[PATCH v2 0/8] A small set of arm cleanups
This patch series presents a set of cleanups I stumbled across while looking at some arm-related code.
A long time ago there was an effort to follow the Linux kernel's convention of putting SoC-specific code in arch/$(ARCH)/mach-$(SOC) instead of the previous location of arch/$(ARCH)/cpu/$(CPU)/$(SOC). For some reason this didn't occur with code for NXP's LPC32xx SoC. Therefore the first patch performs this move.
While moving the code, I noticed that years of editing had caused a list in arch/arm/Makefile to not be sorted alphanumerically anymore, despite the comment's request to do so. Therefore the second patch re-orders the list to put it back in alphanumerical order.
While sorting the above-mentioned list, I noticed that there were 4 symbol names that were not following the convention of other symbols: CONFIG_KIRKWOOD, CONFIG_ORION5X, CONFIG_TEGRA, and CONFIG_STM32. These symbols should have the pattern: CONFIG_ARCH_<machine>. Therefore more patches were created to fix these symbol names.
While renaming the CONFIG_ARCH_ORION5X symbol I noticed that this SoC had code both in arch/$(ARCH)/cpu/$(CPU)/$(SOC) and arch/$(ARCH)/mach-$(SOC), so there's a patch to complete this move.
Also, I found a typo, so another patch.
Changes in v2: - Update the commit message to fix the error identified by checkpatch.pl, namely to fix the formatting used to reference a prior commit. - Improve the wording of the commit message, mostly to specify that the sorting was done assuming all symbols had "ARCH_" in the middle. - Update patch to work on latest master; the location where the SPL linker script is specified has changed. - Add Chris Packham's r-b - Added a cover letter. - In the original series I only renamed 2 of the 4 symbols that were missing the "ARCH_" string (CONFIG_ORION5X and CONFIG_KIRKWOOD), since those were the only 2 with TODOs attached to them. As part of v2 I also converted CONFIG_TEGRA and CONFIG_STM32
Trevor Woerner (8): arm: lpc32xx: move SoC to mach-lpc32xx arch/arm/Makefile: sort machine names rename symbol: CONFIG_ORION5X -> CONFIG_ARCH_ORION5X arm: orion5x: finish moving SoC to mach-orion5x rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRA rename symbol: CONFIG_STM32 -> CONFIG_ARCH_STM32 drivers/reset/Kconfig: fix typo
Kconfig | 2 +- Makefile | 4 ++-- arch/arm/Kconfig | 10 ++++---- arch/arm/Makefile | 24 +++++++++---------- arch/arm/cpu/arm720t/interrupts.c | 2 +- arch/arm/cpu/arm926ejs/Makefile | 1 - arch/arm/cpu/armv7/Kconfig | 2 +- arch/arm/dts/Makefile | 4 ++-- arch/arm/mach-kirkwood/Kconfig | 2 +- .../lpc32xx => mach-lpc32xx}/Kconfig | 0 .../lpc32xx => mach-lpc32xx}/Makefile | 0 .../arm926ejs/lpc32xx => mach-lpc32xx}/clk.c | 0 .../arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c | 0 .../lpc32xx => mach-lpc32xx}/devices.c | 0 .../arm926ejs/lpc32xx => mach-lpc32xx}/dram.c | 0 .../lpc32xx => mach-lpc32xx}/lowlevel_init.S | 0 .../lpc32xx => mach-lpc32xx}/timer.c | 0 arch/arm/mach-mvebu/Makefile | 6 ++--- arch/arm/mach-mvebu/mbus.c | 6 ++--- arch/arm/mach-orion5x/Kconfig | 2 +- .../orion5x => mach-orion5x}/u-boot-spl.lds | 0 arch/arm/mach-stm32/Kconfig | 2 +- arch/arm/mach-tegra/Kconfig | 2 +- board/keymile/Kconfig | 12 +++++----- common/spl/Kconfig | 4 ++-- config.mk | 2 +- configs/SBx81LIFKW_defconfig | 2 +- configs/SBx81LIFXCAT_defconfig | 2 +- configs/apalis-tk1_defconfig | 2 +- configs/apalis_t30_defconfig | 2 +- configs/beaver_defconfig | 2 +- configs/cardhu_defconfig | 2 +- configs/cei-tk1-som_defconfig | 2 +- configs/colibri_t20_defconfig | 2 +- configs/colibri_t30_defconfig | 2 +- configs/d2net_v2_defconfig | 2 +- configs/dalmore_defconfig | 2 +- configs/db-88f6281-bp-nand_defconfig | 2 +- configs/db-88f6281-bp-spi_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/e2220-1170_defconfig | 2 +- configs/edminiv2_defconfig | 4 ++-- configs/goflexhome_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/harmony_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/inetspace_v2_defconfig | 2 +- configs/jetson-tk1_defconfig | 2 +- configs/km_kirkwood_128m16_defconfig | 2 +- configs/km_kirkwood_defconfig | 2 +- configs/km_kirkwood_pci_defconfig | 2 +- configs/kmcoge5un_defconfig | 2 +- configs/kmnusa_defconfig | 2 +- configs/kmsuse2_defconfig | 2 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/medcom-wide_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/nyan-big_defconfig | 2 +- configs/openrd_base_defconfig | 2 +- configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- configs/p2371-0000_defconfig | 2 +- configs/p2371-2180_defconfig | 2 +- configs/p2571_defconfig | 2 +- configs/p2771-0000-000_defconfig | 2 +- configs/p2771-0000-500_defconfig | 2 +- configs/p3450-0000_defconfig | 2 +- configs/paz00_defconfig | 2 +- configs/plutux_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/seaboard_defconfig | 2 +- configs/sheevaplug_defconfig | 2 +- configs/stm32f429-discovery_defconfig | 2 +- configs/stm32f429-evaluation_defconfig | 2 +- configs/stm32f469-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 2 +- configs/stm32f769-disco_defconfig | 2 +- configs/stm32h743-disco_defconfig | 2 +- configs/stm32h743-eval_defconfig | 2 +- configs/tec-ng_defconfig | 2 +- configs/tec_defconfig | 2 +- configs/trimslice_defconfig | 2 +- configs/venice2_defconfig | 2 +- configs/ventana_defconfig | 2 +- disk/Kconfig | 4 ++-- drivers/ata/mvsata_ide.c | 4 ++-- drivers/ata/sata_mv.c | 2 +- drivers/gpio/Kconfig | 2 +- drivers/i2c/Kconfig | 2 +- drivers/i2c/mvtwsi.c | 6 ++--- drivers/mailbox/Kconfig | 2 +- drivers/misc/Kconfig | 2 +- drivers/mmc/Kconfig | 2 +- drivers/net/Kconfig | 2 +- drivers/net/mvgbe.c | 4 ++-- drivers/pci/Kconfig | 2 +- drivers/reset/Kconfig | 4 ++-- drivers/spi/kirkwood_spi.c | 10 ++++---- drivers/usb/host/Kconfig | 4 ++-- drivers/usb/host/ehci-marvell.c | 4 ++-- drivers/video/Kconfig | 2 +- include/serial.h | 2 +- tools/Makefile | 4 ++-- 114 files changed, 144 insertions(+), 147 deletions(-) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Kconfig (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Makefile (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/clk.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/devices.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/dram.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/lowlevel_init.S (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/timer.c (100%) rename arch/arm/{cpu/arm926ejs/orion5x => mach-orion5x}/u-boot-spl.lds (100%)
Following the example of most other SoCs in arch/$(ARCH)/cpu/$(CPU)/$(SOC) move the lpc32xx code from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpc32xx.
