[U-Boot-Users] [PATCH 2/7] DaVinci: U-Boot cpu support
Add cpu support for TI DaVinci boards. Based on initial patch by Sergey Kubushyn ksi@koi8.net.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: uboot/cpu/arm926ejs/davinci/Makefile =================================================================== --- /dev/null +++ uboot/cpu/arm926ejs/davinci/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2007 +# Sergey Kubushyn, himself, ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = timer.o ether.o lxt972.o dp83848.o i2c.o +SOBJS = reset.o + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### Index: uboot/cpu/arm926ejs/davinci/reset.S =================================================================== --- /dev/null +++ uboot/cpu/arm926ejs/davinci/reset.S @@ -0,0 +1,75 @@ +/* + * Processor reset using WDT for TI TMS320DM644x SoC. + * + * Copyright (C) Sergey Kubushyn ksi@koi8.net, 2007. + * + * ----------------------------------------------------- + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +.globl reset_cpu +reset_cpu: + ldr r0, WDT_TGCR + mov r1, $0x08 + str r1, [r0] + ldr r1, [r0] + orr r1, r1, $0x03 + str r1, [r0] + mov r1, $0 + ldr r0, WDT_TIM12 + str r1, [r0] + ldr r0, WDT_TIM34 + str r1, [r0] + ldr r0, WDT_PRD12 + str r1, [r0] + ldr r0, WDT_PRD34 + str r1, [r0] + ldr r0, WDT_TCR + ldr r1, [r0] + orr r1, r1, $0x40 + str r1, [r0] + ldr r0, WDT_WDTCR + ldr r1, [r0] + orr r1, r1, $0x4000 + str r1, [r0] + ldr r1, WDTCR_VAL1 + str r1, [r0] + ldr r1, WDTCR_VAL2 + str r1, [r0] + nop + nop +reset_cpu_loop: + b reset_cpu_loop + +WDT_TGCR: + .word 0x01c21c24 +WDT_TIM12: + .word 0x01c21c10 +WDT_TIM34: + .word 0x01c21c14 +WDT_PRD12: + .word 0x01c21c18 +WDT_PRD34: + .word 0x01c21c1c +WDT_TCR: + .word 0x01c21c20 +WDT_WDTCR: + .word 0x01c21c28 +WDTCR_VAL1: + .word 0xa5c64000 +WDTCR_VAL2: + .word 0xda7e4000 Index: uboot/cpu/arm926ejs/davinci/timer.c =================================================================== --- /dev/null +++ uboot/cpu/arm926ejs/davinci/timer.c @@ -0,0 +1,166 @@ +/* + * (C) Copyright 2003 + * Texas Instruments <www.ti.com> + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002-2004 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2004 + * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * + * (C) Copyright 2007 + * Sergey Kubushyn, himself, ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <arm926ejs.h> + +typedef volatile struct { + u_int32_t pid12; + u_int32_t emumgt_clksped; + u_int32_t gpint_en; + u_int32_t gpdir_dat; + u_int32_t tim12; + u_int32_t tim34; + u_int32_t prd12; + u_int32_t prd34; + u_int32_t tcr; + u_int32_t tgcr; + u_int32_t wdtcr; + u_int32_t tlgc; + u_int32_t tlmr; +} davinci_timer; + +davinci_timer *timer = (davinci_timer *)CFG_TIMERBASE; + +#define TIMER_LOAD_VAL (CFG_HZ_CLOCK / CFG_HZ) +#define READ_TIMER timer->tim34 + +static ulong timestamp; +static ulong lastinc; + +int timer_init(void) +{ + /* We are using timer34 in unchained 32-bit mode, full speed */ + timer->tcr = 0x0; + timer->tgcr = 0x0; + timer->tgcr = 0x06; + timer->tim34 = 0x0; + timer->prd34 = TIMER_LOAD_VAL; + lastinc = 0; + timer->tcr = 0x80 << 16; + timestamp = 0; + + return(0); +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return(get_timer_masked() - base); +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +void udelay(unsigned long usec) +{ + udelay_masked(usec); +} + +void