[PATCH 0/9] Support for 4 GB DDR modules for 32-bit U-Boot builds
This patch series fixes U-Boot code to correctly handle RAM size larger than 2 GB and then fixes fsl ddr driver to do not crash U-Boot when 4 GB DDR module is detected when U-Boot operates in 32-bit mode (as opposite of the 36-bit mode).
With this patch series it is possible to boot 32-bit U-Boot with 4 GB SODIMM DDR3 module without crashes. U-Boot will still use just CONFIG_MAX_MEM_MAPPED amount of RAM, but it is better than crashing due to the truncating of 4GB value to 32-bit number (which is zero).
I tested this patch series on powerpc P2020 based board but only with U-Boot v2022.04 because U-Boot master branch is still broken on P2020.
Pali Rohár (9): common/memsize.c: Fix get_effective_memsize() to always check for CONFIG_MAX_MEM_MAPPED common/memsize.c: Fix get_effective_memsize() to check for overflow board_f: Fix types for board_get_usable_ram_top() board_f: Fix printing gd->ram_size and gd->ram_top ddr: fsl: Fix checking for maximal mappable memory ddr: fsl: Fix fsl_ddr_sdram_size() for 4GB modules with 32-bit phys_size_t ddr: fsl: Allow to detect 4 GB DDR modules in 32-bit mode ddr: fsl: Fix re-align of verbose DRAM information for non-SPL builds powerpc/mpc85xx: Explain TLB unmapped memory message
arch/arm/mach-imx/imx8m/soc.c | 2 +- arch/arm/mach-mvebu/arm64-common.c | 2 +- arch/arm/mach-rockchip/sdram.c | 2 +- arch/arm/mach-stm32mp/dram_init.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-tegra/board2.c | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 2 +- arch/mips/mach-octeon/dram.c | 2 +- arch/powerpc/cpu/mpc85xx/tlb.c | 2 +- arch/riscv/cpu/fu540/dram.c | 2 +- arch/riscv/cpu/fu740/dram.c | 2 +- arch/riscv/cpu/generic/dram.c | 2 +- arch/x86/cpu/broadwell/sdram.c | 2 +- arch/x86/cpu/coreboot/sdram.c | 2 +- arch/x86/cpu/efi/payload.c | 2 +- arch/x86/cpu/efi/sdram.c | 2 +- arch/x86/cpu/intel_common/mrc.c | 4 ++-- arch/x86/cpu/ivybridge/sdram.c | 2 +- arch/x86/cpu/qemu/dram.c | 2 +- arch/x86/cpu/quark/dram.c | 2 +- arch/x86/cpu/slimbootloader/sdram.c | 2 +- arch/x86/cpu/tangier/sdram.c | 2 +- arch/x86/include/asm/mrc_common.h | 2 +- arch/x86/include/asm/u-boot-x86.h | 2 +- arch/x86/lib/fsp1/fsp_dram.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- board/broadcom/bcmns3/ns3.c | 2 +- board/imgtec/boston/ddr.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 +- board/raspberrypi/rpi/rpi.c | 2 +- board/ti/am65x/evm.c | 2 +- board/ti/j721e/evm.c | 2 +- board/ti/j721s2/evm.c | 2 +- board/xilinx/zynqmp/zynqmp.c | 2 +- common/board_f.c | 6 ++--- common/memsize.c | 20 ++++++++++++---- drivers/ddr/fsl/lc_common_dimm_params.c | 3 +++ drivers/ddr/fsl/main.c | 31 ++++++++++++++++++++----- drivers/video/fsl_dcu_fb.c | 2 +- include/init.h | 2 +- 40 files changed, 84 insertions(+), 50 deletions(-)
CONFIG_MAX_MEM_MAPPED when defined specifies upper memory mapped limit. So check for it always, and not only when CONFIG_VERY_BIG_RAM is defined.
Signed-off-by: Pali Rohár pali@kernel.org --- common/memsize.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/memsize.c b/common/memsize.c index d5d13d51bf1f..31884acca0df 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -94,7 +94,7 @@ long get_ram_size(long *base, long maxsize)
phys_size_t __weak get_effective_memsize(void) { -#ifndef CONFIG_VERY_BIG_RAM +#ifndef CONFIG_MAX_MEM_MAPPED return gd->ram_size; #else /* limit stack to what we can reasonable map */
For the series, applied to u-boot/next, thanks!
