[PATCHv2 0/9] Add a subcommand 'release' to cmd/cpu.c
This patch set is to add a subcommand 'release' to the 'cpu' command in cmd/cpu.c, making the command is able to release a core to run baremetal and RTOS applications.
And enabled the 'cpu' command and imx CPU driver for i.MX 8M series EVK boards and i.MX 93 EVK board.
dependence: https://patchwork.ozlabs.org/project/uboot/patch/20240725083655.24486-1-Zhiq...
Hou Zhiqiang (9): cpu: add release_core callback cpu: sandbox: implement release_core callback test: cpu: add test for release CPU core. cpu: imx: implement release_core callback cpu: imx: fix the CPU type field width cpu: imx: Add i.MX 8M series SoCs cmd: cpu: add release subcommand configs: imx8m: enable the 'cpu' command configs: imx93: enable the 'cpu' command
--- V2: - Implemented release_core() in sandbox and added test for the new API. - Increased the CPU type mask in i.MX CPU driver. - Added i.MX 8M series SoCs in i.MX CPU driver
cmd/cpu.c | 44 +++++++++++++++++++++++++++++-- configs/imx8mm_evk_defconfig | 3 +++ configs/imx8mn_evk_defconfig | 3 +++ configs/imx8mp_evk_defconfig | 3 +++ configs/imx93_11x11_evk_defconfig | 1 + drivers/cpu/cpu-uclass.c | 10 +++++++ drivers/cpu/cpu_sandbox.c | 6 +++++ drivers/cpu/imx8_cpu.c | 34 ++++++++++++++++++++++-- include/cpu.h | 15 +++++++++++ test/dm/cpu.c | 2 ++ 10 files changed, 117 insertions(+), 4 deletions(-)
Add a new callback release_core to the cpu_ops, which is used to release a CPU core to run baremetal or RTOS application on a SoC with multiple CPU cores.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V2: - No change.
drivers/cpu/cpu-uclass.c | 10 ++++++++++ include/cpu.h | 15 +++++++++++++++ 2 files changed, 25 insertions(+)
diff --git a/drivers/cpu/cpu-uclass.c b/drivers/cpu/cpu-uclass.c index 16f8f2e5219..2c8e46c05e3 100644 --- a/drivers/cpu/cpu-uclass.c +++ b/drivers/cpu/cpu-uclass.c @@ -104,6 +104,16 @@ int cpu_get_vendor(const struct udevice *dev, char *buf, int size) return ops->get_vendor(dev, buf, size); }
+int cpu_release_core(const struct udevice *dev, phys_addr_t addr) +{ + struct cpu_ops *ops = cpu_get_ops(dev); + + if (!ops->release_core) + return -ENOSYS; + + return ops->release_core(dev, addr); +} + U_BOOT_DRIVER(cpu_bus) = { .name = "cpu_bus", .id = UCLASS_SIMPLE_BUS, diff --git a/include/cpu.h b/include/cpu.h index 2077ff30634..0018910d61f 100644 --- a/include/cpu.h +++ b/include/cpu.h @@ -102,6 +102,15 @@ struct cpu_ops { * if not. */ int (*is_current)(struct udevice *dev); + + /** + * release_core() - Relase a CPU core to the given address to run application + * + * @dev: Device to check (UCLASS_CPU) + * @addr: Address to relese the CPU core + * @return 0 if OK, -ve on error + */ + int (*release_core)(const struct udevice *dev, phys_addr_t addr); };
#define cpu_get_ops(dev) ((struct cpu_ops *)(dev)->driver->ops) @@ -164,4 +173,10 @@ int cpu_is_current(struct udevice *cpu); */ struct udevice *cpu_get_current_dev(void);
+/** + * cpu_release_core() - Relase a CPU core to the given address to run application + * + * @return 0 if OK, -ve on error + */ +int cpu_release_core(const struct udevice *dev, phys_addr_t addr); #endif
V2:
- No change.
Add empty release CPU core function for testing.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V2: - New patch.
drivers/cpu/cpu_sandbox.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/cpu/cpu_sandbox.c b/drivers/cpu/cpu_sandbox.c index e65e1bdc51b..b1527957831 100644 --- a/drivers/cpu/cpu_sandbox.c +++ b/drivers/cpu/cpu_sandbox.c @@ -44,6 +44,11 @@ void cpu_sandbox_set_current(const char *name) cpu_current = name; }
+static int cpu_sandbox_release_core(const struct udevice *dev, phys_addr_t addr) +{ + return 0; +} + static int cpu_sandbox_is_current(struct udevice *dev) { if (!strcmp(dev->name, cpu_current)) @@ -58,6 +63,7 @@ static const struct cpu_ops cpu_sandbox_ops = { .get_count = cpu_sandbox_get_count, .get_vendor = cpu_sandbox_get_vendor, .is_current = cpu_sandbox_is_current, + .release_core = cpu_sandbox_release_core, };
static int cpu_sandbox_bind(struct udevice *dev)
V2:
- New patch.
