[U-Boot-Users] [PATCH 6/8] [SH] SuperH support
6 May
2007
6 May
'07
10:14 p.m.
Hi, all.
I wrote the code in which u-boot was supported for SH [0]. I am maintaining SH-IPL+g[1] that is the boot loader only for SH now. However, I think that I will maintain u-boot in the future.
Now, 0. SDRAM controler 1. Internal serial device 2. Flash 3. Timer working.
I plan to adopt it as a boot loader of the main in the future though only several boards are supported now.
Please apply this patch .
regards, Nobuhiro
[0] : http://america.renesas.com/fmwk.jsp?cnt=superh_family_landing.jsp&fp=/pr... [1] : http://git.nigauri.org
Nobuhiro Iwamatsu
E-Mail : iwamatsu@nigauri.org
GPG ID : 3170EBE9
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
diff --git a/include/asm-sh/io.h b/include/asm-sh/io.h
new file mode 100644
index 0000000..70e60b1
--- /dev/null
+++ b/include/asm-sh/io.h
@@ -0,0 +1,292 @@
+ * linux/include/asm-sh/io.h
+ * Copyright (C) 1996-2000 Russell King
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+ * Modifications:
+ * 16-Sep-1996 RMK Inlined the inx/outx functions & optimised for both
+ * constant addresses and variable addresses.
+ * 04-Dec-1997 RMK Moved a lot of this stuff to the new architecture
+ * specific IO header files.
+ * 27-Mar-1999 PJB Second parameter of memcpy_toio is const..
+ * 04-Apr-1999 PJB Added check_signature.
+ * 12-Dec-1999 RMK More cleanups
+ * 18-Jun-2000 RMK Removed virt_to_* and friends definitions
+#ifndef __ASM_SH_IO_H
+#define __ASM_SH_IO_H
+#ifdef __KERNEL__
+#include <linux/types.h>
+#include <asm/byteorder.h>
+ * Generic virtual read/write. Note that we don't support half-word
+ * read/writes. We define __arch_*[bl] here, and leave __arch_*w
+ * to the architecture specific code.
+#define __arch_getb(a) (*(volatile unsigned char *)(a))
+#define __arch_getw(a) (*(volatile unsigned short *)(a))
+#define __arch_getl(a) (*(volatile unsigned int *)(a))
+#define __arch_putb(v,a) (*(volatile unsigned char *)(a) = (v))
+#define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v))
+#define __arch_putl(v,a) (*(volatile unsigned int *)(a) = (v))
+extern void __raw_writesb(unsigned int addr, const void *data, int bytelen);
+extern void __raw_writesw(unsigned int addr, const void *data, int wordlen);
+extern void __raw_writesl(unsigned int addr, const void *data, int longlen);
+extern void __raw_readsb(unsigned int addr, void *data, int bytelen);
+extern void __raw_readsw(unsigned int addr, void *data, int wordlen);
+extern void __raw_readsl(unsigned int addr, void *data, int longlen);
+#define __raw_writeb(v,a) __arch_putb(v,a)
+#define __raw_writew(v,a) __arch_putw(v,a)
+#define __raw_writel(v,a) __arch_putl(v,a)
+#define __raw_readb(a) __arch_getb(a)
+#define __raw_readw(a) __arch_getw(a)
+#define __raw_readl(a) __arch_getl(a)
+ * The compiler seems to be incapable of optimising constants
+ * properly. Spell it out to the compiler in some cases.
+ * These are only valid for small values of "off" (< 1<<12)
+#define __raw_base_writeb(val,base,off) __arch_base_putb(val,base,off)
+#define __raw_base_writew(val,base,off) __arch_base_putw(val,base,off)
+#define __raw_base_writel(val,base,off) __arch_base_putl(val,base,off)
+#define __raw_base_readb(base,off) __arch_base_getb(base,off)
+#define __raw_base_readw(base,off) __arch_base_getw(base,off)
+#define __raw_base_readl(base,off) __arch_base_getl(base,off)
+ * Now, pick up the machine-defined IO definitions
+#if 0 /* XXX###XXX */
+#include <asm/arch/io.h>
+#endif /* XXX###XXX */
+ * IO port access primitives
+ * The SH doesn't have special IO access instructions; all IO is memory
+ * mapped. Note that these are defined to perform little endian accesses
+ * only. Their primary purpose is to access PCI and ISA peripherals.
