -void (*sconsole_puts) (const char *) = 0; -int (*sconsole_getc) (void) = 0; -int (*sconsole_tstc) (void) = 0; -void (*sconsole_setbrg) (void) = 0; - -int serial_init (void) -{ - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - sb->pos = 0; - sb->size = 0; - sb->max_size = CONFIG_SYS_SCONSOLE_SIZE - sizeof (sconsole_buffer_t); - - return (0); -} - -void serial_putc (char c) -{ - if (sconsole_putc) { - (*sconsole_putc) (c); - } else { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - if (c) { - sb->data[sb->pos++] = c; - if (sb->pos == sb->max_size) { - sb->pos = 0; - } - if (sb->size < sb->max_size) { - sb->size++; - } - } - } -} - -void serial_puts (const char *s) -{ - if (sconsole_puts) { - (*sconsole_puts) (s); - } else { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - while (*s) { - sb->data[sb->pos++] = *s++; - if (sb->pos == sb->max_size) { - sb->pos = 0; - } - if (sb->size < sb->max_size) { - sb->size++; - } - } - } -} - -int serial_getc (void) -{ - if (sconsole_getc) { - return (*sconsole_getc) (); - } else { - return 0; - } -} - -int serial_tstc (void) -{ - if (sconsole_tstc) { - return (*sconsole_tstc) (); - } else { - return 0; - } -} - -void serial_setbrg (void) -{ - if (sconsole_setbrg) { - (*sconsole_setbrg) (); - } -} - -void sconsole_flush (void) -{ - if (sconsole_putc) { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - unsigned int end = sb->pos < sb->size - ? sb->pos + sb->max_size - sb->size - : sb->pos - sb->size; - - while (sb->size) { - (*sconsole_putc) (sb->data[end++]); - if (end == sb->max_size) { - end = 0; - } - sb->size--; - } - } -} diff --git a/board/purple/sconsole.h b/board/purple/sconsole.h deleted file mode 100644 index baed5fb..0000000 --- a/board/purple/sconsole.h +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _SCONSOLE_H_ -#define _SCONSOLE_H_ - -#include <config.h> - -typedef struct sconsole_buffer_s { - unsigned long size; - unsigned long max_size; - unsigned long pos; - char data[1]; -} sconsole_buffer_t; - -#define SCONSOLE_BUFFER ((sconsole_buffer_t *) CONFIG_SYS_SCONSOLE_ADDR) - -extern void (* sconsole_putc) (char); -extern void (* sconsole_puts) (const char *); -extern int (* sconsole_getc) (void); -extern int (* sconsole_tstc) (void); -extern void (* sconsole_setbrg) (void); - -extern void sconsole_flush (void); - -#endif diff --git a/board/purple/u-boot.lds b/board/purple/u-boot.lds deleted file mode 100644 index 719f268..0000000 --- a/board/purple/u-boot.lds +++ /dev/null @@ -1,75 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* -OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") -*/ -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/mips/cpu/start.o (.text) - board/purple/lowlevel_init.o (.text) - . = DEFINED(env_offset) ? env_offset : .; - common/env_embedded.o (.ppcenv) - - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - .sdata : { *(.sdata) } - - .u_boot_cmd : { - __u_boot_cmd_start = .; - *(.u_boot_cmd) - __u_boot_cmd_end = .; - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss) } - .