[U-Boot] [PATCH v3 1/2] fdt: Deprecate "usbethaddr" usage in fdt_fixup_ethernet()
In fdt_fixup_ethernet() only "usbethaddr" is handled to fix up the first usb ethernet port MAC address. Other additional usb ethernet ports are ignored as there is no logic to handle "usbeth%daddr".
It is suggested we should use "ethaddr" for all ethernet devices. Hence deprecate "usbethaddr" usage in fdt_fixup_ethernet().
This actually reverts commit b1f49ab8c7bad60426b30c134ae065ef77d2dfc1 "ARM: fdt support: Add usbethaddr as an acceptable MAC".
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Tom Rini trini@konsulko.com On OMAP4 Panda (+ v4.3 kernel) Tested-by: Tom Rini trini@konsulko.com
Changes in v3: - Update commit message to include full commit id and subject.
Changes in v2: - New patch to deprecate "usbethaddr" usage in fdt_fixup_ethernet()
common/fdt_support.c | 12 +----------- 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index a7ff2df..ec72b86 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -490,18 +490,8 @@ void fdt_fixup_ethernet(void *fdt) if (node < 0) return;
- if (!getenv("ethaddr")) { - if (getenv("usbethaddr")) { - strcpy(mac, "usbethaddr"); - } else { - debug("No ethernet MAC Address defined\n"); - return; - } - } else { - strcpy(mac, "ethaddr"); - } - i = 0; + strcpy(mac, "ethaddr"); while ((tmp = getenv(mac)) != NULL) { sprintf(enet, "ethernet%d", i); path = fdt_getprop(fdt, node, enet, NULL);
Currently in fdt_fixup_ethernet() the MAC address fix up is handled in a loop of which the exit condition is to test the "eth%daddr" env is not NULL. However this creates unnecessary constrains that those "eth%daddr" env variables must be sequential even if "ethernet%d" does not start from 0 in the "/aliases" node. For example, with "/aliases" node below:
aliases { ethernet3 = &enet3; ethernet4 = &enet4; };
"ethaddr", "eth1addr", "eth2addr" must exist in order to fix up ethernet3's MAC address successfully.
Now we change the loop logic to iterate the properties in the "/aliases" node. For each property, test if it is in a format of "ethernet%d", then get its MAC address from corresponding "eth%daddr" env and fix it up in the dtb.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Tom Rini trini@konsulko.com On OMAP4 Panda (+v4.3 kernel) Tested-by: Tom Rini trini@konsulko.com
common/fdt_support.c | 54 ++++++++++++++++++++++++++++++++-------------------- 1 file changed, 33 insertions(+), 21 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index ec72b86..f7aaf9c 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -481,37 +481,49 @@ int fdt_fixup_memory(void *blob, u64 start, u64 size) void fdt_fixup_ethernet(void *fdt) { int node, i, j; - char enet[16], *tmp, *end; + char *tmp, *end; char mac[16]; const char *path; unsigned char mac_addr[6]; + int offset;
node = fdt_path_offset(fdt, "/aliases"); if (node < 0) return;
- i = 0; - strcpy(mac, "ethaddr"); - while ((tmp = getenv(mac)) != NULL) { - sprintf(enet, "ethernet%d", i); - path = fdt_getprop(fdt, node, enet, NULL); - if (!path) { - debug("No alias for %s\n", enet); - sprintf(mac, "eth%daddr", ++i); - continue; - } + for (offset = fdt_first_property_offset(fdt, node); + offset > 0; + offset = fdt_next_property_offset(fdt, offset)) { + const char *name; + int len = strlen("ethernet"); + + path = fdt_getprop_by_offset(fdt, offset, &name, NULL); + if (!strncmp(name, "ethernet", len)) { + i = trailing_strtol(name); + if (i != -1) { + if (i == 0) + strcpy(mac, "ethaddr"); + else + sprintf(mac, "eth%daddr", i); + } else { + continue; + } + tmp = getenv(mac); + if (!tmp) + continue; + + for (j = 0; j < 6; j++) { + mac_addr[j] = tmp ? + simple_strtoul(tmp, &end, 16) : 0; + if (tmp) + tmp = (*end) ? end + 1 : end; + }
- for (j = 0; j < 6; j++) { - mac_addr[j] = tmp ? simple_strtoul(tmp, &end, 16) : 0; - if (tmp) - tmp = (*end) ? end+1 : end; + do_fixup_by_path(fdt, path, "mac-address", + &mac_addr, 6, 0); + do_fixup_by_path(fdt, path, "local-mac-address", + &mac_addr, 6, 1); } - - do_fixup_by_path(fdt, path, "mac-address", &mac_addr, 6, 0); - do_fixup_by_path(fdt, path, "local-mac-address", - &mac_addr, 6, 1); - - sprintf(mac, "eth%daddr", ++i); } }
Hi Bin,
Applied to u-boot-net/master, thanks! -Joe
Hi Joe,
Changes in v3:
Changes in v2:
} else {
return;
} else {
i = 0;
I see these two patches are assigned to you on patchwork. When will these get merged?
Regards, Bin
Hi Bin,
On Sun, Dec 6, 2015 at 7:53 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Joe,
Changes in v3:
Changes in v2:
} else {
return;
} else {
i = 0;
I plan to do another round of patch application next week sometime.
Cheers, -Joe
Hi Joe,
On Wed, Dec 9, 2015 at 7:10 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Bin,
Hi Joe,
Changes in v3:
Changes in v2:
} else {
return;
} else {
i = 0;
ping? I hope this won't miss the release train.
Regards, Bin
Hi Bin,
Bin Meng
Joe Hershberger
