[U-Boot] Please pull u-boot-mpc85xx master
Tom,
The following changes since commit 44afdc4a12b9f6f48338e7975e4f08cfe90dba74:
Merge branch 'master' of git://git.denx.de/u-boot-net (2016-10-13 13:38:49 -0400)
git://git.denx.de/u-boot-mpc85xx.git
for you to fetch changes up to a9320c495ef938cb96f0862dca7cccc9e899e4fa:
arch: powerpc: Remove unused dts frequency fixup for lbc_clk (2016-10-14 10:23:11 -0700)
---------------------------------------------------------------- Prabhakar Kushwaha (1): arch: powerpc: Remove unused dts frequency fixup for lbc_clk
Zhao Qiang (2): Txxx/RCW: Split unified RCW to RCWs for sd, spi and nand. pbl: use "wait" command instead of "flush" command
arch/powerpc/cpu/mpc85xx/fdt.c | 4 -- arch/powerpc/cpu/mpc86xx/fdt.c | 7 -- .../t102xqds/{t1024_rcw.cfg => t1024_nand_rcw.cfg} | 0 board/freescale/t102xqds/t1024_sd_rcw.cfg | 10 +++ board/freescale/t102xqds/t1024_spi_rcw.cfg | 10 +++ .../t102xrdb/{t1023_rcw.cfg => t1023_nand_rcw.cfg} | 0 board/freescale/t102xrdb/t1023_sd_rcw.cfg | 8 +++ board/freescale/t102xrdb/t1023_spi_rcw.cfg | 8 +++ .../t102xrdb/{t1024_rcw.cfg => t1024_nand_rcw.cfg} | 0 board/freescale/t102xrdb/t1024_sd_rcw.cfg | 8 +++ board/freescale/t102xrdb/t1024_spi_rcw.cfg | 8 +++ .../t104xrdb/{t1040_rcw.cfg => t1040_nand_rcw.cfg} | 0 board/freescale/t104xrdb/t1040_sd_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1040_spi_rcw.cfg | 7 ++ .../{t1040d4_rcw.cfg => t1040d4_nand_rcw.cfg} | 0 board/freescale/t104xrdb/t1040d4_sd_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1040d4_spi_rcw.cfg | 7 ++ .../t104xrdb/{t1042_rcw.cfg => t1042_nand_rcw.cfg} | 0 .../{t1042_pi_rcw.cfg => t1042_pi_nand_rcw.cfg} | 0 board/freescale/t104xrdb/t1042_pi_sd_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1042_pi_spi_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1042_sd_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1042_spi_rcw.cfg | 7 ++ .../{t1042d4_rcw.cfg => t1042d4_nand_rcw.cfg} | 0 board/freescale/t104xrdb/t1042d4_sd_rcw.cfg | 7 ++ board/freescale/t104xrdb/t1042d4_spi_rcw.cfg | 7 ++ .../t208xqds/{t2080_rcw.cfg => t2080_nand_rcw.cfg} | 0 board/freescale/t208xqds/t2080_sd_rcw.cfg | 16 +++++ board/freescale/t208xqds/t2080_spi_rcw.cfg | 16 +++++ .../t208xqds/{t2081_rcw.cfg => t2081_nand_rcw.cfg} | 0 board/freescale/t208xqds/t2081_sd_rcw.cfg | 8 +++ board/freescale/t208xqds/t2081_spi_rcw.cfg | 8 +++ board/freescale/t208xqds/t208x_pbi.cfg | 3 +- .../t208xrdb/{t2080_rcw.cfg => t2080_nand_rcw.cfg} | 0 board/freescale/t208xrdb/t2080_pbi.cfg | 3 +- board/freescale/t208xrdb/t2080_sd_rcw.cfg | 19 ++++++ board/freescale/t208xrdb/t2080_spi_rcw.cfg | 19 ++++++ .../t4qds/{t4_rcw.cfg => t4_nand_rcw.cfg} | 2 +- board/freescale/t4qds/t4_pbi.cfg | 3 +- board/freescale/t4qds/t4_sd_rcw.cfg | 7 ++ board/freescale/t4rdb/t4_pbi.cfg | 3 +- .../freescale/t4rdb/{t4_rcw.cfg => t4_sd_rcw.cfg} | 2 +- include/configs/T102xQDS.h | 4 +- include/configs/T102xRDB.h | 20 ++++-- include/configs/T104xRDB.h | 78 +++++++++++++++++----- include/configs/T208xQDS.h | 20 ++++-- include/configs/T208xRDB.h | 4 +- include/configs/T4240QDS.h | 3 +- include/configs/T4240RDB.h | 2 +- tools/pblimage.c | 2 +- 50 files changed, 321 insertions(+), 54 deletions(-) rename board/freescale/t102xqds/{t1024_rcw.cfg => t1024_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t102xqds/t1024_sd_rcw.cfg create mode 100644 board/freescale/t102xqds/t1024_spi_rcw.cfg rename board/freescale/t102xrdb/{t1023_rcw.cfg => t1023_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t102xrdb/t1023_sd_rcw.cfg create mode 100644 board/freescale/t102xrdb/t1023_spi_rcw.cfg rename board/freescale/t102xrdb/{t1024_rcw.cfg => t1024_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t102xrdb/t1024_sd_rcw.cfg create mode 100644 board/freescale/t102xrdb/t1024_spi_rcw.cfg rename board/freescale/t104xrdb/{t1040_rcw.cfg => t1040_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t104xrdb/t1040_sd_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1040_spi_rcw.cfg rename board/freescale/t104xrdb/{t1040d4_rcw.cfg => t1040d4_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t104xrdb/t1040d4_sd_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1040d4_spi_rcw.cfg rename board/freescale/t104xrdb/{t1042_rcw.cfg => t1042_nand_rcw.cfg} (100%) rename board/freescale/t104xrdb/{t1042_pi_rcw.cfg => t1042_pi_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t104xrdb/t1042_pi_sd_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1042_pi_spi_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1042_sd_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1042_spi_rcw.cfg rename board/freescale/t104xrdb/{t1042d4_rcw.cfg => t1042d4_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t104xrdb/t1042d4_sd_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1042d4_spi_rcw.cfg rename board/freescale/t208xqds/{t2080_rcw.cfg => t2080_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t208xqds/t2080_sd_rcw.cfg create mode 100644 board/freescale/t208xqds/t2080_spi_rcw.cfg rename board/freescale/t208xqds/{t2081_rcw.cfg => t2081_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t208xqds/t2081_sd_rcw.cfg create mode 100644 board/freescale/t208xqds/t2081_spi_rcw.cfg rename board/freescale/t208xrdb/{t2080_rcw.cfg => t2080_nand_rcw.cfg} (100%) create mode 100644 board/freescale/t208xrdb/t2080_sd_rcw.cfg create mode 100644 board/freescale/t208xrdb/t2080_spi_rcw.cfg rename board/freescale/t4qds/{t4_rcw.cfg => t4_nand_rcw.cfg} (83%) create mode 100644 board/freescale/t4qds/t4_sd_rcw.cfg rename board/freescale/t4rdb/{t4_rcw.cfg => t4_sd_rcw.cfg} (83%)
Thanks.
York
On Sat, Oct 15, 2016 at 05:02:03PM +0000, york sun wrote:
Tom,
york sun