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } - uboot_end = .; -} diff --git a/boards.cfg b/boards.cfg index 45c3102..63b1cda 100644 --- a/boards.cfg +++ b/boards.cfg @@ -228,7 +228,6 @@ incaip_100MHz mips mips incaip - incaip_133MHz mips mips incaip - - incaip:CPU_CLOCK_RATE=133000000 incaip_150MHz mips mips incaip - - incaip:CPU_CLOCK_RATE=150000000 pb1000 mips mips pb1x00 - - pb1x00:PB1000 -purple mips mips qemu_mips mips mips qemu-mips - - qemu-mips tb0229 mips mips vct_premium mips mips vct micronas - vct:VCT_PREMIUM diff --git a/doc/README.Purple b/doc/README.Purple deleted file mode 100644 index 0098e26..0000000 --- a/doc/README.Purple +++ /dev/null @@ -1,84 +0,0 @@ -Installation Instructions: --------------------------- - -1. Put the s2 switch into the following position: - - Off On - ------ - |x | - | x| - |x | - | X| - ------ - - Put the s3 switch into the following position: - - Off On - ------ - | x | - | x | - | x| - | x| - ------ - - Put the s4 switch into the following position: - - Off On - ------ - |x | - |x | - |x | - |x | - |x | - | x| - | x| - |x | - ------ - -2. Connect to the serial console and to the BDI. Power on. On the - serial line, you should see: - - PURPLE@1.2> - -3. Type '8'. No echo will be displayed. In response, you should get: - - 7A(pass) - -4. From BDI, enter command: - - mmw 0xb800d860 0x0042c7ff - -5. Then, from BDI: - - erase 0xB0000000 - erase 0xB0008000 - erase 0xB000C000 - erase 0xB0010000 - erase 0xB0020000 - - prog 0xB0000000 <u-boot.bin> bin - -6. Power off. Restore the original S2 switch position: - - Off On - ------ - | x| - | x| - |x | - | X| - ------ - - Power on. U-Boot should come up. - - -Implementation Notes: ---------------------- - -Due to the RAM/flash bus arbitration problem the suggested workaround -had to be implemented. It works okay. On the downside is that you -can't really check whether 'erase' is complete by polling flash as it -is usually done. Instead, the flash driver simply waits for a given -time and assumes that erase then has passed. This behaviour is -identical to what the VxWorks driver does; also, the same timeout (6 -seconds) was chosen. Note that this timeout applies for each erase -operation, i. e. per erased sector. diff --git a/include/configs/purple.h b/include/configs/purple.h deleted file mode 100644 index 25d8ebe..0000000 --- a/include/configs/purple.h +++ /dev/null @@ -1,173 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * This file contains the configuration parameters for the PURPLE board. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_MIPS32 1 /* MIPS 5Kc CPU core */ -#define CONFIG_PURPLE 1 /* on a PURPLE Board */ - -#define CPU_CLOCK_RATE 125000000 /* 125 MHz clock for the MIPS core */ -#define ASC_CLOCK_RATE 62500000 /* 62.5 MHz ASC clock */ - -#define INFINEON_EBU_BOOTCFG 0xE0CC - -#define CONFIG_STACKSIZE (128 * 1024) - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BAUDRATE 19200 - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_TIMESTAMP /* Print image info with timestamp */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off\0" \ - "addmisc=setenv bootargs ${bootargs} " \ - "console=ttyS0,${baudrate} " \ - "ethaddr=${ethaddr} " \ - "panic=1\0" \ - "flash_nfs=run nfsargs addip addmisc;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip addmisc;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 80500000 ${bootfile};" \ - "run nfsargs addip addmisc;bootm\0" \ - "rootpath=/opt/eldk/mips_5KC\0" \ - "bootfile=/tftpboot/purple/uImage\0" \ - "kernel_addr=B0040000\0" \ - "ramdisk_addr=B0100000\0" \ - "u-boot=/tftpboot/purple/u-boot.bin\0" \ - "load=tftp 80500000 ${u-boot}\0" \ - "update=protect off 