[U-Boot-Users] [PATCH v2] FSL: Fix common EEPROM_data structure definition
- Fix EEPROM_data structure definition according to System EEPROM Data Format. - Read MAC addresses from EEPROM to ethXaddr before saving ethXaddr to bd->bi_ethaddr.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com ---
This patch was only tested on MPC8641HPCN board, but it is supposed to work for all NXID boards. Please help to verify if possible.
board/freescale/common/sys_eeprom.c | 112 ++++++++++++++++++++++------------- common/cmd_mac.c | 4 +- lib_ppc/board.c | 9 ++- 3 files changed, 78 insertions(+), 47 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 7bc663b..606fb3e 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -29,16 +29,19 @@
#ifdef CFG_ID_EEPROM typedef struct { - unsigned char id[4]; /* 0x0000 - 0x0003 */ - unsigned char sn[12]; /* 0x0004 - 0x000F */ - unsigned char errata[5]; /* 0x0010 - 0x0014 */ - unsigned char date[7]; /* 0x0015 - 0x001a */ - unsigned char res_1[37]; /* 0x001b - 0x003f */ - unsigned char tab_size; /* 0x0040 */ - unsigned char tab_flag; /* 0x0041 */ - unsigned char mac[8][6]; /* 0x0042 - 0x0071 */ - unsigned char res_2[126]; /* 0x0072 - 0x00ef */ - unsigned int crc; /* 0x00f0 - 0x00f3 crc32 checksum */ + u8 id[4]; /* 0x0000 - 0x0003 EEPROM Tag */ + u8 sn[12]; /* 0x0004 - 0x000F Serial Number */ + u8 errata[5]; /* 0x0010 - 0x0014 Errata Level */ + u8 date[6]; /* 0x0015 - 0x001a Build Date */ + u8 res_0; /* 0x001b Reserved */ + u8 version[4]; /* 0x001c - 0x001f Version */ + u8 tempcal[8]; /* 0x0020 - 0x0027 Temperature Calibration Factors*/ + u8 tempcalsys[2]; /* 0x0028 - 0x0029 System Temperature Calibration Factors*/ + u8 res_1[22]; /* 0x0020 - 0x003f Reserved */ + u8 mac_size; /* 0x0040 Mac table size */ + u8 mac_flag; /* 0x0041 Mac table flags */ + u8 mac[8][6]; /* 0x0042 - 0x0071 Mac addresses */ + u32 crc; /* 0x0072 crc32 checksum */ } EEPROM_data;
static EEPROM_data mac_data; @@ -46,28 +49,57 @@ static EEPROM_data mac_data; int mac_show(void) { int i; + u8 mac_size; unsigned char ethaddr[8][18]; + unsigned char enetvar[32]; + + /* Show EEPROM tagID, + * always the four characters 'NXID'. + */ + printf("ID "); + for (i = 0; i < 4; i++) + printf("%c", mac_data.id[i]); + printf("\n"); + + /* Show Serial number, + * 0 to 11 charaters of errata information. + */ + printf("SN "); + for (i = 0; i < 12; i++) + printf("%c", mac_data.sn[i]); + printf("\n");
- printf("ID %c%c%c%c\n", - mac_data.id[0], - mac_data.id[1], - mac_data.id[2], - mac_data.id[3]); - printf("Errata %c%c%c%c%c\n", - mac_data.errata[0], - mac_data.errata[1], - mac_data.errata[2], - mac_data.errata[3], - mac_data.errata[4]); - printf("Date %c%c%c%c%c%c%c\n", + /* Show Errata Level, + * 0 to 4 characters of errata information. + */ + printf("Errata "); + for (i = 0; i < 5; i++) + printf("%c", mac_data.errata[i]); + printf("\n"); + + /* Show Build Date, + * BCD date values, as YYMMDDhhmmss. + */ + printf("Date 20%02x/%02x/%02x %02x:%02x:%02x\n", mac_data.date[0], mac_data.date[1], mac_data.date[2], mac_data.date[3], mac_data.date[4], - mac_data.date[5], - mac_data.date[6]); - for (i = 0; i < 8; i++) { + mac_data.date[5]); + + /* Show MAC table size, + * Value from 0 to 7 indicating how many MAC + * addresses are stored in the system EEPROM. + */ + if((mac_data.mac_size > 0) && (mac_data.mac_size <= 8)) + mac_size = mac_data.mac_size; + else + mac_size = 8; /* Set the max size */ + printf("MACSIZE %x\n", mac_size); + + /* Show Mac addresses */ + for (i = 0; i < mac_size; i++) { sprintf((char *)ethaddr[i], "%02x:%02x:%02x:%02x:%02x:%02x", mac_data.mac[i][0], @@ -77,12 +109,12 @@ int mac_show(void) mac_data.mac[i][4], mac_data.mac[i][5]); printf("MAC %d %s\n", i, ethaddr[i]); - }
