[U-Boot] [PATCH] ARM926: Add mb to the cache invalidate/flush
Add memory barrier to cache invalidate and flush calls. This prevents compiler from reordering the code around these, possibly generating invalid results.
Signed-off-by: Marek Vasut marex@denx.de CC: Albert Aribaud albert.u.boot@aribaud.net Cc: Fabio Estevam festevam@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/cache.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 2740ad7..c4102f6 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -67,7 +67,8 @@ void invalidate_dcache_range(unsigned long start, unsigned long stop) return;
while (start < stop) { - asm volatile("mcr p15, 0, %0, c7, c6, 1\n" : : "r"(start)); + asm volatile("mcr p15, 0, %0, c7, c6, 1\n" + : : "r"(start) : "memory"); start += CONFIG_SYS_CACHELINE_SIZE; } } @@ -78,11 +79,12 @@ void flush_dcache_range(unsigned long start, unsigned long stop) return;
while (start < stop) { - asm volatile("mcr p15, 0, %0, c7, c14, 1\n" : : "r"(start)); + asm volatile("mcr p15, 0, %0, c7, c14, 1\n" + : : "r"(start) : "memory"); start += CONFIG_SYS_CACHELINE_SIZE; }
- asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0)); + asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0) : "memory"); }
void flush_cache(unsigned long start, unsigned long size)
