[U-Boot] [RFC PATCH] Add support for Micron MT29F8G08 8Gb NAND flash MID: 0x2c, DID: 0x38
Microns MT29F8G08 8GBit flash is not identified correctly. Manufacturer ID is 0x2c, device ID is 0x38
Signed-off-by: Lothar Felten lothar.felten@gmail.com CC: scottwood@freescale.com
--- drivers/mtd/nand/nand_ids.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/nand_ids.c b/drivers/mtd/nand/nand_ids.c index f3f0cb6..a43d0e8 100644 --- a/drivers/mtd/nand/nand_ids.c +++ b/drivers/mtd/nand/nand_ids.c @@ -108,6 +108,7 @@ const struct nand_flash_dev nand_flash_ids[] = { /* 8 Gigabit */ {"NAND 1GiB 1,8V 8-bit", 0xA3, 0, 1024, 0, LP_OPTIONS}, {"NAND 1GiB 3,3V 8-bit", 0xD3, 0, 1024, 0, LP_OPTIONS}, + {"NAND 1GiB 3,3V 8-bit", 0x38, 0, 1024, 0, LP_OPTIONS}, {"NAND 1GiB 1,8V 16-bit", 0xB3, 0, 1024, 0, LP_OPTIONS16}, {"NAND 1GiB 3,3V 16-bit", 0xC3, 0, 1024, 0, LP_OPTIONS16},
Is this an ONFI flash? If so, use that instead of the ID table.
-Scott
-Scott
Hi Scott,
yes it's an ONFI flash, but the OOB size is 224 bytes, which results in a data abort (see below). Apparently the supported ONFI detected OOB sizes are 8,16,64 and 128 bytes. I lack a nand_oob_224 struct but I don't know what the default positions would be.
Would the following layout be ok? .eccbytes = 208, .eccpos = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209}, .oobfree = { {.offset = 210, .length = 14 } }
(basically skip first two bytes, 208 bytes data, 14 bytes free)
The cause for the data abort is the following access in nand_scan_tail(struct mtd_info *mtd) as chip->layout has not been set:
/* * The number of bytes available for a client to place data into * the out of band area. */ chip->ecc.layout->oobavail = 0;
If the proposed layout is ok, I'll make a patch.
the data abort:
U-Boot 2014.01-rc1-00027-g78a75bc-dirty (Dec 11 2013 - 21:03:57)
I2C: ready DRAM: 256 MiB WARNING: Caches not enabled NAND: data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<8f7720f8>] lr : [<8f75f654>] sp : 8f630ef0 ip : 00000820 fp : 80849989 r10: 00000002 r9 : 8f630f28 r8 : 4030cdcc r7 : 4030cb7c r6 : 00000002 r5 : 8ffbb000 r4 : 8ffbb0b0 r3 : 00000000 r2 : 00000000 r1 : 8f79f57c r0 : 8f631040 Flags: nZCv IRQs off FIQs on Mode SVC_32 Resetting CPU ...
-- Lo
-Scott
Hi Scott,
What NAND driver are you using? Are you using hardware ECC or software ECC?
-Scott
[snip]
-Scott
Hi Scott,
I use the omap nand driver, the cpu is a AM335x with hw ecc elm. Depending on the flash type, the rom code expects BCH8 or BCH16 unless ECC is completely disabled. I'm not sure if the ecc hw is used but I see oob bytes being used. How can I verify this?
--Lo
[snip]
-Scott
Hi Scott,
What version of U-Boot did you try? In particular, are you using top of tree which has Pekon Gupta's patchset which significantly modifies how ECC and layouts work in that driver?
-Scott
micro1183
Scott Wood