Following the checklist from commit 01f14456306c ("ARM: prepare for moving SoC sources into mach-*"):
[1] move files from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpx32xx [2] add machine entry to arch/arm/Makefile [3] remove "obj-y += ..." from arch/arm/cpu/arm926ejs/Makefile [4] fix the Kconfig file path in arch/arm/Kconfig [5] (no MAINTAINERS update)
Signed-off-by: Trevor Woerner twoerner@gmail.com
Changes in v2: Update the commit message to fix the error identified by checkpatch.pl, namely to fix the formatting used to reference a prior commit.
arch/arm/Kconfig | 2 +- arch/arm/Makefile | 1 + arch/arm/cpu/arm926ejs/Makefile | 1 - arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Kconfig | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Makefile | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/clk.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/devices.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/dram.c | 0 .../arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/lowlevel_init.S | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/timer.c | 0 11 files changed, 2 insertions(+), 2 deletions(-) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Kconfig (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Makefile (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/clk.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/devices.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/dram.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/lowlevel_init.S (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/timer.c (100%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index dd41090fc6..8567c15c26 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1733,7 +1733,7 @@ source "arch/arm/mach-keystone/Kconfig"
source "arch/arm/mach-kirkwood/Kconfig"
-source "arch/arm/cpu/arm926ejs/lpc32xx/Kconfig" +source "arch/arm/mach-lpc32xx/Kconfig"
source "arch/arm/mach-mvebu/Kconfig"
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index e25bb0e594..33bb8923bf 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -62,6 +62,7 @@ machine-$(CONFIG_ARCH_K3) += k3 machine-$(CONFIG_ARCH_KEYSTONE) += keystone # TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD machine-$(CONFIG_KIRKWOOD) += kirkwood +machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index b051025bb0..af63d5cc5e 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -13,7 +13,6 @@ endif endif
obj-$(CONFIG_ARMADA100) += armada100/ -obj-$(if $(filter lpc32xx,$(SOC)),y) += lpc32xx/ obj-$(CONFIG_MX25) += mx25/ obj-$(CONFIG_MX27) += mx27/ obj-$(if $(filter mxs,$(SOC)),y) += mxs/ diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Kconfig b/arch/arm/mach-lpc32xx/Kconfig similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/Kconfig rename to arch/arm/mach-lpc32xx/Kconfig diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/mach-lpc32xx/Makefile similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/Makefile rename to arch/arm/mach-lpc32xx/Makefile diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/clk.c b/arch/arm/mach-lpc32xx/clk.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/clk.c rename to arch/arm/mach-lpc32xx/clk.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c b/arch/arm/mach-lpc32xx/cpu.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/cpu.c rename to arch/arm/mach-lpc32xx/cpu.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/mach-lpc32xx/devices.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/devices.c rename to arch/arm/mach-lpc32xx/devices.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/dram.c b/arch/arm/mach-lpc32xx/dram.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/dram.c rename to arch/arm/mach-lpc32xx/dram.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S b/arch/arm/mach-lpc32xx/lowlevel_init.S similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S rename to arch/arm/mach-lpc32xx/lowlevel_init.S diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/timer.c b/arch/arm/mach-lpc32xx/timer.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/timer.c rename to arch/arm/mach-lpc32xx/timer.c
The comment immediately above the block of machine directory names implored users to keep the macro names sorted, but, alas, this is no longer the case.
Put the list of machine directory names back in alphanumerical order by CONFIG_* macro name, as the comment asks. Sort all the symbols as though they all followed the convention of having the string "ARCH_" in the middle of their definitions.
Changes in v2: Improve the wording of the commit message, mostly to specify that the sorting was done assuming all symbols had "ARCH_" in the middle.
arch/arm/Makefile | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 33bb8923bf..5d32dec29c 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -66,25 +66,25 @@ machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu -# TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA +machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X machine-$(CONFIG_ORION5X) += orion5x -machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 machine-$(CONFIG_ARCH_OWL) += owl +machine-$(CONFIG_ARCH_RMOBILE) += rmobile +machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx -machine-$(CONFIG_ARCH_SUNXI) += sunxi machine-$(CONFIG_ARCH_SNAPDRAGON) += snapdragon machine-$(CONFIG_ARCH_SOCFPGA) += socfpga -machine-$(CONFIG_ARCH_RMOBILE) += rmobile -machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_STM32) += stm32 machine-$(CONFIG_ARCH_STM32MP) += stm32mp +machine-$(CONFIG_ARCH_SUNXI) += sunxi +# TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA machine-$(CONFIG_TEGRA) += tegra machine-$(CONFIG_ARCH_U8500) += u8500 machine-$(CONFIG_ARCH_UNIPHIER) += uniphier +machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQ) += zynq machine-$(CONFIG_ARCH_ZYNQMP) += zynqmp -machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQMP_R5) += zynqmp-r5
machdirs := $(patsubst %,arch/arm/mach-%/,$(machine-y))
Have this symbol follow the pattern of all other such symbols. This patch removes a TODO from the code.
