[U-Boot] [PATCH] 4/12 Multiadapter/multibus I2C, drivers part 1
Signed-off-by: Sergey Kubushyn ksi@koi8.net --- diff -purN u-boot-i2c.orig/drivers/i2c/bfin-twi_i2c.c u-boot-i2c/drivers/i2c/bfin-twi_i2c.c --- u-boot-i2c.orig/drivers/i2c/bfin-twi_i2c.c 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/drivers/i2c/bfin-twi_i2c.c 2009-02-12 10:46:00.000000000 -0800 @@ -1,4 +1,8 @@ /* + * Copyright (c) 2009 Sergey Kubushyn ksi@koi8.net + * + * Changes for multibus/multiadapter I2C support. + * * i2c.c - driver for Blackfin on-chip TWI/I2C * * Copyright (c) 2006-2008 Analog Devices Inc. @@ -44,7 +48,7 @@ #ifdef CONFIG_TWICLK_KHZ # error do not define CONFIG_TWICLK_KHZ ... use CONFIG_SYS_I2C_SPEED #endif -#if CONFIG_SYS_I2C_SPEED > 400000 +#if CONFIG_SYS_BFIN_TWI_I2C_SPEED > 400000 # error The Blackfin I2C hardware can only operate at 400KHz max #endif
@@ -60,6 +64,10 @@ struct i2c_msg { u8 *abuf; /* addr buffer */ };
+i2c_adap_t bfin_twi_i2c_adap; + +DECLARE_GLOBAL_DATA_PTR; + /** * wait_for_completion - manage the actual i2c transfer * @msg: the i2c msg @@ -205,14 +213,14 @@ static int i2c_transfer(uchar chip, uint }
/* - * i2c_init - initialize the i2c bus + * bfin_twi_i2c_init - initialize the i2c bus * @speed: bus speed (in HZ) * @slaveaddr: address of device in slave mode (0 - not slave) * * Slave mode isn't actually implemented. It'll stay that way until * we get a real request for it. */ -void i2c_init(int speed, int slaveaddr) +static void bfin_twi_i2c_init(int speed, int slaveaddr) { uint8_t prescale = ((get_sclk() / 1024 / 1024 + 5) / 10) & 0x7F;
@@ -235,7 +243,7 @@ void i2c_init(int speed, int slaveaddr) debugi("CONTROL:0x%04x CLKDIV:0x%04x", bfin_read_TWI_CONTROL(), bfin_read_TWI_CLKDIV());
-#if CONFIG_SYS_I2C_SLAVE +#if CONFIG_SYS_BFIN_TWI_I2C_SLAVE # error I2C slave support not tested/supported /* If they want us as a slave, do it */ if (slaveaddr) { @@ -243,21 +251,13 @@ void i2c_init(int speed, int slaveaddr) bfin_write_TWI_SLAVE_CTL(SEN); } #endif + if (gd->flags & GD_FLG_RELOC) { + bfin_twi_i2c_adap.init_done = 1; + } }
/** - * i2c_probe - test if a chip exists at a given i2c address - * @chip: i2c chip addr to search for - * @return: 0 if found, non-0 if not found - */ -int i2c_probe(uchar chip) -{ - u8 byte; - return i2c_read(chip, 0, 0, &byte, 1); -} - -/** - * i2c_read - read data from an i2c device + * bfin_twi_i2c_read - read data from an i2c device * @chip: i2c chip addr * @addr: memory (register) address in the chip * @alen: byte size of address @@ -265,13 +265,24 @@ int i2c_probe(uchar chip) * @len: how many bytes to read * @return: 0 on success, non-0 on failure */ -int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) +static int bfin_twi_i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) { return i2c_transfer(chip, addr, alen, buffer, len, (alen ? I2C_M_COMBO : I2C_M_READ)); }
