[U-Boot] [PATCH V2 1/4] ARM: bcm2835: add mailbox driver
The BCM2835 SoC contains (at least) two CPUs; the VideoCore (a/k/a "GPU") and the ARM CPU. The ARM CPU is often thought of as the main CPU. However, the VideoCore actually controls the initial SoC boot, and hides much of the hardware behind a protocol. This protocol is transported using the SoC's mailbox hardware module.
Here, we add a very simplistic driver for the mailbox module, and define a few structures for the property messages.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: * Added documentation to mbox.h. * Implemented macros to set up headers and tags. * Implemented error-checking of response bits in bcm2835_mbox_call_prop(). * Reworked tag structs based on experience writing LCD driver. * Added a lot more video-related tag structs. * Added debug spew and error messages to mbox.c; useful when debugging LCD. * Removed __packed attributes from message structs. * Removed stale FIXME comments. --- arch/arm/cpu/arm1176/bcm2835/Makefile | 2 +- arch/arm/cpu/arm1176/bcm2835/mbox.c | 163 ++++++++++++ arch/arm/include/asm/arch-bcm2835/mbox.h | 406 ++++++++++++++++++++++++++++++ 3 files changed, 570 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/arm1176/bcm2835/mbox.c create mode 100644 arch/arm/include/asm/arch-bcm2835/mbox.h
diff --git a/arch/arm/cpu/arm1176/bcm2835/Makefile b/arch/arm/cpu/arm1176/bcm2835/Makefile index 95da6a8..135de42 100644 --- a/arch/arm/cpu/arm1176/bcm2835/Makefile +++ b/arch/arm/cpu/arm1176/bcm2835/Makefile @@ -17,7 +17,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o -COBJS := init.o reset.o timer.o +COBJS := init.o reset.o timer.o mbox.o
SRCS := $(SOBJS:.o=.c) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm1176/bcm2835/mbox.c b/arch/arm/cpu/arm1176/bcm2835/mbox.c new file mode 100644 index 0000000..3ce76d0 --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/mbox.c @@ -0,0 +1,163 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mbox.h> + +#define TIMEOUT (100 * 1000) /* 100mS in uS */ + +int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) +{ + struct bcm2835_mbox_regs *regs = + (struct bcm2835_mbox_regs *)BCM2835_MBOX_PHYSADDR; + ulong endtime = get_timer(0) + TIMEOUT; + u32 val; + + debug("time: %lu timeout: %lu\n", get_timer(0), endtime); + + if (send & BCM2835_CHAN_MASK) { + printf("mbox: Illegal mbox data 0x%08x\n", send); + return -1; + } + + /* Drain any stale responses */ + + for (;;) { + val = readl(®s->status); + if (val & BCM2835_MBOX_STATUS_RD_EMPTY) + break; + if (get_timer(0) >= endtime) { + printf("mbox: Timeout draining stale responses\n"); + return -1; + } + val = readl(®s->read); + } + + /* Wait for space to send */ + + for (;;) { + val = readl(®s->status); + if (!(val & BCM2835_MBOX_STATUS_WR_FULL)) + break; + if (get_timer(0) >= endtime) { + printf("mbox: Timeout waiting for send space\n"); + return -1; + } + } + + /* Send the request */ + + val = BCM2835_MBOX_PACK(chan, send); + debug("mbox: TX raw: 0x%08x\n", val); + writel(val, ®s->write); + + /* Wait for the response */ + + for (;;) { + val = readl(®s->status); + if (!(val & BCM2835_MBOX_STATUS_RD_EMPTY)) + break; + if (get_timer(0) >= endtime) { + printf("mbox: Timeout waiting for response\n"); + return -1; + } + } + + /* Read the response */ + + val = readl(®s->read); + debug("mbox: RX raw: 0x%08x\n", val); + + /* Validate the response */ + + if (BCM2835_MBOX_UNPACK_CHAN(val) != chan) { + printf("mbox: Response channel mismatch\n"); + return -1; + } + + *recv = BCM2835_MBOX_UNPACK_DATA(val); + + return 0; +} + +#ifdef DEBUG +void dump_buf(struct bcm2835_mbox_hdr *buffer) +{ + u32 *p; + u32 words; + int i; + + p = (u32 *)buffer; + words = buffer->buf_size / 4; + for (i = 0; i < words; i++) + printf(" 0x%04x: 0x%08x\n", i * 4, p[i]); +} +#endif + +int bcm2835_mbox_call_prop(u32 chan, struct bcm2835_mbox_hdr *buffer) +{ + int ret; + u32 rbuffer; + struct bcm2835_mbox_tag_hdr *tag; + int tag_index; + +#ifdef DEBUG + printf("mbox: TX buffer\n"); + dump_buf(buffer); +#endif + + ret = bcm2835_mbox_call_raw(chan, (u32)buffer, &rbuffer); + if (ret) + return ret; + if (rbuffer != (u32)buffer) { + printf("mbox: Response buffer mismatch\n"); + return -1; + } + +#ifdef DEBUG + printf("mbox: RX buffer\n"); + dump_buf(buffer); +#endif + + /* Validate overall response status */ + + if (buffer->code != BCM2835_MBOX_RESP_CODE_SUCCESS) { + printf("mbox: Header response code invalid\n"); + return -1; + } + + /* Validate each tag's response status */ + + tag = (void *)(buffer + 1); + tag_index = 0; + while (tag->tag) { + if (!