Changes in v2: Update patch to work on latest master; the location where the SPL linker script is specified has changed.
arch/arm/Kconfig | 2 +- arch/arm/Makefile | 3 +-- arch/arm/mach-orion5x/Kconfig | 2 +- configs/edminiv2_defconfig | 2 +- drivers/ata/mvsata_ide.c | 2 +- drivers/i2c/mvtwsi.c | 2 +- drivers/net/Kconfig | 2 +- drivers/net/mvgbe.c | 2 +- drivers/usb/host/Kconfig | 2 +- drivers/usb/host/ehci-marvell.c | 2 +- 10 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8567c15c26..5b77b0d613 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -547,7 +547,7 @@ config TARGET_APF27 select CPU_ARM926EJS select SUPPORT_SPL
-config ORION5X +config ARCH_ORION5X bool "Marvell Orion" select CPU_ARM926EJS
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 5d32dec29c..2b44ffb493 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -67,8 +67,7 @@ machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 -# TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X -machine-$(CONFIG_ORION5X) += orion5x +machine-$(CONFIG_ARCH_ORION5X) += orion5x machine-$(CONFIG_ARCH_OWL) += owl machine-$(CONFIG_ARCH_RMOBILE) += rmobile machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip diff --git a/arch/arm/mach-orion5x/Kconfig b/arch/arm/mach-orion5x/Kconfig index 7644b8dc85..5baa6fb935 100644 --- a/arch/arm/mach-orion5x/Kconfig +++ b/arch/arm/mach-orion5x/Kconfig @@ -1,4 +1,4 @@ -if ORION5X +if ARCH_ORION5X
choice prompt "Marvell Orion board select" diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index b9a68a9263..d06f83db04 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y -CONFIG_ORION5X=y +CONFIG_ARCH_ORION5X=y CONFIG_SPL_LDSCRIPT="arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/drivers/ata/mvsata_ide.c b/drivers/ata/mvsata_ide.c index 38181235af..9ac16555d6 100644 --- a/drivers/ata/mvsata_ide.c +++ b/drivers/ata/mvsata_ide.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h>
-#if defined(CONFIG_ORION5X) +#if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 382cf4b304..77fe35a42b 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; */
#ifndef CONFIG_DM_I2C -#if defined(CONFIG_ORION5X) +#if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #elif (defined(CONFIG_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) #include <asm/arch/soc.h> diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 4d1013c984..3fd3e72219 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -303,7 +303,7 @@ config FSLDMAFEC
config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" - depends on KIRKWOOD || ORION5X + depends on KIRKWOOD || ARCH_ORION5X select PHYLIB if DM_ETH help This driver supports the network interface units in the diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 037e59ec6e..b0b8d349a8 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -26,7 +26,7 @@
#if defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> -#elif defined(CONFIG_ORION5X) +#elif defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #endif
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 94ac969058..ee9d6f2a1b 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -129,7 +129,7 @@ config USB_EHCI_ATMEL
config USB_EHCI_MARVELL bool "Support for Marvell on-chip EHCI USB controller" - depends on ARCH_MVEBU || KIRKWOOD || ORION5X + depends on ARCH_MVEBU || KIRKWOOD || ARCH_ORION5X default y ---help--- Enables support for the on-chip EHCI controller on MVEBU SoCs. diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 8efe6b63b9..3b10cdfc58 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -15,7 +15,7 @@
The SPL linker script had been left in arch/$(ARCH)/cpu/$(CPU)/$(SOC); therefore move it to the already-established arch/$(ARCH)/mach-$(SOC) location.
arch/arm/{cpu/arm926ejs/orion5x => mach-orion5x}/u-boot-spl.lds | 0 configs/edminiv2_defconfig | 2 +- 2 files changed, 1 insertion(+), 1 deletion(-) rename arch/arm/{cpu/arm926ejs/orion5x => mach-orion5x}/u-boot-spl.lds (100%)
diff --git a/arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds b/arch/arm/mach-orion5x/u-boot-spl.lds similarity index 100% rename from arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds rename to arch/arm/mach-orion5x/u-boot-spl.lds diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index d06f83db04..9a9d9c58d7 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_ORION5X=y -CONFIG_SPL_LDSCRIPT="arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds" +CONFIG_SPL_LDSCRIPT="arch/arm/mach-orion5x/u-boot-spl.lds" CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code.
Reviewed-by: Chris Packham judge.packham@gmail.com Signed-off-by: Trevor Woerner twoerner@gmail.com
Changes in v2: Add Chris Packham's r-b
Kconfig | 2 +- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 3 +-- arch/arm/dts/Makefile | 2 +- arch/arm/mach-kirkwood/Kconfig | 2 +- arch/arm/mach-mvebu/Makefile | 6 +++--- arch/arm/mach-mvebu/mbus.c | 6 +++--- board/keymile/Kconfig | 12 ++++++------ configs/SBx81LIFKW_defconfig | 2 +- configs/SBx81LIFXCAT_defconfig | 2 +- configs/d2net_v2_defconfig | 2 +- configs/db-88f6281-bp-nand_defconfig | 2 +- configs/db-88f6281-bp-spi_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/goflexhome_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/inetspace_v2_defconfig | 2 +- configs/km_kirkwood_128m16_defconfig | 2 +- configs/km_kirkwood_defconfig | 2 +- configs/km_kirkwood_pci_defconfig | 2 +- configs/kmcoge5un_defconfig | 2 +- configs/kmnusa_defconfig | 2 +- configs/kmsuse2_defconfig | 2 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/openrd_base_defconfig | 2 +- configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/sheevaplug_defconfig | 2 +- drivers/ata/mvsata_ide.c | 2 +- drivers/ata/sata_mv.c | 2 +- drivers/i2c/mvtwsi.c | 4 ++-- drivers/net/Kconfig | 2 +- drivers/net/mvgbe.c | 2 +- drivers/spi/kirkwood_spi.c | 10 +++++----- drivers/usb/host/Kconfig | 2 +- drivers/usb/host/ehci-marvell.c | 2 +- tools/Makefile | 4 ++-- 51 files changed, 66 insertions(+), 67 deletions(-)
diff --git a/Kconfig b/Kconfig index 1b0b6999d8..ca5ed9431d 100644 --- a/Kconfig +++ b/Kconfig @@ -254,7 +254,7 @@ config BUILD_TARGET default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ ARCH_SUNXI || RISCV || ARCH_ZYNQMP) - default "u-boot.kwb" if KIRKWOOD + default "u-boot.kwb" if ARCH_KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL help diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5b77b0d613..6bc1776cfd 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -524,7 +524,7 @@ config ARCH_DAVINCI help Support for TI's DaVinci platform.