/** - * i2c_write - write data to an i2c device + * bfin_twi_i2c_probe - test if a chip exists at a given i2c address + * @chip: i2c chip addr to search for + * @return: 0 if found, non-0 if not found + */ +static int bfin_twi_i2c_probe(uchar chip) +{ + u8 byte; + return bfin_twi_i2c_read(chip, 0, 0, &byte, 1); +} + +/** + * bfin_twi_i2c_write - write data to an i2c device * @chip: i2c chip addr * @addr: memory (register) address in the chip * @alen: byte size of address @@ -279,7 +290,30 @@ int i2c_read(uchar chip, uint addr, int * @len: how many bytes to write * @return: 0 on success, non-0 on failure */ -int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) +static int bfin_twi_i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) { return i2c_transfer(chip, addr, alen, buffer, len, 0); } + +static unsigned int bfin_twi_i2c_set_bus_speed(unsigned int speed) +{ + return(bfin_twi_i2c_adap.speed); +} + +static unsigned int bfin_twi_i2c_get_bus_speed(void) +{ + return(bfin_twi_i2c_adap.speed); +} + +i2c_adap_t bfin_twi_i2c_adap = { + .init = bfin_twi_i2c_init, + .probe = bfin_twi_i2c_probe, + .read = bfin_twi_i2c_read, + .write = bfin_twi_i2c_write, + .set_bus_speed = bfin_twi_i2c_set_bus_speed, + .get_bus_speed = bfin_twi_i2c_get_bus_speed, + .speed = CONFIG_SYS_BFIN_TWI_I2C_SPEED, + .slaveaddr = CONFIG_SYS_BFIN_TWI_I2C_SLAVE, + .init_done = 0, + .name = "bfin_twi_i2c" +}; diff -purN u-boot-i2c.orig/drivers/i2c/fsl_i2c.c u-boot-i2c/drivers/i2c/fsl_i2c.c --- u-boot-i2c.orig/drivers/i2c/fsl_i2c.c 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/drivers/i2c/fsl_i2c.c 2009-02-12 10:46:00.000000000 -0800 @@ -1,4 +1,8 @@ /* + * Copyright (c) 2009 Sergey Kubushyn ksi@koi8.net + * + * Changes for multibus/multiadapter I2C support. + * * Copyright 2006 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or @@ -18,8 +22,6 @@
#include <common.h>
-#ifdef CONFIG_HARD_I2C - #include <command.h> #include <i2c.h> /* Functional interface */
@@ -31,24 +33,15 @@ #define I2C_READ_BIT 1 #define I2C_WRITE_BIT 0
-DECLARE_GLOBAL_DATA_PTR; - -/* Initialize the bus pointer to whatever one the SPD EEPROM is on. - * Default is bus 0. This is necessary because the DDR initialization - * runs from ROM, and we can't switch buses because we can't modify - * the global variables. - */ -#ifndef CONFIG_SYS_SPD_BUS_NUM -#define CONFIG_SYS_SPD_BUS_NUM 0 -#endif -static unsigned int i2c_bus_num __attribute__ ((section (".data"))) = CONFIG_SYS_SPD_BUS_NUM; +#define FSL_NAME(arg) "fsl_i2c@" MK_NAME(arg) +#define MK_NAME(arg) #arg
-static unsigned int i2c_bus_speed[2] = {CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SPEED}; +DECLARE_GLOBAL_DATA_PTR;
static const struct fsl_i2c *i2c_dev[2] = { - (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_I2C_OFFSET), -#ifdef CONFIG_SYS_I2C2_OFFSET - (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_I2C2_OFFSET) + (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_I2C_OFFSET), +#ifdef CONFIG_SYS_FSL_I2C2_OFFSET + (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_I2C2_OFFSET) #endif };
@@ -126,6 +119,8 @@ static const struct { #endif };
+i2c_adap_t fsl_i2c_adap[]; + /** * Set the I2C bus speed for a given I2C device * @@ -169,43 +164,32 @@ static unsigned int set_i2c_bus_speed(co return speed; }
-void -i2c_init(int speed, int slaveadd) + +static void __i2c_init(int adap_no, int speed, int slaveadd) { struct fsl_i2c *dev; unsigned int temp;