1:0-4;era 1:0-4;" \ - "cp.b 80500000 B0000000 ${filesize}\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ELF - - -#define CONFIG_SYS_SDRAM_BASE 0x80000000 - -#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 - -#define CONFIG_SYS_MALLOC_LEN 128*1024 - -#define CONFIG_SYS_BOOTPARAMS_LEN 128*1024 - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "PURPLE # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE/2) -#define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ - -#define CONFIG_SYS_LOAD_ADDR 0x80500000 /* default load address */ - -#define CONFIG_SYS_MEMTEST_START 0x80200000 -#define CONFIG_SYS_MEMTEST_END 0x80800000 - -#define CONFIG_MISC_INIT_R - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT (35) /* max number of sectors on one chip */ - -#define PHYS_FLASH_1 0xb0000000 /* Flash Bank #1 */ - -/* The following #defines are needed to get flash environment right */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (192 << 10) - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (6 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (6 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_ENV_IS_IN_FLASH 1 - -/* Address and size of Primary Environment Sector */ -#define CONFIG_ENV_ADDR 0xB0008000 -#define CONFIG_ENV_SIZE 0x4000 - -#define CONFIG_FLASH_32BIT -#define CONFIG_NR_DRAM_BANKS 1 - -#define CONFIG_PLB2800_ETHER -#define CONFIG_NET_MULTI - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_DCACHE_SIZE 16384 -#define CONFIG_SYS_ICACHE_SIZE 16384 -#define CONFIG_SYS_CACHELINE_SIZE 32 - -/* - * Temporary buffer for serial data until the real serial driver - * is initialised (memtest will destroy this buffer) - */ -#define CONFIG_SYS_SCONSOLE_ADDR (CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_INIT_SP_OFFSET - \ - CONFIG_SYS_DCACHE_SIZE / 2) -#define CONFIG_SYS_SCONSOLE_SIZE (CONFIG_SYS_DCACHE_SIZE / 4) - -#endif /* __CONFIG_H */ -- 1.7.4.1
All current CPUs and SoCs are based on Mips32 arch. The complete code resides in the global arch/mips/cpu directory. This is not suitable if other Mips architectures like Mips64 or Octeon should be supported in the future.
To achieve this the current CPU code is moved to its own mips32 subdirectory. All Mips32 boards have to use mips32 as config switch in board.cfg.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de Cc: Thomas Lange thomas@corelatus.se Cc: Vlad Lungu vlad.lungu@windriver.com --- arch/mips/cpu/{ => mips32}/Makefile | 0 arch/mips/cpu/{ => mips32}/asc_serial.c | 0 arch/mips/cpu/{ => mips32}/asc_serial.h | 0 arch/mips/cpu/{ => mips32}/au1x00_eth.c | 0 arch/mips/cpu/{ => mips32}/au1x00_serial.c | 0 arch/mips/cpu/{ => mips32}/au1x00_usb_ohci.c | 0 arch/mips/cpu/{ => mips32}/au1x00_usb_ohci.h | 0 arch/mips/cpu/{ => mips32}/cache.S | 0 arch/mips/cpu/{ => mips32}/config.mk | 0 arch/mips/cpu/{ => mips32}/cpu.c | 0 arch/mips/cpu/{ => mips32}/incaip_clock.c | 0 arch/mips/cpu/{ => mips32}/incaip_wdt.S | 0 arch/mips/cpu/{ => mips32}/interrupts.c | 0 arch/mips/cpu/{ => mips32}/start.S | 0 boards.cfg | 50 +++++++++++++------------- 15 files changed, 25 insertions(+), 25 deletions(-) rename arch/mips/cpu/{ => mips32}/Makefile (100%) rename arch/mips/cpu/{ => mips32}/asc_serial.c (100%) rename arch/mips/cpu/{ => mips32}/asc_serial.h (100%) rename arch/mips/cpu/{ => mips32}/au1x00_eth.c (100%) rename arch/mips/cpu/{ => mips32}/au1x00_serial.c (100%) rename arch/mips/cpu/{ => mips32}/au1x00_usb_ohci.c (100%) rename arch/mips/cpu/{ => mips32}/au1x00_usb_ohci.h (100%) rename arch/mips/cpu/{ => mips32}/cache.S (100%) rename arch/mips/cpu/{ => mips32}/config.mk (100%) rename arch/mips/cpu/{ => mips32}/cpu.c (100%) rename arch/mips/cpu/{ => mips32}/incaip_clock.c (100%) rename arch/mips/cpu/{ => mips32}/incaip_wdt.S (100%) rename arch/mips/cpu/{ => mips32}/interrupts.c (100%) rename arch/mips/cpu/{ => mips32}/start.S (100%)
