[U-Boot] [PATCH] configs: rk3399: add gpt and fs support
To compatible with distro boot, we need to add gpt and fs support, including gpt table and vfat, ext2, ext4 support.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
include/configs/rk3399_common.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index a9c9d29..12327d5 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -35,6 +35,15 @@ #define CONFIG_BOUNCE_BUFFER #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
+#define CONFIG_DOS_PARTITION +#define CONFIG_PARTITION_UUIDS +#define CONFIG_SUPPORT_VFAT +#define CONFIG_FS_FAT +#define CONFIG_FAT_WRITE +#define CONFIG_CMD_PART + +/* EXT4 FS */ +#define CONFIG_FS_EXT4 #define CONFIG_FAT_WRITE
/* RAW SD card / eMMC locations. */ @@ -60,6 +69,14 @@ "kernel_addr_r=0x02000000\0" \ "ramdisk_addr_r=0x04000000\0"
+#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID +#define CONFIG_EFI_PARTITION +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=boot,start=16M,size=32M,bootable;" \ + "name=rootfs,size=-,uuid=${uuid_gpt_rootfs};" \ + /* First try to boot from SD (index 0), then eMMC (index 1) */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ @@ -67,6 +84,8 @@
#include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + "partitions=" PARTS_DEFAULT \ BOOTENV
#endif
Sorry, this MACRO CONFIG_FAT_WRITE is duplicated, will fix in next version, I will waiting for other comments before send out V2 tomorrow.
Thanks, - Kever
- "uuid_disk=${uuid_gpt_disk};" \
- "name=boot,start=16M,size=32M,bootable;" \
- "name=rootfs,size=-,uuid=${uuid_gpt_rootfs};" \
- /* First try to boot from SD (index 0), then eMMC (index 1) */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \
@@ -67,6 +84,8 @@
#endif
Hi kever,
CONFIG_DOS_PARTITION and CONFIG_EFI_PARTITION are already included in config_distro_defaults.h, you not need to define it. See 77337c1 rockchip: remove the duplicated macro config
miss '\0'. should be "name=rootfs,size=-,uuid=${uuid_gpt_rootfs};\0" \
@@ -67,6 +84,8 @@
#endif
On 2016年08月02日 10:56, Ziyuan Xu wrote:
Hi kever,
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index a9c9d29..12327d5 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -35,6 +35,15 @@ #define CONFIG_BOUNCE_BUFFER #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000 +#define CONFIG_DOS_PARTITION
+/* EXT4 FS */ +#define CONFIG_FS_EXT4 #define CONFIG_FAT_WRITE /* RAW SD card / eMMC locations. */ @@ -60,6 +69,14 @@ "kernel_addr_r=0x02000000\0" \ "ramdisk_addr_r=0x04000000\0" +#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID +#define CONFIG_EFI_PARTITION +#define PARTS_DEFAULT \
I think partitions table should be defined in includes/configs/${board}.h
@@ -67,6 +84,8 @@ #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \
- ENV_MEM_LAYOUT_SETTINGS \
- "partitions=" PARTS_DEFAULT \ BOOTENV #endif
Hi kever,
Apart from the comments mentioned:
Hi kever,
I think partitions table should be defined in includes/configs/${board}.h.
Kever Yang
Ziyuan Xu