(tag->val_len & BCM2835_MBOX_TAG_VAL_LEN_RESPONSE)) { + printf("mbox: Tag %d missing val_len response bit\n", + tag_index); + return -1; + } + /* + * Clear the reponse bit so clients can just look right at the + * length field without extra processing + */ + tag->val_len &= ~BCM2835_MBOX_TAG_VAL_LEN_RESPONSE; + tag = (void *)(((u8 *)tag) + sizeof(*tag) + tag->val_buf_size); + tag_index++; + } + + return 0; +} diff --git a/arch/arm/include/asm/arch-bcm2835/mbox.h b/arch/arm/include/asm/arch-bcm2835/mbox.h new file mode 100644 index 0000000..6e040c5 --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/mbox.h @@ -0,0 +1,406 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BCM2835_MBOX_H +#define _BCM2835_MBOX_H + +#include <linux/compiler.h> + +/* + * The BCM2835 SoC contains (at least) two CPUs; the VideoCore (a/k/a "GPU") + * and the ARM CPU. The ARM CPU is often thought of as the main CPU. + * However, the VideoCore actually controls the initial SoC boot, and hides + * much of the hardware behind a protocol. This protocol is transported + * using the SoC's mailbox hardware module. + * + * The mailbox hardware supports passing 32-bit values back and forth. + * Presumably by software convention of the firmware, the bottom 4 bits of the + * value are used to indicate a logical channel, and the upper 28 bits are the + * actual payload. Various channels exist using these simple raw messages. See + * https://github.com/raspberrypi/firmware/wiki/Mailboxes for a list. As an + * example, the messages on the power management channel are a bitmask of + * devices whose power should be enabled. + * + * The property mailbox channel passes messages that contain the (16-byte + * aligned) ARM physical address of a memory buffer. This buffer is passed to + * the VC for processing, is modified in-place by the VC, and the address then + * passed back to the ARM CPU as the response mailbox message to indicate + * request completion. The buffers have a generic and extensible format; each + * buffer contains a standard header, a list of "tags", and a terminating zero + * entry. Each tag contains an ID indicating its type, and length fields for + * generic parsing. With some limitations, an arbitrary set of tags may be + * combined together into a single message buffer. This file defines structs + * representing the header and many individual tag layouts and IDs. + */ + +/* Raw mailbox HW */ + +#define BCM2835_MBOX_PHYSADDR 0x2000b880 + +struct bcm2835_mbox_regs { + u32 read; + u32 rsvd0[5]; + u32 status; + u32 config; + u32 write; +}; + +#define BCM2835_MBOX_STATUS_WR_FULL 0x80000000 +#define BCM2835_MBOX_STATUS_RD_EMPTY 0x40000000 + +/* Lower 4-bits are channel ID */ +#define BCM2835_CHAN_MASK 0xf +#define BCM2835_MBOX_PACK(chan, data) (((data) & (~BCM2835_CHAN_MASK)) | \ + (chan & BCM2835_CHAN_MASK)) +#define BCM2835_MBOX_UNPACK_CHAN(val) ((val) & BCM2835_CHAN_MASK) +#define BCM2835_MBOX_UNPACK_DATA(val) ((val) & (~BCM2835_CHAN_MASK)) + +/* Property mailbox buffer structures */ + +#define BCM2835_MBOX_PROP_CHAN 8 + +/* All message buffers must start with this header */ +struct bcm2835_mbox_hdr { + u32 buf_size; + u32 code; +}; + +#define BCM2835_MBOX_REQ_CODE 0 +#define BCM2835_MBOX_RESP_CODE_SUCCESS 0x80000000 + +#define BCM2835_MBOX_INIT_HDR(_m_) { \ + memset((_m_), 0, sizeof(*(_m_))); \ + (_m_)->hdr.buf_size = sizeof(*(_m_)); \ + (_m_)->hdr.code = 0; \ + (_m_)->end_tag = 0; \ + } + +/* + * A message buffer contains a list of tags. Each tag must also start with + * a standardized header. + */ +struct bcm2835_mbox_tag_hdr { + u32 tag; + u32 val_buf_size; + u32 val_len; +}; + +#define