diff --git a/arch/mips/cpu/Makefile b/arch/mips/cpu/mips32/Makefile similarity index 100% rename from arch/mips/cpu/Makefile rename to arch/mips/cpu/mips32/Makefile diff --git a/arch/mips/cpu/asc_serial.c b/arch/mips/cpu/mips32/asc_serial.c similarity index 100% rename from arch/mips/cpu/asc_serial.c rename to arch/mips/cpu/mips32/asc_serial.c diff --git a/arch/mips/cpu/asc_serial.h b/arch/mips/cpu/mips32/asc_serial.h similarity index 100% rename from arch/mips/cpu/asc_serial.h rename to arch/mips/cpu/mips32/asc_serial.h diff --git a/arch/mips/cpu/au1x00_eth.c b/arch/mips/cpu/mips32/au1x00_eth.c similarity index 100% rename from arch/mips/cpu/au1x00_eth.c rename to arch/mips/cpu/mips32/au1x00_eth.c diff --git a/arch/mips/cpu/au1x00_serial.c b/arch/mips/cpu/mips32/au1x00_serial.c similarity index 100% rename from arch/mips/cpu/au1x00_serial.c rename to arch/mips/cpu/mips32/au1x00_serial.c diff --git a/arch/mips/cpu/au1x00_usb_ohci.c b/arch/mips/cpu/mips32/au1x00_usb_ohci.c similarity index 100% rename from arch/mips/cpu/au1x00_usb_ohci.c rename to arch/mips/cpu/mips32/au1x00_usb_ohci.c diff --git a/arch/mips/cpu/au1x00_usb_ohci.h b/arch/mips/cpu/mips32/au1x00_usb_ohci.h similarity index 100% rename from arch/mips/cpu/au1x00_usb_ohci.h rename to arch/mips/cpu/mips32/au1x00_usb_ohci.h diff --git a/arch/mips/cpu/cache.S b/arch/mips/cpu/mips32/cache.S similarity index 100% rename from arch/mips/cpu/cache.S rename to arch/mips/cpu/mips32/cache.S diff --git a/arch/mips/cpu/config.mk b/arch/mips/cpu/mips32/config.mk similarity index 100% rename from arch/mips/cpu/config.mk rename to arch/mips/cpu/mips32/config.mk diff --git a/arch/mips/cpu/cpu.c b/arch/mips/cpu/mips32/cpu.c similarity index 100% rename from arch/mips/cpu/cpu.c rename to arch/mips/cpu/mips32/cpu.c diff --git a/arch/mips/cpu/incaip_clock.c b/arch/mips/cpu/mips32/incaip_clock.c similarity index 100% rename from arch/mips/cpu/incaip_clock.c rename to arch/mips/cpu/mips32/incaip_clock.c diff --git a/arch/mips/cpu/incaip_wdt.S b/arch/mips/cpu/mips32/incaip_wdt.S similarity index 100% rename from arch/mips/cpu/incaip_wdt.S rename to arch/mips/cpu/mips32/incaip_wdt.S diff --git a/arch/mips/cpu/interrupts.c b/arch/mips/cpu/mips32/interrupts.c similarity index 100% rename from arch/mips/cpu/interrupts.c rename to arch/mips/cpu/mips32/interrupts.c diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/mips32/start.S similarity index 100% rename from arch/mips/cpu/start.S rename to arch/mips/cpu/mips32/start.S diff --git a/boards.cfg b/boards.cfg index 63b1cda..8194bb2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -217,31 +217,31 @@ M5282EVB m68k mcf52x2 m5282evb freesca M53017EVB m68k mcf52x2 m53017evb freescale EP2500 m68k mcf52x2 ep2500 Mercury microblaze-generic microblaze microblaze microblaze-generic xilinx -dbau1000 mips mips dbau1x00 - - dbau1x00:DBAU1000 -dbau1100 mips mips dbau1x00 - - dbau1x00:DBAU1100 -dbau1500 mips mips dbau1x00 - - dbau1x00:DBAU1500 -dbau1550 mips mips dbau1x00 - - dbau1x00:DBAU1550 -dbau1550_el mips mips dbau1x00 - - dbau1x00:DBAU1550 -gth2 mips mips -incaip mips mips -incaip_100MHz mips mips incaip - - incaip:CPU_CLOCK_RATE=100000000 -incaip_133MHz mips mips incaip - - incaip:CPU_CLOCK_RATE=133000000 -incaip_150MHz mips mips incaip - - incaip:CPU_CLOCK_RATE=150000000 -pb1000 mips mips pb1x00 - - pb1x00:PB1000 -qemu_mips mips mips qemu-mips - - qemu-mips -tb0229 mips mips -vct_premium mips mips vct micronas - vct:VCT_PREMIUM -vct_premium_small mips mips vct micronas - vct:VCT_PREMIUM,VCT_SMALL_IMAGE -vct_premium_onenand mips mips vct micronas - vct:VCT_PREMIUM,VCT_ONENAND -vct_premium_onenand_small mips mips vct micronas - vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinum mips mips vct micronas - vct:VCT_PLATINUM -vct_platinum_small mips mips vct micronas - vct:VCT_PLATINUM,VCT_SMALL_IMAGE -vct_platinum_onenand mips mips vct micronas - vct:VCT_PLATINUM,VCT_ONENAND -vct_platinum_onenand_small mips mips vct micronas - vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinumavc mips mips vct micronas - vct:VCT_PLATINUMAVC -vct_platinumavc_small mips mips vct micronas - vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE -vct_platinumavc_onenand mips mips vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND -vct_platinumavc_onenand_small mips mips vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE +dbau1000 mips mips32 dbau1x00 - - dbau1x00:DBAU1000 +dbau1100 mips mips32 dbau1x00 - - dbau1x00:DBAU1100 +dbau1500 mips mips32 dbau1x00 - - dbau1x00:DBAU1500 +dbau1550 mips mips32 dbau1x00 - - dbau1x00:DBAU1550 +dbau1550_el mips mips32 dbau1x00 - - dbau1x00:DBAU1550 +gth2 mips mips32 +incaip mips mips32 +incaip_100MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=100000000 +incaip_133MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=133000000 +incaip_150MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=150000000 +pb1000 mips mips32 pb1x00 - - pb1x00:PB1000 +qemu_mips mips mips32 qemu-mips - - qemu-mips +tb0229 mips mips32 +vct_premium mips mips32 vct micronas - vct:VCT_PREMIUM +vct_premium_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_SMALL_IMAGE +vct_premium_onenand mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND +vct_premium_onenand_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE +vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM +vct_platinum_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_SMALL_IMAGE +vct_platinum_onenand mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND +vct_platinum_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE +vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC +vct_platinumavc_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE +vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND +vct_platinumavc_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE PCI5441 nios2 nios2 pci5441 psyent PK1C20 nios2 nios2 pk1c20 psyent EVB64260 powerpc 74xx_7xx evb64260 - - EVB64260 -- 1.7.4.1
The current MIPS CPU config.mk code always expects a Mips 4kc core. This is not appropiate for other CPUs and SoCs.
Replace the current MIPSFLAGS code by cc-option macro and use -march=mips32r2 as default optimization level for all Mips32 CPUs.
