[U-Boot] [PATCH 34/34] drivers/net/fec: phy_init: remove redundant logic
The phy_connect_dev(...) function from phy.c does all the handling (inclusive catching fixed-link). So we drop here the single steps and call just phy_connect_dev(...). Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Best regards, Stefano Babic
Hi Stefano
On Wed, 2019-03-13 at 08:28 +0000, sbabic@denx.de wrote:
The phy_connect_dev(...) function from phy.c does all the handling (inclusive catching fixed-link). So we drop here the single steps and call just phy_connect_dev(...). Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com
Unfortunately, this commit broke Ethernet on the Vybrid. When re-basing my Colibri VF50/VF61 clean-up patch set ("colibri vybrid fixes, device tree enablement and driver model conversion") I noticed that Ethernet no longer works giving the following error messages:
Net: Could not get PHY for FEC0: addr -19 eth-1: fec@400d1000 Colibri VFxx # dhcp Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 No ethernet found. Could not get PHY for FEC0: addr -19 Colibri VFxx #
Bisecting points to this commit and reverting it indeed makes it work again.
Has anybody else seen a similar issue (e.g. @Lukasz on pcm052)?
Cheers
Marcel
Hi Marcel,
Hi Stefano
I did not checked yet - as I was waiting for the code to settle down to mainline (after the v2019.04 u-boot release).
I will check it on bk4.
Cheers
Marcel
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Dear Tom, Marcel, Stefano
Hi Marcel,
Hi Stefano
Maybe not on BK4, but surely on (HSC): CPU: Freescale i.MX53 rev2.1 at 800 MHz
=> dhcp Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 No ethernet found. Could not get PHY for FEC0: addr -19
I can confirm the error.
So I do expect that we have some more IMX boards broken (imx53, vybrid).
I think that it would be best to revert this patch before v2019.04 release and look for clean up opportunities afterwards.
Cheers
Marcel
Lukasz Majewski
Lukasz Majewski
HI Lukas,
please can you test with this patch:
But i agree, for 2019.04 it would be ok reverting this and then look if the provided patch can be applied.
Joe, what do you mean?
cheers, Hannes
Lukasz Majewski lukma@denx.de schrieb am 28.03.2019 11:47:34:
Von: Lukasz Majewski lukma@denx.de An: Marcel Ziswiler marcel.ziswiler@toradex.com, "sbabic@denx.de" sbabic@denx.de, Tom Rini trini@konsulko.com Kopie: "u-boot@lists.denx.de" u-boot@lists.denx.de,
"hannes.schmelzer@br-
automation.com" hannes.schmelzer@br-automation.com, Joe Hershberger joe.hershberger@ni.com Datum: 28.03.2019 11:47 Betreff: Re: [REGRESSION: PATCH 34/34] drivers/net/fec: phy_init: remove
redundant logic
Hi Marcel,
Hi Stefano
Cheers
Marcel
Lukasz Majewski
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de [Anhang "att09yen.dat" gelöscht von Hannes Schmelzer/Gilgenberg/AT/B&R]
On 3/25/19 5:07 PM, Marcel Ziswiler wrote:
Hi Stefano
The phy_connect_dev(...) function from phy.c does all the handling (inclusive catching fixed-link). So we drop here the single steps and call just phy_connect_dev(...). Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Hi, sorry for that issue. I will look into tomorrow, to see what happens there.
cheers, Hannes
Hi Stefano
Cheers
Marcel _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Marcel, does this board use DM ? which defconfig uses the board?
cheers, Hannes
Hi Hannes
Hi Stefano
The phy_connect_dev(...) function from phy.c does all the handling (inclusive catching fixed-link). So we drop here the single steps and call just phy_connect_dev(...). Signed-off-by: Hannes Schmelzer < hannes.schmelzer@br-automation.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Unfortunately, this commit broke Ethernet on the Vybrid. When re- basing my Colibri VF50/VF61 clean-up patch set ("colibri vybrid fixes, device tree enablement and driver model conversion") I noticed that Ethernet no longer works giving the following error messages:
Cheers
Yes, I moved it to DM. The latest patch set is the following:
https://patchwork.ozlabs.org/cover/1064570/
Also available on our git server here:
http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
That would be colibri_vf_defconfig.
cheers, Hannes
Cheers
Marcel
participants (5)
Hannes Schmelzer
Hannes Schmelzer
Lukasz Majewski
Marcel Ziswiler
sbabic@denx.de
