[U-Boot] [PATCH] arm64/ls1046a: Enable ERRATUM_A008850 for ls1046a SoC
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index a99b1c6..25588c8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -36,6 +36,7 @@ config ARCH_LS1046A select SYS_FSL_DDR_VER_50 select SYS_FSL_ERRATUM_A008336 select SYS_FSL_ERRATUM_A008511 + select SYS_FSL_ERRATUM_A008850 select SYS_FSL_ERRATUM_A009801 select SYS_FSL_ERRATUM_A009803 select SYS_FSL_ERRATUM_A009942
Applied to u-boot-fsl-qoriq master, awaiting upstream. Thanks.
York
Shengzhou Liu
York Sun