Ensure that top of RAM can be represented by phys_size_t type. If RAM is too large or RAM base address is too upper then limit RAM size to prevent address space overflow.
Signed-off-by: Pali Rohár pali@kernel.org --- common/memsize.c | 18 +++++++++++++++--- 1 file changed, 15 insertions(+), 3 deletions(-)
diff --git a/common/memsize.c b/common/memsize.c index 31884acca0df..d11ed67632fb 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -94,11 +94,23 @@ long get_ram_size(long *base, long maxsize)
phys_size_t __weak get_effective_memsize(void) { + phys_size_t ram_size = gd->ram_size; + + /* + * Check for overflow and limit ram size to some representable value. + * It is required that ram_base + ram_size must be representable by + * phys_size_t type and must be aligned by direct access, therefore + * calculate it from last 4kB sector which should work as alignment + * on any platform. + */ + if (gd->ram_base + ram_size < gd->ram_base) + ram_size = ((phys_size_t)~0xfffULL) - gd->ram_base; + #ifndef CONFIG_MAX_MEM_MAPPED - return gd->ram_size; + return ram_size; #else /* limit stack to what we can reasonable map */ - return ((gd->ram_size > CONFIG_MAX_MEM_MAPPED) ? - CONFIG_MAX_MEM_MAPPED : gd->ram_size); + return ((ram_size > CONFIG_MAX_MEM_MAPPED) ? + CONFIG_MAX_MEM_MAPPED : ram_size); #endif }
Commit 37dc958947ed ("global_data.h: Change ram_top type to phys_addr_t") changed type of ram_top member from ulong to phys_addr_t but did not changed types in board_get_usable_ram_top() function which returns value for ram_top.
So change ulong to phys_addr_t type also in board_get_usable_ram_top() signature and implementations.
Fixes: 37dc958947ed ("global_data.h: Change ram_top type to phys_addr_t") Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-imx/imx8m/soc.c | 2 +- arch/arm/mach-mvebu/arm64-common.c | 2 +- arch/arm/mach-rockchip/sdram.c | 2 +- arch/arm/mach-stm32mp/dram_init.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-tegra/board2.c | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 2 +- arch/mips/mach-octeon/dram.c | 2 +- arch/riscv/cpu/fu540/dram.c | 2 +- arch/riscv/cpu/fu740/dram.c | 2 +- arch/riscv/cpu/generic/dram.c | 2 +- arch/x86/cpu/broadwell/sdram.c | 2 +- arch/x86/cpu/coreboot/sdram.c | 2 +- arch/x86/cpu/efi/payload.c | 2 +- arch/x86/cpu/efi/sdram.c | 2 +- arch/x86/cpu/intel_common/mrc.c | 4 ++-- arch/x86/cpu/ivybridge/sdram.c | 2 +- arch/x86/cpu/qemu/dram.c | 2 +- arch/x86/cpu/quark/dram.c | 2 +- arch/x86/cpu/slimbootloader/sdram.c | 2 +- arch/x86/cpu/tangier/sdram.c | 2 +- arch/x86/include/asm/mrc_common.h | 2 +- arch/x86/include/asm/u-boot-x86.h | 2 +- arch/x86/lib/fsp1/fsp_dram.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- board/broadcom/bcmns3/ns3.c | 2 +- board/imgtec/boston/ddr.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 +- board/raspberrypi/rpi/rpi.c | 2 +- board/ti/am65x/evm.c | 2 +- board/ti/j721e/evm.c | 2 +- board/ti/j721s2/evm.c | 2 +- board/xilinx/zynqmp/zynqmp.c | 2 +- common/board_f.c | 2 +- drivers/video/fsl_dcu_fb.c | 2 +- include/init.h | 2 +- 36 files changed, 37 insertions(+), 37 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 1a5a391443de..895b447ccc15 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -309,7 +309,7 @@ phys_size_t get_effective_memsize(void) #endif }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { ulong top_addr = PHYS_SDRAM + gd->ram_size;
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index 5357aa554db4..3dd94e7dde6b 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; */ #define USABLE_RAM_SIZE 0x80000000
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { if (gd->ram_size > USABLE_RAM_SIZE) return USABLE_RAM_SIZE; diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index 705ec7ba6450..12f1d7ee5637 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -205,7 +205,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { unsigned long top = CONFIG_SYS_SDRAM_BASE + SDRAM_MAX_SIZE;
diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 920b99bb68f2..9346fa8546d2 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -40,7 +40,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 9a7673d82dc1..5af037df4bd4 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -65,7 +65,7 @@ static struct mm_region sunxi_mem_map[] = { }; struct mm_region *mem_map = sunxi_mem_map;
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { /* Some devices (like the EMAC) have a 32-bit DMA limit. */ if (gd->ram_top > (1ULL << 32)) diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 8950e678a619..1994db0e15f5 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -401,7 +401,7 @@ int dram_init_banksize(void) * This function is called before dram_init_banksize(), so we can't simply * return gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { ulong ram_top;
diff --git a/arch/mips/mach-jz47xx/jz4780/jz4780.c b/arch/mips/mach-jz47xx/jz4780/jz4780.c index fefba12873b8..a57ec7802bbf 100644 --- a/arch/mips/mach-jz47xx/jz4780/jz4780.c +++ b/arch/mips/mach-jz47xx/jz4780/jz4780.c @@ -76,7 +76,7 @@ void board_init_f(ulong dummy) } #endif /* CONFIG_SPL_BUILD */
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return CONFIG_SYS_SDRAM_BASE + (256 * 1024 * 1024); } diff --git a/arch/mips/mach-octeon/dram.c b/arch/mips/mach-octeon/dram.c index 4679260f17ad..9c5789b1c8eb 100644 --- a/arch/mips/mach-octeon/dram.c +++ b/arch/mips/mach-octeon/dram.c @@ -77,7 +77,7 @@ phys_size_t get_effective_memsize(void) return UBOOT_RAM_SIZE_MAX; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { if (IS_ENABLED(CONFIG_RAM_OCTEON)) { /* Map a maximum of 256MiB - return not size but address */ diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c index 1fdc7837b864..44e11bd56c5d 100644 --- a/arch/riscv/cpu/fu540/dram.c +++ b/arch/riscv/cpu/fu540/dram.c @@ -21,7 +21,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { /* * Ensure that we run from first 4GB so that all diff --git a/arch/riscv/cpu/fu740/dram.c b/arch/riscv/cpu/fu740/dram.c index 1dc77efeca55..d6d4a41d25e3 100644 --- a/arch/riscv/cpu/fu740/dram.c +++ b/arch/riscv/cpu/fu740/dram.c @@ -20,7 +20,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_64BIT /* diff --git a/arch/riscv/cpu/generic/dram.c b/arch/riscv/cpu/generic/dram.c index 1fdc7837b864..44e11bd56c5d 100644 --- a/arch/riscv/cpu/generic/dram.c +++ b/arch/riscv/cpu/generic/dram.c @@ -21,7 +21,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { /* * Ensure that we run from first 4GB so that all diff --git a/arch/x86/cpu/broadwell/sdram.c b/arch/x86/cpu/broadwell/sdram.c index c104a849a545..1295121ae5b6 100644 --- a/arch/x86/cpu/broadwell/sdram.c +++ b/arch/x86/cpu/broadwell/sdram.c @@ -25,7 +25,7 @@ #include <asm/arch/pei_data.h> #include <asm/arch/pm.h>
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return mrc_common_board_get_usable_ram_top(total_size); } diff --git a/arch/x86/cpu/coreboot/sdram.c b/arch/x86/cpu/coreboot/sdram.c index 4a256bad4458..f4ee4cdf5d8c 100644 --- a/arch/x86/cpu/coreboot/sdram.c +++ b/arch/x86/cpu/coreboot/sdram.c @@ -27,7 +27,7 @@ unsigned int install_e820_map(unsigned int max_entries, * address, and how far U-Boot is moved by relocation are set in the global * data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { uintptr_t dest_addr = 0; int i; diff --git a/arch/x86/cpu/efi/payload.c b/arch/x86/cpu/efi/payload.c index b7778565b19e..1c28a43778ec 100644 --- a/arch/x86/cpu/efi/payload.c +++ b/arch/x86/cpu/efi/payload.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR; * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { struct efi_mem_desc *desc, *end; struct efi_entry_memmap *map; diff --git a/arch/x86/cpu/efi/sdram.c b/arch/x86/cpu/efi/sdram.c index af65982fd0c0..f3086db42c49 100644 --- a/arch/x86/cpu/efi/sdram.c +++ b/arch/x86/cpu/efi/sdram.c @@ -11,7 +11,7 @@
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return (ulong)efi_get_ram_base() + gd->ram_size; } diff --git a/arch/x86/cpu/intel_common/mrc.c b/arch/x86/cpu/intel_common/mrc.c index a97b0b7ceb41..a4918fbad61a 100644 --- a/arch/x86/cpu/intel_common/mrc.c +++ b/arch/x86/cpu/intel_common/mrc.c @@ -25,7 +25,7 @@ static const char *const ecc_decoder[] = { "active" };