- dev = (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_I2C_OFFSET); + dev = i2c_dev[adap_no];
writeb(0, &dev->cr); /* stop I2C controller */ udelay(5); /* let it shutdown in peace */ temp = set_i2c_bus_speed(dev, gd->i2c1_clk, speed); - if (gd->flags & GD_FLG_RELOC) - i2c_bus_speed[0] = temp; - writeb(slaveadd << 1, &dev->adr); /* write slave address */ - writeb(0x0, &dev->sr); /* clear status register */ - writeb(I2C_CR_MEN, &dev->cr); /* start I2C controller */ - -#ifdef CONFIG_SYS_I2C2_OFFSET - dev = (struct fsl_i2c *) (CONFIG_SYS_IMMR + CONFIG_SYS_I2C2_OFFSET); - - writeb(0, &dev->cr); /* stop I2C controller */ - udelay(5); /* let it shutdown in peace */ - temp = set_i2c_bus_speed(dev, gd->i2c2_clk, speed); - if (gd->flags & GD_FLG_RELOC) - i2c_bus_speed[1] = temp; + if (gd->flags & GD_FLG_RELOC) { + fsl_i2c_adap[adap_no].speed = temp; + fsl_i2c_adap[adap_no].slaveaddr = slaveadd; + } writeb(slaveadd << 1, &dev->adr); /* write slave address */ writeb(0x0, &dev->sr); /* clear status register */ writeb(I2C_CR_MEN, &dev->cr); /* start I2C controller */ -#endif }
-static __inline__ int -i2c_wait4bus(void) + +static __inline__ int i2c_wait4bus(int adap_no) { unsigned long long timeval = get_ticks();
- while (readb(&i2c_dev[i2c_bus_num]->sr) & I2C_SR_MBB) { + while (readb(&i2c_dev[adap_no]->sr) & I2C_SR_MBB) { if ((get_ticks() - timeval) > usec2ticks(I2C_TIMEOUT)) return -1; } @@ -213,18 +197,18 @@ i2c_wait4bus(void) return 0; }
-static __inline__ int -i2c_wait(int write) + +static __inline__ int i2c_wait(int adap_no, int write) { u32 csr; unsigned long long timeval = get_ticks();
do { - csr = readb(&i2c_dev[i2c_bus_num]->sr); + csr = readb(&i2c_dev[adap_no]->sr); if (!(csr & I2C_SR_MIF)) continue;
- writeb(0x0, &i2c_dev[i2c_bus_num]->sr); + writeb(0x0, &i2c_dev[adap_no]->sr);
if (csr & I2C_SR_MAL) { debug("i2c_wait: MAL\n"); @@ -248,85 +232,85 @@ i2c_wait(int write) return -1; }
-static __inline__ int -i2c_write_addr (u8 dev, u8 dir, int rsta) + +static __inline__ int i2c_write_addr (int adap_no, u8 dev, u8 dir, int rsta) { writeb(I2C_CR_MEN | I2C_CR_MSTA | I2C_CR_MTX | (rsta ? I2C_CR_RSTA : 0), - &i2c_dev[i2c_bus_num]->cr); + &i2c_dev[adap_no]->cr);
- writeb((dev << 1) | dir, &i2c_dev[i2c_bus_num]->dr); + writeb((dev << 1) | dir, &i2c_dev[adap_no]->dr);
- if (i2c_wait(I2C_WRITE_BIT) < 0) + if (i2c_wait(adap_no, I2C_WRITE_BIT) < 0) return 0;
return 1; }
-static __inline__ int -__i2c_write(u8 *data, int length) + +static __inline__ int i2c_write_data(int adap_no, u8 *data, int length) { int i;
writeb(I2C_CR_MEN | I2C_CR_MSTA | I2C_CR_MTX, - &i2c_dev[i2c_bus_num]->cr); + &i2c_dev[adap_no]->cr);
for (i = 0; i < length; i++) { - writeb(data[i], &i2c_dev[i2c_bus_num]->dr); + writeb(data[i], &i2c_dev[adap_no]->dr);
- if (i2c_wait(I2C_WRITE_BIT) < 0) + if (i2c_wait(adap_no, I2C_WRITE_BIT) < 0) break; }
return i; }
-static __inline__ int -__i2c_read(u8 *data, int length) + +static __inline__ int i2c_read_data(int adap_no, u8 *data, int length) { int i;
