[PATCH] Makefile: Improve generated_defconfig file handling
Commit 2027e99e61aa ("Makefile: Run defconfig files through the C preprocessor") adds `generated_defconfig' file, but fails to clean that up. It might be useful to have that file around after `make' is done, but it's better to clean that up on `make clean'. Also we probably want to hide it in `git status' list. This patch makes the described changes, and also adds `-P' parameter to the CPP command that produces the `generated_defconfig' to avoid generating linemarkers.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Fixes: 2027e99e61aa ("Makefile: Run defconfig files through the C preprocessor") --- .gitignore | 1 + Makefile | 1 + scripts/kconfig/Makefile | 2 +- 3 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/.gitignore b/.gitignore index 330148119264..d9a64d742fd7 100644 --- a/.gitignore +++ b/.gitignore @@ -63,6 +63,7 @@ fit-dtb.blob* /spl/ /tpl/ /defconfig +/generated_defconfig
# # Generated include files diff --git a/Makefile b/Makefile index a2bc9d590329..6fd0e92c7d5a 100644 --- a/Makefile +++ b/Makefile @@ -2205,6 +2205,7 @@ clean: $(clean-dirs) -o -name modules.builtin -o -name '.tmp_*.o.*' \ -o -name 'dsdt_generated.aml' -o -name 'dsdt_generated.asl.tmp' \ -o -name 'dsdt_generated.c' \ + -o -name 'generated_defconfig' \ -o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ -type f -print | xargs rm -f
diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index 5ce5845e8247..079add4d5dab 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -93,7 +93,7 @@ endif endif
%_defconfig: $(obj)/conf - $(Q)$(CPP) -nostdinc -I $(srctree) -undef -x assembler-with-cpp $(srctree)/arch/$(SRCARCH)/configs/$@ -o generated_defconfig + $(Q)$(CPP) -nostdinc -P -I $(srctree) -undef -x assembler-with-cpp $(srctree)/arch/$(SRCARCH)/configs/$@ -o generated_defconfig $(Q)$< $(silent) --defconfig=generated_defconfig $(Kconfig)
# Added for U-Boot (backward compatibility)
All look like sensible improvements to me,
Acked-by: Andrew Davis afd@ti.com
-o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ -type f -print | xargs rm -f-o -name 'generated_defconfig' \
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Fixes: 2027e99e61aa ("Makefile: Run defconfig files through the C preprocessor") Acked-by: Andrew Davis afd@ti.com
Andrew Davis
Sam Protsenko
