[U-Boot] [PATCH] usb_storage: fix ehci driver max transfer size
The commit 5dd95cf93dfffa1d19a1928990852aac9f55b9d9 'usb_storage: Fix EHCI "out of buffer pointers" with CD-ROM' introduce a bug in usb_storage as it wrongly assumes that every transfer can use 4k per qt_buffer. This is wrong if the start address of the data is not 4k aligned and leads to 'EHCI timed out on TD' messages because of 'out of buffer pointers' in ehci_td_buffer function.
Cc: Marek Vasut marex@denx.de Signed-off-by: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net --- common/usb_storage.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index faad237..612a553 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -1416,10 +1416,10 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type);
/* - * The U-Boot EHCI driver cannot handle more than 4096 * 5 bytes in a - * transfer without running itself out of qt_buffers. + * The U-Boot EHCI driver cannot handle more than 4096 * 4 bytes in a + * unaligned transfer without running itself out of qt_buffers. */ - ss->max_xfer_blk = (4096 * 5) / dev_desc->blksz; + ss->max_xfer_blk = (4096 * 4) / dev_desc->blksz;
init_part(dev_desc);
Dear Stefan Herbrechtsmeier,
Stefan, thanks a lot for finding this! I'll look into it on 21st I hope.
*/* unaligned transfer without running itself out of qt_buffers.
Best regards, Marek Vasut
Ok, first I have to admit I broke my promise to look into this ASAP, sorry about it :-(
Just curious, but shouldn't it be ((4096 * 5) / dev_desc->blk_sz) - 1 ?
Am 03.07.2012 20:10, schrieb Marek Vasut:
No problem, as long as we get it into the next release. ;-)
No, because the first blk need to be aligned with the 4096. In worst case the blk is at the end of the 4096 range. If we assume that the blk is aligned to blk_sz we can change it to ((4096 * 4) / dev_desc->blk_sz) + 1. I skip the last blk (+ 1) because with 4096 aligned first blk we unaligned the next transfer and add extra short packages to each ehci transfer.
If we want to maximise the usage we need to calculate the max_xfer_blk depending on the start address of the first blk.
about
it :-(
- I skip the last blk (+ 1) because with 4096 aligned first blk we
I admit to not totally getting it. However, there are two things that come to my mind: - Doesn't the EHCI Specification mention exactly five buffers that can/should/must be used? - I think I once stumbled across some comment that said as much as the blocks always having to be aligned anyway?
:-) Kolja
*dev,
part_type);
a
a
Am 04.07.2012 08:57, schrieb Schneider, Kolja:
about
it :-(
Yes, you can use up to five 4096 byte buffers.
The buffers must be aligned to a 4096 byte page. This means that you have to use the first and last buffer to align your data to the next or previous 4096 byte page boundary.
about
it :-(
to my mind:
can/should/must
be used?
the
blocks
All right, I managed to replicate the issue. This (or similar) doesn't work for you, right:
usb read 0x42000004 0x0 0x400
The proper solution would be to introduce a bounce buffer for such unaligned transfers. A proper, generic bounce buffer that can be configured to bounce on specified boundaries and warns about performance penalties.
Am 07.07.2012 23:58, schrieb Marek Vasut:
about
it :-(
to my mind:
can/should/must
be used?
the
blocks
I observe the bug during fatload usb 0 0x800000 uImage
... dev=0ffb0440, pipe=c8008283, buffer=00a90000, length=20480, req=(null) ... dev=0ffb0440, pipe=c8008283, buffer=00a95000, length=20480, req=(null) ... dev=0ffb0440, pipe=c8008283, buffer=00a9a000, length=18432, req=(null) ... dev=0ffb0440, pipe=c8008283, buffer=00a9e800, length=20480, req=(null) out of buffer pointers (2048 bytes left) ...
It looks like the file is fragmented. During load the start address becomes unaligned and thereby the code wrongly tries to transfer more blocks than possible.
Before the above mentioned patch the max_xfer_blk was much smaller (20), so that the problem never appears.