writeb(I2C_CR_MEN | I2C_CR_MSTA | ((length == 1) ? I2C_CR_TXAK : 0), - &i2c_dev[i2c_bus_num]->cr); + &i2c_dev[adap_no]->cr);
/* dummy read */ - readb(&i2c_dev[i2c_bus_num]->dr); + readb(&i2c_dev[adap_no]->dr);
for (i = 0; i < length; i++) { - if (i2c_wait(I2C_READ_BIT) < 0) + if (i2c_wait(adap_no, I2C_READ_BIT) < 0) break;
/* Generate ack on last next to last byte */ if (i == length - 2) writeb(I2C_CR_MEN | I2C_CR_MSTA | I2C_CR_TXAK, - &i2c_dev[i2c_bus_num]->cr); + &i2c_dev[adap_no]->cr);
/* Generate stop on last byte */ if (i == length - 1) - writeb(I2C_CR_MEN | I2C_CR_TXAK, &i2c_dev[i2c_bus_num]->cr); + writeb(I2C_CR_MEN | I2C_CR_TXAK, &i2c_dev[adap_no]->cr);
- data[i] = readb(&i2c_dev[i2c_bus_num]->dr); + data[i] = readb(&i2c_dev[adap_no]->dr); }
return i; }
-int -i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) + +static int __i2c_read(int adap_no, u8 dev, uint addr, int alen, u8 *data, int length) { int i = -1; /* signal error */ u8 *a = (u8*)&addr;
- if (i2c_wait4bus() >= 0 - && i2c_write_addr(dev, I2C_WRITE_BIT, 0) != 0 - && __i2c_write(&a[4 - alen], alen) == alen) + if (i2c_wait4bus(adap_no) >= 0 + && i2c_write_addr(adap_no, dev, I2C_WRITE_BIT, 0) != 0 + && i2c_write_data(adap_no, &a[4 - alen], alen) == alen) i = 0; /* No error so far */
if (length - && i2c_write_addr(dev, I2C_READ_BIT, 1) != 0) - i = __i2c_read(data, length); + && i2c_write_addr(adap_no, dev, I2C_READ_BIT, 1) != 0) + i = i2c_read_data(adap_no, data, length);
- writeb(I2C_CR_MEN, &i2c_dev[i2c_bus_num]->cr); + writeb(I2C_CR_MEN, &i2c_dev[adap_no]->cr);
if (i == length) return 0; @@ -334,19 +318,19 @@ i2c_read(u8 dev, uint addr, int alen, u8 return -1; }
-int -i2c_write(u8 dev, uint addr, int alen, u8 *data, int length) + +static int __i2c_write(int adap_no, u8 dev, uint addr, int alen, u8 *data, int length) { int i = -1; /* signal error */ u8 *a = (u8*)&addr;
- if (i2c_wait4bus() >= 0 - && i2c_write_addr(dev, I2C_WRITE_BIT, 0) != 0 - && __i2c_write(&a[4 - alen], alen) == alen) { - i = __i2c_write(data, length); + if (i2c_wait4bus(adap_no) >= 0 + && i2c_write_addr(adap_no, dev, I2C_WRITE_BIT, 0) != 0 + && i2c_write_data(adap_no, &a[4 - alen], alen) == alen) { + i = i2c_write_data(adap_no, data, length); }
if (i == length) return 0; @@ -354,54 +338,123 @@ i2c_write(u8 dev, uint addr, int alen, u return -1; }
-int -i2c_probe(uchar chip) + +static int __i2c_probe(int adap_no, uchar chip) { /* For unknow reason the controller will ACK when * probing for a slave with the same address, so skip * it. */ - if (chip == (readb(&i2c_dev[i2c_bus_num]->adr) >> 1)) + if (chip == (readb(&i2c_dev[adap_no]->adr) >> 1)) return -1;
- return i2c_read(chip, 0, 0, NULL, 0); + return __i2c_read(adap_no, chip, 0, 0, NULL, 0); }
-int i2c_set_bus_num(unsigned int bus) + +static int __i2c_set_bus_speed(int adap_no, unsigned int speed) { -#ifdef CONFIG_SYS_I2C2_OFFSET - if (bus > 1) { -#else - if (bus > 0) { -#endif - return -1; - } + unsigned int i2c_clk = (adap_no == 1) ? gd->i2c2_clk : gd->i2c1_clk;
- i2c_bus_num = bus; + writeb(0, &i2c_dev[adap_no]->cr); /* stop controller */ + fsl_i2c_adap[adap_no].speed = + set_i2c_bus_speed(i2c_dev[adap_no], i2c_clk, speed); + writeb(I2C_CR_MEN, &i2c_dev[adap_no]->cr); /* start controller */
