[U-Boot] Pull request: u-boot-spi/master
Hi Tom,
Please pull this PR.
thanks! Jagan.
The following changes since commit d622ac39274a949b6445f1bfd92dc1644014388b:
powerpc: mpc824x: remove MPC824X cpu support (2015-01-05 12:08:55 -0500)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to adc0fabfd9662fa690e866332cd4277351f991c4:
imx:mx6sxsabresd support qspi AHB read (2015-01-09 00:03:28 +0530)
---------------------------------------------------------------- Axel Lin (3): spi: designware_spi: Fix detecting FIFO depth spi: cadence_qspi: Fix checking return value of fdt_first_subnode() spi: ftssp010_spi: Simplify code flow in ftssp010_[wait|wait_tx|wait_rx]
Marek Vasut (2): dt: socfpga: Rename snps, dw-spi-mmio to snps, dw-apb-ssi dt: socfpga: Replace num-chipselect with num-cs
Peng Fan (4): spi:fsl-quadspi support bank register read write mx6sxsabresd: support qspi flash bigger than 16MB qspi:fsl implement AHB read imx:mx6sxsabresd support qspi AHB read
arch/arm/dts/socfpga.dtsi | 10 +- drivers/spi/cadence_qspi.c | 2 +- drivers/spi/designware_spi.c | 6 +- drivers/spi/fsl_qspi.c | 297 +++++++++++++++++++++++++++++++++++++---- drivers/spi/fsl_qspi.h | 15 +++ drivers/spi/ftssp010_spi.c | 36 ++--- include/configs/mx6sxsabresd.h | 8 ++ 7 files changed, 316 insertions(+), 58 deletions(-)
On Fri, Jan 09, 2015 at 12:10:35AM +0530, Jagannadha Sutradharudu Teki wrote:
Hi Tom,
thanks! Jagan.