-config KIRKWOOD +config ARCH_KIRKWOOD bool "Marvell Kirkwood" select ARCH_MISC_INIT select BOARD_EARLY_INIT_F diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 2b44ffb493..9b3ca9772c 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -60,8 +60,7 @@ machine-$(CONFIG_ARCH_EXYNOS) += exynos machine-$(CONFIG_ARCH_HIGHBANK) += highbank machine-$(CONFIG_ARCH_K3) += k3 machine-$(CONFIG_ARCH_KEYSTONE) += keystone -# TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD -machine-$(CONFIG_KIRKWOOD) += kirkwood +machine-$(CONFIG_ARCH_KIRKWOOD) += kirkwood machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6d1e8668e7..20d3adc5d4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -34,7 +34,7 @@ dtb-$(CONFIG_ARCH_DAVINCI) += \ da850-lcdk.dtb \ da850-lego-ev3.dtb
-dtb-$(CONFIG_KIRKWOOD) += \ +dtb-$(CONFIG_ARCH_KIRKWOOD) += \ kirkwood-atl-sbx81lifkw.dtb \ kirkwood-atl-sbx81lifxcat.dtb \ kirkwood-blackarmor-nas220.dtb \ diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index 2f68092f82..ae44cb665e 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -1,4 +1,4 @@ -if KIRKWOOD +if ARCH_KIRKWOOD
choice prompt "Marvell Kirkwood board select" diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index b73952044d..7e9c206ed6 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -10,14 +10,14 @@ obj-y += arm64-common.o
else # CONFIG_ARM64
-ifdef CONFIG_KIRKWOOD +ifdef CONFIG_ARCH_KIRKWOOD
obj-y = dram.o obj-y += gpio.o obj-y += mbus.o obj-y += timer.o
-else # CONFIG_KIRKWOOD +else # CONFIG_ARCH_KIRKWOOD
obj-y = cpu.o obj-y += dram.o @@ -73,5 +73,5 @@ obj-$(CONFIG_SPL_BUILD) += lowlevel_spl.o obj-$(CONFIG_ARMADA_38X) += serdes/a38x/ obj-$(CONFIG_ARMADA_XP) += serdes/axp/
-endif # CONFIG_KIRKWOOD +endif # CONFIG_ARCH_KIRKWOOD endif # CONFIG_ARM64 diff --git a/arch/arm/mach-mvebu/mbus.c b/arch/arm/mach-mvebu/mbus.c index a95db5e5c3..39bd200c83 100644 --- a/arch/arm/mach-mvebu/mbus.c +++ b/arch/arm/mach-mvebu/mbus.c @@ -411,7 +411,7 @@ int mvebu_mbus_del_window(phys_addr_t base, size_t size) return 0; }
-#ifndef CONFIG_KIRKWOOD +#ifndef CONFIG_ARCH_KIRKWOOD static void mvebu_mbus_get_lowest_base(struct mvebu_mbus_state *mbus, phys_addr_t *base) { @@ -479,7 +479,7 @@ int mbus_dt_setup_win(struct mvebu_mbus_state *mbus, return -ENOMEM; }
-#ifndef CONFIG_KIRKWOOD +#ifndef CONFIG_ARCH_KIRKWOOD /* * Re-configure the mbus bridge registers each time this function * is called. Since it may get called from the board code in @@ -497,7 +497,7 @@ int mvebu_mbus_probe(struct mbus_win windows[], int count) int ret; int i;
-#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_ARCH_KIRKWOOD) mbus_state.soc = &kirkwood_mbus_data; #endif #if defined(CONFIG_ARCH_MVEBU) diff --git a/board/keymile/Kconfig b/board/keymile/Kconfig index 7f4cad86aa..e20c017436 100644 --- a/board/keymile/Kconfig +++ b/board/keymile/Kconfig @@ -28,7 +28,7 @@ config KM_PHRAM
config KM_RESERVED_PRAM hex "Reserved RAM" - default 0x801000 if KIRKWOOD + default 0x801000 if ARCH_KIRKWOOD default 0x0 if MPC83xx default 0x1000 if MPC85xx depends on !ARCH_SOCFPGA @@ -37,7 +37,7 @@ config KM_RESERVED_PRAM
config KM_CRAMFS_ADDR hex "CRAMFS Address" - default 0x2400000 if KIRKWOOD + default 0x2400000 if ARCH_KIRKWOOD default 0xC00000 if MPC83xx default 0x2000000 if MPC85xx depends on !ARCH_SOCFPGA @@ -46,7 +46,7 @@ config KM_CRAMFS_ADDR
config KM_KERNEL_ADDR hex "Kernel Load Address" - default 0x2000000 if KIRKWOOD + default 0x2000000 if ARCH_KIRKWOOD default 0x400000 if MPC83xx default 0x1000000 if MPC85xx || ARCH_SOCFPGA help @@ -54,7 +54,7 @@ config KM_KERNEL_ADDR
config KM_FDT_ADDR hex "FDT Load Address" - default 0x23E0000 if KIRKWOOD || ARCH_SOCFPGA + default 0x23E0000 if ARCH_KIRKWOOD || ARCH_SOCFPGA default 0xB80000 if MPC83xx default 0x1F80000 if MPC85xx help @@ -74,7 +74,7 @@ config KM_DEF_NETDEV
config KM_COMMON_ETH_INIT bool "Common Ethernet Initialization" - default y if KIRKWOOD || MPC83xx + default y if ARCH_KIRKWOOD || MPC83xx default n if MPC85xx || ARCH_SOCFPGA help Use the Ethernet initialization implemented in common code, which @@ -96,7 +96,7 @@ config KM_MVEXTSW_ADDR config KM_IVM_BUS int "IVM I2C Bus" default 0 if ARCH_SOCFPGA - default 1 if KIRKWOOD || MPC85xx + default 1 if ARCH_KIRKWOOD || MPC85xx default 2 if MPC83xx help Identifier number of I2C bus, where the inventory EEPROM is connected to. diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 379a4c26c2..63d1559ce9 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFKW=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index d5b73b9f72..b13657fa2d 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index eea3e0abe3..8cd8b90992 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index e7a8b406dd..54493be208 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig index ec63ffb4b7..6690971ec5 100644 --- a/configs/db-88f6281-bp-spi_defconfig +++ b/configs/db-88f6281-bp-spi_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 8457806282..e44ec51ce9 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DNS325=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 079b6652f1..fcc597d249 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DOCKSTAR=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index ebc3eb4872..9d038139df 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DREAMPLUG=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 0d7b895cc7..d22112f7e7 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DS109=y CONFIG_ENV_SIZE=0x10000 diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 97b1615c8a..9384244ebb 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GOFLEXHOME=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 2bdd78041d..8d862696ca 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GURUPLUG=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 9da976f399..fea69d32e9 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_IB62X0=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 