[U-Boot-Users] [patch] add support for "eeprom info"
This patch adds a new sub command to eeprom called "info". This allows eeprom driver writers to implement a way of querying the device. For example, SPI flashes have status commands, jedec ids, part ids, and other fun stuff. It's useful to be able to quickly probe this data (so you know things are detected properly and all that jazz).
For example, on Blackfin boards, you can do: bfin> eeprom info SPI Device: m25p128 0x20 (ST) 0x20 0x18 Parameters: num sectors = 64, sector size = 262144, write size = 256 Flash Size: 128 mbit (16 mbyte) Status: 0x00
I made the function weak so that people aren't required to implement this function (mostly so that it does not break all the SPI drivers out there right now).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index e5000e9..cc8c277 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -49,6 +49,7 @@ extern int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); extern int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); +extern int eeprom_info (void) __attribute__((weak)); #if defined(CFG_EEPROM_WREN) extern int eeprom_write_enable (unsigned dev_addr, int state); #endif @@ -104,7 +105,8 @@ int do_eeprom ( cmd_tbl_t * cmdtp, int flag, int argc, char *argv[])
puts ("done\n"); return rcode; - } + } else if (argc == 2 && eeprom_info && strcmp (argv[1], "info") == 0) + return eeprom_info (); }
printf ("Usage:\n%s\n", cmdtp->usage); @@ -435,6 +437,7 @@ U_BOOT_CMD( "read devaddr addr off cnt\n" "eeprom write devaddr addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'\n" + "eeprom info\n" ); #else /* One EEPROM */ U_BOOT_CMD( @@ -443,6 +446,7 @@ U_BOOT_CMD( "read addr off cnt\n" "eeprom write addr off cnt\n" " - read/write `cnt' bytes at EEPROM offset `off'\n" + "eeprom info\n" ); #endif /* CFG_I2C_MULTI_EEPROMS */
diff --git a/include/common.h b/include/common.h index 54083f1..511e2f6 100644 --- a/include/common.h +++ b/include/common.h @@ -298,6 +298,7 @@ int eeprom_probe (unsigned dev_addr, unsigned offset); #endif int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); +int eeprom_info (void) __attribute__((weak)); /* optional interface */ #ifdef CONFIG_LWMON extern uchar pic_read (uchar reg); extern void pic_write (uchar reg, uchar val);
How is this suppoesed to work on the "normal" EEPROm devices which are typically attached to the I2C bus?
... and I2C.
... && eeprom_info && ...?
Does that mean that a weak function resolves to a NULL pointer? Is this guaranteed?
... and I2C.
i have no idea, i dont use i2c flashes. i dont know if there is any standard for them. if there isnt, easy enough to protect with CONFIG_SPI.
of course. an undefined weak function resolves to 0. -mike
In message 200801231615.09447.vapier@gentoo.org you wrote:
... and I2C.
We're not talking about flashes. We're talking about EEPROM. For example things like a AT24C164 or similar, see for example http://www.atmel.com/dyn/resources/prod_documents/doc0105.pdf
Ah. I didn't know that. Thanks.
... and I2C.
the semantics are irrelevant. it's an external non-volatile memory device accessed via the eeprom command. the document you posted looks like that device doesnt have any way of querying it, so eeprom_info() for that device would be useless. if this is normal among i2c eeproms, i'll repost the patch with eeprom_info behind CONFIG_SPI. most SPI flashes nowadays support the jedec id command which allows for dynamic detection (which is how the Blackfin SPI driver that i wrote works). hook up any SPI flash and it "just works". -mike
Indeed. There is no way to query such devices.
Thsi is normal for basicly *all* EEPROM and FRAM devices I know with I2C or SPI interfaces.
with eeprom_info behind CONFIG_SPI. most SPI flashes nowadays support the jedec id command which allows for dynamic detection (which is how the Blackfin SPI driver that i wrote works). hook up any SPI flash and it "jus> t works".
I think you are doing something wrong when you try to use "eeprom" to access "SPI flash" - these are differnt entities...
then what is the "correct" method ? i dont see any other usable option in u-boot for hooking up SPI flashes without writing my own subsystem. -mike
Hey Mike,
Until recently SPI in U-boot was synonymous with 'SPI-based EEPROM'. In fact, CONFIG_SPI doesn't mean 'configure support for a SPI controller', it means 'configure support for a SPI EEPROM'. This is of course yet another artifact from another day that it would be nice to clean up.
