[PATCH] arm64: zynqmp: Define all eeproms for SC on vck190
There are multiple eeproms on vck190 that's why list all of them. FMC eeproms are present only when fmcs are plugged.
U-Boot 2021.10-rc4-00055-g43682f4ae2ab (Sep 24 2021 - 14:27:37 +0200)
CPU: ZynqMP Silicon: v3 Model: Versal System Controller on a2197 Eval board RevA Board: Xilinx ZynqMP DRAM: 2 GiB PMUFW: v1.1 Xilinx I2C FRU format at nvmem0: Manufacturer Name: XILINX Product Name: VCK190 Serial No: 822124130510 Part Number: 043123456 File ID: 0x0 Revision Number: REV_B01 Xilinx I2C FRU format at nvmem1: Manufacturer Name: XILINX Product Name: X-EBM-01 Serial No: 057922110-129412 Part Number: 190 File ID: 0x0 Revision Number: REV_A02 Xilinx I2C FRU format at nvmem2: Manufacturer Name: XILINX Product Name: FMC-XM119-PMOD Serial No: 118690 Part Number: 0 File ID: 0x0 Revision Number: B Board area require minimum 5 fields Xilinx I2C FRU format at nvmem3: Manufacturer Name: Avnet Product Name: FMC-IMAGEON Serial No: 9930 Part Number: AES-FMCIMAGEON-G File ID: 0x0 Revision Number: B EL Level: EL2 Chip ID: zu4e WDT: Not found!
--- arch/arm/dts/zynqmp-e-a2197-00-revA.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/zynqmp-e-a2197-00-revA.dts b/arch/arm/dts/zynqmp-e-a2197-00-revA.dts index bd0ba557e072..f229880a7021 100644 --- a/arch/arm/dts/zynqmp-e-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-e-a2197-00-revA.dts @@ -24,6 +24,9 @@ i2c1 = &i2c1; mmc0 = &sdhci1; nvmem0 = &eeprom; + nvmem1 = &eeprom_ebm; + nvmem2 = &eeprom_fmc1; + nvmem3 = &eeprom_fmc2; rtc0 = &rtc; serial0 = &uart0; serial1 = &dcc; @@ -477,6 +480,10 @@ silabs,skip-recall; }; /* and connector J212D */ + eeprom_ebm: eeprom@52 { /* x-ebm module */ + compatible = "st,24c128", "atmel,24c128"; + reg = <0x52>; + }; }; fmc1: i2c@1 { /* FMCP1_IIC */ #address-cells = <1>; @@ -484,6 +491,10 @@ reg = <1>; /* FIXME connection to Samtec J51C */ /* expected eeprom 0x50 FMC cards */ + eeprom_fmc1: eeprom@50 { + compatible = "st,24c128", "atmel,24c128"; + reg = <0x50>; + }; }; fmc2: i2c@2 { /* FMCP2_IIC */ #address-cells = <1>; @@ -491,6 +502,10 @@ reg = <2>; /* FIXME connection to Samtec J53C */ /* expected eeprom 0x50 FMC cards */ + eeprom_fmc2: eeprom@50 { + compatible = "st,24c128", "atmel,24c128"; + reg = <0x50>; + }; }; i2c@3 { /* DDR4_DIMM1 */ #address-cells = <1>;
Michal Simek
