[U-Boot] [PATCH] armv8: ls1088a: Unset USE_BOOTCOMMAND in defconfig
Unset USE_BOOTCOMMAND for all ls1088 defconfig files to fix redefinition error
USE_BOOTCOMMAND was introduced in commit-id b6251db8c3f ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND").
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 850be3e..58276f7 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" # CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 214de54..8629800 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_PARTITIONS=y CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" CONFIG_SD_BOOT=y # CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_SPL=y CONFIG_SPL_BUILD=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 1f3d581..bb5e72c 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" # CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 8e5cf3b..7c143e9 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_PARTITIONS=y CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" CONFIG_SD_BOOT=y # CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_SPL=y CONFIG_SPL_BUILD=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
Applied to fsl-qoriq master. Thanks.
York
Ashish Kumar
York Sun
