[PATCH] usb: dwc2: Rename CONFIG_DWC2 namespace to DWC2
There are a number of DWC2 configuration options that are set in dwc2.h and referenced in dwc2.c only. Move these out of the CONFIG_DWC2 namespace and in to the DWC2 namespace. Note that hikey was defining an option that was already always enabled, so we can remove that hunk.
Cc: Marek Vasut marex@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- drivers/usb/host/dwc2.c | 52 ++++++++++++++++++------------------ drivers/usb/host/dwc2.h | 42 ++++++++++++++--------------- include/configs/hikey.h | 4 --- scripts/config_whitelist.txt | 20 -------------- 4 files changed, 47 insertions(+), 71 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 43cc2e04339c..23060fc369c0 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -86,14 +86,14 @@ static void init_fslspclksel(struct dwc2_core_regs *regs) { uint32_t phyclk;
-#if (CONFIG_DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) +#if (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) phyclk = DWC2_HCFG_FSLSPCLKSEL_48_MHZ; /* Full speed PHY */ #else /* High speed PHY running at full speed or high speed */ phyclk = DWC2_HCFG_FSLSPCLKSEL_30_60_MHZ; #endif
-#ifdef CONFIG_DWC2_ULPI_FS_LS +#ifdef DWC2_ULPI_FS_LS uint32_t hwcfg2 = readl(®s->ghwcfg2); uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; @@ -257,28 +257,28 @@ static void dwc_otg_core_host_init(struct udevice *dev,
/* Initialize Host Configuration Register */ init_fslspclksel(regs); -#ifdef CONFIG_DWC2_DFLT_SPEED_FULL +#ifdef DWC2_DFLT_SPEED_FULL setbits_le32(®s->host_regs.hcfg, DWC2_HCFG_FSLSSUPP); #endif
/* Configure data FIFO sizes */ -#ifdef CONFIG_DWC2_ENABLE_DYNAMIC_FIFO +#ifdef DWC2_ENABLE_DYNAMIC_FIFO if (readl(®s->ghwcfg2) & DWC2_HWCFG2_DYNAMIC_FIFO) { /* Rx FIFO */ - writel(CONFIG_DWC2_HOST_RX_FIFO_SIZE, ®s->grxfsiz); + writel(DWC2_HOST_RX_FIFO_SIZE, ®s->grxfsiz);
/* Non-periodic Tx FIFO */ - nptxfifosize |= CONFIG_DWC2_HOST_NPERIO_TX_FIFO_SIZE << + nptxfifosize |= DWC2_HOST_NPERIO_TX_FIFO_SIZE << DWC2_FIFOSIZE_DEPTH_OFFSET; - nptxfifosize |= CONFIG_DWC2_HOST_RX_FIFO_SIZE << + nptxfifosize |= DWC2_HOST_RX_FIFO_SIZE << DWC2_FIFOSIZE_STARTADDR_OFFSET; writel(nptxfifosize, ®s->gnptxfsiz);