Note: Since commit f62fb99941c625605aa16a0097b396a5c16d2c88 all toolchains with binutils prior to v2.16 are not working anymore. As agreed with Shinya Kuribayashi the support for those toolchains will be dropped officially with this patch.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Wolfgang Denk wd@denx.de --- arch/mips/cpu/mips32/config.mk | 15 ++++++++------- 1 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/mips/cpu/mips32/config.mk b/arch/mips/cpu/mips32/config.mk index a173c54..4d1b273 100644 --- a/arch/mips/cpu/mips32/config.mk +++ b/arch/mips/cpu/mips32/config.mk @@ -20,13 +20,14 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -v=$(shell $(AS) --version | grep 'GNU assembler' | egrep -o '2.[0-9.]+' | cut -d. -f2) -MIPSFLAGS:=$(shell \ -if [ "$v" -lt "14" ]; then \ - echo "-mcpu=4kc"; \ -else \ - echo "-march=4kc -mtune=4kc"; \ -fi) + +# +# Default optimization level for MIPS32 +# +# Note: Toolchains with binutils prior to v2.16 +# are no longer supported by U-Boot MIPS tree! +# +MIPSFLAGS = -march=mips32r2
ifneq (,$(findstring 4KCle,$(CROSS_COMPILE))) ENDIANNESS = -EL -- 1.7.4.1
IncaIP is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Wolfgang Denk wd@denx.de --- arch/mips/cpu/mips32/Makefile | 2 - arch/mips/cpu/mips32/incaip/Makefile | 46 ++++++++++++++++++++++ arch/mips/cpu/mips32/{ => incaip}/asc_serial.c | 0 arch/mips/cpu/mips32/{ => incaip}/asc_serial.h | 0 arch/mips/cpu/mips32/incaip/config.mk | 24 +++++++++++ arch/mips/cpu/mips32/{ => incaip}/incaip_clock.c | 0 arch/mips/cpu/mips32/{ => incaip}/incaip_wdt.S | 0 boards.cfg | 8 ++-- 8 files changed, 74 insertions(+), 6 deletions(-) create mode 100644 arch/mips/cpu/mips32/incaip/Makefile rename arch/mips/cpu/mips32/{ => incaip}/asc_serial.c (100%) rename arch/mips/cpu/mips32/{ => incaip}/asc_serial.h (100%) create mode 100644 arch/mips/cpu/mips32/incaip/config.mk rename arch/mips/cpu/mips32/{ => incaip}/incaip_clock.c (100%) rename arch/mips/cpu/mips32/{ => incaip}/incaip_wdt.S (100%)
diff --git a/arch/mips/cpu/mips32/Makefile b/arch/mips/cpu/mips32/Makefile index 816b76c..88e3023 100644 --- a/arch/mips/cpu/mips32/Makefile +++ b/arch/mips/cpu/mips32/Makefile @@ -29,8 +29,6 @@ START = start.o SOBJS-y = cache.o COBJS-y = cpu.o interrupts.o
-SOBJS-$(CONFIG_INCA_IP) += incaip_wdt.o -COBJS-$(CONFIG_INCA_IP) += asc_serial.o incaip_clock.o COBJS-$(CONFIG_SOC_AU1X00) += au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/mips/cpu/mips32/incaip/Makefile b/arch/mips/cpu/mips32/incaip/Makefile new file mode 100644 index 0000000..9c2b1aa --- /dev/null +++ b/arch/mips/cpu/mips32/incaip/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2011 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +SOBJS = incaip_wdt.o +COBJS = incaip_clock.o asc_serial.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/mips/cpu/mips32/asc_serial.c b/arch/mips/cpu/mips32/incaip/asc_serial.c similarity index 100% rename from arch/mips/cpu/mips32/asc_serial.c rename to arch/mips/cpu/mips32/incaip/asc_serial.c diff --git a/arch/mips/cpu/mips32/asc_serial.h b/arch/mips/cpu/mips32/incaip/asc_serial.h similarity index 100% rename from arch/mips/cpu/mips32/asc_serial.h rename to arch/mips/cpu/mips32/incaip/asc_serial.h diff --git a/arch/mips/cpu/mips32/incaip/config.mk b/arch/mips/cpu/mips32/incaip/config.mk new file mode 100644 index 0000000..568f333 --- /dev/null +++ b/arch/mips/cpu/mips32/incaip/config.mk @@ -0,0 +1,24 @@ +# +# (C) Copyright 2011 