[U-Boot] [PATCH] S5PC2XX: add the sromc header file
Add missing header file.
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/include/asm/arch-s5pc2xx/sromc.h | 51 +++++++++++++++++++++++++++++ 1 files changed, 51 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-s5pc2xx/sromc.h
diff --git a/arch/arm/include/asm/arch-s5pc2xx/sromc.h b/arch/arm/include/asm/arch-s5pc2xx/sromc.h new file mode 100644 index 0000000..f616bcb --- /dev/null +++ b/arch/arm/include/asm/arch-s5pc2xx/sromc.h @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2010 Samsung Electronics + * Naveen Krishna Ch ch.naveen@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * Note: This file contains the register description for SROMC + * + */ + +#ifndef __ASM_ARCH_SROMC_H_ +#define __ASM_ARCH_SROMC_H_ + +#define SROMC_DATA16_WIDTH(x) (1<<((x*4)+0)) +#define SROMC_BYTE_ADDR_MODE(x) (1<<((x*4)+1)) /* 0-> Half-word base address*/ + /* 1-> Byte base address*/ +#define SROMC_WAIT_ENABLE(x) (1<<((x*4)+2)) +#define SROMC_BYTE_ENABLE(x) (1<<((x*4)+3)) + +#define SROMC_BC_TACS(x) (x << 28) /* address set-up */ +#define SROMC_BC_TCOS(x) (x << 24) /* chip selection set-up */ +#define SROMC_BC_TACC(x) (x << 16) /* access cycle */ +#define SROMC_BC_TCOH(x) (x << 12) /* chip selection hold */ +#define SROMC_BC_TAH(x) (x << 8) /* address holding time */ +#define SROMC_BC_TACP(x) (x << 4) /* page mode access cycle */ +#define SROMC_BC_PMC(x) (x << 0) /* normal(1data)page mode configuration */ + +#ifndef __ASSEMBLY__ +struct s5p_sromc { + unsigned int bw; + unsigned int bc[4]; +}; +#endif /* __ASSEMBLY__ */ + +/* Configure the Band Width and Bank Control Regs for required SROMC Bank */ +void s5p_config_sromc(u32 srom_bank, u32 srom_bw_conf, u32 srom_bc_conf); + +#endif /* __ASM_ARCH_SROMC_H_ */
Dear Minkyu Kang,
This should not be handled separately, but rather be squashed into the patch that now creates the problem, i. e.
04/15 Chander Kashyap [U-Boot] [PATCH] S5P:SROM config code moved to s5p-common directory http://article.gmane.org/gmane.comp.boot-loaders.u-boot/97781
Minkyu Kang
