[U-Boot] [PATCH] FDT: don't use private kernel header files
On some systems (for example Fedora Core 4) U-Boot builds with the following wanrings only:
... In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead!
This patch fixes this problem.
Signed-off-by: Wolfgang Denk wd@denx.de --- include/image.h | 20 +++++++++++--------- include/libfdt_env.h | 19 ++++++++++++++----- 2 files changed, 25 insertions(+), 14 deletions(-)
diff --git a/include/image.h b/include/image.h index 82e6345..1598b61 100644 --- a/include/image.h +++ b/include/image.h @@ -33,27 +33,29 @@ #ifndef __IMAGE_H__ #define __IMAGE_H__
-#include <asm/byteorder.h> -#include <command.h> - -#ifndef USE_HOSTCC -#include <lmb.h> -#include <linux/string.h> -#include <asm/u-boot.h> - -#else +#if USE_HOSTCC +#include <endian.h>
/* new uImage format support enabled on host */ #define CONFIG_FIT 1 #define CONFIG_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
+#else + +#include <lmb.h> +#include <linux/string.h> +#include <asm/u-boot.h> +#include <asm/byteorder.h> + #endif /* USE_HOSTCC */
#if defined(CONFIG_FIT) && !defined(CONFIG_OF_LIBFDT) #error "CONFIG_OF_LIBFDT not enabled, required by CONFIG_FIT!" #endif
+#include <command.h> + #if defined(CONFIG_FIT) #include <fdt.h> #include <libfdt.h> diff --git a/include/libfdt_env.h b/include/libfdt_env.h index 671c3a8..355ebf2 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -24,19 +24,28 @@ #ifdef USE_HOSTCC #include <stdint.h> #include <string.h> +#include <endian.h> +#include <byteswap.h> #else #include <linux/string.h> #include <linux/types.h> +#include <asm/byteorder.h> #endif /* USE_HOSTCC */
#include <stddef.h> -#include <asm/byteorder.h> extern struct fdt_header *working_fdt; /* Pointer to the working fdt */
-#define fdt32_to_cpu(x) __be32_to_cpu(x) -#define cpu_to_fdt32(x) __cpu_to_be32(x) -#define fdt64_to_cpu(x) __be64_to_cpu(x) -#define cpu_to_fdt64(x) __cpu_to_be64(x) +#if __BYTE_ORDER == __LITTLE_ENDIAN +#define fdt32_to_cpu(x) bswap_32(x) +#define cpu_to_fdt32(x) bswap_32(x) +#define fdt64_to_cpu(x) bswap_64(x) +#define cpu_to_fdt64(x) bswap_64(x) +#else +#define fdt32_to_cpu(x) (x) +#define cpu_to_fdt32(x) (x) +#define fdt64_to_cpu(x) (x) +#define cpu_to_fdt64(x) (x) +#endif
/* * Types for `void *' pointers.
Dear Wolfgang Denk,
Applied.