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +PLATFORM_CPPFLAGS += -mtune=4kc diff --git a/arch/mips/cpu/mips32/incaip_clock.c b/arch/mips/cpu/mips32/incaip/incaip_clock.c similarity index 100% rename from arch/mips/cpu/mips32/incaip_clock.c rename to arch/mips/cpu/mips32/incaip/incaip_clock.c diff --git a/arch/mips/cpu/mips32/incaip_wdt.S b/arch/mips/cpu/mips32/incaip/incaip_wdt.S similarity index 100% rename from arch/mips/cpu/mips32/incaip_wdt.S rename to arch/mips/cpu/mips32/incaip/incaip_wdt.S diff --git a/boards.cfg b/boards.cfg index 8194bb2..7844bbd 100644 --- a/boards.cfg +++ b/boards.cfg @@ -223,10 +223,10 @@ dbau1500 mips mips32 dbau1x00 - dbau1550 mips mips32 dbau1x00 - - dbau1x00:DBAU1550 dbau1550_el mips mips32 dbau1x00 - - dbau1x00:DBAU1550 gth2 mips mips32 -incaip mips mips32 -incaip_100MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=100000000 -incaip_133MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=133000000 -incaip_150MHz mips mips32 incaip - - incaip:CPU_CLOCK_RATE=150000000 +incaip mips mips32 incaip - incaip +incaip_100MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=100000000 +incaip_133MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=133000000 +incaip_150MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=150000000 pb1000 mips mips32 pb1x00 - - pb1x00:PB1000 qemu_mips mips mips32 qemu-mips - - qemu-mips tb0229 mips mips32 -- 1.7.4.1
Au1x00 is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Thomas Lange thomas@corelatus.se --- arch/mips/cpu/mips32/Makefile | 2 - arch/mips/cpu/mips32/au1x00/Makefile | 45 ++++++++++++++++++++ arch/mips/cpu/mips32/{ => au1x00}/au1x00_eth.c | 0 arch/mips/cpu/mips32/{ => au1x00}/au1x00_serial.c | 0 .../mips/cpu/mips32/{ => au1x00}/au1x00_usb_ohci.c | 0 .../mips/cpu/mips32/{ => au1x00}/au1x00_usb_ohci.h | 0 arch/mips/cpu/mips32/au1x00/config.mk | 24 ++++++++++ boards.cfg | 14 +++--- 8 files changed, 76 insertions(+), 9 deletions(-) create mode 100644 arch/mips/cpu/mips32/au1x00/Makefile rename arch/mips/cpu/mips32/{ => au1x00}/au1x00_eth.c (100%) rename arch/mips/cpu/mips32/{ => au1x00}/au1x00_serial.c (100%) rename arch/mips/cpu/mips32/{ => au1x00}/au1x00_usb_ohci.c (100%) rename arch/mips/cpu/mips32/{ => au1x00}/au1x00_usb_ohci.h (100%) create mode 100644 arch/mips/cpu/mips32/au1x00/config.mk
diff --git a/arch/mips/cpu/mips32/Makefile b/arch/mips/cpu/mips32/Makefile index 88e3023..e315c1b 100644 --- a/arch/mips/cpu/mips32/Makefile +++ b/arch/mips/cpu/mips32/Makefile @@ -29,8 +29,6 @@ START = start.o SOBJS-y = cache.o COBJS-y = cpu.o interrupts.o
-COBJS-$(CONFIG_SOC_AU1X00) += au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o - SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) START := $(addprefix $(obj),$(START)) diff --git a/arch/mips/cpu/mips32/au1x00/Makefile b/arch/mips/cpu/mips32/au1x00/Makefile new file mode 100644 index 0000000..dc58475 --- /dev/null +++ b/arch/mips/cpu/mips32/au1x00/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2011 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS = au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/mips/cpu/mips32/au1x00_eth.c b/arch/mips/cpu/mips32/au1x00/au1x00_eth.c similarity index 100% rename from arch/mips/cpu/mips32/au1x00_eth.c rename to arch/mips/cpu/mips32/au1x00/au1x00_eth.c diff --git a/arch/mips/cpu/mips32/au1x00_serial.c b/arch/mips/cpu/mips32/au1x00/au1x00_serial.c similarity index 100% rename from arch/mips/cpu/mips32/au1x00_serial.c rename to