Add test for API cpu_release_core().
test/dm/cpu.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/dm/cpu.c b/test/dm/cpu.c index acba8105996..8af25316cea 100644 --- a/test/dm/cpu.c +++ b/test/dm/cpu.c @@ -43,6 +43,8 @@ static int dm_test_cpu(struct unit_test_state *uts) ut_assertok(cpu_get_vendor(dev, text, sizeof(text))); ut_assertok(strcmp(text, "Languid Example Garbage Inc."));
+ ut_assertok(cpu_release_core(dev, 0)); + return 0; }
V2:
- New patch.
Release the secondary cores through the PSCI request.
drivers/cpu/imx8_cpu.c | 26 +++++++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 4781a565547..5942a28be4b 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -1,12 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2024 NXP */
#include <cpu.h> #include <dm.h> #include <thermal.h> #include <asm/global_data.h> +#include <asm/ptrace.h> #include <asm/system.h> #include <firmware/imx/sci/sci.h> #include <asm/arch/sys_proto.h> @@ -15,6 +16,7 @@ #include <imx_thermal.h> #include <linux/bitops.h> #include <linux/clk-provider.h> +#include <linux/psci.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -236,12 +238,34 @@ static int cpu_imx_is_current(struct udevice *dev) return 0; }
+static int cpu_imx_release_core(const struct udevice *dev, phys_addr_t addr) +{ + struct cpu_imx_plat *plat = dev_get_plat(dev); + struct pt_regs regs; + + regs.regs[0] = PSCI_0_2_FN64_CPU_ON; + regs.regs[1] = plat->mpidr; + regs.regs[2] = addr; + regs.regs[3] = 0; + + smc_call(®s); + if (regs.regs[0]) { + printf("Failed to release CPU core (mpidr: 0x%x)\n", plat->mpidr); + return -1; + } + + printf("Released CPU core (mpidr: 0x%x) to address 0x%llx\n", plat->mpidr, addr); + + return 0; +} + static const struct cpu_ops cpu_imx_ops = { .get_desc = cpu_imx_get_desc, .get_info = cpu_imx_get_info, .get_count = cpu_imx_get_count, .get_vendor = cpu_imx_get_vendor, .is_current = cpu_imx_is_current, + .release_core = cpu_imx_release_core, };
static const struct udevice_id cpu_imx_ids[] = {
Increase one more bit to cover all CPU types. Otherwise it shows wrong CPU info on some platforms, such as i.MX8M Plus:
U-Boot 2024.04+g674440bc73e+p0 (Jun 06 2024 - 10:05:34 +0000)
CPU: NXP i.MX8MM Rev1.1 A53 at 4154504685 MHz at 30C
Model: NXP i.MX8MPlus LPDDR4 EVK board
drivers/cpu/imx8_cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 5942a28be4b..0509becf91e 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -311,7 +311,7 @@ static int imx_cpu_probe(struct udevice *dev) cpurev = get_cpu_rev(); plat->cpurev = cpurev; plat->rev = get_imx_rev_str(cpurev & 0xFFF); - plat->type = get_imx_type_str((cpurev & 0xFF000) >> 12); + plat->type = get_imx_type_str((cpurev & 0x1FF000) >> 12); plat->freq_mhz = imx_get_cpu_rate(dev) / 1000000; plat->mpidr = dev_read_addr(dev); if (plat->mpidr == FDT_ADDR_T_NONE) {
Add i.MX 8M Mini, Nano and Plus SoCs support.
drivers/cpu/imx8_cpu.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 0509becf91e..dfedc9ffd14 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -33,6 +33,12 @@ struct cpu_imx_plat { static const char *get_imx_type_str(u32 imxtype) { switch (imxtype) { + case MXC_CPU_IMX8MM: + return "8MM"; + case MXC_CPU_IMX8MN: + return "8MN"; + case MXC_CPU_IMX8MP: + return "8MP"; case MXC_CPU_IMX8QXP: case MXC_CPU_IMX8QXP_A0: return "8QXP";
Add a new subcommand 'release' to bring up a core to run baremetal and RTOS applications.
