[U-Boot] [PATCH V2] BOOT: Add RAW ramdisk support to bootz
This patch allows loading RAW ramdisk via bootz command. The raw ramdisk is loaded only in case it's size is specified:
bootz <kernel addr> <ramdisk addr>:<ramdisk size> <fdt addr>
For example:
bootz 0x42000000 0x43000000:0x12345 0x44000000
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Warren TWarren@nvidia.com Cc: albert.u.boot@aribaud.net Cc: afleming@gmail.com, Cc: Simon Glass sjg@chromium.org, Cc: Stephen Warren swarren@nvidia.com Cc: Nicolas Pitre nico@fluxnic.net Cc: Wolfgang Denk wd@denx.de Cc: Detlev Zundel dzu@denx.de --- README | 5 +++++ common/cmd_bootm.c | 6 ++++-- common/image.c | 31 +++++++++++++++++++++++++++---- 3 files changed, 36 insertions(+), 6 deletions(-)
V2: Make this feature configurable Document this feature
diff --git a/README b/README index b273070..43fa160 100644 --- a/README +++ b/README @@ -4422,6 +4422,11 @@ On some platforms, it's possible to boot Linux zImage. This is done using the "bootz" command. The syntax of "bootz" command is the same as the syntax of "bootm" command.
+Note, defining the CONFIG_SUPPORT_INITRD_RAW allows user to supply +kernel with raw initrd images. The syntax is slightly different, the +address of the initrd must be augmented by it's size, in the following +format: "<initrd addres>:<initrd size>". +
Standalone HOWTO: ================= diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 9efac8b..872a49c 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -1628,9 +1628,11 @@ static int do_bootz(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( bootz, CONFIG_SYS_MAXARGS, 1, do_bootz, "boot Linux zImage image from memory", - "[addr [initrd] [fdt]]\n - boot Linux zImage stored in memory\n" + "[addr [initrd[:size]] [fdt]]\n" + " - boot Linux zImage stored in memory\n" "\tThe argument 'initrd' is optional and specifies the address\n" - "\tof the initrd in memory.\n" + "\tof the initrd in memory. The optional argument ':size' allows\n" + "\tspecifying the size of RAW initrd.\n" #if defined(CONFIG_OF_LIBFDT) "\tWhen booting a Linux kernel which requires a flat device-tree\n" "\ta third argument is required which is the address of the\n" diff --git a/common/image.c b/common/image.c index 95c7a15..1908df6 100644 --- a/common/image.c +++ b/common/image.c @@ -797,6 +797,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, ulong rd_addr, rd_load; ulong rd_data, rd_len; const image_header_t *rd_hdr; + char *end; #if defined(CONFIG_FIT) void *fit_hdr; const char *fit_uname_config = NULL; @@ -845,10 +846,21 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, } else #endif { - rd_addr = simple_strtoul(argv[2], NULL, 16); + rd_addr = simple_strtoul(argv[2], &end, 16); debug("* ramdisk: cmdline image address = " "0x%08lx\n", rd_addr); + +#ifdef CONFIG_SUPPORT_RAW_INITRD + if (end[0] == ':') { + rd_len = simple_strtoul(++end, + NULL, 16); + debug("* ramdisk: cmdline image " + "length = 0x%08lx\n", + rd_len); + } +#endif + } #if defined(CONFIG_FIT) } else { @@ -990,9 +1002,20 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, break; #endif default: - puts("Wrong Ramdisk Image Format\n"); - rd_data = rd_len = rd_load = 0; - return 1; +#ifdef CONFIG_SUPPORT_RAW_INITRD + /* + * Check if rd_len was manually overridden, if it was, + * we're loading RAW ramdisk. + */ + if (rd_len != 0) { + rd_data = rd_addr; + } else +#endif + { + puts("Wrong Ramdisk Image Format\n"); + rd_data = rd_len = rd_load = 0; + return 1; + } } } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy,
For example:
Standalone HOWTO:
- "[addr [initrd[:size]] [fdt]]\n"
- " - boot Linux zImage stored in memory\n" "\tThe argument 'initrd' is optional and specifies the address\n"
- "\tof the initrd in memory. The optional argument ':size' allows\n"
- "\tspecifying the size of RAW initrd.\n"
- char *end;
V1 did not work for me and it looks like V2 has the same problem. You'll never get to this else because of the call to fit_parse_subimage above:
* fit_parse_subimage() expects subimage spec in the for of * [<addr>]:<subimage>, where <addr> is a FIT image address that contains * subimage with a <subimg> unit name.