8121867008..4281aa93bc 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_ICONNECT=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 5bae7a8819..ad0a4a3250 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index d185100f66..9bbbfd9442 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index a8374d9fc2..887893ef33 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_ENV_SIZE=0x2000 diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 7ad69e1639..81c9f697bb 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 1775273807..cce53d2837 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 3cef72cc86..3f01a58b28 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/kmsuse2_defconfig b/configs/kmsuse2_defconfig index e81a8b02fc..b77a60b239 100644 --- a/configs/kmsuse2_defconfig +++ b/configs/kmsuse2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 716aca30b1..396fa0a2bc 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_ENV_SIZE=0x10000 diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 2e760e5176..9831c56480 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_ENV_SIZE=0x10000 diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index eb7effe98f..918fd26b05 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NAS220=y CONFIG_ENV_SIZE=0x10000 diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index d334db0ae0..e4fe7b284d 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index cb00d483ce..d609a506b2 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 0317cb9555..3073a6a226 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index a87aaddb87..ae3973ff2d 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index e4e08a2e85..6e5dbfb203 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 6a1073c30b..7a864bddf3 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NSA310S=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index f575bf24e7..2551f284af 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 42f3786918..c0bf3be373 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 47189da080..ab97d66e89 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 8957a87639..e254ac0393 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_E02=y CONFIG_ENV_SIZE=0x20000 diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 723ef7bb46..d350429cad 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y -CONFIG_KIRKWOOD=y +CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_SHEEVAPLUG=y CONFIG_ENV_SIZE=0x20000 diff --git a/drivers/ata/mvsata_ide.c b/drivers/ata/mvsata_ide.c index 9ac16555d6..6bbb345f6e 100644 --- a/drivers/ata/mvsata_ide.c +++ b/drivers/ata/mvsata_ide.c @@ -10,7 +10,7 @@
#if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> -#elif defined(CONFIG_KIRKWOOD) +#elif defined(CONFIG_ARCH_KIRKWOOD) #include <asm/arch/soc.h> #elif defined(CONFIG_ARCH_MVEBU) #include <linux/mbus.h> diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index 6019ac089e..9ced9c0fa8 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -46,7 +46,7 @@ #include <linux/mbus.h>
#include <asm/arch/soc.h> -#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_ARCH_KIRKWOOD) #define SATAHC_BASE KW_SATA_BASE #else #define SATAHC_BASE MVEBU_AXP_SATA_BASE diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 77fe35a42b..d4b2031249 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR; #ifndef CONFIG_DM_I2C #if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> -#elif (defined(CONFIG_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) +#elif (defined(CONFIG_ARCH_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) #include <asm/arch/soc.h> #elif defined(CONFIG_ARCH_SUNXI) #include <asm/arch/i2c.h> @@ -821,7 +821,7 @@ static int mvtwsi_i2c_bind(struct udevice *bus) struct mvtwsi_registers *twsi = devfdt_get_addr_ptr(bus);
/* Disable the hidden slave in i2c0 of these platforms */ - if ((IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_KIRKWOOD)) + if ((IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_ARCH_KIRKWOOD)) && bus->req_seq == 0) twsi_disable_i2c_slave(twsi);
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 3fd3e72219..2c8dd93dbe 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -303,7 +303,7 @@ config FSLDMAFEC
config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" - depends on KIRKWOOD || ARCH_ORION5X + depends on ARCH_KIRKWOOD || ARCH_ORION5X select PHYLIB if DM_ETH help This driver supports the network interface units in the diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index b0b8d349a8..6d56360a20 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -24,7 +24,7 @@ #include <asm/byteorder.h> #include <asm/arch/cpu.h>
-#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_ARCH_KIRKWOOD) #include <asm/arch/soc.h> #elif defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index c725625146..38fe4143f5 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -13,7 +13,7 @@ #include <spi.h> #include <asm/io.h> #include <asm/arch/soc.h> -#ifdef CONFIG_KIRKWOOD +#ifdef CONFIG_ARCH_KIRKWOOD #include <asm/arch/mpp.h> #endif #include <asm/arch-mvebu/spi.h> @@ -98,7 +98,7 @@ static int _spi_xfer(struct kwspi_registers *reg, unsigned int bitlen, static struct kwspi_registers *spireg = (struct kwspi_registers *)MVEBU_SPI_BASE;
-#ifdef CONFIG_KIRKWOOD +#ifdef CONFIG_ARCH_KIRKWOOD static u32 cs_spi_mpp_back[2]; #endif
@@ -107,7 +107,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, { struct spi_slave *slave; u32 data; -#ifdef CONFIG_KIRKWOOD +#ifdef CONFIG_ARCH_KIRKWOOD static const u32 kwspi_mpp_config[2][2] = { { MPP0_SPI_SCn, 0 }, /* if cs == 0 */ { MPP7_SPI_SCn, 0 } /* if cs != 0 */ @@ -135,7 +135,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, writel(KWSPI_SMEMRDIRQ, &spireg->irq_cause); writel(KWSPI_IRQMASK, &spireg->irq_mask);
