[U-Boot] [PATCH v2 08/10] sunxi: Add basic A33 basic support
Enable full support for the A33 SoC including display, otg-usb, etc.
Signed-off-by: Vishnu Patekar vishnupatekar0510@gmail.com Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v2: -Add a comment to explain the 0 write to the usb CSR register on A33 --- arch/arm/cpu/armv7/sunxi/Makefile | 4 ++++ arch/arm/cpu/armv7/sunxi/board.c | 8 +++++--- arch/arm/cpu/armv7/sunxi/cpu_info.c | 2 ++ arch/arm/cpu/armv7/sunxi/rsb.c | 2 +- arch/arm/cpu/armv7/sunxi/usbc.c | 9 +++++++++ board/sunxi/Kconfig | 19 ++++++++++++++----- board/sunxi/board.c | 4 ++-- drivers/power/Kconfig | 4 ++-- drivers/usb/musb-new/musb_regs.h | 5 +++++ drivers/video/sunxi_display.c | 3 +++ include/configs/sunxi-common.h | 3 ++- 11 files changed, 49 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index b2e5e5d..b299635 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -16,15 +16,18 @@ obj-y += pinmux.o obj-y += usbc.o obj-$(CONFIG_MACH_SUN6I) += prcm.o obj-$(CONFIG_MACH_SUN8I_A23) += prcm.o +obj-$(CONFIG_MACH_SUN8I_A33) += prcm.o obj-$(CONFIG_MACH_SUN9I) += prcm.o obj-$(CONFIG_MACH_SUN6I) += p2wi.o obj-$(CONFIG_MACH_SUN8I_A23) += rsb.o +obj-$(CONFIG_MACH_SUN8I_A33) += rsb.o obj-$(CONFIG_MACH_SUN9I) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN6I) += clock_sun6i.o obj-$(CONFIG_MACH_SUN7I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += clock_sun6i.o +obj-$(CONFIG_MACH_SUN8I_A33) += clock_sun6i.o obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o
ifndef CONFIG_SPL_BUILD @@ -39,5 +42,6 @@ obj-$(CONFIG_MACH_SUN5I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN6I) += dram_sun6i.o obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o +obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-y += fel_utils.o endif diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 610d889..7e8f6ef 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -46,7 +46,7 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif -#if defined(CONFIG_MACH_SUN8I_A23) +#if defined(CONFIG_MACH_SUN8I_A23) || defined(CONFIG_MACH_SUN8I_A33) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0_TX); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0_RX); #else @@ -70,7 +70,8 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I_A23) +#elif CONFIG_CONS_INDEX == 5 && \ + (defined(CONFIG_MACH_SUN8I_A23) || defined(CONFIG_MACH_SUN8I_A33)) sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); @@ -96,7 +97,8 @@ void s_init(void) #endif #if defined CONFIG_MACH_SUN6I || \ defined CONFIG_MACH_SUN7I || \ - defined CONFIG_MACH_SUN8I_A23 + defined CONFIG_MACH_SUN8I_A23 || \ + defined CONFIG_MACH_SUN8I_A33 /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ asm volatile( "mrc p15, 0, r0, c1, c0, 1\n" diff --git a/arch/arm/cpu/armv7/sunxi/cpu_info.c b/arch/arm/cpu/armv7/sunxi/cpu_info.c index 77435f3..30ec4ac 100644 --- a/arch/arm/cpu/armv7/sunxi/cpu_info.c +++ b/arch/arm/cpu/armv7/sunxi/cpu_info.c @@ -66,6 +66,8 @@ int print_cpuinfo(void) puts("CPU: Allwinner A20 (SUN7I)\n"); #elif defined CONFIG_MACH_SUN8I_A23 puts("CPU: Allwinner A23 (SUN8I)\n"); +#elif defined CONFIG_MACH_SUN8I_A33 + puts("CPU: Allwinner A33 (SUN8I)\n"); #else #warning Please update cpu_info.c with correct CPU information puts("CPU: SUNXI Family\n"); diff --git a/arch/arm/cpu/armv7/sunxi/rsb.c b/arch/arm/cpu/armv7/sunxi/rsb.c index d8d4957..076592b 100644 --- a/arch/arm/cpu/armv7/sunxi/rsb.c +++ b/arch/arm/cpu/armv7/sunxi/rsb.c @@ -20,7 +20,7 @@ static int rsb_set_device_mode(void);
