Pull request: u-boot-rockchip-20191231
Hi Tom,
Please pull the rockchip updates/fixes: - Fix latest mainline kernel for rk3308 - Update rk3288-evb config to suport OP-TEE - Fix for firefly-px30 DEBUG_UART channel and make it standalone - Script make_fit_atf add python3 support - Fix rk3328 timer with correct COUNTER_FREQUENCY - Fix rk3328 ATF support with enable spl-fifo-mode
Travis: https://travis-ci.org/keveryang/u-boot/builds/631247159
Thanks, - Kever
The following changes since commit d792b63febf492a07a106245e46532c0d43a7ecd:
Merge branch 'master' of git://git.denx.de/u-boot-usb (2019-12-22 09:14:35 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20191231
for you to fetch changes up to c0a474b9d9a1c370f46b3f76ea0707f92d55b0b1:
rockchip: evb-rk3328: Enable support ATF in SPL (2019-12-31 16:04:16 +0800)
---------------------------------------------------------------- Andy Yan (2): rockchip: rk3308: allow loading larger kernel Image doc: rockchip: Fix reference the wrong defconfig name of ROC-CC-RK3308
Jack Mitchell (1): rockchip: make_fit_atf: explicitly use python3
Jeffy Chen (3): rockchip: mkimage: support packing optional second level boot-loader doc: rockchip: document packing second level loader with mkimage rockchip: mkimage: fix wrong range of rc4 encoding for boot image
Kever Yang (9): rockchip: fit_spl_optee: get text and optee base from build rockchip: rk3288-evb: update SPL_STACK/MALLOC_LEN config with rk3399 rockchip: rk3288-evb: update CONFIG_NR_DRAM_BANKS to 2 rockchip: rk3288-evb: update config to support OPTEE rockchip: firefly-px30: Fix the MACRO for CONFIG_DEBUG_UART2_CHANNEL rockchip: px30-firefly add standalone dts rockchip: rk3328: add COUNTER_FREQUENCY definition rockchip: rk3328: enable spl-fifo-mode for emmc and sdmmc rockchip: evb-rk3328: Enable support ATF in SPL
Thomas Hebb (1): rockchip: add description for TPL_ROCKCHIP_COMMON_BOARD
arch/arm/dts/Makefile | 3 +- arch/arm/dts/px30-firefly-u-boot.dtsi | 84 +++++ arch/arm/dts/px30-firefly.dts | 531 ++++++++++++++++++++++++++++++++ arch/arm/dts/rk3328-u-boot.dtsi | 6 + arch/arm/mach-rockchip/Kconfig | 2 +- arch/arm/mach-rockchip/fit_spl_optee.sh | 12 +- arch/arm/mach-rockchip/make_fit_atf.py | 2 +- configs/evb-rk3288_defconfig | 11 +- configs/evb-rk3328_defconfig | 6 +- configs/firefly-px30_defconfig | 6 +- doc/README.rockchip | 15 +- include/configs/rk3308_common.h | 2 +- include/configs/rk3328_common.h | 1 + tools/imagetool.h | 1 + tools/mkimage.c | 8 + tools/rkcommon.c | 242 ++++++++++++--- tools/rkcommon.h | 18 +- tools/rkimage.c | 2 +- tools/rksd.c | 35 +-- tools/rkspi.c | 42 +-- 20 files changed, 897 insertions(+), 132 deletions(-) create mode 100644 arch/arm/dts/px30-firefly-u-boot.dtsi create mode 100644 arch/arm/dts/px30-firefly.dts
On Thu, Jan 02, 2020 at 04:34:23PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