BCM2835_MBOX_INIT_TAG(_t_, _id_) { \ + (_t_)->tag_hdr.tag = BCM2835_MBOX_TAG_##_id_; \ + (_t_)->tag_hdr.val_buf_size = sizeof((_t_)->body); \ + (_t_)->tag_hdr.val_len = sizeof((_t_)->body.req); \ + } + +#define BCM2835_MBOX_INIT_TAG_NO_REQ(_t_, _id_) { \ + (_t_)->tag_hdr.tag = BCM2835_MBOX_TAG_##_id_; \ + (_t_)->tag_hdr.val_buf_size = sizeof((_t_)->body); \ + (_t_)->tag_hdr.val_len = 0; \ + } + +/* When responding, the VC sets this bit in val_len to indicate a response */ +#define BCM2835_MBOX_TAG_VAL_LEN_RESPONSE 0x80000000 + +/* + * Below we define the ID and struct for many possible tags. This header only + * defines individual tag structs, not entire message structs, since in + * general an arbitrary set of tags may be combined into a single message. + * Clients of the mbox API are expected to define their own overall message + * structures by combining the header, a set of tags, and a terminating + * entry. For example, + * + * struct msg { + * struct bcm2835_mbox_hdr hdr; + * struct bcm2835_mbox_tag_get_arm_mem get_arm_mem; + * ... perhaps other tags here ... + * u32 end_tag; + * }; + */ + +#define BCM2835_MBOX_TAG_GET_ARM_MEMORY 0x00010005 + +struct bcm2835_mbox_tag_get_arm_mem { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + } req; + struct { + u32 mem_base; + u32 mem_size; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_ALLOCATE_BUFFER 0x00040001 + +struct bcm2835_mbox_tag_allocate_buffer { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + u32 alignment; + } req; + struct { + u32 fb_address; + u32 fb_size; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_RELEASE_BUFFER 0x00048001 + +struct bcm2835_mbox_tag_release_buffer { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + } req; + struct { + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_BLANK_SCREEN 0x00040002 + +struct bcm2835_mbox_tag_blank_screen { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + /* bit 0 means on, other bots reserved */ + u32 state; + } req; + struct { + u32 state; + } resp; + } body; +}; + +/* Physical means output signal */ +#define BCM2835_MBOX_TAG_GET_PHYSICAL_W_H 0x00040003 +#define BCM2835_MBOX_TAG_TEST_PHYSICAL_W_H 0x00044003 +#define BCM2835_MBOX_TAG_SET_PHYSICAL_W_H 0x00048003 + +struct bcm2835_mbox_tag_physical_w_h { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 width; + u32 height; + } req; + struct { + u32 width; + u32 height; + } resp; + } body; +}; + +/* Virtual means display buffer */ +#define BCM2835_MBOX_TAG_GET_VIRTUAL_W_H 0x00040004 +#define BCM2835_MBOX_TAG_TEST_VIRTUAL_W_H 0x00044004 +#define BCM2835_MBOX_TAG_SET_VIRTUAL_W_H 0x00048004 + +struct bcm2835_mbox_tag_virtual_w_h { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 width; + u32 height; + } req; + struct { + u32 width; + u32 height; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_DEPTH 0x00040005 +#define BCM2835_MBOX_TAG_TEST_DEPTH 0x00044005 +#define BCM2835_MBOX_TAG_SET_DEPTH 0x00048005 + +struct bcm2835_mbox_tag_depth { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 bpp; + } req; + struct { + u32 bpp; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_PIXEL_ORDER 0x00040006 +#define BCM2835_MBOX_TAG_TEST_PIXEL_ORDER 0x00044005 +#define BCM2835_MBOX_TAG_SET_PIXEL_ORDER 0x00048006 + +#define BCM2835_MBOX_PIXEL_ORDER_BGR 0 +#define BCM2835_MBOX_PIXEL_ORDER_RGB 1 + +struct bcm2835_mbox_tag_pixel_order { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 order; + } req; + struct { + u32 order; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_ALPHA_MODE 0x00040007 +#define BCM2835_MBOX_TAG_TEST_ALPHA_MODE 0x00044007 +#define BCM2835_MBOX_TAG_SET_ALPHA_MODE 0x00048007 + +#define BCM2835_MBOX_ALPHA_MODE_0_OPAQUE 0 +#define BCM2835_MBOX_ALPHA_MODE_0_TRANSPARENT 1 +#define BCM2835_MBOX_ALPHA_MODE_IGNORED 2 + +struct bcm2835_mbox_tag_alpha_mode { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 alpha; + } req; + struct { + u32 alpha; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_PITCH 0x00040008 + +struct bcm2835_mbox_tag_pitch { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + } req; + struct { + u32 pitch; + } resp; + } body; +}; + +/* Offset of display window within buffer */ +#define BCM2835_MBOX_TAG_GET_VIRTUAL_OFFSET 0x00040009 +#define BCM2835_MBOX_TAG_TEST_VIRTUAL_OFFSET 0x00044009 +#define BCM2835_MBOX_TAG_SET_VIRTUAL_OFFSET 0x00048009 + +struct bcm2835_mbox_tag_virtual_offset { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 x; + u32 y; + } req; + struct { + u32 x; + u32 y; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_OVERSCAN 0x0004000a +#define BCM2835_MBOX_TAG_TEST_OVERSCAN 0x0004400a +#define BCM2835_MBOX_TAG_SET_OVERSCAN 0x0004800a + +struct bcm2835_mbox_tag_overscan { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + /* req not used for get */ + struct { + u32 top; + u32 bottom; + u32 left; + u32 right; + } req; + struct { + u32 top; + u32 bottom; + u32 left; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_GET_PALETTE 0x0004000b + +struct bcm2835_mbox_tag_get_palette { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + } req; + struct { + u32 data[1024]; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_TEST_PALETTE 0x0004400b + +struct bcm2835_mbox_tag_test_palette { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + u32 offset; + u32 num_entries; + u32 data[256]; + } req; + struct { + u32 is_invalid; + } resp; + } body; +}; + +#define BCM2835_MBOX_TAG_SET_PALETTE 0x0004800b + +struct bcm2835_mbox_tag_set_palette { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + u32 offset; + u32 num_entries; + u32 data[256]; + } req; + struct { + u32 is_invalid; + } resp; + } body; +}; + +/* + * Pass a raw u32 message to the VC, and receive a raw u32 back. + * + * Returns 0 for success, any other value for error. + */ +int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv); + +/* + * Pass a complete property-style buffer to the VC, and wait until it has + * been processed. + * + * This function expects a pointer to the mbox_hdr structure in an attempt + * to ensure some degree of type safety. However, some number of tags and + * a termination value are expected to immediately follow the header in + * memory, as required by the property protocol. + * + * Returns 0 for success, any other value for error. + */ +int bcm2835_mbox_call_prop(u32 chan, struct bcm2835_mbox_hdr *buffer); + +#endif
The firmware running on the bcm2835 SoC's VideoCore CPU determines how much of the system RAM is available for use by the ARM CPU. Previously, U-Boot assumed that only 128MB was available, since this was the smallest value configured by any public firmware. However, we can now query the actual value at run-time from the firmware using the mbox property protocol.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: Updated to use macros etc. added in v2 of mbox driver patch. --- board/raspberrypi/rpi_b/rpi_b.c | 21 ++++++++++++++++++++- 1 file changed, 20 insertions(+), 1 deletion(-)
diff --git a/board/raspberrypi/rpi_b/rpi_b.c b/board/raspberrypi/rpi_b/rpi_b.c index 688b0aa..3c654a1 100644 --- a/board/raspberrypi/rpi_b/rpi_b.c +++ b/board/raspberrypi/rpi_b/rpi_b.c @@ -15,13 +15,32 @@ */
#include <common.h> +#include <asm/arch/mbox.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR;
+struct msg_get_arm_mem { + struct bcm2835_mbox_hdr hdr; + struct bcm2835_mbox_tag_get_arm_mem get_arm_mem; + u32 end_tag; +}; + int dram_init(void) { - gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + ALLOC_ALIGN_BUFFER(struct msg_get_arm_mem, msg, 1, 16); + int ret; + + BCM2835_MBOX_INIT_HDR(msg); + BCM2835_MBOX_INIT_TAG(&msg->get_arm_mem, GET_ARM_MEMORY); + + ret = bcm2835_mbox_call_prop(BCM2835_MBOX_PROP_CHAN, &msg->hdr); + if (ret) { + printf("bcm2835: Could not query ARM memory size\n"); + return -1; + } + + gd->ram_size = msg->get_arm_mem.body.resp.mem_size;
return 0; }
When an LCD driver is actually driving a regular external display, e.g. an HDMI monitor, the display resolution might not be known until the display controller has initialized, i.e. during lcd_ctrl_init(). However, lcd.c calculates lcd_line_length before calling this function, thus relying on a hard-coded resolution in struct panel_info.