-#ifdef CONFIG_KIRKWOOD +#ifdef CONFIG_ARCH_KIRKWOOD /* program mpp registers to select SPI_CSn */ kirkwood_mpp_conf(kwspi_mpp_config[cs ? 1 : 0], cs_spi_mpp_back); #endif @@ -145,7 +145,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
void spi_free_slave(struct spi_slave *slave) { -#ifdef CONFIG_KIRKWOOD +#ifdef CONFIG_ARCH_KIRKWOOD kirkwood_mpp_conf(cs_spi_mpp_back, NULL); #endif free(slave); diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index ee9d6f2a1b..0d54fdad8a 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -129,7 +129,7 @@ config USB_EHCI_ATMEL
config USB_EHCI_MARVELL bool "Support for Marvell on-chip EHCI USB controller" - depends on ARCH_MVEBU || KIRKWOOD || ARCH_ORION5X + depends on ARCH_MVEBU || ARCH_KIRKWOOD || ARCH_ORION5X default y ---help--- Enables support for the on-chip EHCI controller on MVEBU SoCs. diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 3b10cdfc58..5a9bd549e3 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -13,7 +13,7 @@ #include <asm/arch/cpu.h> #include <dm.h>
-#if defined(CONFIG_KIRKWOOD) +#if defined(CONFIG_ARCH_KIRKWOOD) #include <asm/arch/soc.h> #elif defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> diff --git a/tools/Makefile b/tools/Makefile index c2b2634004..12130f6672 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -5,7 +5,7 @@
# Enable all the config-independent tools ifneq ($(HOST_TOOLS_ALL),) -CONFIG_KIRKWOOD = y +CONFIG_ARCH_KIRKWOOD = y CONFIG_LCD_LOGO = y CONFIG_CMD_LOADS = y CONFIG_CMD_NET = y @@ -204,7 +204,7 @@ ubsha1-objs := os_support.o ubsha1.o lib/sha1.o
HOSTCFLAGS_ubsha1.o := -pedantic
-hostprogs-$(CONFIG_KIRKWOOD) += kwboot +hostprogs-$(CONFIG_ARCH_KIRKWOOD) += kwboot hostprogs-$(CONFIG_ARCH_MVEBU) += kwboot hostprogs-y += proftool hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela
Signed-off-by: Trevor Woerner twoerner@gmail.com ---
Changes in v2: added
Makefile | 4 ++-- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 7 +++---- arch/arm/cpu/arm720t/interrupts.c | 2 +- arch/arm/cpu/armv7/Kconfig | 2 +- arch/arm/dts/Makefile | 2 +- arch/arm/mach-tegra/Kconfig | 2 +- common/spl/Kconfig | 4 ++-- config.mk | 2 +- configs/apalis-tk1_defconfig | 2 +- configs/apalis_t30_defconfig | 2 +- configs/beaver_defconfig | 2 +- configs/cardhu_defconfig | 2 +- configs/cei-tk1-som_defconfig | 2 +- configs/colibri_t20_defconfig | 2 +- configs/colibri_t30_defconfig | 2 +- configs/dalmore_defconfig | 2 +- configs/e2220-1170_defconfig | 2 +- configs/harmony_defconfig | 2 +- configs/jetson-tk1_defconfig | 2 +- configs/medcom-wide_defconfig | 2 +- configs/nyan-big_defconfig | 2 +- configs/p2371-0000_defconfig | 2 +- configs/p2371-2180_defconfig | 2 +- configs/p2571_defconfig | 2 +- configs/p2771-0000-000_defconfig | 2 +- configs/p2771-0000-500_defconfig | 2 +- configs/p3450-0000_defconfig | 2 +- configs/paz00_defconfig | 2 +- configs/plutux_defconfig | 2 +- configs/seaboard_defconfig | 2 +- configs/tec-ng_defconfig | 2 +- configs/tec_defconfig | 2 +- configs/trimslice_defconfig | 2 +- configs/venice2_defconfig | 2 +- configs/ventana_defconfig | 2 +- disk/Kconfig | 4 ++-- drivers/i2c/Kconfig | 2 +- drivers/mailbox/Kconfig | 2 +- drivers/mmc/Kconfig | 2 +- drivers/pci/Kconfig | 2 +- drivers/usb/host/Kconfig | 2 +- drivers/video/Kconfig | 2 +- include/serial.h | 2 +- 44 files changed, 49 insertions(+), 50 deletions(-)
diff --git a/Makefile b/Makefile index 26307fd4a6..882fa91295 100644 --- a/Makefile +++ b/Makefile @@ -931,7 +931,7 @@ ALL-y += u-boot-sunxi-with-spl.bin endif
# enable combined SPL/u-boot/dtb rules for tegra -ifeq ($(CONFIG_TEGRA)$(CONFIG_SPL),yy) +ifeq ($(CONFIG_ARCH_TEGRA)$(CONFIG_SPL),yy) ALL-y += u-boot-tegra.bin u-boot-nodtb-tegra.bin ALL-$(CONFIG_OF_SEPARATE) += u-boot-dtb-tegra.bin endif @@ -1609,7 +1609,7 @@ u-boot-sunxi-with-spl.bin: spl/sunxi-spl.bin u-boot.itb FORCE endif endif
-ifneq ($(CONFIG_TEGRA),) +ifneq ($(CONFIG_ARCH_TEGRA),) ifneq ($(CONFIG_BINMAN),) # Makes u-boot-dtb-tegra.bin u-boot-tegra.bin u-boot-nodtb-tegra.bin %-dtb-tegra.bin %-tegra.bin %-nodtb-tegra.bin: \ diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6bc1776cfd..4b0cab553a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1109,7 +1109,7 @@ config ARCH_ZYNQMP imply MP imply DM_USB_GADGET
-config TEGRA +config ARCH_TEGRA bool "NVIDIA Tegra" imply DISTRO_DEFAULTS imply FAT_WRITE diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 9b3ca9772c..e91b37fb34 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TEGRA),yy) +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) CONFIG_CPU_V7A= CONFIG_CPU_ARM720T=y endif @@ -22,7 +22,7 @@ arch-$(CONFIG_ARM64) =-march=armv8-a
# On Tegra systems we must build SPL for the armv4 core on the device # but otherwise we can use the value in CONFIG_SYS_ARM_ARCH -ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TEGRA),yy) +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) arch-y += -D__LINUX_ARM_ARCH__=4 else arch-y += -D__LINUX_ARM_ARCH__=$(CONFIG_SYS_ARM_ARCH) @@ -76,8 +76,7 @@ machine-$(CONFIG_ARCH_SOCFPGA) += socfpga machine-$(CONFIG_STM32) += stm32 machine-$(CONFIG_ARCH_STM32MP) += stm32mp machine-$(CONFIG_ARCH_SUNXI) += sunxi -# TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA -machine-$(CONFIG_TEGRA) += tegra +machine-$(CONFIG_ARCH_TEGRA) += tegra machine-$(CONFIG_ARCH_U8500) += u8500 machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSAL) += versal diff --git a/arch/arm/cpu/arm720t/interrupts.c b/arch/arm/cpu/arm720t/interrupts.c index 8437717a7b..f0fc58dead 100644 --- a/arch/arm/cpu/arm720t/interrupts.c +++ b/arch/arm/cpu/arm720t/interrupts.c @@ -11,7 +11,7 @@
#include <common.h>
-#if defined(CONFIG_TEGRA) +#if defined(CONFIG_ARCH_TEGRA) static ulong timestamp; static ulong lastdec;
diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index 73d57a2aae..14569e560b 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -19,7 +19,7 @@ config ARMV7_NONSEC config ARMV7_BOOT_SEC_DEFAULT bool "Boot in secure mode by default" if EXPERT depends on ARMV7_NONSEC - default y if TEGRA + default y if ARCH_TEGRA ---help--- Say Y here to boot in secure mode by default even if non-secure mode is supported. This option is useful to boot kernels which do not diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 20d3adc5d4..391197387e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -157,7 +157,7 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-g12b-a311d-khadas-vim3.dtb \ meson-sm1-khadas-vim3l.dtb \ meson-sm1-sei610.dtb -dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ +dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ tegra20-plutux.dtb \ diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index ff9f29f2d5..00facf492e 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -1,4 +1,4 @@ -if TEGRA +if ARCH_TEGRA
config SPL_GPIO_SUPPORT default y diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 9d52b75cb4..7a95ee3b7a 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -985,7 +985,7 @@ config SPL_POWER_DOMAIN
config SPL_RAM_SUPPORT bool "Support booting from RAM" - default y if MICROBLAZE || ARCH_SOCFPGA || TEGRA || ARCH_ZYNQ + default y if MICROBLAZE || ARCH_SOCFPGA || ARCH_TEGRA || ARCH_ZYNQ help Enable booting of an image in RAM. The image can be preloaded or it can be loaded by SPL directly into RAM (e.g. using USB). @@ -993,7 +993,7 @@ config SPL_RAM_SUPPORT config SPL_RAM_DEVICE bool "Support booting from preloaded image in RAM" depends on SPL_RAM_SUPPORT - default y if MICROBLAZE || ARCH_SOCFPGA || TEGRA || ARCH_ZYNQ + default y if MICROBLAZE || ARCH_SOCFPGA || ARCH_TEGRA || ARCH_ZYNQ help Enable booting of an image already loaded in RAM. The image has to be already in memory when SPL takes over, e.g. loaded by the boot diff --git a/config.mk b/config.mk index 097d1f67d2..7bb1fd4ed1 100644 --- a/config.mk +++ b/config.mk @@ -23,7 +23,7 @@ VENDOR := ARCH := $(CONFIG_SYS_ARCH:"%"=%) CPU := $(CONFIG_SYS_CPU:"%"=%) ifdef CONFIG_SPL_BUILD -ifdef CONFIG_TEGRA +ifdef CONFIG_ARCH_TEGRA CPU := arm720t endif endif diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 150941fd1a..604a473fa9 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index b2e3ff6614..a5db39129e 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index d70467012c..89f4dc1144 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 6145861060..bf2f5f5208 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index c30b37e8c7..366a90dd42 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index cf3e4e0beb..a1d6ab206a 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 4937433af0..d44ed05784 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index cad56f131b..483a7cfeb5 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index 951ed1df55..911b6be37e 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 197add3945..ec8f4dad22 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1FFE0000 diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 116950ea7b..74f4456d89 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index bfca54d857..95c9dfa807 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1FFE0000 diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 8c08ee6233..b9d54eb654 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x81000100 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 70817194c3..2a93790496 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index c70217c82d..bea11adc8d 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 43c24b8330..60ba6e8ede 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 8bf84193e6..dfa327752f 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index 1f40333b0e..37cb0151ce 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/p3450-0000_defconfig b/configs/p3450-0000_defconfig index f78e1d3867..bdc0cff71d 100644 --- a/configs/p3450-0000_defconfig +++ b/configs/p3450-0000_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80080000 CONFIG_TEGRA210=y CONFIG_TARGET_P3450_0000=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 8536c64fc0..4330d141a3 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 3c716d6e27..6b70a240f5 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1FFE0000 diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 9c285b96aa..ba19ceb5ac 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 2fc0470b34..d31db78818 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/tec_defconfig b/configs/tec_defconfig index fd7b1b6267..34df740bc5 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1FFE0000 diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 6613701e3c..84193b364f 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 94211e5091..58fb867e9e 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x80110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index bb94e23ad5..9ff4f1c8ac 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_TEGRA=y +CONFIG_ARCH_TEGRA=y CONFIG_SYS_TEXT_BASE=0x00110000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 diff --git a/disk/Kconfig b/disk/Kconfig index 747275c2ba..cee16a80bc 100644 --- a/disk/Kconfig +++ b/disk/Kconfig @@ -53,7 +53,7 @@ config ISO_PARTITION bool "Enable ISO partition table" depends on PARTITIONS default y if DISTRO_DEFAULTS - default y if MIPS || TEGRA + default y if MIPS || ARCH_TEGRA
config SPL_ISO_PARTITION bool "Enable ISO partition table for SPL" @@ -75,7 +75,7 @@ config EFI_PARTITION bool "Enable EFI GPT partition table" depends on PARTITIONS default y if DISTRO_DEFAULTS - default y if TEGRA + default y if ARCH_TEGRA select LIB_UUID help Say Y here if you would like to use device under U-Boot which diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 03d2fed341..7ecf0dc5ed 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -394,7 +394,7 @@ config SYS_I2C_STM32F7
config SYS_I2C_TEGRA bool "NVIDIA Tegra internal I2C controller" - depends on TEGRA + depends on ARCH_TEGRA help Support for NVIDIA I2C controller available in Tegra SoCs.
