[U-Boot] [PATCH] da850evm: fix NAND WSTROBE and TA timings
The current NAND timings, introduced in commit a3f88293ddd13facd734769c1664d35ab4ed681f da850evm: setup the NAND flash timings , incorrectly set WSTROBE and TA to 0. A more recent inspection of the values set by the Linux kernel indicates that these should be set to 1.
Set the WSTROBE and TA field of the EMIFA cycle-count timings configuration to 1 to match the values set by linux.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Stefano Babic sbabic@denx.de CC: Sandeep Paulraj s-paulraj@ti.com CC: Scott Wood scottwood@freescale.com Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- board/davinci/da8xxevm/da850evm.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index b088c9c..73eaa48 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -179,12 +179,12 @@ int board_init(void) * Linux kernel @ 25MHz EMIFA */ writel((DAVINCI_ABCR_WSETUP(0) | - DAVINCI_ABCR_WSTROBE(0) | + DAVINCI_ABCR_WSTROBE(1) | DAVINCI_ABCR_WHOLD(0) | DAVINCI_ABCR_RSETUP(0) | DAVINCI_ABCR_RSTROBE(1) | DAVINCI_ABCR_RHOLD(0) | - DAVINCI_ABCR_TA(0) | + DAVINCI_ABCR_TA(1) | DAVINCI_ABCR_ASIZE_8BIT), &davinci_emif_regs->ab2cr); /* CS3 */ #endif
s-paulraj@ti.com