- setenv("ethaddr", (char *)ethaddr[0]); - setenv("eth1addr", (char *)ethaddr[1]); - setenv("eth2addr", (char *)ethaddr[2]); - setenv("eth3addr", (char *)ethaddr[3]); + sprintf((char *)enetvar, + i ? "eth%daddr" : "ethaddr", i); + setenv((char *)enetvar, (char *)ethaddr[i]); + + }
return 0; } @@ -121,17 +153,14 @@ int mac_prog(void) unsigned char dev = ID_EEPROM_ADDR, *ptr; unsigned char *eeprom_data = (unsigned char *)(&mac_data);
- for (i = 0; i < sizeof(mac_data.res_1); i++) - mac_data.res_1[i] = 0; - for (i = 0; i < sizeof(mac_data.res_2); i++) - mac_data.res_2[i] = 0; + mac_data.res_0 = 0; + memset((void *)mac_data.res_1, 0, sizeof(mac_data.res_1)); + length = sizeof(EEPROM_data); crc = crc32(crc, eeprom_data, length - 4); mac_data.crc = crc; for (i = 0, ptr = eeprom_data; i < length; i += 8, ptr += 8) { - ret = - i2c_write(dev, i, 1, ptr, - (length - i) < 8 ? (length - i) : 8); + ret = i2c_write(dev, i, 1, ptr, min((length - i),8)); udelay(5000); /* 5ms write cycle timing */ if (ret) break; @@ -180,12 +209,13 @@ int do_mac(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) } break; case 'd': /* date */ - for (i = 0; i < 7; i++) { - mac_data.date[i] = argv[2][i]; + mac_val = simple_strtoull(argv[2], NULL, 16); + for (i = 0; i < 6; i++) { + mac_data.date[i] = (mac_val >> (40 - 8 * i)); } break; - case 'p': /* number of ports */ - mac_data.tab_size = + case 'p': /* mac table size */ + mac_data.mac_size = (unsigned char)simple_strtoul(argv[2], NULL, 16); break; case '0': /* mac 0 */ diff --git a/common/cmd_mac.c b/common/cmd_mac.c index 0add432..faed8f7 100644 --- a/common/cmd_mac.c +++ b/common/cmd_mac.c @@ -33,7 +33,7 @@ U_BOOT_CMD( "mac - display and program the system ID and MAC addresses in EEPROM\n", "[read|save|id|num|errata|date|ports|0|1|2|3|4|5|6|7]\n" "read\n" - " - show content of mac\n" + " - show content of EEPROM\n" "mac save\n" " - save to the EEPROM\n" "mac id\n" @@ -43,7 +43,7 @@ U_BOOT_CMD( "mac errata\n" " - program errata data\n" "mac date\n" - " - program data date\n" + " - program date\n" "mac ports\n" " - program the number of ports\n" "mac 0\n" diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 9aa67f9..68b652a 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -832,6 +832,11 @@ void board_init_r (gd_t *id, ulong dest_addr) #if defined(CONFIG_SC3) sc3_read_eeprom(); #endif + +#ifdef CFG_ID_EEPROM + mac_read_from_eeprom(); +#endif + s = getenv ("ethaddr"); #if defined (CONFIG_MBX) || \ defined (CONFIG_RPXCLASSIC) || \ @@ -899,10 +904,6 @@ void board_init_r (gd_t *id, ulong dest_addr) } #endif
-#ifdef CFG_ID_EEPROM - mac_read_from_eeprom(); -#endif - #if defined(CONFIG_TQM8xxL) || defined(CONFIG_TQM8260) || \ defined(CONFIG_TQM8272) || \ defined(CONFIG_CCM) || defined(CONFIG_KUP4K) || \
Jon Loeliger