/* Periodic Tx FIFO */ - ptxfifosize |= CONFIG_DWC2_HOST_PERIO_TX_FIFO_SIZE << + ptxfifosize |= DWC2_HOST_PERIO_TX_FIFO_SIZE << DWC2_FIFOSIZE_DEPTH_OFFSET; - ptxfifosize |= (CONFIG_DWC2_HOST_RX_FIFO_SIZE + - CONFIG_DWC2_HOST_NPERIO_TX_FIFO_SIZE) << + ptxfifosize |= (DWC2_HOST_RX_FIFO_SIZE + + DWC2_HOST_NPERIO_TX_FIFO_SIZE) << DWC2_FIFOSIZE_STARTADDR_OFFSET; writel(ptxfifosize, ®s->hptxfsiz); } @@ -340,7 +340,7 @@ static void dwc_otg_core_init(struct udevice *dev) struct dwc2_core_regs *regs = priv->regs; uint32_t ahbcfg = 0; uint32_t usbcfg = 0; - uint8_t brst_sz = CONFIG_DWC2_DMA_BURST_SIZE; + uint8_t brst_sz = DWC2_DMA_BURST_SIZE;
/* Common Initialization */ usbcfg = readl(®s->gusbcfg); @@ -357,7 +357,7 @@ static void dwc_otg_core_init(struct udevice *dev) }
/* Set external TS Dline pulsing */ -#ifdef CONFIG_DWC2_TS_DLINE +#ifdef DWC2_TS_DLINE usbcfg |= DWC2_GUSBCFG_TERM_SEL_DL_PULSE; #else usbcfg &= ~DWC2_GUSBCFG_TERM_SEL_DL_PULSE; @@ -371,8 +371,8 @@ static void dwc_otg_core_init(struct udevice *dev) * This programming sequence needs to happen in FS mode before * any other programming occurs */ -#if defined(CONFIG_DWC2_DFLT_SPEED_FULL) && \ - (CONFIG_DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) +#if defined(DWC2_DFLT_SPEED_FULL) && \ + (DWC2_PHY_TYPE == DWC2_PHY_TYPE_FS) /* If FS mode with FS PHY */ setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_PHYSEL);
@@ -387,7 +387,7 @@ static void dwc_otg_core_init(struct udevice *dev) if (readl(®s->gintsts) & DWC2_GINTSTS_CURMODE_HOST) init_fslspclksel(regs);
-#ifdef CONFIG_DWC2_I2C_ENABLE +#ifdef DWC2_I2C_ENABLE /* Program GUSBCFG.OtgUtmifsSel to I2C */ setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_OTGUTMIFSSEL);
@@ -407,16 +407,16 @@ static void dwc_otg_core_init(struct udevice *dev) * immediately after setting phyif. */ usbcfg &= ~(DWC2_GUSBCFG_ULPI_UTMI_SEL | DWC2_GUSBCFG_PHYIF); - usbcfg |= CONFIG_DWC2_PHY_TYPE << DWC2_GUSBCFG_ULPI_UTMI_SEL_OFFSET; + usbcfg |= DWC2_PHY_TYPE << DWC2_GUSBCFG_ULPI_UTMI_SEL_OFFSET;
if (usbcfg & DWC2_GUSBCFG_ULPI_UTMI_SEL) { /* ULPI interface */ -#ifdef CONFIG_DWC2_PHY_ULPI_DDR +#ifdef DWC2_PHY_ULPI_DDR usbcfg |= DWC2_GUSBCFG_DDRSEL; #else usbcfg &= ~DWC2_GUSBCFG_DDRSEL; #endif } else { /* UTMI+ interface */ -#if (CONFIG_DWC2_UTMI_WIDTH == 16) +#if (DWC2_UTMI_WIDTH == 16) usbcfg |= DWC2_GUSBCFG_PHYIF; #endif } @@ -429,7 +429,7 @@ static void dwc_otg_core_init(struct udevice *dev)
usbcfg = readl(®s->gusbcfg); usbcfg &= ~(DWC2_GUSBCFG_ULPI_FSLS | DWC2_GUSBCFG_ULPI_CLK_SUS_M); -#ifdef CONFIG_DWC2_ULPI_FS_LS +#ifdef DWC2_ULPI_FS_LS uint32_t hwcfg2 = readl(®s->ghwcfg2); uint32_t hval = (ghwcfg2 & DWC2_HWCFG2_HS_PHY_TYPE_MASK) >> DWC2_HWCFG2_HS_PHY_TYPE_OFFSET; @@ -456,14 +456,14 @@ static void dwc_otg_core_init(struct udevice *dev) brst_sz >>= 1; }