return 0; }
-int i2c_set_bus_speed(unsigned int speed) + +/* Wrappers for the first controller */ +static void fsl_i2c1_init(int speed, int slaveadd) +{ + __i2c_init(0, speed, slaveadd); +} + +static int fsl_i2c1_read(u8 dev, uint addr, int alen, u8 *data, int length) { - unsigned int i2c_clk = (i2c_bus_num == 1) ? gd->i2c2_clk : gd->i2c1_clk; + return(__i2c_read(0, dev, addr, alen, data, length)); +}
- writeb(0, &i2c_dev[i2c_bus_num]->cr); /* stop controller */ - i2c_bus_speed[i2c_bus_num] = - set_i2c_bus_speed(i2c_dev[i2c_bus_num], i2c_clk, speed); - writeb(I2C_CR_MEN, &i2c_dev[i2c_bus_num]->cr); /* start controller */ +static int fsl_i2c1_write(u8 dev, uint addr, int alen, u8 *data, int length) +{ + return(__i2c_write(0, dev, addr, alen, data, length)); +}
- return 0; +static int fsl_i2c1_probe(uchar chip) +{ + return(__i2c_probe(0, chip)); +} + +static unsigned int fsl_i2c1_set_bus_speed(unsigned int speed) +{ + return(__i2c_set_bus_speed(0, speed)); }
-unsigned int i2c_get_bus_num(void) +static unsigned int fsl_i2c1_get_bus_speed(void) +{ + return(fsl_i2c_adap[0].speed); +} + + +/* Second controller */ +#ifdef CONFIG_SYS_FSL_I2C2_OFFSET +static void fsl_i2c2_init(int speed, int slaveadd) { - return i2c_bus_num; + __i2c_init(1, speed, slaveadd); }
-unsigned int i2c_get_bus_speed(void) +static int fsl_i2c2_read(u8 dev, uint addr, int alen, u8 *data, int length) { - return i2c_bus_speed[i2c_bus_num]; + return(__i2c_read(1, dev, addr, alen, data, length)); }
-#endif /* CONFIG_HARD_I2C */ +static int fsl_i2c2_write(u8 dev, uint addr, int alen, u8 *data, int length) +{ + return(__i2c_write(1, dev, addr, alen, data, length)); +} + +static int fsl_i2c2_probe(uchar chip) +{ + return(__i2c_probe(1, chip)); +} + +static unsigned int fsl_i2c2_set_bus_speed(unsigned int speed) +{ + return(__i2c_set_bus_speed(1, speed)); +} + +static unsigned int fsl_i2c2_get_bus_speed(void) +{ + return(fsl_i2c_adap[1].speed); +} +#endif + +i2c_adap_t fsl_i2c_adap[] = { + { + .init = fsl_i2c1_init, + .probe = fsl_i2c1_probe, + .read = fsl_i2c1_read, + .write = fsl_i2c1_write, + .set_bus_speed = fsl_i2c1_set_bus_speed, + .get_bus_speed = fsl_i2c1_get_bus_speed, + .speed = CONFIG_SYS_FSL_I2C_SPEED, + .slaveaddr = CONFIG_SYS_FSL_I2C_SLAVE, + .init_done = 0, + .name = FSL_NAME(CONFIG_SYS_FSL_I2C_OFFSET) + }, +#ifdef CONFIG_SYS_FSL_I2C2_OFFSET + { + .init = fsl_i2c2_init, + .probe = fsl_i2c2_probe, + .read = fsl_i2c2_read, + .write = fsl_i2c2_write, + .set_bus_speed = fsl_i2c2_set_bus_speed, + .get_bus_speed = fsl_i2c2_get_bus_speed, + .speed = CONFIG_SYS_FSL_I2C2_SPEED, + .slaveaddr = CONFIG_SYS_FSL_I2C2_SLAVE, + .init_done = 0, + .name = FSL_NAME(CONFIG_SYS_FSL_I2C2_OFFSET) + }, +#endif +}; diff -purN u-boot-i2c.orig/drivers/i2c/mxc_i2c.c u-boot-i2c/drivers/i2c/mxc_i2c.c --- u-boot-i2c.orig/drivers/i2c/mxc_i2c.c 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/drivers/i2c/mxc_i2c.c 2009-02-12 10:46:00.000000000 -0800 @@ -1,6 +1,10 @@ /* * i2c driver for Freescale mx31 * + * Copyright (c) 2009 Sergey Kubushyn ksi@koi8.net + * + * Changes for multibus/multiadapter I2C support. + * * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de * * See file CREDITS for list of people who contributed to this @@ -24,11 +28,11 @@