For example on i.MX8M Plus EVK, release the LAST core to run a RTOS application, passing the sequence number of the CPU core to release, here it is 3: u-boot=> cpu list 0: cpu@0 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 31C
1: cpu@1 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 30C
2: cpu@2 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 31C
3: cpu@3 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 31C
u-boot=> load mmc 1:2 C0000000 /hello_world.bin 66008 bytes read in 5 ms (12.6 MiB/s) u-boot=> dcache flush; icache flush u-boot=> cpu release 3 C0000000 Released CPU core (mpidr: 0x3) to address 0xc0000000
cmd/cpu.c | 44 ++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 42 insertions(+), 2 deletions(-)
diff --git a/cmd/cpu.c b/cmd/cpu.c index 9e323069b9e..27552507564 100644 --- a/cmd/cpu.c +++ b/cmd/cpu.c @@ -3,6 +3,7 @@ * Copyright (c) 2015 Google, Inc * Written by Simon Glass sjg@chromium.org * Copyright (c) 2017 Álvaro Fernández Rojas noltari@gmail.com + * Copyright 2024 NXP */
#include <command.h> @@ -18,6 +19,19 @@ static const char *cpu_feature_name[CPU_FEAT_COUNT] = { "Device ID", };
+static struct udevice *cpu_find_device(unsigned long cpu_id) +{ + struct udevice *dev; + + for (uclass_first_device(UCLASS_CPU, &dev); dev; + uclass_next_device(&dev)) { + if (cpu_id == dev_seq(dev)) + return dev; + } + + return NULL; +} + static int print_cpu_list(bool detail) { struct udevice *dev; @@ -82,10 +96,36 @@ static int do_cpu_detail(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
+static int do_cpu_release(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + unsigned long cpu_id; + unsigned long long boot_addr; + + if (argc != 3) + return CMD_RET_USAGE; + + cpu_id = dectoul(argv[1], NULL); + dev = cpu_find_device(cpu_id); + if (!dev) + return CMD_RET_FAILURE; + + boot_addr = simple_strtoull(argv[2], NULL, 16); + + if (cpu_release_core(dev, boot_addr)) + return CMD_RET_FAILURE; + + return 0; +} + U_BOOT_LONGHELP(cpu, "list - list available CPUs\n" - "cpu detail - show CPU detail"); + "cpu detail - show CPU detail\n" + "cpu release <core ID> <addr> - Release CPU <core ID> at <addr>\n" + " <core ID>: the sequence number in list subcommand outputs");
U_BOOT_CMD_WITH_SUBCMDS(cpu, "display information about CPUs", cpu_help_text, U_BOOT_SUBCMD_MKENT(list, 1, 1, do_cpu_list), - U_BOOT_SUBCMD_MKENT(detail, 1, 0, do_cpu_detail)); + U_BOOT_SUBCMD_MKENT(detail, 1, 0, do_cpu_detail), + U_BOOT_SUBCMD_MKENT(release, 3, 0, do_cpu_release));
Hi Zhiqiang,
1: cpu@1 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 30C 2: cpu@2 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 31C 3: cpu@3 NXP i.MX8MP Rev1.1 A53 at 1200 MHz at 31C u-boot=> load mmc 1:2 C0000000 /hello_world.bin 66008 bytes read in 5 ms (12.6 MiB/s) u-boot=> dcache flush; icache flush u-boot=> cpu release 3 C0000000 Released CPU core (mpidr: 0x3) to address 0xc0000000
V2:
- No change.
While you are here, would you mind adding a doc/usage/cmd/cpu.rst as that is missing.
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Thursday, July 25, 2024 10:03 PM To: Z.Q. Hou zhiqiang.hou@nxp.com Cc: u-boot@lists.denx.de; trini@konsulko.com; Peng Fan peng.fan@nxp.com; festevam@gmail.com Subject: Re: [PATCHv2 7/9] cmd: cpu: add release subcommand
Hi Zhiqiang,
V2:
- No change.
Yes, I'd like to.
Zhiqiang
Hi Zhiqiang,
This looks much better now. Thanks for fixing it.
Enable the 'cpu' command and the depended imx CPU driver to display the CPU info and release CPU core to run baremetal or RTOS applications.
configs/imx8mm_evk_defconfig | 3 +++ configs/imx8mn_evk_defconfig | 3 +++ configs/imx8mp_evk_defconfig | 3 +++ 3 files changed, 9 insertions(+)
diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index ff33d1532a0..8b04586f861 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -118,3 +118,6 @@ CONFIG_SDP_LOADADDR=0x40400000 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_IMX_WATCHDOG=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_CMD_CPU=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 2402e9e8bfb..ee7a5e90883 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -105,3 +105,6 @@ CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_WATCHDOG=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_CMD_CPU=y diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index f5ba022b075..31760699916 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -137,3 +137,6 @@ CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_IMX_WATCHDOG=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_CMD_CPU=y
Enable the 'cpu' command to display the CPU info and release CPU core to run baremetal or RTOS applications.
configs/imx93_11x11_evk_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 2246715d822..93ab0b9aa30 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -52,6 +52,7 @@ CONFIG_CMD_ERASEENV=y # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y +CONFIG_CMD_CPU=y CONFIG_CMD_DFU=y CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y
Fabio Estevam
Z.Q. Hou
Zhiqiang Hou