Why not limit the max_xfer_blk to the maximum save count [(4096 * 4) / dev_desc->blksz)] or calculate the max_xfer_blk depending on the start address of the transfer:
max_xfer_blk = ((4096 * 5) - (start & ~4096) / dev_desc->blksz
Regards, Stefan
> The commit 5dd95cf93dfffa1d19a1928990852aac9f55b9d9 'usb_storage: > Fix EHCI "out of buffer pointers" with CD-ROM' introduce a bug in > usb_storage as it wrongly assumes that every transfer can use 4k > per qt_buffer. This is wrong if the start address of the data > is not 4k aligned and leads to 'EHCI timed out on TD' messages > because of 'out of buffer pointers' in ehci_td_buffer function. > > Cc: Marek Vasut marex@denx.de > Signed-off-by: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net
about
it :-(
to my mind:
can/should/must
be used?
the
blocks
This looks like a much better solution ;-) Can you redo the patch for that? Also, there's some macro for that rounding in include/common.h
Regards, Stefan
The commit 5dd95cf93dfffa1d19a1928990852aac9f55b9d9 'usb_storage: Fix EHCI "out of buffer pointers" with CD-ROM' introduce a bug in usb_storage as it wrongly assumes that every transfer can use 4096 bytes per qt_buffer. This is wrong if the start address of the data is not page aligned to 4096 bytes and leads to 'EHCI timed out on TD' messages because of 'out of buffer pointers' in ehci_td_buffer function.
The bug appears during load of a fragmented file and read from or write to an unaligned memory address.
--- Changes for v2: - Replace fixed worst case calculation with dynamic computation based on start address of transfer
common/usb_storage.c | 37 ++++++++++++++++++++----------------- 1 file changed, 20 insertions(+), 17 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index faad237..bdc306f 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -150,12 +150,17 @@ struct us_data { unsigned int irqpipe; /* pipe for release_irq */ unsigned char irqmaxp; /* max packed for irq Pipe */ unsigned char irqinterval; /* Intervall for IRQ Pipe */ - unsigned long max_xfer_blk; /* Max blocks per xfer */ ccb *srb; /* current srb */ trans_reset transport_reset; /* reset routine */ trans_cmnd transport; /* transport routine */ };
+/* + * The U-Boot EHCI driver cannot handle more than 5 page aligned buffers + * of 4096 bytes in a transfer without running itself out of qt_buffers + */ +#define USB_MAX_XFER_BLK(start, blksz) (((4096 * 5) - (start % 4096)) / blksz) + static struct us_data usb_stor[USB_MAX_STOR_DEV];
@@ -1041,7 +1046,7 @@ static void usb_bin_fixup(struct usb_device_descriptor descriptor, unsigned long usb_stor_read(int device, unsigned long blknr, unsigned long blkcnt, void *buffer) { - unsigned long start, blks, buf_addr; + unsigned long start, blks, buf_addr, max_xfer_blk; unsigned short smallblks; struct usb_device *dev; struct us_data *ss; @@ -1083,12 +1088,14 @@ unsigned long usb_stor_read(int device, unsigned long blknr, /* XXX need some comment here */ retry = 2; srb->pdata = (unsigned char *)buf_addr; - if (blks > ss->max_xfer_blk) - smallblks = ss->max_xfer_blk; + max_xfer_blk = USB_MAX_XFER_BLK(buf_addr, + usb_dev_desc[device].blksz); + if (blks > max_xfer_blk) + smallblks = (unsigned short) max_xfer_blk; else smallblks = (unsigned short) blks; retry_it: - if (smallblks == ss->max_xfer_blk) + if (smallblks == max_xfer_blk) usb_show_progress(); srb->datalen = usb_dev_desc[device].blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; @@ -1109,7 +1116,7 @@ retry_it: start, smallblks, buf_addr);
