[PULL] u-boot-at91-fixes-2022.04-a
Hello Tom,
Please pull tag u-boot-at91-fixes-2022.04-a , the first set of at91 fixes for the next cycle 2022.04 .
This fixes set includes only a single fix for the Ethernet on sama7g5ek board which is broken at the moment.
Thanks, Eugen
The following changes since commit df887a045a1d726bbd654ef266e5cbe8cc0c2db3:
Prepare v2022.04-rc1 (2022-01-31 17:57:32 -0500)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-fixes-2022.04-a
for you to fetch changes up to 17a9f3f53d644d025a1a9e6d3a61fc71adf8b9d8:
ARM: dts: at91: sama7g5ek: disable slew rate for GMACs non MDIO pins (2022-02-04 13:53:58 +0200)
---------------------------------------------------------------- First set of u-boot-atmel fixes for the 2022.04 cycle
---------------------------------------------------------------- Codrin Ciubotariu (1): ARM: dts: at91: sama7g5ek: disable slew rate for GMACs non MDIO pins
arch/arm/dts/sama7g5ek.dts | 25 +++++++++++++++++++------ 1 file changed, 19 insertions(+), 6 deletions(-)
On Thu, Mar 03, 2022 at 10:08:29AM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks, Eugen
I assume these dts changes are going upstream already and applied to u-boot/master, thanks!