#include <common.h>
-#if defined(CONFIG_HARD_I2C) - #include <asm/arch/mx31.h> #include <asm/arch/mx31-regs.h>
+#include <i2c.h> + #define IADR 0x00 #define IFDR 0x04 #define I2CR 0x08 @@ -47,15 +51,8 @@ #define I2SR_IIF (1 << 1) #define I2SR_RX_NO_AK (1 << 0)
-#ifdef CONFIG_SYS_I2C_MX31_PORT1 -#define I2C_BASE 0x43f80000 -#elif defined (CONFIG_SYS_I2C_MX31_PORT2) -#define I2C_BASE 0x43f98000 -#elif defined (CONFIG_SYS_I2C_MX31_PORT3) -#define I2C_BASE 0x43f84000 -#else -#error "define CONFIG_SYS_I2C_MX31_PORTx to use the mx31 I2C driver" -#endif +#define MXC_NAME(arg) "mxc_i2c@" MK_NAME(arg) +#define MK_NAME(arg) #arg
#ifdef DEBUG #define DPRINTF(args...) printf(args) @@ -63,11 +60,15 @@ #define DPRINTF(args...) #endif
+i2c_adap_t mxc_i2c_adap[]; + static u16 div[] = { 30, 32, 36, 42, 48, 52, 60, 72, 80, 88, 104, 128, 144, 160, 192, 240, 288, 320, 384, 480, 576, 640, 768, 960, 1152, 1280, 1536, 1920, 2304, 2560, 3072, 3840};
-void i2c_init(int speed, int unused) +DECLARE_GLOBAL_DATA_PTR; + +static void _i2c_init(int speed, int unused, ulong base) { int freq = mx31_get_ipg_clk(); int i; @@ -78,125 +79,278 @@ void i2c_init(int speed, int unused)
DPRINTF("%s: speed: %d\n",__FUNCTION__, speed);
- __REG16(I2C_BASE + I2CR) = 0; /* Reset module */ - __REG16(I2C_BASE + IFDR) = i; - __REG16(I2C_BASE + I2CR) = I2CR_IEN; - __REG16(I2C_BASE + I2SR) = 0; + __REG16(base + I2CR) = 0; /* Reset module */ + __REG16(base + IFDR) = i; + __REG16(base + I2CR) = I2CR_IEN; + __REG16(base + I2SR) = 0; }
-static int wait_busy(void) +static int wait_busy(ulong base) { int timeout = 10000;
- while (!(__REG16(I2C_BASE + I2SR) & I2SR_IIF) && --timeout) + while (!(__REG16(base + I2SR) & I2SR_IIF) && --timeout) udelay(1); - __REG16(I2C_BASE + I2SR) = 0; /* clear interrupt */ + __REG16(base + I2SR) = 0; /* clear interrupt */
return timeout; }
-static int tx_byte(u8 byte) +static int tx_byte(u8 byte, ulong base) { - __REG16(I2C_BASE + I2DR) = byte; + __REG16(base + I2DR) = byte;
- if (!wait_busy() || __REG16(I2C_BASE + I2SR) & I2SR_RX_NO_AK) + if (!wait_busy(base) || __REG16(base + I2SR) & I2SR_RX_NO_AK) return -1; return 0; }
-static int rx_byte(void) +static int rx_byte(ulong base) { - if (!wait_busy()) + if (!wait_busy(base)) return -1;
- return __REG16(I2C_BASE + I2DR); + return __REG16(base + I2DR); }
-int i2c_probe(uchar chip) +static int _i2c_probe(uchar chip, ulong base) { int ret;
- __REG16(I2C_BASE + I2CR) = 0; /* Reset module */ - __REG16(I2C_BASE + I2CR) = I2CR_IEN; + __REG16(base + I2CR) = 0; /* Reset module */ + __REG16(base + I2CR) = I2CR_IEN;
- __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX; - ret = tx_byte(chip << 1); - __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MTX; + __REG16(base + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX; + ret = tx_byte(chip << 1, base); + __REG16(base + I2CR) = I2CR_IEN | I2CR_MTX;
return ret; }
