[U-Boot] [PATCH 1/2] driver/fsl_pci: Added fsl_pci_init_port function to initialize a single PCIe port.
* Added a generic function fsl_pci_init_port in drivers/pci/fsl_pci.c to initialize a PCIe port. * fsl_pci_init_port can be called from board specific pcie initialization routine, per-port. * This will reduce the code redundancy in the most of the Freescale board specific PCIe inits. * All the FSL 85xx boards can use it for PCIe initialization.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- - applies on git.denx.de/u-boot-mpc85xx.git branch->next - next patch following it makes use of this patch for PCIe initialization on P1&P2 RDB drivers/pci/fsl_pci_init.c | 41 +++++++++++++++++++++++++++++++++++++++++ include/asm-ppc/fsl_pci.h | 26 ++++++++++++++++++++++++++ 2 files changed, 67 insertions(+), 0 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index ee89aaa..9e9e1b7 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -412,6 +412,47 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) } }
+int fsl_pci_init_port(struct fsl_pci_info *pci_info, + struct pci_controller *hose, int busno) +{ + volatile ccsr_fsl_pci_t *pci; + struct pci_region *r; + + pci = (ccsr_fsl_pci_t *) pci_info->regs; + + if (in_be32(&pci->pme_msg_det)) { + out_be32(&pci->pme_msg_det, 0xffffffff); + debug (" with errors. Clearing. Now 0x%08x", + pci->pme_msg_det); + } + + r = hose->regions + hose->region_count; + + /* outbound memory */ + pci_set_region(r++, + pci_info->mem_bus, + pci_info->mem_phys, + pci_info->mem_size, + PCI_REGION_MEM); + + /* outbound io */ + pci_set_region(r++, + pci_info->io_bus, + pci_info->io_phys, + pci_info->io_size, + PCI_REGION_IO); + + hose->region_count = r - hose->regions; + hose->first_busno = busno; + + fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); + + printf("\n PCIE%x on bus %02x - %02x\n", pci_info->pci_num, + hose->first_busno, hose->last_busno); + + return(hose->last_busno + 1); +} + /* Enable inbound PCI config cycles for agent/endpoint interface */ void fsl_pci_config_unlock(struct pci_controller *hose) { diff --git a/include/asm-ppc/fsl_pci.h b/include/asm-ppc/fsl_pci.h index b2ff0e9..2b6421a 100644 --- a/include/asm-ppc/fsl_pci.h +++ b/include/asm-ppc/fsl_pci.h @@ -154,4 +154,30 @@ typedef struct ccsr_pci { char res24[252]; } ccsr_fsl_pci_t;
+struct fsl_pci_info { + phys_size_t regs; + pci_addr_t mem_bus; + phys_size_t mem_phys; + pci_size_t mem_size; + pci_addr_t io_bus; + phys_size_t io_phys; + pci_size_t io_size; + int pci_num; +}; + +int fsl_pci_init_port(struct fsl_pci_info *pci_info, + struct pci_controller *hose, int busno); + +#define SET_STD_PCIE_INFO(x, num) \ +{ \ + x.regs = CONFIG_SYS_PCIE##num##_ADDR; \ + x.mem_bus = CONFIG_SYS_PCIE##num##_MEM_BUS; \ + x.mem_phys = CONFIG_SYS_PCIE##num##_MEM_PHYS; \ + x.mem_size = CONFIG_SYS_PCIE##num##_MEM_SIZE; \ + x.io_bus = CONFIG_SYS_PCIE##num##_IO_BUS; \ + x.io_phys = CONFIG_SYS_PCIE##num##_IO_PHYS; \ + x.io_size = CONFIG_SYS_PCIE##num##_IO_SIZE; \ + x.pci_num = num; \ +} + #endif
On Aug 20, 2009, at 8:59 PM, Poonam Aggrwal wrote:
- Added a generic function fsl_pci_init_port in drivers/pci/fsl_pci.c to initialize a PCIe port.
- fsl_pci_init_port can be called from board specific pcie
- This will reduce the code redundancy in the most of the Freescale
- All the FSL 85xx boards can use it for PCIe initialization.
initialization on P1&P2 RDB drivers/pci/fsl_pci_init.c | 41 +++++++++++++++++++++++++++++++++++ ++++++ include/asm-ppc/fsl_pci.h | 26 ++++++++++++++++++++++++++ 2 files changed, 67 insertions(+), 0 deletions(-)
applied to 85xx next
- k
Kumar Gala
Poonam Aggrwal
