[U-Boot] [PATCH] dm: (re)sort uclass ids alphabetically
The comment in uclass-id.h states that "U-Boot uclasses start here - in alphabetical order" but the subsequent list is not sorted alphabetically. This reestablishes order.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
include/dm/uclass-id.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index c91dca1..aad5d26 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -29,6 +29,7 @@ enum uclass_id { /* U-Boot uclasses start here - in alphabetical order */ UCLASS_ADC, /* Analog-to-digital converter */ UCLASS_AHCI, /* SATA disk controller */ + UCLASS_AXI, /* AXI bus */ UCLASS_BLK, /* Block device */ UCLASS_BOARD, /* Device information from hardware */ UCLASS_CLK, /* Clock source, e.g. used by peripherals */ @@ -38,15 +39,14 @@ enum uclass_id { UCLASS_DMA, /* Direct Memory Access */ UCLASS_EFI, /* EFI managed devices */ UCLASS_ETH, /* Ethernet device */ + UCLASS_FIRMWARE, /* Firmware */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ - UCLASS_FIRMWARE, /* Firmware */ UCLASS_I2C, /* I2C bus */ UCLASS_I2C_EEPROM, /* I2C EEPROM device */ UCLASS_I2C_GENERIC, /* Generic I2C device */ UCLASS_I2C_MUX, /* I2C multiplexer */ UCLASS_IDE, /* IDE device */ - UCLASS_AXI, /* AXI bus */ UCLASS_IRQ, /* Interrupt controller */ UCLASS_KEYBOARD, /* Keyboard input device */ UCLASS_LED, /* Light-emitting diode (LED) */ @@ -68,8 +68,8 @@ enum uclass_id { UCLASS_PINCONFIG, /* Pin configuration node device */ UCLASS_PINCTRL, /* Pinctrl (pin muxing/configuration) device */ UCLASS_PMIC, /* PMIC I/O device */ - UCLASS_PWM, /* Pulse-width modulator */ UCLASS_POWER_DOMAIN, /* (SoC) Power domains */ + UCLASS_PWM, /* Pulse-width modulator */ UCLASS_PWRSEQ, /* Power sequence device */ UCLASS_RAM, /* RAM controller */ UCLASS_REGULATOR, /* Regulator device */ @@ -80,9 +80,9 @@ enum uclass_id { UCLASS_SERIAL, /* Serial UART */ UCLASS_SMEM, /* Shared memory interface */ UCLASS_SPI, /* SPI bus */ - UCLASS_SPMI, /* System Power Management Interface bus */ UCLASS_SPI_FLASH, /* SPI flash */ UCLASS_SPI_GENERIC, /* Generic SPI flash target */ + UCLASS_SPMI, /* System Power Management Interface bus */ UCLASS_SYSCON, /* System configuration device */ UCLASS_SYSRESET, /* System reset device */ UCLASS_TEE, /* Trusted Execution Environment device */
Applied to u-boot-dm/master, thanks!
Philipp Tomsich
sjg@google.com