With debug turned on, it thinks my size is the sub-image name:
* ramdisk: subimage '3DC72E' from image at 0x01000000 ramdisk start = 0x1ff912fc, ramdisk end = 0x3fe98ab4
Rob
NULL, 16);
rd_len);
return 1;
if (rd_len != 0) {
rd_data = rd_addr;
} else
return 1;
} } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy,}
Dear Rob Herring,
loaded only in case it's size is specified: bootz <kernel addr> <ramdisk addr>:<ramdisk size> <fdt addr>
For example: bootz 0x42000000 0x43000000:0x12345 0x44000000
Standalone HOWTO:
U_BOOT_CMD(
- char *end;
} else
#endif
- fit_parse_subimage() expects subimage spec in the for of
- [<addr>]:<subimage>, where <addr> is a FIT image address that contains
- subimage with a <subimg> unit name.
- ramdisk: subimage '3DC72E' from image at 0x01000000 ramdisk start = 0x1ff912fc, ramdisk end = 0x3fe98ab4
Good catch, thanks for testing ... will poke around further. But if you have any suggestions now that you dug in it, they're welcome :)
Rob
NULL, 16);
rd_len);
} else {
break;
#endif
default:
return 1;
if (rd_len != 0) {
rd_data = rd_addr;
} else
return 1;
For example:
Signed-off-by: Marek Vasut marex@denx.de Signed-off-by: Rob Herring rob.herring@calxeda.com Cc: Tom Warren TWarren@nvidia.com Cc: albert.u.boot@aribaud.net Cc: afleming@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stephen Warren swarren@nvidia.com Cc: Nicolas Pitre nico@fluxnic.net Cc: Wolfgang Denk wd@denx.de Cc: Detlev Zundel dzu@denx.de --- V3: - fix operation when CONFIG_FIT is enabled as FIT images use <addr>[:<subimage>]
README | 5 +++++ common/cmd_bootm.c | 6 ++++-- common/image.c | 15 ++++++++++++--- 3 files changed, 21 insertions(+), 5 deletions(-)
diff --git a/README b/README index 5141751..068ec71 100644 --- a/README +++ b/README @@ -4330,6 +4330,11 @@ On some platforms, it's possible to boot Linux zImage. This is done using the "bootz" command. The syntax of "bootz" command is the same as the syntax of "bootm" command.
Standalone HOWTO: ================= diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index b49d4f7..2f9b214 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -1634,9 +1634,11 @@ static int do_bootz(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( bootz, CONFIG_SYS_MAXARGS, 1, do_bootz, "boot Linux zImage image from memory", - "[addr [initrd] [fdt]]\n - boot Linux zImage stored in memory\n" + "[addr [initrd[:size]] [fdt]]\n" + " - boot Linux zImage stored in memory\n" "\tThe argument 'initrd' is optional and specifies the address\n" - "\tof the initrd in memory.\n" + "\tof the initrd in memory. The optional argument ':size' allows\n" + "\tspecifying the size of RAW initrd.\n" #if defined(CONFIG_OF_LIBFDT) "\tWhen booting a Linux kernel which requires a flat device-tree\n" "\ta third argument is required which is the address of the\n" diff --git a/common/image.c b/common/image.c index 77ca6e4..2a25f5f 100644 --- a/common/image.c +++ b/common/image.c @@ -796,6 +796,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, ulong rd_addr, rd_load; ulong rd_data, rd_len; const image_header_t *rd_hdr; + char *end; #if defined(CONFIG_FIT) void *fit_hdr; const char *fit_uname_config = NULL; @@ -989,9 +990,17 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, break; #endif default: - puts("Wrong Ramdisk Image Format\n"); - rd_data = rd_len = rd_load = 0; - return 1; +#ifdef CONFIG_SUPPORT_RAW_INITRD + if (argc >= 3 && (end = strchr(argv[2], ':'))) { + rd_len = simple_strtoul(++end, NULL, 16); + rd_data = rd_addr; + } else +#endif + { + puts("Wrong Ramdisk Image Format\n"); + rd_data = rd_len = rd_load = 0; + return 1; + } } } else if (images->legacy_hdr_valid && image_check_type(&images->legacy_hdr_os_copy,
Dear Rob Herring,
For example:
Doesn't this still colide with CONFIG_FIT? Aka. in case of CONFIG_FIT enabled, you can't use raw ramdisk?