-ulong mrc_common_board_get_usable_ram_top(ulong total_size) +phys_size_t mrc_common_board_get_usable_ram_top(phys_size_t total_size) { struct memory_info *info = &gd->arch.meminfo; uintptr_t dest_addr = 0; @@ -50,7 +50,7 @@ ulong mrc_common_board_get_usable_ram_top(ulong total_size)
dest_addr = largest->start + largest->size;
- return (ulong)dest_addr; + return (phys_size_t)dest_addr; }
void mrc_common_dram_init_banksize(void) diff --git a/arch/x86/cpu/ivybridge/sdram.c b/arch/x86/cpu/ivybridge/sdram.c index dd6b8753de68..1a0ec433e654 100644 --- a/arch/x86/cpu/ivybridge/sdram.c +++ b/arch/x86/cpu/ivybridge/sdram.c @@ -44,7 +44,7 @@ DECLARE_GLOBAL_DATA_PTR; #define CMOS_OFFSET_MRC_SEED_S3 156 #define CMOS_OFFSET_MRC_SEED_CHK 160
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return mrc_common_board_get_usable_ram_top(total_size); } diff --git a/arch/x86/cpu/qemu/dram.c b/arch/x86/cpu/qemu/dram.c index c1745501294c..595c397d4a4f 100644 --- a/arch/x86/cpu/qemu/dram.c +++ b/arch/x86/cpu/qemu/dram.c @@ -71,7 +71,7 @@ int dram_init_banksize(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return qemu_get_low_memory_size(); } diff --git a/arch/x86/cpu/quark/dram.c b/arch/x86/cpu/quark/dram.c index 2287dce12b52..8b1ee2d5ae57 100644 --- a/arch/x86/cpu/quark/dram.c +++ b/arch/x86/cpu/quark/dram.c @@ -184,7 +184,7 @@ int dram_init_banksize(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return gd->ram_size; } diff --git a/arch/x86/cpu/slimbootloader/sdram.c b/arch/x86/cpu/slimbootloader/sdram.c index c6f10e22e315..d748d5c7d469 100644 --- a/arch/x86/cpu/slimbootloader/sdram.c +++ b/arch/x86/cpu/slimbootloader/sdram.c @@ -48,7 +48,7 @@ static struct sbl_memory_map_info *get_memory_map_info(void) * @total_size: The memory size that u-boot occupies * Return: : The top available memory address lower than 4GB */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { struct sbl_memory_map_info *data; int i; diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c index afb08476ed3b..8a4b1c5d2d72 100644 --- a/arch/x86/cpu/tangier/sdram.c +++ b/arch/x86/cpu/tangier/sdram.c @@ -204,7 +204,7 @@ unsigned int install_e820_map(unsigned int max_entries, * address, and how far U-Boot is moved by relocation are set in the global * data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { struct sfi_table_simple *sb; struct sfi_mem_entry *mentry; diff --git a/arch/x86/include/asm/mrc_common.h b/arch/x86/include/asm/mrc_common.h index 3d7f00c9f92b..a7f260a7079a 100644 --- a/arch/x86/include/asm/mrc_common.h +++ b/arch/x86/include/asm/mrc_common.h @@ -47,7 +47,7 @@ int mrc_add_memory_area(struct memory_info *info, uint64_t start, * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -ulong mrc_common_board_get_usable_ram_top(ulong total_size); +phys_size_t mrc_common_board_get_usable_ram_top(phys_size_t total_size);
void mrc_common_dram_init_banksize(void);
diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index a1655e1cea5c..4cf41e935416 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -77,7 +77,7 @@ int x86_cleanup_before_linux(void); void x86_enable_caches(void); void x86_disable_caches(void); int x86_init_cache(void); -ulong board_get_usable_ram_top(ulong total_size); +phys_size_t board_get_usable_ram_top(phys_size_t total_size); int default_print_cpuinfo(void);
/* Set up a UART which can be used with printch(), printhex8(), etc. */ diff --git a/arch/x86/lib/fsp1/fsp_dram.c b/arch/x86/lib/fsp1/fsp_dram.c index cfd9b9f48c34..5825221d1e5d 100644 --- a/arch/x86/lib/fsp1/fsp_dram.c +++ b/arch/x86/lib/fsp1/fsp_dram.c @@ -34,7 +34,7 @@ int dram_init(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return fsp_get_usable_lowmem_top(gd->arch.hob_list); } diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index 42d3892b7626..f9ea1ab3baad 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -77,7 +77,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { if (!ll_boot_init()) return gd->ram_size; diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 88036c16c951..26652e8f7733 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -183,7 +183,7 @@ int dram_init_banksize(void) }