arch/mips/cpu/mips32/au1x00/au1x00_serial.c diff --git a/arch/mips/cpu/mips32/au1x00_usb_ohci.c b/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c similarity index 100% rename from arch/mips/cpu/mips32/au1x00_usb_ohci.c rename to arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c diff --git a/arch/mips/cpu/mips32/au1x00_usb_ohci.h b/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.h similarity index 100% rename from arch/mips/cpu/mips32/au1x00_usb_ohci.h rename to arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.h diff --git a/arch/mips/cpu/mips32/au1x00/config.mk b/arch/mips/cpu/mips32/au1x00/config.mk new file mode 100644 index 0000000..568f333 --- /dev/null +++ b/arch/mips/cpu/mips32/au1x00/config.mk @@ -0,0 +1,24 @@ +# +# (C) Copyright 2011 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +PLATFORM_CPPFLAGS += -mtune=4kc diff --git a/boards.cfg b/boards.cfg index 7844bbd..9a8dbb3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -217,17 +217,17 @@ M5282EVB m68k mcf52x2 m5282evb freesca M53017EVB m68k mcf52x2 m53017evb freescale EP2500 m68k mcf52x2 ep2500 Mercury microblaze-generic microblaze microblaze microblaze-generic xilinx -dbau1000 mips mips32 dbau1x00 - - dbau1x00:DBAU1000 -dbau1100 mips mips32 dbau1x00 - - dbau1x00:DBAU1100 -dbau1500 mips mips32 dbau1x00 - - dbau1x00:DBAU1500 -dbau1550 mips mips32 dbau1x00 - - dbau1x00:DBAU1550 -dbau1550_el mips mips32 dbau1x00 - - dbau1x00:DBAU1550 -gth2 mips mips32 +dbau1000 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1000 +dbau1100 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1100 +dbau1500 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1500 +dbau1550 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 +dbau1550_el mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 +gth2 mips mips32 - - au1x00 incaip mips mips32 incaip - incaip incaip_100MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=100000000 incaip_133MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=133000000 incaip_150MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=150000000 -pb1000 mips mips32 pb1x00 - - pb1x00:PB1000 +pb1000 mips mips32 pb1x00 - au1x00 pb1x00:PB1000 qemu_mips mips mips32 qemu-mips - - qemu-mips tb0229 mips mips32 vct_premium mips mips32 vct micronas - vct:VCT_PREMIUM -- 1.7.4.1
On 03/29/2011 01:33 AM, daniel.schwierzeck@googlemail.com wrote:
This patch series refactors the Mips CPU directory and put all current code into an own mips32 subdirectory. Furthermore the SoC specific code of IncaIP and Au1x00 is moved to separate SoC subdirectories. The support for Purple is dropped because not actively maintained anymore.
Changes since RFC/v1:
- drop Purple supported as agreed with Wolfgang Denk
- use MIPS rather than Mips in patch subject
- fixed Cc lines in all patches
Changes since v2:
- reverted patch for endianess flag setup
- always use -march=mips32r2 as default CPU optimization for all MIPS32 CPU cores
Daniel Schwierzeck (5): MIPS: Purple: Remove Purple support MIPS: Move content of arch/mips/cpu to arch/mips/cpu/mips32 MIPS: Optimize the setup of CPU optimization flags MIPS: IncaIP: Move all IncaIP specific code to separate subdirectory MIPS: Au1x00: Move all Au1x00 specific code to separate subdirectory
I've reviewed and build tested, all patches look good.
Applied and queued to u-boot-mips tree along with several s/Mips/MIPS/ keyword cleanups in the git commitlogs. Will make a pull-request once v2011.03 gets released.
Shinya Kuribayashi
