[U-Boot] [RESEND PATCH] distro_bootcmd: refactor virtio to support PCI block devices
Starting libvirt v5.3.0 with QEMU 4.0.0 use of PCI is automatic and thus storage is connected via PCI, which is not visible to U-Boot out-of-the-box.
Refactor to do "pci enum" followed by "virtio scan" to see PCI connected storage, and allow bootloader to load kernel and initramfs images.
Tested with Fedora/RISCV using releases: libvirt 5.4.0 & 5.5.0, QEMU 4.0.0 and U-Boot 2019.07 RC4.
Signed-off-by: David Abdurachmanov david.abdurachmanov@sifive.com --- include/config_distro_bootcmd.h | 27 +++++++++++++++++++++------ 1 file changed, 21 insertions(+), 6 deletions(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 26e61ef196..3570a32dff 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -254,11 +254,11 @@ #endif
#if defined(CONFIG_DM_PCI) -#define BOOTENV_RUN_NET_PCI_ENUM "run boot_net_pci_enum; " +#define BOOTENV_RUN_PCI_ENUM "run boot_pci_enum; " #define BOOTENV_SHARED_PCI \ - "boot_net_pci_enum=pci enum\0" + "boot_pci_enum=pci enum\0" #else -#define BOOTENV_RUN_NET_PCI_ENUM +#define BOOTENV_RUN_PCI_ENUM #define BOOTENV_SHARED_PCI #endif
@@ -281,10 +281,24 @@ #endif
#ifdef CONFIG_CMD_VIRTIO -#define BOOTENV_SHARED_VIRTIO BOOTENV_SHARED_BLKDEV(virtio) +#define BOOTENV_RUN_VIRTIO_INIT "run virtio_init; " +#define BOOTENV_SET_VIRTIO_NEED_INIT "virtio_need_init=; " +#define BOOTENV_SHARED_VIRTIO \ + "virtio_init=" \ + "if ${virtio_need_init}; then " \ + "virtio_need_init=false; " \ + "virtio scan; " \ + "fi\0" \ + \ + "virtio_boot=" \ + BOOTENV_RUN_PCI_ENUM \ + BOOTENV_RUN_VIRTIO_INIT \ + BOOTENV_SHARED_BLKDEV_BODY(virtio) #define BOOTENV_DEV_VIRTIO BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_VIRTIO BOOTENV_DEV_NAME_BLKDEV #else +#define BOOTENV_RUN_VIRTIO_INIT +#define BOOTENV_SET_VIRTIO_NEED_INIT #define BOOTENV_SHARED_VIRTIO #define BOOTENV_DEV_VIRTIO \ BOOT_TARGET_DEVICES_references_VIRTIO_without_CONFIG_CMD_VIRTIO @@ -350,7 +364,7 @@ #define BOOTENV_DEV_DHCP(devtypeu, devtypel, instance) \ "bootcmd_dhcp=" \ BOOTENV_RUN_NET_USB_START \ - BOOTENV_RUN_NET_PCI_ENUM \ + BOOTENV_RUN_PCI_ENUM \ "if dhcp ${scriptaddr} ${boot_script_dhcp}; then " \ "source ${scriptaddr}; " \ "fi;" \ @@ -369,7 +383,7 @@ #define BOOTENV_DEV_PXE(devtypeu, devtypel, instance) \ "bootcmd_pxe=" \ BOOTENV_RUN_NET_USB_START \ - BOOTENV_RUN_NET_PCI_ENUM \ + BOOTENV_RUN_PCI_ENUM \ "dhcp; " \ "if pxe get; then " \ "pxe boot; " \ @@ -465,6 +479,7 @@ "distro_bootcmd=" BOOTENV_SET_SCSI_NEED_INIT \ BOOTENV_SET_NVME_NEED_INIT \ BOOTENV_SET_IDE_NEED_INIT \ + BOOTENV_SET_VIRTIO_NEED_INIT \ "for target in ${boot_targets}; do " \ "run bootcmd_${target}; " \ "done\0"
David Abdurachmanov
