[U-Boot] [PATCH 0/2] imx: ventana: Add pci fixup for PLX switch
Many of the Gateworks Ventana boards have a PLX PCIe switch where GPIO on the switch is used as the PERST# of the downstream ports. In the Linux kernel there is a PCI fixup that asserts these properly when the upstream port is enumerated.
The first patch in this serial adds a board_pci_fixup_dev function define to allow hooking similarly to the kernel pci fixup functionality.
The second patch uses the board_pci_fixup_dev function to perform the GPIO configuration on the switch for the downstream ports.
Tim Harvey (2): pci: add support for board_pci_fixup_dev function imx: ventana: add pci fixup for PLX PEX860x switch GPIO
board/gateworks/gw_ventana/gw_ventana.c | 30 ++++++++++++++++++++++++++++++ drivers/pci/pci.c | 4 ++++ include/configs/gw_ventana.h | 1 + include/pci.h | 7 +++++++ 4 files changed, 42 insertions(+)
Some board-level drivers may wish to have per-device fixup functions for PCI devices.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/pci/pci.c | 4 ++++ include/pci.h | 7 +++++++ 2 files changed, 11 insertions(+)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index ed113bf..e269468 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -648,6 +648,10 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) pci_hose_read_config_word(hose, dev, PCI_DEVICE_ID, &device); pci_hose_read_config_word(hose, dev, PCI_CLASS_DEVICE, &class);
+#ifdef CONFIG_PCI_FIXUP_DEV + board_pci_fixup_dev(hose, dev, vendor, device, class); +#endif + #ifdef CONFIG_PCI_SCAN_SHOW indent++;
diff --git a/include/pci.h b/include/pci.h index 461f17c..2ff7365 100644 --- a/include/pci.h +++ b/include/pci.h @@ -659,6 +659,13 @@ extern int pci_hose_find_cap_start(struct pci_controller *hose, pci_dev_t dev, extern int pci_find_cap(struct pci_controller *hose, pci_dev_t dev, int pos, int cap);
+#ifdef CONFIG_PCI_FIXUP_DEV +extern void board_pci_fixup_dev(struct pci_controller *hose, pci_dev_t dev, + unsigned short vendor, + unsigned short device, + unsigned short class); +#endif + const char * pci_class_str(u8 class); int pci_last_busno(void);
Hi Tim,
Best regards, Stefano Babic
Most Gateworks Ventana boards use a PLX PEX860x PCIe switch for PCIe expansion. These boards use GPIO on the PLX device as PERST# for the downstream ports thus we assert this when the PLX is enumerated.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 30 ++++++++++++++++++++++++++++++ include/configs/gw_ventana.h | 1 + 2 files changed, 31 insertions(+)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 70b90d8..186cd38 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -31,6 +31,7 @@ #include <mmc.h> #include <mtd_node.h> #include <netdev.h> +#include <pci.h> #include <power/pmic.h> #include <power/ltc3676_pmic.h> #include <power/pfuze100_pmic.h> @@ -1092,6 +1093,35 @@ int imx6_pcie_toggle_reset(void) } return 0; } + +/* + * Most Ventana boards have a PLX PEX860x PCIe switch onboard and use its + * GPIO's as PERST# signals for its downstream ports - configure the GPIO's + * properly and assert reset for 100ms. + */ +void board_pci_fixup_dev(struct pci_controller *hose, pci_dev_t dev, + unsigned short vendor, unsigned short device, + unsigned short class) +{ + u32 dw; + + debug("%s: %02d:%02d.%02d: %04x:%04x\n", __func__, + PCI_BUS(dev), PCI_DEV(dev), PCI_FUNC(dev), vendor, device); + if (vendor == PCI_VENDOR_ID_PLX && + (device & 0xfff0) == 0x8600 && + PCI_DEV(dev) == 0 && PCI_FUNC(dev) == 0) { + debug("configuring PLX 860X downstream PERST#\n"); + pci_hose_read_config_dword(hose, dev, 0x62c, &dw); + dw |= 0xaaa8; /* GPIO1-7 outputs */ + pci_hose_write_config_dword(hose, dev, 0x62c, dw); + + pci_hose_read_config_dword(hose, dev, 0x644, &dw); + dw |= 0xfe; /* GPIO1-7 output high */ + pci_hose_write_config_dword(hose, dev, 0x644, dw); + + mdelay(100); + } +} #endif /* CONFIG_CMD_PCI */
#ifdef CONFIG_SERIAL_TAG diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index b991b09..0e5c200 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -141,6 +141,7 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCI_FIXUP_DEV #define CONFIG_PCIE_IMX #endif
Hi Tim,
-- 1.8.3.2
Any comments on these? I'm wondering if there is someone else I should be including with regards to reviewing pci changes.
Regards,
Tim
-- 1.8.3.2
No comment, and I do not see any bad influence on other boards - I am going to apply them.
Regards, Stefano Babic
Stefano Babic
Tim Harvey
