[PATCH] mx6sabresd: Convert PCI to driver model
Convert imx6sabresd PCI to driver model to fix the following warning:
===================== WARNING ====================== This board does not use CONFIG_DM_PCI Please update the board to use CONFIG_DM_PCI before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
After the conversion the following commands were used for testing:
=> pci enum PCI: Failed autoconfig bar 10 PCI: Failed autoconfig bar 10 => pci 1 Scanning PCI devices on bus 1 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 01.00.00 0x8086 0x08b1 Network controller 0x80
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- board/freescale/mx6sabresd/mx6sabresd.c | 11 ----------- configs/mx6sabresd_defconfig | 1 + 2 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index b346ca4ced..4a208277ac 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -231,16 +231,6 @@ static void setup_spi(void) SETUP_IOMUX_PADS(ecspi1_pads); }
-iomux_v3_cfg_t const pcie_pads[] = { - IOMUX_PADS(PAD_EIM_D19__GPIO3_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* POWER */ - IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* RESET */ -}; - -static void setup_pcie(void) -{ - SETUP_IOMUX_PADS(pcie_pads); -} - iomux_v3_cfg_t const di0_pads[] = { IOMUX_PADS(PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK), /* DISP0_CLK */ IOMUX_PADS(PAD_DI0_PIN2__IPU1_DI0_PIN02), /* DISP0_HSYNC */ @@ -508,7 +498,6 @@ int overwrite_console(void) int board_eth_init(bd_t *bis) { setup_iomux_enet(); - setup_pcie();
return cpu_eth_init(bis); } diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 0bd686ec86..e3b8908928 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -83,6 +83,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y
Convert imx6sabresd ethernet to driver model to fix the following warning:
===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- board/freescale/mx6sabresd/mx6sabresd.c | 29 ------------------------- configs/mx6sabresd_defconfig | 5 +++++ include/configs/mx6sabresd.h | 9 -------- 3 files changed, 5 insertions(+), 38 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 4a208277ac..4b0af86f0b 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -21,7 +21,6 @@ #include <mmc.h> #include <fsl_esdhc_imx.h> #include <miiphy.h> -#include <netdev.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> @@ -44,9 +43,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - #define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
@@ -73,31 +69,6 @@ static iomux_v3_cfg_t const uart1_pads[] = { IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
-static iomux_v3_cfg_t const enet_pads[] = { - IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), - /* AR8031 PHY Reset */ - IOMUX_PADS(PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -static void setup_iomux_enet(void) -{ - SETUP_IOMUX_PADS(enet_pads); -} - static iomux_v3_cfg_t const usdhc2_pads[] = { IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index e3b8908928..05428a142c 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -81,6 +81,11 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index d810202117..ec1537541a 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -62,13 +62,4 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Enabled USB controller number */ #endif
-#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 1 - -#define CONFIG_PHY_ATHEROS - - #endif /* __MX6SABRESD_CONFIG_H */
Reviewed-by: Fabio Estevam festevam@gmail.com
Alifer Moraes
Fabio Estevam