usb_disable_asynch(0); /* asynch transfer allowed */ - if (blkcnt >= ss->max_xfer_blk) + if (blkcnt >= max_xfer_blk) debug("\n"); return blkcnt; } @@ -1117,7 +1124,7 @@ retry_it: unsigned long usb_stor_write(int device, unsigned long blknr, unsigned long blkcnt, const void *buffer) { - unsigned long start, blks, buf_addr; + unsigned long start, blks, buf_addr, max_xfer_blk; unsigned short smallblks; struct usb_device *dev; struct us_data *ss; @@ -1162,12 +1169,14 @@ unsigned long usb_stor_write(int device, unsigned long blknr, */ retry = 2; srb->pdata = (unsigned char *)buf_addr; - if (blks > ss->max_xfer_blk) - smallblks = ss->max_xfer_blk; + max_xfer_blk = USB_MAX_XFER_BLK(buf_addr, + usb_dev_desc[device].blksz); + if (blks > max_xfer_blk) + smallblks = (unsigned short) max_xfer_blk; else smallblks = (unsigned short) blks; retry_it: - if (smallblks == ss->max_xfer_blk) + if (smallblks == max_xfer_blk) usb_show_progress(); srb->datalen = usb_dev_desc[device].blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; @@ -1188,7 +1197,7 @@ retry_it: start, smallblks, buf_addr);
@@ -1415,12 +1424,6 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, USB_STOR_PRINTF(" address %d\n", dev_desc->target); USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type);
- /* - * The U-Boot EHCI driver cannot handle more than 4096 * 5 bytes in a - * transfer without running itself out of qt_buffers. - */ - ss->max_xfer_blk = (4096 * 5) / dev_desc->blksz; - init_part(dev_desc);
Yes, this can be simply confirmed even with USB stick by loading to unaligned address. It'll make the buffers overflow too.
Changes for v2:
- The U-Boot EHCI driver cannot handle more than 5 page aligned buffers
- of 4096 bytes in a transfer without running itself out of qt_buffers
Can't something in include/common.h around line 900 can't be used?
btw put braces around (start) in the macro and around (blksz) .
The rest is good, thanks! :-)
Am 10.07.2012 04:12, schrieb Marek Vasut:
Changes for v2:
If you mean the round functions I don't need them, as I need the leftover of 4096 and I need to divide round down the count.
I will send a v3 tonight.
Regards, Stefan
Changes for v2:
Ok then, I think this is just perfect than and it should definitelly hit this release :-)
Thank you very much, sorry for pestering you too much and adding delays. Shame on my maintaining skills.
Regards, Stefan
--- Changes for v2: - Replace fixed worst case calculation with dynamic computation based on start address of transfer Changes for v3: - Add parentheses within macro around parameters
common/usb_storage.c | 38 +++++++++++++++++++++----------------- 1 file changed, 21 insertions(+), 17 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index faad237..c528979 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -150,12 +150,18 @@ struct us_data { unsigned int irqpipe; /* pipe for release_irq */ unsigned char irqmaxp; /* max packed for irq Pipe */ unsigned char irqinterval; /* Intervall for IRQ Pipe */ - unsigned long max_xfer_blk; /* Max blocks per xfer */ ccb *srb; /* current srb */ trans_reset transport_reset; /* reset routine */ trans_cmnd transport; /* transport routine */ };
+/* + * The U-Boot EHCI driver cannot handle more than 5 page aligned buffers + * of 4096 bytes in a transfer without running itself out of qt_buffers + */ +#define USB_MAX_XFER_BLK(start, blksz) \ + (((4096 * 5) - ((start) % 4096)) / (blksz)) + static struct us_data usb_stor[USB_MAX_STOR_DEV];