-#ifdef CONFIG_DWC2_DMA_ENABLE +#ifdef DWC2_DMA_ENABLE ahbcfg |= DWC2_GAHBCFG_DMAENABLE; #endif break;
case DWC2_HWCFG2_ARCHITECTURE_INT_DMA: ahbcfg |= DWC2_GAHBCFG_HBURSTLEN_INCR4; -#ifdef CONFIG_DWC2_DMA_ENABLE +#ifdef DWC2_DMA_ENABLE ahbcfg |= DWC2_GAHBCFG_DMAENABLE; #endif break; @@ -476,7 +476,7 @@ static void dwc_otg_core_init(struct udevice *dev)
if (!priv->hnp_srp_disable) usbcfg |= DWC2_GUSBCFG_HNPCAP | DWC2_GUSBCFG_SRPCAP; -#ifdef CONFIG_DWC2_IC_USB_CAP +#ifdef DWC2_IC_USB_CAP usbcfg |= DWC2_GUSBCFG_IC_USB_CAP; #endif
@@ -939,9 +939,9 @@ int chunk_msg(struct dwc2_priv *priv, struct usb_device *dev, debug("%s: msg: pipe %lx pid %d in %d len %d\n", __func__, pipe, *pid, in, len);
- max_xfer_len = CONFIG_DWC2_MAX_PACKET_COUNT * max; - if (max_xfer_len > CONFIG_DWC2_MAX_TRANSFER_SIZE) - max_xfer_len = CONFIG_DWC2_MAX_TRANSFER_SIZE; + max_xfer_len = DWC2_MAX_PACKET_COUNT * max; + if (max_xfer_len > DWC2_MAX_TRANSFER_SIZE) + max_xfer_len = DWC2_MAX_TRANSFER_SIZE; if (max_xfer_len > DWC2_DATA_BUF_SIZE) max_xfer_len = DWC2_DATA_BUF_SIZE;
@@ -1198,7 +1198,7 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) return -ENODEV; }
-#ifdef CONFIG_DWC2_PHY_ULPI_EXT_VBUS +#ifdef DWC2_PHY_ULPI_EXT_VBUS priv->ext_vbus = 1; #else priv->ext_vbus = 0; diff --git a/drivers/usb/host/dwc2.h b/drivers/usb/host/dwc2.h index 97a06c48f216..a6f562fe60e2 100644 --- a/drivers/usb/host/dwc2.h +++ b/drivers/usb/host/dwc2.h @@ -759,32 +759,32 @@ struct dwc2_core_regs { #define RH_B_PPCM 0xffff0000 /* port power control mask */
/* Default driver configuration */ -#define CONFIG_DWC2_DMA_ENABLE -#define CONFIG_DWC2_DMA_BURST_SIZE 32 /* DMA burst len */ -#undef CONFIG_DWC2_DFLT_SPEED_FULL /* Do not force DWC2 to FS */ -#define CONFIG_DWC2_ENABLE_DYNAMIC_FIFO /* Runtime FIFO size detect */ -#define CONFIG_DWC2_MAX_CHANNELS 16 /* Max # of EPs */ -#define CONFIG_DWC2_HOST_RX_FIFO_SIZE (516 + CONFIG_DWC2_MAX_CHANNELS) -#define CONFIG_DWC2_HOST_NPERIO_TX_FIFO_SIZE 0x100 /* nPeriodic TX FIFO */ -#define CONFIG_DWC2_HOST_PERIO_TX_FIFO_SIZE 0x200 /* Periodic TX FIFO */ -#define CONFIG_DWC2_MAX_TRANSFER_SIZE 65535 -#define CONFIG_DWC2_MAX_PACKET_COUNT 511 +#define DWC2_DMA_ENABLE +#define DWC2_DMA_BURST_SIZE 32 /* DMA burst len */ +#undef DWC2_DFLT_SPEED_FULL /* Do not force DWC2 to FS */ +#define DWC2_ENABLE_DYNAMIC_FIFO /* Runtime FIFO size detect */ +#define DWC2_MAX_CHANNELS 16 /* Max # of EPs */ +#define DWC2_HOST_RX_FIFO_SIZE (516 + DWC2_MAX_CHANNELS) +#define DWC2_HOST_NPERIO_TX_FIFO_SIZE 0x100 /* nPeriodic TX FIFO */ +#define DWC2_HOST_PERIO_TX_FIFO_SIZE 0x200 /* Periodic TX FIFO */ +#define DWC2_MAX_TRANSFER_SIZE 65535 +#define DWC2_MAX_PACKET_COUNT 511