/* Limit RAM used by U-Boot to the DDR first bank End region */ -ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return BCM_NS3_MEM_END; } diff --git a/board/imgtec/boston/ddr.c b/board/imgtec/boston/ddr.c index 182f79b9182d..5b245cb44734 100644 --- a/board/imgtec/boston/ddr.c +++ b/board/imgtec/boston/ddr.c @@ -23,7 +23,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 9545e633a3dc..7f3a1d8f7630 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -42,7 +42,7 @@ DECLARE_GLOBAL_DATA_PTR;
static u32 mx53_dram_size[2];
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { /* * WARNING: We must override get_effective_memsize() function here diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 17b8108cc88f..00afb352bd1e 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -335,7 +335,7 @@ static void set_fdt_addr(void) /* * Prevent relocation from stomping on a firmware provided FDT blob. */ -unsigned long board_get_usable_ram_top(unsigned long total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { if ((gd->ram_top - fw_dtb_pointer) > SZ_64M) return gd->ram_top; diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 7182a8cad1a4..bda0fae80b1f 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -61,7 +61,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index e6ff54c065de..e6dd2b73d6a5 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -57,7 +57,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 3c75ecfc0fe4..e09adc8ad34e 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -46,7 +46,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 70b3c81f1284..c20d8e71ef1d 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -511,7 +511,7 @@ int dram_init(void) return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; diff --git a/common/board_f.c b/common/board_f.c index ac7e2d65694c..15e442a0cf33 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -302,7 +302,7 @@ __weak int mach_cpu_init(void) }
/* Get the top of usable RAM */ -__weak ulong board_get_usable_ram_top(ulong total_size) +__weak phys_size_t board_get_usable_ram_top(phys_size_t total_size) { #if defined(CONFIG_SYS_SDRAM_BASE) && CONFIG_SYS_SDRAM_BASE > 0 /* diff --git a/drivers/video/fsl_dcu_fb.c b/drivers/video/fsl_dcu_fb.c index dc5b24c98bb8..9c04f0685af1 100644 --- a/drivers/video/fsl_dcu_fb.c +++ b/drivers/video/fsl_dcu_fb.c @@ -372,7 +372,7 @@ int fsl_dcu_init(struct fb_info *fbinfo, unsigned int xres, return 0; }
-ulong board_get_usable_ram_top(ulong total_size) +phys_size_t board_get_usable_ram_top(phys_size_t total_size) { return gd->ram_top - CONFIG_VIDEO_FSL_DCU_MAX_FB_SIZE_MB; } diff --git a/include/init.h b/include/init.h index 20c3976af09a..a83c0b148924 100644 --- a/include/init.h +++ b/include/init.h @@ -290,7 +290,7 @@ int show_board_info(void); * * @param total_size Size of U-Boot (unused?) */ -ulong board_get_usable_ram_top(ulong total_size); +phys_size_t board_get_usable_ram_top(phys_size_t total_size);
int board_early_init_f(void);
Members gd->ram_size and gd->ram_top are of type phys_addr_t which does not have to fit into ulong type. So cast them into unsigned long long.
Fixes: 37dc958947ed ("global_data.h: Change ram_top type to phys_addr_t") Signed-off-by: Pali Rohár pali@kernel.org --- common/board_f.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 15e442a0cf33..9e34fbee147e 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -325,7 +325,7 @@ static int setup_dest_addr(void) /* * Ram is setup, size stored in gd !! */ - debug("Ram size: %08lX\n", (ulong)gd->ram_size); + debug("Ram size: %08llX\n", (unsigned long long)gd->ram_size); #if defined(CONFIG_SYS_MEM_TOP_HIDE) /* * Subtract specified amount of memory to hide so that it won't @@ -345,7 +345,7 @@ static int setup_dest_addr(void) gd->ram_top = gd->ram_base + get_effective_memsize(); gd->ram_top = board_get_usable_ram_top(gd->mon_len); gd->relocaddr = gd->ram_top; - debug("Ram top: %08lX\n", (ulong)gd->ram_top); + debug("Ram top: %08llX\n", (unsigned long long)gd->ram_top); #if defined(CONFIG_MP) && (defined(CONFIG_MPC86xx) || defined(CONFIG_E500)) /* * We need to make sure the location we intend to put secondary core
Hi Pali,
Which board does this break?