reset_timer_masked(void) +{ + lastinc = READ_TIMER; + timestamp = 0; +} + +ulong get_timer_raw(void) +{ + ulong now = READ_TIMER; + + if (now >= lastinc) { + /* normal mode */ + timestamp += now - lastinc; + } else { + /* overflow ... */ + timestamp += now + TIMER_LOAD_VAL - lastinc; + } + lastinc = now; + return timestamp; +} + +ulong get_timer_masked(void) +{ + return(get_timer_raw() / TIMER_LOAD_VAL); +} + +void udelay_masked(unsigned long usec) +{ + ulong tmo; + ulong endtime; + signed long diff; + + tmo = CFG_HZ_CLOCK / 1000; + tmo *= usec; + tmo /= 1000; + + endtime = get_timer_raw() + tmo; + + do { + ulong now = get_timer_raw(); + diff = endtime - now; + } while (diff >= 0); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return(get_timer(0)); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + ulong tbclk; + + tbclk = CFG_HZ; + return(tbclk); +} Index: uboot/cpu/arm926ejs/davinci/i2c.c =================================================================== --- /dev/null +++ uboot/cpu/arm926ejs/davinci/i2c.c @@ -0,0 +1,349 @@ +/* + * TI DaVinci (TMS320DM644x) I2C driver. + * + * Copyright (C) Sergey Kubushyn ksi@koi8.net, 2007. + * + * -------------------------------------------------------- + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#ifdef CONFIG_DRIVER_DAVINCI_I2C + +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/i2c_defs.h> + +#define CHECK_NACK \ + if (tmp & (I2C_TIMEOUT | I2C_STAT_NACK)) {\ + I2C_CON = 0;\ + return(1);\ + } + + +static int wait_for_bus(void) +{ + int stat, timeout; + + I2C_STAT = 0xffff; + + for (timeout = 0; timeout < 10; timeout++) { + if (!((stat = I2C_STAT) & I2C_STAT_BB)) { + I2C_STAT = 0xffff; + return(0); + } + + I2C_STAT = stat; + udelay(50000); + } + + I2C_STAT = 0xffff; + return(1); +} + + +static int poll_i2c_irq(int mask) +{ + int stat, timeout; + + for (timeout = 0; timeout < 10; timeout++) { + udelay(1000); + stat = I2C_STAT; + if (stat & mask) { + return(stat); + } + } + + I2C_STAT = 0xffff; + return(stat | I2C_TIMEOUT); +} + + +void flush_rx(void) +{ + int dummy; + + while (1) { + if (!(I2C_STAT & I2C_STAT_RRDY)) + break; + + dummy = I2C_DRR; + I2C_STAT = I2C_STAT_RRDY; + udelay(1000); + } +} + + +void i2c_init(int speed, int slaveadd) +{ + u_int32_t div, psc; + + if (I2C_CON & I2C_CON_EN) { + I2C_CON = 0; + udelay (50000); + } + + psc = 2; + div = (CFG_HZ_CLOCK / ((psc + 1) * speed)) - 10; /* SCLL + SCLH */ + I2C_PSC = psc; /* 27MHz / (2 + 1) = 9MHz */ + I2C_SCLL = (div * 50) / 100; /* 50% Duty */ + I2C_SCLH = div - I2C_SCLL; + + I2C_OA = slaveadd; + I2C_CNT = 0; + + /* Interrupts must be enabled or I2C module won't work */ + I2C_IE = I2C_IE_SCD_IE | I2C_IE_XRDY_IE | + I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE; + + /* Now enable I2C controller (get it out of reset) */ + I2C_CON = I2C_CON_EN; + + udelay(1000); +} + + +int i2c_probe(u_int8_t chip) +{ + int rc = 1; + + if (chip == I2C_OA) { + return(rc); + } + + I2C_CON = 0; + if (wait_for_bus()) {return(1);} + + /* try to read one byte from current (or only) address */ + I2C_CNT = 1; + I2C_SA = chip; + I2C_CON = (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP); + udelay (50000); + + if (!