-static int i2c_addr(uchar chip, uint addr, int alen) +static int i2c_addr(uchar chip, uint addr, int alen, ulong base) { - __REG16(I2C_BASE + I2SR) = 0; /* clear interrupt */ - __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX; + __REG16(base + I2SR) = 0; /* clear interrupt */ + __REG16(base + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX;
- if (tx_byte(chip << 1)) + if (tx_byte(chip << 1, base)) return -1;
while (alen--) - if (tx_byte((addr >> (alen * 8)) & 0xff)) + if (tx_byte((addr >> (alen * 8)) & 0xff, base)) return -1; return 0; }
-int i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len) +static int _i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len, ulong base) { int timeout = 10000; int ret;
DPRINTF("%s chip: 0x%02x addr: 0x%04x alen: %d len: %d\n",__FUNCTION__, chip, addr, alen, len);
- if (i2c_addr(chip, addr, alen)) { + if (i2c_addr(chip, addr, alen, base)) { printf("i2c_addr failed\n"); return -1; }
- __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX | I2CR_RSTA; + __REG16(base + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_MTX | I2CR_RSTA;
- if (tx_byte(chip << 1 | 1)) + if (tx_byte(chip << 1 | 1, base)) return -1;
- __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MSTA | ((len == 1) ? I2CR_TX_NO_AK : 0); + __REG16(base + I2CR) = I2CR_IEN | I2CR_MSTA | ((len == 1) ? I2CR_TX_NO_AK : 0);
- ret = __REG16(I2C_BASE + I2DR); + ret = __REG16(base + I2DR);
while (len--) { - if ((ret = rx_byte()) < 0) + if ((ret = rx_byte(base)) < 0) return -1; *buf++ = ret; if (len <= 1) - __REG16(I2C_BASE + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_TX_NO_AK; + __REG16(base + I2CR) = I2CR_IEN | I2CR_MSTA | I2CR_TX_NO_AK; }
- wait_busy(); + wait_busy(base);
- __REG16(I2C_BASE + I2CR) = I2CR_IEN; + __REG16(base + I2CR) = I2CR_IEN;
- while (__REG16(I2C_BASE + I2SR) & I2SR_IBB && --timeout) + while (__REG16(base + I2SR) & I2SR_IBB && --timeout) udelay(1);
return 0; }
-int i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) +static int _i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len, ulong base) { int timeout = 10000; DPRINTF("%s chip: 0x%02x addr: 0x%04x alen: %d len: %d\n",__FUNCTION__, chip, addr, alen, len);
- if (i2c_addr(chip, addr, alen)) + if (i2c_addr(chip, addr, alen, base)) return -1;
while (len--) - if (tx_byte(*buf++)) + if (tx_byte(*buf++, base)) return -1;
return 0; }
-#endif /* CONFIG_HARD_I2C */ +static void mxc_i2c_init(int speed, int slaveaddr) +{ + _i2c_init(speed, slaveaddr, CONFIG_SYS_MXC_I2C_BASE); + + if (gd->flags & GD_FLG_RELOC) { + mxc_i2c_adap[0].init_done = 1; + mxc_i2c_adap[0].speed = speed; + mxc_i2c_adap[0].slaveaddr = slaveaddr; + } +} + +static int mxc_i2c_read(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_read(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C_BASE)); +} + +static int mxc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_write(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C_BASE)); +} + +static int mxc_i2c_probe(uchar chip) +{ + return(_i2c_probe(chip, CONFIG_SYS_MXC_I2C_BASE)); +} + +static unsigned int mxc_i2c_set_bus_speed(unsigned int