I introduced CONFIG_HARD_SPI in the latest release cycle, and included a driver for a Freescale controller. It would be nice to have other drivers added for generic SPI support. My preference would be for you to expand the 'spi' command with something like:
'spi eeprom info'
regards, Ben
On Wednesday 23 January 2008, Ben Warren wrote:
Hey Mike,
i'm aware of this
'spi eeprom info'
i dont see how in the long run, this is any different from today. Wolfgang can still argue that the SPI flash is not an eeprom device, so "spi eeprom ..." is not appropriate. which means there is still no subsystem whatsoever for accessing SPI flashes. -mike
'spi eeprom info'
You are right - I think "spi eeprom" is not a good choice - if it is an EEPROM, then the "eeprom" command should work, no matter what the actual bus interface is.
If the device is SPI flash, then why not call it like that, i. e.
spi flash info
Or spiflash info
to make it similar to the "nand" commands?
On the other hand, it might be still too shortsighted to tie this to the bus interface. For example, what about dataflash? As discussed many times before, we have similar issues with dataflash devices.
I don't have a good idea how to do it, but maybe this is a chance to get a good solution for NAND, dataflash, SPI flash and who knows what else?
spi flash info
i dont like this because of the integration it'd require with the generic spi command
Or spiflash info
this sounds easy enough that i could probably do this ...
i'm not sure i follow. what do you mean by dataflash ? the atmel dataflashes ? the AT45DBxxx parts ?
i can see the motivation for this, but i'm not sure if it's worth the overhead ... SPI flash is more like parallel NOR flash than NAND. there are no bad blocks, ecc, etc... with SPI flashes. -mike
let's make sure we're talking about the same thing. SPI flashes are eeproms that have a SPI interface. so Spansion's S25FLxxxx, ST's m25pxtmels AT45DBxxxx, Winbond's W25Xxx/W25Pxx, and such. they need to be erased before writing, are split up into some unit size, etc... all SPI flashes nowadays conform to the JEDEC standard (JEP106) which allows for querying of manufacturer/device ids so that they can be dynamically detected. sounds to me like "eeprom" is the correct interface for utilizing these devices. -mike
Sounds to me as if you were talking about flash devices with a SPI bus interface.
The original SPI eeprom support was implemented som 7+ years ago for the Siemens CCM board; this is where the "CONFIG_SPI" stuff in common/cmd_eeprom.c comes from, and this was supported by the cpu/mpc8xx/spi.c SPI driver. Note that this was a real EEPROM device, i. e. we just needed spi_read() and spi_write() functions to access it. No erase, no sectors or any such stuff.
That was an EEPROM - what you have looks like a flash device to me.
OK, thanks for the explanation. this is much before my time ;).
at the moment, the Blackfin SPI flash driver hides all of the erasing/writing stuff for the user so that it integrates easily into the eeprom command. i'm going to guess that you dont like the sound of that at all ;). -mike
You know me pretty well.
Well, there is a big difference between NOR flash and your device: NOR flash is memory, but your's is a storage device attached to some bus interface (SPI here). The problem is that we don't have a good solution to interface with such devices yet.
Using the eeprom command for such devices is misleading, IMO. If you can live with the spiflash command, then this is not perfect, but I guess it will have to do for now as we don't have a better solution yet.
so we're clear, the proposed interface is: spiflash info spiflash <read|write> address offset count spiflash erase offset count
and once this comes together (i dont think it'll take long), we can consider a generic "flash" command. i'm still not sure what it'll gain us (if anything) ... but i guess once we have more things to look at and compare, we can make a better decision -mike
This sounds fine to me. The address is obviously a ram source/destination address. I vote for an offset in bytes and a count in bytes. If the offset is not an appropriate sector boundary, it is an error. The count can be a partial sector without problems. Having the offset and count in different units is confusing IMHO, so bytes for both. Also, Mike, I assume you will also add a module similar to env_eeprom.c to support environment in spiflash?
Best Regards, Bill Campbell
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
it would be exactly the same as all other interfaces. we dont hold the users hand by calculating pages for them in other places, so we wont here either. in other words, yes. ;)
yes -mike
Ben Warren
J. William Campbell
Mike Frysinger