Instead, defer this calculation until after lcd_ctrl_init() has had the chance to dynamically determine the resolution. This needs to happen before lcd_clear(), since the value is used there.
grep indicates that no code outside lcd.c uses this lcd_line_length; in particular, no lcd_ctrl_init() implementations read it.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- common/lcd.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index b6be800..1a20f85 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -333,8 +333,6 @@ int drv_lcd_init (void)
lcd_base = (void *)(gd->fb_base);
- lcd_line_length = (panel_info.vl_col * NBITS (panel_info.vl_bpix)) / 8; - lcd_init(lcd_base); /* LCD initialization */
/* Device initialization */ @@ -416,6 +414,7 @@ static int lcd_init(void *lcdbase) debug("[LCD] Initializing LCD frambuffer at %p\n", lcdbase);
lcd_ctrl_init(lcdbase); + lcd_line_length = (panel_info.vl_col * NBITS(panel_info.vl_bpix)) / 8; lcd_is_enabled = 1; lcd_clear(); lcd_enable ();
On Thu, 18 Oct 2012 22:51:33 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
Acked-by: Anatolij Gustschin agust@denx.de
Thanks, Anatolij
The firmware running on the bcm2835 SoC's VideoCore CPU manages the display controller. Add a simple "LCD" drive that communicates with the firmware using the property mailbox protocol. This configures the display and frame-buffer to match whatever physical resolution the firmware chosen when booting, which is typically the native resolution of the attached display device, presumably unless otherwise specified in config.txt on the boot media.
Enable this driver in the Raspberry Pi board configuration.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- v2: New patch. --- drivers/video/Makefile | 1 + drivers/video/bcm2835.c | 126 +++++++++++++++++++++++++++++++++++++++++++++++ include/configs/rpi_b.h | 16 ++++++ 3 files changed, 143 insertions(+) create mode 100644 drivers/video/bcm2835.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index ebb6da8..e6efda6 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_S6E8AX0) += s6e8ax0.o COBJS-$(CONFIG_S6E63D6) += s6e63d6.o COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_AMBA) += amba.o +COBJS-$(CONFIG_VIDEO_BCM2835) += bcm2835.o COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o diff --git a/drivers/video/bcm2835.c b/drivers/video/bcm2835.c new file mode 100644 index 0000000..739a639 --- /dev/null +++ b/drivers/video/bcm2835.c @@ -0,0 +1,126 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <lcd.h> +#include <asm/arch/mbox.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Global variables that lcd.c expects to exist */ +int lcd_line_length; +int lcd_color_fg; +int lcd_color_bg; +void *lcd_base; +void *lcd_console_address; +short console_col; +short console_row; +vidinfo_t panel_info; +char lcd_cursor_enabled; +ushort lcd_cursor_width; +ushort lcd_cursor_height; + +struct msg_query { + struct bcm2835_mbox_hdr hdr; + struct bcm2835_mbox_tag_physical_w_h physical_w_h; + u32 end_tag; +}; + +struct msg_setup { + struct bcm2835_mbox_hdr hdr; + struct bcm2835_mbox_tag_physical_w_h physical_w_h; + struct bcm2835_mbox_tag_virtual_w_h virtual_w_h; + struct bcm2835_mbox_tag_depth depth; + struct bcm2835_mbox_tag_pixel_order pixel_order; + struct bcm2835_mbox_tag_alpha_mode alpha_mode; + struct bcm2835_mbox_tag_virtual_offset virtual_offset; + struct bcm2835_mbox_tag_overscan overscan; + struct bcm2835_mbox_tag_allocate_buffer allocate_buffer; + u32 end_tag; +}; + +void lcd_ctrl_init(void *lcdbase) +{ + ALLOC_ALIGN_BUFFER(struct msg_query, msg_query, 1, 16); + ALLOC_ALIGN_BUFFER(struct msg_setup, msg_setup, 1, 16); + int ret; + u32 w, h; + + debug("bcm2835: Query resolution...