[U-Boot] [PATCH v2] powerpc/p1022ds: Add sdcard and spi boot support to P1022DS
Signed-off-by: Dirk Eibach eibach@gdsys.de Cc: Timur Tabi timur@freescale.com --- Changes in v2: - add Cc - split up original patch series
board/freescale/p1022ds/p1022ds.c | 4 ++ board/freescale/p1022ds/tlb.c | 10 ++++++ boards.cfg | 4 ++ include/configs/P1022DS.h | 63 ++++++++++++++++++++++++++++++++++--- 4 files changed, 76 insertions(+), 5 deletions(-)
diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 456d9b0..c4bdbad 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -37,6 +37,10 @@ int board_early_init_f(void) { ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
+ /* Reset eLBC_DIU and SPI_eLBC in case we are booting from SD */ + clrbits_be32(&gur->pmuxcr, 0x00600000); + setbits_be32(&gur->pmuxcr, 0x80000000); + /* Set pmuxcr to allow both i2c1 and i2c2 */ setbits_be32(&gur->pmuxcr, 0x1000);
diff --git a/board/freescale/p1022ds/tlb.c b/board/freescale/p1022ds/tlb.c index e620112..1e9969f 100644 --- a/board/freescale/p1022ds/tlb.c +++ b/board/freescale/p1022ds/tlb.c @@ -71,6 +71,16 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, PIXIS_BASE, PIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 7, BOOKE_PAGESZ_4K, 1), + +#if defined(CONFIG_SYS_RAMBOOT) + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 8, BOOKE_PAGESZ_1G, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_1G, 1) +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 24c5879..8de4235 100644 --- a/boards.cfg +++ b/boards.cfg @@ -700,6 +700,10 @@ P1021RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freesca P1021RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SPIFLASH P1022DS powerpc mpc85xx p1022ds freescale P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT +P1022DS_36BIT_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SDCARD +P1022DS_36BIT_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SPIFLASH +P1022DS_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:SDCARD +P1022DS_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:SPIFLASH P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND P1024RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 70d751d..73a56a6 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -26,6 +26,18 @@ #define CONFIG_P1022DS #define CONFIG_MP /* support multiple processors */
+#ifdef CONFIG_SDCARD +#define CONFIG_RAMBOOT_SDCARD 1 +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + +#ifdef CONFIG_SPIFLASH +#define CONFIG_RAMBOOT_SPIFLASH 1 +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + #ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xeff80000 #endif @@ -52,8 +64,14 @@
#define CONFIG_FSL_LAW /* Use common FSL init code */
+#if 0 +#define CONFIG_SYS_CLK_FREQ 99999000 /* get_board_sys_clk() */ +#define CONFIG_DDR_CLK_FREQ 99999000 /* get_board_ddr_clk() */ +#else #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() +#endif + #define CONFIG_ICS307_REFCLK_HZ 33333000 /* ICS307 clock chip ref freq */
/* @@ -138,6 +156,14 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
+#if defined(CONFIG_RAMBOOT_NAND) || defined(CONFIG_RAMBOOT_SDCARD) || \ + defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#else +#undef CONFIG_SYS_RAMBOOT +#endif + #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO @@ -403,11 +429,38 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_RAMBOOT_NAND) +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) +#elif defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_RAMBOOT_SDCARD) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_FSL_FIXED_MMC_LOCATION +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#else + #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) + #define CONFIG_ENV_SIZE 0x2000 +#endif +#else + #define CONFIG_ENV_IS_IN_FLASH + #define CONFIG_ENV_OVERWRITE + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_SECT_SIZE 0x20000 +#endif
#define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE
When CONFIG_ZERO_BOOTDELAY_CHECK is not defined, bootdelay==0 prevents the check for console input (as stated in README.autoboot). This must also work in CONFIG_AUTOBOOT_KEYED mode.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- Changes in v2: - split up original patch series
common/main.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/common/main.c b/common/main.c index 3b9e39a..b40f96e 100644 --- a/common/main.c +++ b/common/main.c @@ -113,6 +113,11 @@ int abortboot(int bootdelay) u_int presskey_max = 0; u_int i;
+#ifndef CONFIG_ZERO_BOOTDELAY_CHECK + if (bootdelay == 0) + return 0; +#endif + # ifdef CONFIG_AUTOBOOT_PROMPT printf(CONFIG_AUTOBOOT_PROMPT); # endif
Dear Dirk Eibach,
Changes in v2:
Applied, thanks.
But _please_ use a line length of <70 characters in the subject and the commit message. Thanks.
Changes in v2:
- add Cc
- /* Reset eLBC_DIU and SPI_eLBC in case we are booting from SD */
- clrbits_be32(&gur->pmuxcr, 0x00600000);
- setbits_be32(&gur->pmuxcr, 0x80000000);
Please use clrsetbits_be32().
- SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE,
- MAS3_SX|MAS3_SW|MAS3_SR, 0,
- 0, 8, BOOKE_PAGESZ_1G, 1),
- SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000,
- CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000,
- 0, 9, BOOKE_PAGESZ_1G, 1)
+#endif };
Why add these lines?
- defined(CONFIG_RAMBOOT_SPIFLASH)
Is the #undef really necessary?
Dirk Eibach
Tabi Timur-B04825
