Hello Stefan,
do you have some ARM Kirkwood board? I am working on some env patches, because the code in the env/ directory is a pain in the ass of old relics, and Kirkwood is the only platform using the eeprom environment driver.
I would like to ask about Kirkwood stack size.
In arch/arm/mach-kirkwood/include/mach/config.h it says
/* Kirkwood has 2k of Security SRAM, use it for SP */ #define CONFIG_SYS_INIT_SP_ADDR 0xC8012000
So if I understand correctly, Kirkwood has only 2k of init stack.
But the env_eeprom_load() method in env/eeprom.c allocates a CONFIG_ENV_SIZE bytes long array for environment, and CONFIG_ENV_SIZE is 2k.
Is the init stack changed to another stack before environment is loaded? I couldn't find code which would do that. As far as I am able to determine, this 2k long init stack is used, and this means that the code in env/eeprom.c is wrong, since it allocates below stack space.
Maybe no one used newer U-Boot on Kirkwood for a long time and this was not noticed? Should we remove support for Kirkwood?
Marek
Hi Marek,
On 28.10.21 00:07, Marek Behún wrote:
Hello Stefan,
No, I don't have of them here. Sorry.
As you have noticed, Tony is actively working on Kirkwood support lately.
Thanks, Stefan
Marek Behún
Stefan Roese