+ * The machine specific io.h include defines __io to translate an "IO"
+ * address to a memory address.
+ * Note that we prevent GCC re-ordering or caching values in expressions
+ * by introducing sequence points into the in*() definitions. Note that
+ * __raw_* do not guarantee this behaviour.
+ * The {in,out}[bwl] macros are for emulating x86-style PCI/ISA IO space.
+#ifdef __io
+#define outb(v,p) __raw_writeb(v,__io(p))
+#define outw(v,p) __raw_writew(cpu_to_le16(v),__io(p))
+#define outl(v,p) __raw_writel(cpu_to_le32(v),__io(p))
+#define inb(p) ({ unsigned int __v = __raw_readb(__io(p)); __v; })
+#define inw(p) ({ unsigned int __v = le16_to_cpu(__raw_readw(__io(p))); __v; })
+#define inl(p) ({ unsigned int __v = le32_to_cpu(__raw_readl(__io(p))); __v; })
+#define outsb(p,d,l) __raw_writesb(__io(p),d,l)
+#define outsw(p,d,l) __raw_writesw(__io(p),d,l)
+#define outsl(p,d,l) __raw_writesl(__io(p),d,l)
+#define insb(p,d,l) __raw_readsb(__io(p),d,l)
+#define insw(p,d,l) __raw_readsw(__io(p),d,l)
+#define insl(p,d,l) __raw_readsl(__io(p),d,l)
+#define outb_p(val,port) outb((val),(port))
+#define outw_p(val,port) outw((val),(port))
+#define outl_p(val,port) outl((val),(port))
+#define inb_p(port) inb((port))
+#define inw_p(port) inw((port))
+#define inl_p(port) inl((port))
+#define outsb_p(port,from,len) outsb(port,from,len)
+#define outsw_p(port,from,len) outsw(port,from,len)
+#define outsl_p(port,from,len) outsl(port,from,len)
+#define insb_p(port,to,len) insb(port,to,len)
+#define insw_p(port,to,len) insw(port,to,len)
+#define insl_p(port,to,len) insl(port,to,len)
+ * ioremap and friends.
+ * ioremap takes a PCI memory address, as specified in
+ * linux/Documentation/IO-mapping.txt. If you want a
+ * physical address, use __ioremap instead.
+extern void * __ioremap(unsigned long offset, size_t size, unsigned long flags);
+extern void __iounmap(void *addr);
+ * Generic ioremap support.
+ * Define:
+ * iomem_valid_addr(off,size)
+ * iomem_to_phys(off)
+#ifdef iomem_valid_addr
+#define __arch_ioremap(off,sz,nocache) \
+ unsigned long _off = (off), _size = (sz); \
+ void *_ret = (void *)0; \
+ if (iomem_valid_addr(_off, _size)) \
+ _ret = __ioremap(iomem_to_phys(_off),_size,0); \
+ _ret; \
+#define __arch_iounmap __iounmap
+#define ioremap(off,sz) __arch_ioremap((off),(sz),0)
+#define ioremap_nocache(off,sz) __arch_ioremap((off),(sz),1)
+#define iounmap(_addr) __arch_iounmap(_addr)
+ * DMA-consistent mapping functions. These allocate/free a region of
+ * uncached, unwrite-buffered mapped memory space for use with DMA
+ * devices. This is the "generic" version. The PCI specific version
+ * is in pci.h
+extern void *consistent_alloc(int gfp, size_t size, dma_addr_t *handle);
+extern void consistent_free(void *vaddr, size_t size, dma_addr_t handle);
+extern void consistent_sync(void *vaddr, size_t size, int rw);
+ * String version of IO memory access ops:
+extern void _memcpy_fromio(void *, unsigned long, size_t);
+extern void _memcpy_toio(unsigned long, const void *, size_t);
+extern void _memset_io(unsigned long, int, size_t);
+extern void __readwrite_bug(const char *fn);
+ * If this architecture has PCI memory IO, then define the read/write
+ * macros. These should only be used with the cookie passed from
+ * ioremap.