\n"); + + BCM2835_MBOX_INIT_HDR(msg_query); + BCM2835_MBOX_INIT_TAG_NO_REQ(&msg_query->physical_w_h, + GET_PHYSICAL_W_H); + ret = bcm2835_mbox_call_prop(BCM2835_MBOX_PROP_CHAN, &msg_query->hdr); + if (ret) { + printf("bcm2835: Could not query display resolution\n"); + /* FIXME: How to disable the LCD to prevent errors? hang()? */ + return; + } + + w = msg_query->physical_w_h.body.resp.width; + h = msg_query->physical_w_h.body.resp.height; + + debug("bcm2835: Setting up display for %d x %d\n", w, h); + + BCM2835_MBOX_INIT_HDR(msg_setup); + BCM2835_MBOX_INIT_TAG(&msg_setup->physical_w_h, SET_PHYSICAL_W_H); + msg_setup->physical_w_h.body.req.width = w; + msg_setup->physical_w_h.body.req.height = h; + BCM2835_MBOX_INIT_TAG(&msg_setup->virtual_w_h, SET_VIRTUAL_W_H); + msg_setup->virtual_w_h.body.req.width = w; + msg_setup->virtual_w_h.body.req.height = h; + BCM2835_MBOX_INIT_TAG(&msg_setup->depth, SET_DEPTH); + msg_setup->depth.body.req.bpp = 16; + BCM2835_MBOX_INIT_TAG(&msg_setup->pixel_order, SET_PIXEL_ORDER); + msg_setup->pixel_order.body.req.order = BCM2835_MBOX_PIXEL_ORDER_BGR; + BCM2835_MBOX_INIT_TAG(&msg_setup->alpha_mode, SET_ALPHA_MODE); + msg_setup->alpha_mode.body.req.alpha = BCM2835_MBOX_ALPHA_MODE_IGNORED; + BCM2835_MBOX_INIT_TAG(&msg_setup->virtual_offset, SET_VIRTUAL_OFFSET); + msg_setup->virtual_offset.body.req.x = 0; + msg_setup->virtual_offset.body.req.y = 0; + BCM2835_MBOX_INIT_TAG(&msg_setup->overscan, SET_OVERSCAN); + msg_setup->overscan.body.req.top = 0; + msg_setup->overscan.body.req.bottom = 0; + msg_setup->overscan.body.req.left = 0; + msg_setup->overscan.body.req.right = 0; + BCM2835_MBOX_INIT_TAG(&msg_setup->allocate_buffer, ALLOCATE_BUFFER); + msg_setup->allocate_buffer.body.req.alignment = 0x100; + + ret = bcm2835_mbox_call_prop(BCM2835_MBOX_PROP_CHAN, &msg_setup->hdr); + if (ret) { + printf("bcm2835: Could not configure display\n"); + /* FIXME: How to disable the LCD to prevent errors? hang()? */ + return; + } + + w = msg_setup->physical_w_h.body.resp.width; + h = msg_setup->physical_w_h.body.resp.height; + + debug("bcm2835: Final resolution is %d x %d\n", w, h); + + panel_info.vl_col = w; + panel_info.vl_row = h; + panel_info.vl_bpix = LCD_COLOR16; + + gd->fb_base = msg_setup->allocate_buffer.body.resp.fb_address; + lcd_base = (void *)gd->fb_base; +} + +void lcd_enable(void) +{ +} diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index cf62e45..a709feb 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -57,6 +57,17 @@ /* Devices */ /* GPIO */ #define CONFIG_BCM2835_GPIO +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR16 +/* + * Prevent allocation of RAM for FB; the real FB address is queried + * dynamically from the VideoCore co-processor, and comes from RAM + * not owned by the ARM CPU. + */ +#define CONFIG_FB_ADDR 0 +#define CONFIG_VIDEO_BCM2835 +#define CONFIG_SYS_WHITE_ON_BLACK
/* Console UART */ #define CONFIG_PL011_SERIAL @@ -74,6 +85,11 @@ #define CONFIG_ENV_SIZE SZ_16K #define CONFIG_ENV_IS_NOWHERE #define CONFIG_SYS_LOAD_ADDR 0x1000000 +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_EXTRA_ENV_SETTINGS "stdin=serial\0" \ + "stderr=serial,lcd\0" \ + "stdout=serial,lcd\0"
/* Shell */ #define CONFIG_SYS_HUSH_PARSER
On Thu, 18 Oct 2012 22:51:34 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
s/drive/driver
- (C) Copyright 2012 Stephen Warren
- project.