diff --git a/drivers/mailbox/Kconfig b/drivers/mailbox/Kconfig index 85c2a829ae..dd4b0ac0c3 100644 --- a/drivers/mailbox/Kconfig +++ b/drivers/mailbox/Kconfig @@ -19,7 +19,7 @@ config SANDBOX_MBOX
config TEGRA_HSP bool "Enable Tegra HSP controller support" - depends on DM_MAILBOX && TEGRA + depends on DM_MAILBOX && ARCH_TEGRA help This enables support for the NVIDIA Tegra HSP Hw module, which implements doorbells, mailboxes, semaphores, and shared interrupts. diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index bb38787eca..f6e793ca4d 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -615,7 +615,7 @@ config MMC_SDHCI_TANGIER
config MMC_SDHCI_TEGRA bool "SDHCI platform support for the Tegra SD/MMC Controller" - depends on TEGRA + depends on ARCH_TEGRA select BOUNCE_BUFFER default y help diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 437cd9a055..6fc26884e2 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -111,7 +111,7 @@ config PCI_SANDBOX
config PCI_TEGRA bool "Tegra PCI support" - depends on TEGRA + depends on ARCH_TEGRA depends on (TEGRA186 && POWER_DOMAIN) || (!TEGRA186) help Enable support for the PCIe controller found on some generations of diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 0d54fdad8a..0ba010b034 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -197,7 +197,7 @@ config USB_EHCI_PCI
config USB_EHCI_TEGRA bool "Support for NVIDIA Tegra on-chip EHCI USB controller" - depends on TEGRA + depends on ARCH_TEGRA ---help--- Enable support for Tegra on-chip EHCI USB controller
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 7c5012a67f..38123543a5 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -128,7 +128,7 @@ config CONSOLE_TRUETYPE_SIZE
config SYS_WHITE_ON_BLACK bool "Display console as white on a black background" - default y if ARCH_AT91 || ARCH_EXYNOS || ARCH_ROCKCHIP || TEGRA || X86 || ARCH_SUNXI + default y if ARCH_AT91 || ARCH_EXYNOS || ARCH_ROCKCHIP || ARCH_TEGRA || X86 || ARCH_SUNXI help Normally the display is black on a white background, Enable this option to invert this, i.e. white on a black background. This can be diff --git a/include/serial.h b/include/serial.h index 54b21a0470..c590637b1f 100644 --- a/include/serial.h +++ b/include/serial.h @@ -28,7 +28,7 @@ extern struct serial_device *default_serial_console(void);
#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || \ defined(CONFIG_MPC86xx) || \ - defined(CONFIG_TEGRA) || defined(CONFIG_SYS_COREBOOT) || \ + defined(CONFIG_ARCH_TEGRA) || defined(CONFIG_SYS_COREBOOT) || \ defined(CONFIG_MICROBLAZE) extern struct serial_device serial0_device; extern struct serial_device serial1_device;
arch/arm/Kconfig | 2 +- arch/arm/Makefile | 2 +- arch/arm/mach-stm32/Kconfig | 2 +- configs/stm32f429-discovery_defconfig | 2 +- configs/stm32f429-evaluation_defconfig | 2 +- configs/stm32f469-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 2 +- configs/stm32f769-disco_defconfig | 2 +- configs/stm32h743-disco_defconfig | 2 +- configs/stm32h743-eval_defconfig | 2 +- drivers/gpio/Kconfig | 2 +- drivers/misc/Kconfig | 2 +- drivers/reset/Kconfig | 2 +- 13 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4b0cab553a..dee31952ca 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1563,7 +1563,7 @@ config ARCH_UNIPHIER Support for UniPhier SoC family developed by Socionext Inc. (formerly, System LSI Business Division of Panasonic Corporation)
-config STM32 +config ARCH_STM32 bool "Support STMicroelectronics STM32 MCU with cortex M" select CPU_V7M select DM diff --git a/arch/arm/Makefile b/arch/arm/Makefile index e91b37fb34..94eb50bf72 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -73,7 +73,7 @@ machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx machine-$(CONFIG_ARCH_SNAPDRAGON) += snapdragon machine-$(CONFIG_ARCH_SOCFPGA) += socfpga -machine-$(CONFIG_STM32) += stm32 +machine-$(CONFIG_ARCH_STM32) += stm32 machine-$(CONFIG_ARCH_STM32MP) += stm32mp machine-$(CONFIG_ARCH_SUNXI) += sunxi machine-$(CONFIG_ARCH_TEGRA) += tegra diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index cea5ee2ce5..b42b05669a 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -1,4 +1,4 @@ -if STM32 +if ARCH_STM32
config STM32F4 bool "stm32f4 family" diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 52a577f97b..da43317ae5 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32f429-evaluation_defconfig b/configs/stm32f429-evaluation_defconfig index 24f79b51bf..f67ce3e407 100644 --- a/configs/stm32f429-evaluation_defconfig +++ b/configs/stm32f429-evaluation_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index 0ab00514d5..082fb0cc19 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index c9e22563a3..574bc61db0 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_F_LEN=0xE00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 19a7493d00..3f53c11c24 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_F_LEN=0xE00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32h743-disco_defconfig b/configs/stm32h743-disco_defconfig index 6b7a1d6d68..21ea90a2c1 100644 --- a/configs/stm32h743-disco_defconfig +++ b/configs/stm32h743-disco_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/stm32h743-eval_defconfig b/configs/stm32h743-eval_defconfig index 7564d97707..432fce0181 100644 --- a/configs/stm32h743-eval_defconfig +++ b/configs/stm32h743-eval_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y -CONFIG_STM32=y +CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0xF00 CONFIG_ENV_SIZE=0x2000 diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 2081520f42..d87f6cc105 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -318,7 +318,7 @@ config PIC32_GPIO
config STM32_GPIO bool "ST STM32 GPIO driver" - depends on DM_GPIO && (STM32 || ARCH_STM32MP) + depends on DM_GPIO && (ARCH_STM32 || ARCH_STM32MP) default y help Device model driver support for STM32 GPIO controller. It should be diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 766402745d..81ed9eb209 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -310,7 +310,7 @@ config STM32MP_FUSE
config STM32_RCC bool "Enable RCC driver for the STM32 SoC's family" - depends on (STM32 || ARCH_STM32MP) && MISC + depends on (ARCH_STM32 || ARCH_STM32MP) && MISC help Enable the STM32 RCC driver. The RCC block (Reset and Clock Control block) is responsible of the management of the clock and reset diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 75ccd65799..65101ab4e8 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -30,7 +30,7 @@ config STI_RESET
config STM32_RESET bool "Enable the STM32 reset" - depends on STM32 || ARCH_STM32MP + depends on ARCH_STM32 || ARCH_STM32MP help Support for reset controllers on STMicroelectronics STM32 family SoCs. This resset driver is compatible with STM32 F4/F7 and H7 SoCs.
drivers/reset/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 65101ab4e8..88d3be1593 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -33,7 +33,7 @@ config STM32_RESET depends on ARCH_STM32 || ARCH_STM32MP help Support for reset controllers on STMicroelectronics STM32 family SoCs. - This resset driver is compatible with STM32 F4/F7 and H7 SoCs. + This reset driver is compatible with STM32 F4/F7 and H7 SoCs.
config TEGRA_CAR_RESET bool "Enable Tegra CAR-based reset driver"
Trevor Woerner
