[U-Boot] [PATCH 2/4] NAND: Add support for MPC8572DS board
This patch defines 1M TLB&LAW size for NAND on MPC8572DS, assigns 0xffa00000 for CONFIG_SYS_NAND_BASE and adds other NAND supports in config file.
It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image, to make room for the increased code size with NAND enabled.
Signed-off-by: Jason Jin Jason.Jin@freescale.com Signed-off-by: Haiying Wang Haiying.Wang@freescale.com Signed-off-by: Scott Wood scottwood@freescale.com --- board/freescale/mpc8572ds/law.c | 1 + board/freescale/mpc8572ds/tlb.c | 6 ++++ include/configs/MPC8572DS.h | 56 ++++++++++++++++++++++++++++++++++++++- 3 files changed, 62 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mpc8572ds/law.c b/board/freescale/mpc8572ds/law.c index 9f11902..83eb681 100644 --- a/board/freescale/mpc8572ds/law.c +++ b/board/freescale/mpc8572ds/law.c @@ -36,6 +36,7 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_3), SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), SET_LAW(PIXIS_BASE, LAW_SIZE_4K, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/mpc8572ds/tlb.c b/board/freescale/mpc8572ds/tlb.c index 1c5ed3f..8d1f646 100644 --- a/board/freescale/mpc8572ds/tlb.c +++ b/board/freescale/mpc8572ds/tlb.c @@ -80,6 +80,12 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_PHYS, CONFIG_SYS_PCIE3_IO_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 6, BOOKE_PAGESZ_256K, 1), + + /* *I*G - NAND */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 7, BOOKE_PAGESZ_1M, 1), + };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index eefb06c..f98e7fb 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -158,6 +158,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Localbus non-cacheable * 0xe000_0000 0xe80f_ffff Promjet/free 128M non-cacheable * 0xe800_0000 0xefff_ffff FLASH 128M non-cacheable + * 0xffa0_0000 0xffaf_ffff NAND 1M non-cacheable * 0xffdf_0000 0xffdf_7fff PIXIS 32K non-cacheable TLB0 * 0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable @@ -260,6 +261,59 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
+#define CONFIG_SYS_NAND_BASE 0xffa00000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE,\ + CONFIG_SYS_NAND_BASE + 0x40000, \ + CONFIG_SYS_NAND_BASE + 0x80000,\ + CONFIG_SYS_NAND_BASE + 0xC0000} +#define CONFIG_SYS_MAX_NAND_DEVICE 4 +#define NAND_MAX_CHIPS 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND 1 +#define CONFIG_NAND_FSL_ELBC 1 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* NAND flash config */ +#define CONFIG_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE_PHYS \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_NAND_OR_PRELIM (0xFFFC0000 /* length 256K */ \ + | OR_FCM_PGS /* Large Page*/ \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) + +#define CONFIG_SYS_BR2_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ +#define CONFIG_SYS_OR2_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ + +#define CONFIG_SYS_BR4_PRELIM ((CONFIG_SYS_NAND_BASE_PHYS + 0x40000)\ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR4_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_NAND_BASE_PHYS + 0x80000)\ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR5_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ + +#define CONFIG_SYS_BR6_PRELIM ((CONFIG_SYS_NAND_BASE_PHYS + 0xC0000)\ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR6_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ + + + /* Serial Port - controlled on board with jumper J8 * open - index 2 * shorted - index 1 @@ -455,7 +509,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 #define CONFIG_ENV_ADDR 0xfff80000 #else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x70000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) #endif #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */
Scott Wood