- modify it under the terms of the GNU General Public License
- version 2 as published by the Free Software Foundation.
All new code that gets added to U-Boot shall use GPLv3-compatible licensing since there are plans to move later versions of U-Boot to version 3 of the GPL. Therefore we ask for "GPL, either version 2, or (at your option) any later version" phrase.
Thanks, Anatolij
- project.
Um, that doesn't seem possible. Or, is U-Boot simply going to delete any GPL-v2-only code? I don't have stats, but I would guess that there is a significant amount of GPL-v2-only code, isn't there?
BTW, is this documented anywhere for reference?
On Mon, 05 Nov 2012 10:19:36 -0700 Stephen Warren swarren@wwwdotorg.org wrote:
- project.
I do not have stats too and do not know the details how it is supposed to be done. In my understanding switching go GPLv3 it is a long term goal and we shouldn't make it harder by adding more GPLv3 incompatible code. Ccing Wolfgang, maybe Wolfgang can tell more here.
It is documented here [1].
Thanks, Anatolij
Hi Stephen,
On Thu, 18 Oct 2012 22:51:31 -0600, Stephen Warren swarren@wwwdotorg.org wrote:
v2:
- Added documentation to mbox.h.
- Implemented macros to set up headers and tags.
- Implemented error-checking of response bits in bcm2835_mbox_call_prop().
- Reworked tag structs based on experience writing LCD driver.
- Added a lot more video-related tag structs.
- Added debug spew and error messages to mbox.c; useful when debugging LCD.
- Removed __packed attributes from message structs.
- Removed stale FIXME comments.
- project.
- This program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of
- struct bcm2835_mbox_regs *regs =
- ulong endtime = get_timer(0) + TIMEOUT;
- u32 val;
- debug("time: %lu timeout: %lu\n", get_timer(0), endtime);
- if (send & BCM2835_CHAN_MASK) {
return -1;
- /* Drain any stale responses */
- for (;;) {
break;
return -1;
- /* Wait for space to send */
- for (;;) {
break;
return -1;
- /* Send the request */
- val = BCM2835_MBOX_PACK(chan, send);
- debug("mbox: TX raw: 0x%08x\n", val);
- writel(val, ®s->write);
- /* Wait for the response */
- for (;;) {
break;
return -1;
- /* Read the response */
- val = readl(®s->read);
- debug("mbox: RX raw: 0x%08x\n", val);
- /* Validate the response */
- if (BCM2835_MBOX_UNPACK_CHAN(val) != chan) {
return -1;
- *recv = BCM2835_MBOX_UNPACK_DATA(val);
- u32 *p;
- u32 words;
- int i;
- p = (u32 *)buffer;
- words = buffer->buf_size / 4;
- for (i = 0; i < words; i++)
+} +#endif
- int ret;
- u32 rbuffer;
- struct bcm2835_mbox_tag_hdr *tag;
- int tag_index;
+#ifdef DEBUG
- printf("mbox: TX buffer\n");
- dump_buf(buffer);
- ret = bcm2835_mbox_call_raw(chan, (u32)buffer, &rbuffer);
- if (ret)
return ret;
- if (rbuffer != (u32)buffer) {
return -1;
+#ifdef DEBUG
- printf("mbox: RX buffer\n");
- dump_buf(buffer);
- /* Validate overall response status */
- if (buffer->code != BCM2835_MBOX_RESP_CODE_SUCCESS) {
return -1;
- /* Validate each tag's response status */
- tag = (void *)(buffer + 1);
- tag_index = 0;
- while (tag->tag) {
tag_index);
return -1;
tag_index++;
- project.