@@ -1041,7 +1047,7 @@ static void usb_bin_fixup(struct usb_device_descriptor descriptor, unsigned long usb_stor_read(int device, unsigned long blknr, unsigned long blkcnt, void *buffer) { - unsigned long start, blks, buf_addr; + unsigned long start, blks, buf_addr, max_xfer_blk; unsigned short smallblks; struct usb_device *dev; struct us_data *ss; @@ -1083,12 +1089,14 @@ unsigned long usb_stor_read(int device, unsigned long blknr, /* XXX need some comment here */ retry = 2; srb->pdata = (unsigned char *)buf_addr; - if (blks > ss->max_xfer_blk) - smallblks = ss->max_xfer_blk; + max_xfer_blk = USB_MAX_XFER_BLK(buf_addr, + usb_dev_desc[device].blksz); + if (blks > max_xfer_blk) + smallblks = (unsigned short) max_xfer_blk; else smallblks = (unsigned short) blks; retry_it: - if (smallblks == ss->max_xfer_blk) + if (smallblks == max_xfer_blk) usb_show_progress(); srb->datalen = usb_dev_desc[device].blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; @@ -1109,7 +1117,7 @@ retry_it: start, smallblks, buf_addr);
usb_disable_asynch(0); /* asynch transfer allowed */ - if (blkcnt >= ss->max_xfer_blk) + if (blkcnt >= max_xfer_blk) debug("\n"); return blkcnt; } @@ -1117,7 +1125,7 @@ retry_it: unsigned long usb_stor_write(int device, unsigned long blknr, unsigned long blkcnt, const void *buffer) { - unsigned long start, blks, buf_addr; + unsigned long start, blks, buf_addr, max_xfer_blk; unsigned short smallblks; struct usb_device *dev; struct us_data *ss; @@ -1162,12 +1170,14 @@ unsigned long usb_stor_write(int device, unsigned long blknr, */ retry = 2; srb->pdata = (unsigned char *)buf_addr; - if (blks > ss->max_xfer_blk) - smallblks = ss->max_xfer_blk; + max_xfer_blk = USB_MAX_XFER_BLK(buf_addr, + usb_dev_desc[device].blksz); + if (blks > max_xfer_blk) + smallblks = (unsigned short) max_xfer_blk; else smallblks = (unsigned short) blks; retry_it: - if (smallblks == ss->max_xfer_blk) + if (smallblks == max_xfer_blk) usb_show_progress(); srb->datalen = usb_dev_desc[device].blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; @@ -1188,7 +1198,7 @@ retry_it: start, smallblks, buf_addr);
@@ -1415,12 +1425,6 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, USB_STOR_PRINTF(" address %d\n", dev_desc->target); USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type);
This one is good :-)
Thank you, Stefan! For your contribution and your patience.
I'll test it on friday and I'll talk to WD to include it in current release. The fix looks very reasonable. Though I'd like to get some tests done. Tom, Ilya, can you possibly try this on your toys please? [...]
The patch is good in the sense it does fix the real problem. But I wonder if it's a good idea to expose lower layer details (like size/number of buffers per EHCI TD) to upper layer driver? I know EHCI is most common USB HCD but we have drivers for a bunch of others... How about them?
Regards, Ilya.
Dear Ilya Yanok,
No, it's not ... it's yet another usb-is-full-of-crap-in-uboot kind of bugs :-(
I'd like to queue this for the current release, we can work on proper rework for -next. Agreed?
Regards, Ilya.
Dear Marek,
USB
Agreed,
Regards, Ilya.
Dear Ilya Yanok,
Dear Marek,
USB
Agreed,
Thanks! I'm marking this important in my mailbox to avoid missing that we need to fix this. Ilya, can you check the driver model papers and see if we can somehow integrate this into that?
Regards, Ilya.
Dear Marek,
I will try to.
Regards, Ilya.
Dear Wolfgang Denk,
I'd like to get this patch:
http://patchwork.ozlabs.org/patch/170256/
applied into current release. If you consider a pullRQ is better, I'll prepare one.
I applied this and pushed into u-boot-usb. Thanks again for finding and fixing this.
I'm still uncertain if we should add it into current release so late, probably not though. Therefore I'll queue it for next, ok?
Am 18.07.2012 14:50, schrieb Marek Vasut:
Given that there was nobody other than me with the problem until now, it should be okay.
Regards, Stefan
Ilya Yanok
Schneider, Kolja