speed) +{ + return(mxc_i2c_adap[0].speed); +} + +static unsigned int mxc_i2c_get_bus_speed(void) +{ + return(mxc_i2c_adap[0].speed); +} + +#ifdef CONFIG_SYS_MXC_I2C2_BASE +static void mxc_i2c2_init(int speed, int slaveaddr) +{ + _i2c_init(speed, slaveaddr, CONFIG_SYS_MXC_I2C2_BASE); + + if (gd->flags & GD_FLG_RELOC) { + mxc_i2c_adap[1].init_done = 1; + mxc_i2c_adap[1].speed = speed; + mxc_i2c_adap[1].slaveaddr = slaveaddr; + } +} + +static int mxc_i2c2_read(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_read(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C2_BASE)); +} + +static int mxc_i2c2_write(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_write(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C2_BASE)); +} + +static int mxc_i2c2_probe(uchar chip) +{ + return(_i2c_probe(chip, CONFIG_SYS_MXC_I2C2_BASE)); +} + +static unsigned int mxc_i2c2_set_bus_speed(unsigned int speed) +{ + return(mxc_i2c_adap[1].speed); +} + +static unsigned int mxc_i2c2_get_bus_speed(void) +{ + return(mxc_i2c_adap[1].speed); +} +#endif + +#ifdef CONFIG_SYS_MXC_I2C3_BASE +static void mxc_i2c3_init(int speed, int slaveaddr) +{ + _i2c_init(speed, slaveaddr, CONFIG_SYS_MXC_I2C3_BASE); + + if (gd->flags & GD_FLG_RELOC) { + mxc_i2c_adap[2].init_done = 1; + mxc_i2c_adap[2].speed = speed; + mxc_i2c_adap[2].slaveaddr = slaveaddr; + } +} + +static int mxc_i2c3_read(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_read(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C3_BASE)); +} + +static int mxc_i2c3_write(uchar chip, uint addr, int alen, uchar *buf, int len) +{ + return(_i2c_write(chip, addr, alen, buf, len, CONFIG_SYS_MXC_I2C3_BASE)); +} + +static int mxc_i2c_probe(uchar chip) +{ + return(_i2c_probe(chip, CONFIG_SYS_MXC_I2C3_BASE)); +} + +static unsigned int mxc_i2c3_set_bus_speed(unsigned int speed) +{ + return(mxc_i2c_adap[2].speed); +} + +static unsigned int mxc_i2c3_get_bus_speed(void) +{ + return(mxc_i2c_adap[2].speed); +} +#endif + +i2c_adap_t mxc_i2c_adap[] = { + { + .init = mxc_i2c_init, + .probe = mxc_i2c_probe, + .read = mxc_i2c_read, + .write = mxc_i2c_write, + .set_bus_speed = mxc_i2c_set_bus_speed, + .get_bus_speed = mxc_i2c_get_bus_speed, + .speed = CONFIG_SYS_MXC_I2C_SPEED, + .slaveaddr = CONFIG_SYS_MXC_I2C_SLAVE, + .init_done = 0, + .name = MXC_NAME(CONFIG_SYS_MXC_I2C_BASE) + }, +#ifdef CONFIG_SYS_MXC_I2C2_BASE + { + .init = mxc_i2c2_init, + .probe = mxc_i2c2_probe, + .read = mxc_i2c2_read, + .write = mxc_i2c2_write, + .set_bus_speed = mxc_i2c2_set_bus_speed, + .get_bus_speed = mxc_i2c2_get_bus_speed, + .speed = CONFIG_SYS_MXC_I2C2_SPEED, + .slaveaddr = CONFIG_SYS_MXC_I2C2_SLAVE, + .init_done = 0, + .name = MXC_NAME(CONFIG_SYS_MXC_I2C2_BASE) + }, +#endif +#ifdef CONFIG_SYS_MXC_I2C3_BASE + { + .init = mxc_i2c3_init, + .probe = mxc_i2c3_probe, + .read = mxc_i2c3_read, + .write = mxc_i2c3_write, + .set_bus_speed = mxc_i2c3_set_bus_speed, + .get_bus_speed = mxc_i2c3_get_bus_speed, + .speed = CONFIG_SYS_MXC_I2C3_SPEED, + .slaveaddr = CONFIG_SYS_MXC_I2C3_SLAVE, + .init_done = 0, + .name = MXC_NAME(CONFIG_SYS_MXC_I2C3_BASE) + }, +#endif +};
ksi@koi8.net