(I2C_STAT & I2C_STAT_NACK)) { + rc = 0; + flush_rx(); + I2C_STAT = 0xffff; + } else { + I2C_STAT = 0xffff; + I2C_CON |= I2C_CON_STP; + udelay(20000); + if (wait_for_bus()) {return(1);} + } + + flush_rx(); + I2C_STAT = 0xffff; + I2C_CNT = 0; + return(rc); +} + + +int i2c_read(u_int8_t chip, u_int32_t addr, int alen, u_int8_t *buf, int len) +{ + u_int32_t tmp; + int i; + + if ((alen < 0) || (alen > 2)) { + printf("%s(): bogus address length %x\n", __FUNCTION__, alen); + return(1); + } + + if (wait_for_bus()) {return(1);} + + if (alen != 0) { + /* Start address phase */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX; + I2C_CNT = alen; + I2C_SA = chip; + I2C_CON = tmp; + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK + + switch (alen) { + case 2: + /* Send address MSByte */ + if (tmp & I2C_STAT_XRDY) { + I2C_DXR = (addr >> 8) & 0xff; + } else { + I2C_CON = 0; + return(1); + } + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK + /* No break, fall through */ + case 1: + /* Send address LSByte */ + if (tmp & I2C_STAT_XRDY) { + I2C_DXR = addr & 0xff; + } else { + I2C_CON = 0; + return(1); + } + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK | I2C_STAT_ARDY); + + CHECK_NACK + + if (!(tmp & I2C_STAT_ARDY)) { + I2C_CON = 0; + return(1); + } + } + } + + /* Address phase is over, now read 'len' bytes and stop */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP; + I2C_CNT = len & 0xffff; + I2C_SA = chip; + I2C_CON = tmp; + + for (i = 0; i < len; i++) { + tmp = poll_i2c_irq(I2C_STAT_RRDY | I2C_STAT_NACK | I2C_STAT_ROVR); + + CHECK_NACK + + if (tmp & I2C_STAT_RRDY) { + buf[i] = I2C_DRR; + } else { + I2C_CON = 0; + return(1); + } + } + + tmp = poll_i2c_irq(I2C_STAT_SCD | I2C_STAT_NACK); + + CHECK_NACK + + if (!(tmp & I2C_STAT_SCD)) { + I2C_CON = 0; + return(1); + } + + flush_rx(); + I2C_STAT = 0xffff; + I2C_CNT = 0; + I2C_CON = 0; + + return(0); +} + + +int i2c_write(u_int8_t chip, u_int32_t addr, int alen, u_int8_t *buf, int len) +{ + u_int32_t tmp; + int i; + + if ((alen < 0) || (alen > 2)) { + printf("%s(): bogus address length %x\n", __FUNCTION__, alen); + return(1); + } + if (len < 0) { + printf("%s(): bogus length %x\n", __FUNCTION__, len); + return(1); + } + + if (wait_for_bus()) {return(1);} + + /* Start address phase */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | I2C_CON_STP; + I2C_CNT = (alen == 0) ? len & 0xffff : (len & 0xffff) + alen; + I2C_SA = chip; + I2C_CON = tmp; + + switch (alen) { + case 2: + /* Send address MSByte */ + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK + + if (tmp & I2C_STAT_XRDY) { + I2C_DXR = (addr >> 8) & 0xff; + } else { + I2C_CON = 0; + return(1); + } + /* No break, fall through */ + case 1: + /* Send address LSByte */ + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK + + if (tmp & I2C_STAT_XRDY) { + I2C_DXR = addr & 0xff; + } else { + I2C_CON = 0; + return(1); + } + } + + for (i = 0; i < len; i++) { + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK + + if (tmp & I2C_STAT_XRDY) { + I2C_DXR = buf[i]; + } else { + return(1); + } + } + + tmp = poll_i2c_irq(I2C_STAT_SCD | I2C_STAT_NACK); + + CHECK_NACK + + if (!(tmp & I2C_STAT_SCD)) { + I2C_CON = 0; + return(1); + } + + flush_rx(); + I2C_STAT = 0xffff; + I2C_CNT = 0; + I2C_CON = 0; + + return(0); +} + + +u_int8_t i2c_reg_read(u_int8_t chip, u_int8_t reg) +{ + u_int8_t tmp; + + i2c_read(chip, reg, 1, &tmp, 1); + return(tmp); +} + + +void i2c_reg_write(u_int8_t chip, u_int8_t reg, u_int8_t val) +{ + u_int8_t tmp; + + i2c_write(chip, reg, 1, &tmp, 1); +} + +#endif /* CONFIG_DRIVER_DAVINCI_I2C */
Dirk Behme