#if defined(CONFIG_MP) && (defined(CONFIG_MPC86xx) || defined(CONFIG_E500)) /* * We need to make sure the location we intend to put secondary core -- 2.20.1
This seems OK, as it still only shows 8 digits in most cases.
On Friday 09 September 2022 12:20:57 Simon Glass wrote:
Hi Pali,
Uff.. I'm not sure right now as I have this patch for months. Anyway, looking at it I think the issue is with 36-bit powerpc stuff where phys_addr_t is 64-bit, ulong is 32-bit and therefore ram_size can be up to 64 GB. Of course addressable RAM maximally 4 GB. Anyway, there should not be any break, this is just debug output.
No? IIRC %08 prints at least 8 digits (not at most).
Hi Pali,
Hi Pali,
OK
Yes we are saying the same thing. It is %016x that I would object to.
Check needs to be done against CONFIG_MAX_MEM_MAPPED macro and not fixed size 4GB (as CONFIG_MAX_MEM_MAPPED can be lower and for example for e500 cores it is just 2GB). Also fix printf re-align, which should be applied only for non-SPL builds, during init_dram() call.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/ddr/fsl/main.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index f389e5ef9524..ec040f265da2 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -856,13 +856,22 @@ phys_size_t __fsl_ddr_sdram(fsl_ddr_info_t *pinfo) debug("total_memory by %s = %llu\n", __func__, total_memory);
#if !defined(CONFIG_PHYS_64BIT) - /* Check for 4G or more. Bad. */ - if ((first_ctrl == 0) && (total_memory >= (1ull << 32))) { + /* Check for more than max memory. Bad. */ + if ((first_ctrl == 0) && (total_memory > CONFIG_MAX_MEM_MAPPED)) { puts("Detected "); print_size(total_memory, " of memory\n"); - printf(" This U-Boot only supports < 4G of DDR\n"); - printf(" You could rebuild it with CONFIG_PHYS_64BIT\n"); - printf(" "); /* re-align to match init_dram print */ +#ifndef CONFIG_SPL_BUILD + puts(" "); /* re-align to match init_dram print */ +#endif + puts("This U-Boot only supports <= "); + print_size(CONFIG_MAX_MEM_MAPPED, " of DDR\n"); +#ifndef CONFIG_SPL_BUILD + puts(" "); /* re-align to match init_dram print */ +#endif + puts("You could rebuild it with CONFIG_PHYS_64BIT\n"); +#ifndef CONFIG_SPL_BUILD + puts(" "); /* re-align to match init_dram print */ +#endif total_memory = CONFIG_MAX_MEM_MAPPED; } #endif
Function fsl_ddr_compute() always return size in unsigned long long type, but function fsl_ddr_sdram_size() returns size in phys_size_t type.
When 36-bit addressing mode is not enabled then phys_size_t type is only 32-bit and thus it cannot store value 4GB (0x100000000). Function fsl_ddr_sdram_size() in this case returns truncated value 0x0.
Fix this issue by returning the highest representable value, which is 0xffffffff (4GB - 1 byte).