+#ifdef __mem_pci
+#define readb(c) ({ unsigned int __v = __raw_readb(__mem_pci(c)); __v; })
+#define readw(c) ({ unsigned int __v = le16_to_cpu(__raw_readw(__mem_pci(c))); __v; })
+#define readl(c) ({ unsigned int __v = le32_to_cpu(__raw_readl(__mem_pci(c))); __v; })
+#define writeb(v,c) __raw_writeb(v,__mem_pci(c))
+#define writew(v,c) __raw_writew(cpu_to_le16(v),__mem_pci(c))
+#define writel(v,c) __raw_writel(cpu_to_le32(v),__mem_pci(c))
+#define memset_io(c,v,l) _memset_io(__mem_pci(c),(v),(l))
+#define memcpy_fromio(a,c,l) _memcpy_fromio((a),__mem_pci(c),(l))
+#define memcpy_toio(c,a,l) _memcpy_toio(__mem_pci(c),(a),(l))
+#define eth_io_copy_and_sum(s,c,l,b) \
+ eth_copy_and_sum((s),__mem_pci(c),(l),(b))
+static inline int
+check_signature(unsigned long io_addr, const unsigned char *signature,
+ int length)
+ int retval = 0;
+ do {
+ if (readb(io_addr) != *signature)
+ goto out;
+ io_addr++;
+ signature++;
+ length--;
+ } while (length);
+ retval = 1;
+out:
+ return retval;
+#elif !defined(readb)
+#define readb(addr) (__readwrite_bug("readb"),0)
+#define readw(addr) (__readwrite_bug("readw"),0)
+#define readl(addr) (__readwrite_bug("readl"),0)
+#define writeb(v,addr) __readwrite_bug("writeb")
+#define writew(v,addr) __readwrite_bug("writew")
+#define writel(v,addr) __readwrite_bug("writel")
+#define eth_io_copy_and_sum(a,b,c,d) __readwrite_bug("eth_io_copy_and_sum")
+#define check_signature(io,sig,len) (0)
+#endif /* __mem_pci */
+ * If this architecture has ISA IO, then define the isa_read/isa_write
+ * macros.
+#ifdef __mem_isa
+#define isa_readb(addr) __raw_readb(__mem_isa(addr))
+#define isa_readw(addr) __raw_readw(__mem_isa(addr))
+#define isa_readl(addr) __raw_readl(__mem_isa(addr))
+#define isa_writeb(val,addr) __raw_writeb(val,__mem_isa(addr))
+#define isa_writew(val,addr) __raw_writew(val,__mem_isa(addr))
+#define isa_writel(val,addr) __raw_writel(val,__mem_isa(addr))
+#define isa_memset_io(a,b,c) _memset_io(__mem_isa(a),(b),(c))
+#define isa_memcpy_fromio(a,b,c) _memcpy_fromio((a),__mem_isa(b),(c))
+#define isa_memcpy_toio(a,b,c) _memcpy_toio(__mem_isa((a)),(b),(c))
+#define isa_eth_io_copy_and_sum(a,b,c,d) \
+ eth_copy_and_sum((a),__mem_isa(b),(c),(d))
+static inline int
+isa_check_signature(unsigned long io_addr, const unsigned char *signature,
+ int length)
+ int retval = 0;
+ do {
+ if (isa_readb(io_addr) != *signature)
+ goto out;
+ io_addr++;
+ signature++;
+ length--;
+ } while (length);
+ retval = 1;
+out:
+ return retval;
+#else /* __mem_isa */
+#define isa_readb(addr) (__readwrite_bug("isa_readb"),0)
+#define isa_readw(addr) (__readwrite_bug("isa_readw"),0)
+#define isa_readl(addr) (__readwrite_bug("isa_readl"),0)
+#define isa_writeb(val,addr) __readwrite_bug("isa_writeb")
+#define isa_writew(val,addr) __readwrite_bug("isa_writew")
+#define isa_writel(val,addr) __readwrite_bug("isa_writel")
+#define isa_memset_io(a,b,c) __readwrite_bug("isa_memset_io")
+#define isa_memcpy_fromio(a,b,c) __readwrite_bug("isa_memcpy_fromio")
+#define isa_memcpy_toio(a,b,c) __readwrite_bug("isa_memcpy_toio")
+ __readwrite_bug("isa_eth_io_copy_and_sum")
+#define isa_check_signature(io,sig,len) (0)
+static inline void sync(void)
+#endif /* __mem_isa */
+#endif /* __KERNEL__ */
+#endif /* __ASM_SH_IO_H */
6575
Nobuhiro Iwamatsu