btw. maybe we should use "@" instead of ":" and be done with it?
V3:
Standalone HOWTO:
- char *end;
return 1;
rd_data = rd_addr;
} else
return 1;
Best regards, Marek Vasut
On 03/22/2012 04:10 AM, Marek Vasut wrote:
Dear Rob Herring,
For example:
No. All the parsing now is done after trying to read the image type. Only if a valid legacy or FIT uImage is not found, do we hit the raw image code and parse the size. I tested both with and without CONFIG_FIT enabled.
Sub images will have an @ in the name. I thought about parsing for that, but DT has no requirement that you have to have an @ in the node name and it's not clear to me if u-boot convention requires it or not. Then I came up with the current patch, so it doesn't matter.
Rob
V3:
Standalone HOWTO:
- char *end;
return 1;
rd_data = rd_addr;
} else
return 1;
Dear Rob Herring,
Dear Rob Herring,
Dear Wolfgang Denk, are we OK with applying this and bootz patch please? Can we get it into .04 release please?
Rob
V3:
<addr>[:<subimage>]
Standalone HOWTO:
- char *end;
#endif
default:
return 1;
rd_data = rd_addr;
} else
return 1;
Dear Marek,
"this" - which patch version exactly are you referring to?
In any case this has been submitted long after the close of the MW, so this is stuff for "next".
Dear Wolfgang Denk,
Dear Marek,
Revision V6.
I believe this patch is quite important to the linux-arm people and early adoption of this stuff would be very beneficial. Also, there are other patches that were applied after the MW was closed. Finally, this patch started long before .04 release cycle.
Dear Marek Vasut,
Revision V6.
Could you please be a bit more specific? Like posting a link to the respective message on gmane, or in patchwork?
The Subject: of this message is "BOOT: Add RAW ramdisk support to bootz", but I have not seen any V6 for this patch. Ican only guess that you might be referring to [PATCH V6] BOOT: Add "bootz" command to boot Linux zImage on ARM - but I'd rather be sure.
Where/when?
Dear Wolfgang Denk,
Dear Marek Vasut,
Revision V6.
http://patchwork.ozlabs.org/patch/146848/ http://patchwork.ozlabs.org/patch/147440/
Yes, see above two links please.
Where/when?
If you mean the patch, here: http://patchwork.ozlabs.org/patch/125318/
If you talk about accepting patches way past MW, almost all the time, at least in the ARM stuffs. And this works OK so far I believe, I see no breakage. Also, we didn't reach the RC phase yet either. Lastly, this change is not intrusive in any way.
Dear Wolfgang Denk,
Dear Marek Vasut,
Revision V6.
Where/when?
Did you made up your mind on this patch please?
Dear Rob Herring,
In message 1332107278-24123-1-git-send-email-robherring2@gmail.com you wrote:
For example:
V3:
Applied, thanks.
Dear Rob & Marek,
For example:
V3:
Argh...
This causes build warnings:
+ ./MAKEALL TQM860L Configuring for TQM860L board... image.c: In function 'boot_get_ramdisk': image.c:800: warning: unused variable 'end'
Why do I get this at all? I did not enable any of the related bootz stuff on my board!
Please fix!
Rob Herring