- The BCM2835 SoC contains (at least) two CPUs; the VideoCore (a/k/a "GPU")
- and the ARM CPU. The ARM CPU is often thought of as the main CPU.
- However, the VideoCore actually controls the initial SoC boot, and hides
- much of the hardware behind a protocol. This protocol is transported
- using the SoC's mailbox hardware module.
- The mailbox hardware supports passing 32-bit values back and forth.
- Presumably by software convention of the firmware, the bottom 4 bits of the
- value are used to indicate a logical channel, and the upper 28 bits are the
- actual payload. Various channels exist using these simple raw messages. See
- https://github.com/raspberrypi/firmware/wiki/Mailboxes for a list. As an
- example, the messages on the power management channel are a bitmask of
- devices whose power should be enabled.
- The property mailbox channel passes messages that contain the (16-byte
- aligned) ARM physical address of a memory buffer. This buffer is passed to
- the VC for processing, is modified in-place by the VC, and the address then
- passed back to the ARM CPU as the response mailbox message to indicate
- request completion. The buffers have a generic and extensible format; each
- buffer contains a standard header, a list of "tags", and a terminating zero
- entry. Each tag contains an ID indicating its type, and length fields for
- generic parsing. With some limitations, an arbitrary set of tags may be
- combined together into a single message buffer. This file defines structs
- representing the header and many individual tag layouts and IDs.
- u32 read;
- u32 rsvd0[5];
- u32 status;
- u32 config;
- u32 write;
- u32 buf_size;
- u32 code;
- A message buffer contains a list of tags. Each tag must also start with
- a standardized header.
- u32 tag;
- u32 val_buf_size;
- u32 val_len;
- Below we define the ID and struct for many possible tags. This header only
- defines individual tag structs, not entire message structs, since in
- general an arbitrary set of tags may be combined into a single message.
- Clients of the mbox API are expected to define their own overall message
- structures by combining the header, a set of tags, and a terminating
- entry. For example,
- struct msg {
u32 end_tag;
- struct bcm2835_mbox_tag_hdr tag_hdr;
- union {
struct {
} req;
struct {
u32 mem_base;
u32 mem_size;
} resp;
- } body;
- union {
struct {
u32 alignment;
} req;
struct {
u32 fb_address;
u32 fb_size;
} resp;
- } body;
- union {
struct {
} req;
struct {
} resp;
- } body;
- union {
struct {
u32 state;
} req;
struct {
u32 state;
} resp;
- } body;
- union {
struct {
u32 width;
u32 height;
} req;
struct {
u32 width;
u32 height;
} resp;
- } body;
- union {
struct {
u32 width;
u32 height;
} req;
struct {
u32 width;
u32 height;
} resp;
- } body;
- union {
struct {
u32 bpp;
} req;
struct {
u32 bpp;
} resp;
- } body;
- union {
struct {
u32 order;
} req;
struct {
u32 order;
} resp;
- } body;
- union {
struct {
u32 alpha;
} req;
struct {
u32 alpha;
} resp;
- } body;
- union {
struct {
} req;
struct {
u32 pitch;
} resp;
- } body;
- union {
struct {
u32 x;
u32 y;
} req;
struct {
u32 x;
u32 y;
} resp;
- } body;
- union {
struct {
u32 top;
u32 bottom;
u32 left;
u32 right;
} req;
struct {
u32 top;
u32 bottom;
u32 left;
} resp;
- } body;
- union {
struct {
} req;
struct {
u32 data[1024];
} resp;
- } body;
- union {
struct {
u32 offset;
u32 num_entries;
u32 data[256];
} req;
struct {
u32 is_invalid;
} resp;
- } body;
- union {
struct {
u32 offset;
u32 num_entries;
u32 data[256];
} req;
struct {
u32 is_invalid;
} resp;
- } body;
- Pass a raw u32 message to the VC, and receive a raw u32 back.
- Returns 0 for success, any other value for error.
- Pass a complete property-style buffer to the VC, and wait until it has
- been processed.
- This function expects a pointer to the mbox_hdr structure in an attempt
- to ensure some degree of type safety. However, some number of tags and
- a termination value are expected to immediately follow the header in
- memory, as required by the property protocol.
Cc: Anatolij as the video custodian.
2 of the 4 commits in this patch set are ARM related, 2 are video related. Anatolij, if you ack the last two, I can pull the whole series in ARM directly.
Amicalement,
Albert ARIBAUD
Anatolij Gustschin
Stephen Warren