#define DWC2_PHY_TYPE_FS 0 #define DWC2_PHY_TYPE_UTMI 1 #define DWC2_PHY_TYPE_ULPI 2 -#define CONFIG_DWC2_PHY_TYPE DWC2_PHY_TYPE_UTMI /* PHY type */ -#ifndef CONFIG_DWC2_UTMI_WIDTH -#define CONFIG_DWC2_UTMI_WIDTH 8 /* UTMI bus width (8/16) */ +#define DWC2_PHY_TYPE DWC2_PHY_TYPE_UTMI /* PHY type */ +#ifndef DWC2_UTMI_WIDTH +#define DWC2_UTMI_WIDTH 8 /* UTMI bus width (8/16) */ #endif
-#undef CONFIG_DWC2_PHY_ULPI_DDR /* ULPI PHY uses DDR mode */ -#define CONFIG_DWC2_PHY_ULPI_EXT_VBUS /* ULPI PHY controls VBUS */ -#undef CONFIG_DWC2_I2C_ENABLE /* Enable I2C */ -#undef CONFIG_DWC2_ULPI_FS_LS /* ULPI is FS/LS */ -#undef CONFIG_DWC2_TS_DLINE /* External DLine pulsing */ -#undef CONFIG_DWC2_THR_CTL /* Threshold control */ -#define CONFIG_DWC2_TX_THR_LENGTH 64 -#undef CONFIG_DWC2_IC_USB_CAP /* IC Cap */ +#undef DWC2_PHY_ULPI_DDR /* ULPI PHY uses DDR mode */ +#define DWC2_PHY_ULPI_EXT_VBUS /* ULPI PHY controls VBUS */ +#undef DWC2_I2C_ENABLE /* Enable I2C */ +#undef DWC2_ULPI_FS_LS /* ULPI is FS/LS */ +#undef DWC2_TS_DLINE /* External DLine pulsing */ +#undef DWC2_THR_CTL /* Threshold control */ +#define DWC2_TX_THR_LENGTH 64 +#undef DWC2_IC_USB_CAP /* IC Cap */
#endif /* __DWC2_H__ */ diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 659fbee052d5..45b01463acb1 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -47,10 +47,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_8M)
-#ifdef CONFIG_USB_DWC2 -#define CONFIG_DWC2_ENABLE_DYNAMIC_FIFO -#endif - #define CONFIG_HIKEY_GPIO
/* BOOTP options */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2d70bf5da7c5..9384aa8e4e0b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -282,26 +282,6 @@ CONFIG_DRIVER_AT91EMAC_PHYADDR CONFIG_DRIVER_AT91EMAC_QUIET CONFIG_DRIVER_DM9000 CONFIG_DSP_CLUSTER_START -CONFIG_DWC2_DFLT_SPEED_FULL -CONFIG_DWC2_DMA_BURST_SIZE -CONFIG_DWC2_DMA_ENABLE -CONFIG_DWC2_ENABLE_DYNAMIC_FIFO -CONFIG_DWC2_HOST_NPERIO_TX_FIFO_SIZE -CONFIG_DWC2_HOST_PERIO_TX_FIFO_SIZE -CONFIG_DWC2_HOST_RX_FIFO_SIZE -CONFIG_DWC2_I2C_ENABLE -CONFIG_DWC2_IC_USB_CAP -CONFIG_DWC2_MAX_CHANNELS -CONFIG_DWC2_MAX_PACKET_COUNT -CONFIG_DWC2_MAX_TRANSFER_SIZE -CONFIG_DWC2_PHY_TYPE -CONFIG_DWC2_PHY_ULPI_DDR -CONFIG_DWC2_PHY_ULPI_EXT_VBUS -CONFIG_DWC2_THR_CTL -CONFIG_DWC2_TS_DLINE -CONFIG_DWC2_TX_THR_LENGTH -CONFIG_DWC2_ULPI_FS_LS -CONFIG_DWC2_UTMI_WIDTH CONFIG_DWCDDR21MCTL CONFIG_DWCDDR21MCTL_BASE CONFIG_DWC_AHSATA_BASE_ADDR