static void rsb_cfg_io(void) { -#if defined CONFIG_MACH_SUN8I_A23 +#if defined CONFIG_MACH_SUN8I_A23 || defined CONFIG_MACH_SUN8I_A33 sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL_R_RSB); sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL_R_RSB); sunxi_gpio_set_pull(SUNXI_GPL(0), 1); diff --git a/arch/arm/cpu/armv7/sunxi/usbc.c b/arch/arm/cpu/armv7/sunxi/usbc.c index 7d55e41..7b883fb 100644 --- a/arch/arm/cpu/armv7/sunxi/usbc.c +++ b/arch/arm/cpu/armv7/sunxi/usbc.c @@ -28,7 +28,11 @@ #endif
#define SUNXI_USB_PMU_IRQ_ENABLE 0x800 +#ifdef CONFIG_MACH_SUN8I_A33 +#define SUNXI_USB_CSR 0x410 +#else #define SUNXI_USB_CSR 0x404 +#endif #define SUNXI_USB_PASSBY_EN 1
#define SUNXI_EHCI_AHB_ICHR8_EN (1 << 10) @@ -103,6 +107,11 @@ static void usb_phy_write(struct sunxi_usbc_hcd *sunxi_usbc, int addr, int j = 0, usbc_bit = 0; void *dest = sunxi_usbc_get_io_base(0) + SUNXI_USB_CSR;
+#ifdef CONFIG_MACH_SUN8I_A33 + /* CSR needs to be explicitly initialized to 0 on A33 */ + writel(0, dest); +#endif + usbc_bit = 1 << (sunxi_usbc->id * 2); for (j = 0; j < len; j++) { /* set the bit address to be written */ diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 5024733..8dd3c37 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -52,11 +52,17 @@ config MACH_SUN8I_A23 select SUNXI_GEN_SUN6I select SUPPORT_SPL
+config MACH_SUN8I_A33 + bool "sun8i (Allwinner A33)" + select CPU_V7 + select SUNXI_GEN_SUN6I + select SUPPORT_SPL + endchoice
config DRAM_CLK int "sunxi dram clock speed" - default 312 if MACH_SUN6I || MACH_SUN8I_A23 + default 312 if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 default 360 if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I ---help--- Set the dram clock speed, valid range 240 - 480, must be a multiple @@ -73,7 +79,8 @@ endif
config DRAM_ZQ int "sunxi dram zq value" - default 123 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN8I_A23 + default 123 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I + default 123 if MACH_SUN8I_A23 || MACH_SUN8I_A33 default 127 if MACH_SUN7I ---help--- Set the dram zq value. @@ -156,7 +163,7 @@ endif config SYS_CLK_FREQ default 912000000 if MACH_SUN7I default 1008000000 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I - default 1008000000 if MACH_SUN8I_A23 + default 1008000000 if MACH_SUN8I_A23 || MACH_SUN8I_A33
config SYS_CONFIG_NAME default "sun4i" if MACH_SUN4I @@ -164,6 +171,7 @@ config SYS_CONFIG_NAME default "sun6i" if MACH_SUN6I default "sun7i" if MACH_SUN7I default "sun8i" if MACH_SUN8I_A23 + default "sun8i" if MACH_SUN8I_A33
config SYS_BOARD default "sunxi" @@ -339,7 +347,7 @@ config VIDEO
config VIDEO_HDMI boolean "HDMI output support" - depends on VIDEO && !MACH_SUN8I_A23 + depends on VIDEO && !MACH_SUN8I_A23 && !MACH_SUN8I_A33 default y ---help--- Say Y here to add support for outputting video over HDMI. @@ -353,7 +361,8 @@ config VIDEO_VGA
config VIDEO_VGA_VIA_LCD boolean "VGA via LCD controller support" - depends on VIDEO && (MACH_SUN5I || MACH_SUN6I || MACH_SUN8I_A23) + depends on VIDEO + depends on MACH_SUN5I || MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 default n ---help--- Say Y here to add support for external DACs connected to the parallel diff --git a/board/sunxi/board.c b/board/sunxi/board.c index dee2621..e0fec57 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -116,7 +116,7 @@ static void mmc_pinmux_setup(int sdc) sunxi_gpio_set_pull(pin, SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(pin, 2); } -#elif defined(CONFIG_MACH_SUN8I_A23) +#elif defined(CONFIG_MACH_SUN8I_A23) || defined(CONFIG_MACH_SUN8I_A33) if (pins == SUNXI_GPIO_D) { /* SDC1: PD2-PD7 */ for (pin = SUNXI_GPD(2); pin <= SUNXI_GPD(7); pin++) { @@ -181,7 +181,7 @@ static void mmc_pinmux_setup(int sdc) sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(SUNXI_GPC(24), 2); } -#elif defined(CONFIG_MACH_SUN8I_A23) +#elif defined(CONFIG_MACH_SUN8I_A23) || defined(CONFIG_MACH_SUN8I_A33) /* SDC2: PC5-PC6, PC8-PC16 */ for (pin = SUNXI_GPC(5); pin <= SUNXI_GPC(6); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index 39051e4..02ea6c1 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -1,6 +1,6 @@ config AXP221_POWER boolean "axp221 / axp223 pmic support" - depends on MACH_SUN6I || MACH_SUN8I_A23 + depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 default y ---help--- Say y here to enable support for the axp221 / axp223 pmic found on most @@ -47,7 +47,7 @@ config AXP221_ALDO2_VOLT int "axp221 aldo2 voltage" depends on AXP221_POWER default 0 if MACH_SUN6I - default 2500 if MACH_SUN8I_A23 + default 2500 if MACH_SUN8I_A23 || MACH_SUN8I_A33 ---help--- Set the voltage (mV) to program the axp221 aldo2 at, set to 0 to disable aldo2. On sun6i (A31) boards this is typically unused and diff --git a/drivers/usb/musb-new/musb_regs.h b/drivers/usb/musb-new/musb_regs.h index 27e4ed4..90288c4 100644 --- a/drivers/usb/musb-new/musb_regs.h +++ b/drivers/usb/musb-new/musb_regs.h @@ -458,8 +458,13 @@ static inline u8 musb_read_ulpi_buscontrol(void __iomem *mbase)
static inline u8 musb_read_configdata(void __iomem *mbase) { +#ifdef CONFIG_MACH_SUN8I_A33 + /* <Sigh> allwinner saves a reg, and we need to hardcode this */ + return 0xde; +#else musb_writeb(mbase, MUSB_INDEX, 0); return musb_readb(mbase, 0x10 + MUSB_CONFIGDATA); +#endif }
static inline u16 musb_read_hwvers(void __iomem *mbase) diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi_display.c index 5073329..0fca057 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi_display.c @@ -947,6 +947,9 @@ static void sunxi_drc_init(void) (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
/* On sun6i the drc must be clocked even when in pass-through mode */ +#ifdef CONFIG_MACH_SUN8I_A33 + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_SAT); +#endif setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_DRC0); clock_set_de_mod_clock(&ccm->iep_drc0_clk_cfg, 300000000); #endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 4a8c452..9f10e76 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -241,7 +241,8 @@ extern int soft_i2c_gpio_scl; #endif #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) #define OF_STDOUT_PATH "/soc@01c00000/serial@01c28400:115200" -#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I_A23) +#elif CONFIG_CONS_INDEX == 5 && \ + (defined(CONFIG_MACH_SUN8I_A23) || defined(CONFIG_MACH_SUN8I_A33)) #define OF_STDOUT_PATH "/soc@01c00000/serial@01f02800:115200" #else #error Unsupported console port nr. Please fix stdout-path in sunxi-common.h.
Acked-by: Ian Campbell ijc@hellion.org.uk
There's a lot of these A23||A33 (and !A23&&!A33). Perhaps a hidden MACH_SUN8I_COMMON selected by both would be helpful?
With or without the _COMMON suffix as you prefer, although without would remove 90% of the changes in this patch.
Can defer it until later if you prefer, or you may retain my ack if you want to make the change in the obvious way.
Ian.
Adding a hidden config for this without the _COMMON is a very good idea, that will greatly reduce the size of some of the patches in the A33 set.
I'll go make that happen in my personal tree, retaining your ack :)
Regards,
Hans
Hans de Goede
Ian Campbell