This change fixes crashing of proper U-Boot because it detected 4 GB module as RAM with zero size.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/ddr/fsl/main.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index ec040f265da2..dd55e61a7a73 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -949,5 +949,9 @@ fsl_ddr_sdram_size(void) /* Compute it once normally. */ total_memory = fsl_ddr_compute(&info, STEP_GET_SPD, 1);
+ /* Ensure that total_memory does not overflow on return */ + if (total_memory > (phys_size_t)~0ULL) + total_memory = (phys_size_t)~0ULL; + return total_memory; }
U-Boot core code already handles the case when RAM size is bigger than CONFIG_MAX_MEM_MAPPED. So there is no need to do duplicate check in fsl ddr driver for CONFIG_MAX_MEM_MAPPED. Instead simplify code to just check if RAM size can be representable in phys_size_t type. And avoid printing warning if phys_size_t is just 1 byte smaller than RAM size, which is the typical situation with 4 GB DDR module.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/ddr/fsl/main.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index dd55e61a7a73..577ca569b042 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -856,15 +856,18 @@ phys_size_t __fsl_ddr_sdram(fsl_ddr_info_t *pinfo) debug("total_memory by %s = %llu\n", __func__, total_memory);
#if !defined(CONFIG_PHYS_64BIT) - /* Check for more than max memory. Bad. */ - if ((first_ctrl == 0) && (total_memory > CONFIG_MAX_MEM_MAPPED)) { + /* + * Show warning about big DDR moodules. But avoid warning for 4 GB DDR + * modules when U-Boot supports RAM of maximal size 4 GB - 1 byte. + */ + if ((first_ctrl == 0) && (total_memory - 1 > (phys_size_t)~0ULL)) { puts("Detected "); print_size(total_memory, " of memory\n"); #ifndef CONFIG_SPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif puts("This U-Boot only supports <= "); - print_size(CONFIG_MAX_MEM_MAPPED, " of DDR\n"); + print_size((unsigned long long)((phys_size_t)~0ULL)+1, " of DDR\n"); #ifndef CONFIG_SPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif @@ -872,10 +875,13 @@ phys_size_t __fsl_ddr_sdram(fsl_ddr_info_t *pinfo) #ifndef CONFIG_SPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif - total_memory = CONFIG_MAX_MEM_MAPPED; } #endif
During init_dram() is called also compute_lowest_common_dimm_parameters() function which prints multi-line detailed output. So print also re-aligning filler after "Detected ?DIMM" line to have "DRAM: " output aligned.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/ddr/fsl/lc_common_dimm_params.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/ddr/fsl/lc_common_dimm_params.c b/drivers/ddr/fsl/lc_common_dimm_params.c index d738ae3a7c66..5e4ad56f0714 100644 --- a/drivers/ddr/fsl/lc_common_dimm_params.c +++ b/drivers/ddr/fsl/lc_common_dimm_params.c @@ -422,6 +422,9 @@ compute_lowest_common_dimm_parameters(const unsigned int ctrl_num, dimm_params[i].mpart); #endif } +#ifndef CONFIG_SPL_BUILD + puts(" "); +#endif } }
At some point could this move to drivers/ram ?
Depends on if we're keeping / making drivers/ram mean uses uclass and drivers/ddr does not, I think.
Hi Tom,
Yes, except for Altera:
$ git grep UCLASS_RAM drivers/ddr drivers/ddr/altera/sdram_gen5.c: .id = UCLASS_RAM, drivers/ddr/altera/sdram_soc64.c: .id = UCLASS_RAM,
On Fri, Sep 09, 2022 at 01:39:25PM -0600, Simon Glass wrote:
Hi Tom,
Then we should move those over to drivers/ram/altera/ and leave the rest as-is. And of course, totally outside the scope of this series.
Currently U-Boot SPL prints just generic message "2 GiB left unmapped". Change it to more detailed "2 GiB of DDR memory left unmapped in U-Boot". This is just U-Boot configuration and operating system may map more (or also less) memory.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/cpu/mpc85xx/tlb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 550d45da0efa..6107a91ecd3c 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -311,7 +311,7 @@ unsigned int setup_ddr_tlbs_phys(phys_addr_t p_addr, if (size || memsize > CONFIG_MAX_MEM_MAPPED) { print_size(memsize > CONFIG_MAX_MEM_MAPPED ? memsize - CONFIG_MAX_MEM_MAPPED + size : size, - " left unmapped\n"); + " of DDR memory left unmapped in U-Boot\n"); }
return memsize_in_meg;
During init_dram() is called also setup_ddr_tlbs_phys() function which may print message about unmapped DDR memory. So in this case print also re-aligning filler after unmapped DDR memory message.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/cpu/mpc85xx/tlb.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 6107a91ecd3c..723ee1d599fd 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -312,6 +312,9 @@ unsigned int setup_ddr_tlbs_phys(phys_addr_t p_addr, print_size(memsize > CONFIG_MAX_MEM_MAPPED ? memsize - CONFIG_MAX_MEM_MAPPED + size : size, " of DDR memory left unmapped in U-Boot\n"); +#ifndef CONFIG_SPL_BUILD + puts(" "); +#endif }
Pali Rohár
