[U-Boot] [PATCH] EXYNOS: EXYNOS4X12: extract Exynos4x12 IPs clock frequency
Adds functions to extract clock frequency of Exynos4x12 IPs.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/cpu/armv7/exynos/clock.c | 163 +++++++++++++++++++++++++++++++++++-- 1 file changed, 158 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index a042423..012beab 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -100,6 +100,36 @@ static unsigned long exynos4_get_pll_clk(int pllreg) return exynos_get_pll_clk(pllreg, r, k); }
+/* exynos4x12: return pll clock frequency */ +static unsigned long exynos4x12_get_pll_clk(int pllreg) +{ + struct exynos4x12_clock *clk = + (struct exynos4x12_clock *)samsung_get_base_clock(); + unsigned long r, k = 0; + + switch (pllreg) { + case APLL: + r = readl(&clk->apll_con0); + break; + case MPLL: + r = readl(&clk->mpll_con0); + break; + case EPLL: + r = readl(&clk->epll_con0); + k = readl(&clk->epll_con1); + break; + case VPLL: + r = readl(&clk->vpll_con0); + k = readl(&clk->vpll_con1); + break; + default: + printf("Unsupported PLL (%d)\n", pllreg); + return 0; + } + + return exynos_get_pll_clk(pllreg, r, k); +} + /* exynos5: return pll clock frequency */ static unsigned long exynos5_get_pll_clk(int pllreg) { @@ -181,6 +211,28 @@ static unsigned long exynos4_get_arm_clk(void) return armclk; }
+/* exynos4x12: return ARM clock frequency */ +static unsigned long exynos4x12_get_arm_clk(void) +{ + struct exynos4x12_clock *clk = + (struct exynos4x12_clock *)samsung_get_base_clock(); + unsigned long div; + unsigned long armclk; + unsigned int core_ratio; + unsigned int core2_ratio; + + div = readl(&clk->div_cpu0); + + /* CORE_RATIO: [2:0], CORE2_RATIO: [30:28] */ + core_ratio = (div >> 0) & 0x7; + core2_ratio = (div >> 28) & 0x7; + + armclk = get_pll_clk(APLL) / (core_ratio + 1); + armclk /= (core2_ratio + 1); + + return armclk; +} + /* exynos5: return ARM clock frequency */ static unsigned long exynos5_get_arm_clk(void) { @@ -246,6 +298,20 @@ static unsigned long exynos4_get_pwm_clk(void) return pclk; }
+/* exynos4x12: return pwm clock frequency */ +static unsigned long exynos4x12_get_pwm_clk(void) +{ + unsigned long pclk, sclk; + unsigned int ratio; + + sclk = get_pll_clk(MPLL); + ratio = 8; + + pclk = sclk / (ratio + 1); + + return pclk; +} + /* exynos5: return pwm clock frequency */ static unsigned long exynos5_get_pwm_clk(void) { @@ -314,6 +380,51 @@ static unsigned long exynos4_get_uart_clk(int dev_index) return uclk; }
+/* exynos4x12: return uart clock frequency */ +static unsigned long exynos4x12_get_uart_clk(int dev_index) +{ + struct exynos4x12_clock *clk = + (struct exynos4x12_clock *)samsung_get_base_clock(); + unsigned long uclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_PERIL0 + * UART0_SEL [3:0] + * UART1_SEL [7:4] + * UART2_SEL [8:11] + * UART3_SEL [12:15] + * UART4_SEL [16:19] + */ + sel = readl(&clk->src_peril0); + sel = (sel >> (dev_index << 2)) & 0xf; + + if (sel == 0x6) + sclk = get_pll_clk(MPLL); + else if (sel == 0x7) + sclk = get_pll_clk(EPLL); + else if (sel == 0x8) + sclk = get_pll_clk(VPLL); + else + return 0; + + /* + * CLK_DIV_PERIL0 + * UART0_RATIO [3:0] + * UART1_RATIO [7:4] + * UART2_RATIO [8:11] + * UART3_RATIO [12:15] + * UART4_RATIO [16:19] + */ + ratio = readl(&clk->div_peril0); + ratio = (ratio >> (dev_index << 2)) & 0xf; + + uclk = sclk / (ratio + 1); + + return uclk; +} + /* exynos5: return uart clock frequency */ static unsigned long exynos5_get_uart_clk(int dev_index) { @@ -388,6 +499,33 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) writel(val, addr); }
+/* exynos4x12: set the mmc clock */ +static void exynos4x12_set_mmc_clk(int dev_index, unsigned int div) +{ + struct exynos4x12_clock *clk = + (struct exynos4x12_clock *)samsung_get_base_clock(); + unsigned int addr; + unsigned int val; + + /* + * CLK_DIV_FSYS1 + * MMC0_PRE_RATIO [15:8], MMC1_PRE_RATIO [31:24] + * CLK_DIV_FSYS2 + * MMC2_PRE_RATIO [15:8], MMC3_PRE_RATIO [31:24] + */ + if (dev_index < 2) { + addr = (unsigned int)&clk->div_fsys1; + } else { + addr = (unsigned int)&clk->div_fsys2; + dev_index -= 2; + } + + val = readl(addr); + val &= ~(0xff << ((dev_index << 4) + 8)); + val |= (div & 0xff) << ((dev_index << 4) + 8); + writel(val, addr); +} + /* exynos5: set the mmc clock */ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) { @@ -710,16 +848,22 @@ unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) return exynos5_get_pll_clk(pllreg); - else + else { + if (proid_is_exynos4412()) + return exynos4x12_get_pll_clk(pllreg); return exynos4_get_pll_clk(pllreg); + } }
unsigned long get_arm_clk(void) { if (cpu_is_exynos5()) return exynos5_get_arm_clk(); - else + else { + if (proid_is_exynos4412()) + return exynos4x12_get_arm_clk(); return exynos4_get_arm_clk(); + } }
unsigned long get_i2c_clk(void) @@ -736,24 +880,33 @@ unsigned long get_pwm_clk(void) { if (cpu_is_exynos5()) return exynos5_get_pwm_clk(); - else + else { + if (proid_is_exynos4412()) + return exynos4x12_get_pwm_clk(); return exynos4_get_pwm_clk(); + } }
unsigned long get_uart_clk(int dev_index) { if (cpu_is_exynos5()) return exynos5_get_uart_clk(dev_index); - else + else { + if (proid_is_exynos4412()) + return exynos4x12_get_uart_clk(dev_index); return exynos4_get_uart_clk(dev_index); + } }
void set_mmc_clk(int dev_index, unsigned int div) { if (cpu_is_exynos5()) exynos5_set_mmc_clk(dev_index, div); - else + else { + if (proid_is_exynos4412()) + exynos4x12_set_mmc_clk(dev_index, div); exynos4_set_mmc_clk(dev_index, div); + } }
unsigned long get_lcd_clk(void)
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org javascript:;>
applied to u-boot-samsung/master
thanks Minkyu Kang
Chander Kashyap
Minkyu Kang
