[U-Boot] [PATCH] driver/ifc:Change accessor function to take care of endianness
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP.
So update acessor function with common IFC accessors to take care both type of endianness.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- README | 6 + arch/powerpc/include/asm/config_mpc85xx.h | 3 + drivers/mtd/nand/fsl_ifc_nand.c | 243 +++++++++++++++-------------- drivers/mtd/nand/fsl_ifc_spl.c | 60 +++---- include/fsl_ifc.h | 42 +++-- 5 files changed, 190 insertions(+), 164 deletions(-)
diff --git a/README b/README index aea82be..d948afa 100644 --- a/README +++ b/README @@ -472,6 +472,12 @@ The following options need to be configured: Board config to use DDR3. It can be enabled for SoCs with Freescale DDR3 controllers.
+ CONFIG_SYS_FSL_IFC_BE + Define the IFC controller register space as Big Endian + + CONFIG_SYS_FSL_IFC_LE + Define the IFC controller register space as Little Endian + - Intel Monahans options: CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 54ce2f0..32307c8 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -22,6 +22,9 @@ #define FSL_DDR_VER_4_7 47 #define FSL_DDR_VER_5_0 50
+/* IP endianness */ +#define CONFIG_SYS_FSL_IFC_BE + /* Number of TLB CAM entries we have on FSL Book-E chips */ #if defined(CONFIG_E500MC) #define CONFIG_SYS_NUM_TLBCAMS 64 diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 1808a7f..be5a16a 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -230,8 +230,8 @@ static void set_addr(struct mtd_info *mtd, int column, int page_addr, int oob) ctrl->page = page_addr;
/* Program ROW0/COL0 */ - out_be32(&ifc->ifc_nand.row0, page_addr); - out_be32(&ifc->ifc_nand.col0, (oob ? IFC_NAND_COL_MS : 0) | column); + ifc_out32(&ifc->ifc_nand.row0, page_addr); + ifc_out32(&ifc->ifc_nand.col0, (oob ? IFC_NAND_COL_MS : 0) | column);
buf_num = page_addr & priv->bufnum_mask;
@@ -294,23 +294,23 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) int i;
/* set the chip select for NAND Transaction */ - out_be32(&ifc->ifc_nand.nand_csel, ifc_ctrl->cs_nand); + ifc_out32(&ifc->ifc_nand.nand_csel, ifc_ctrl->cs_nand);
/* start read/write seq */ - out_be32(&ifc->ifc_nand.nandseq_strt, - IFC_NAND_SEQ_STRT_FIR_STRT); + ifc_out32(&ifc->ifc_nand.nandseq_strt, + IFC_NAND_SEQ_STRT_FIR_STRT);
/* wait for NAND Machine complete flag or timeout */ end_tick = usec2ticks(IFC_TIMEOUT_MSECS * 1000) + get_ticks();
while (end_tick > get_ticks()) { - ctrl->status = in_be32(&ifc->ifc_nand.nand_evter_stat); + ctrl->status = ifc_in32(&ifc->ifc_nand.nand_evter_stat);
if (ctrl->status & IFC_NAND_EVTER_STAT_OPC) break; }
- out_be32(&ifc->ifc_nand.nand_evter_stat, ctrl->status); + ifc_out32(&ifc->ifc_nand.nand_evter_stat, ctrl->status);
if (ctrl->status & IFC_NAND_EVTER_STAT_FTOER) printf("%s: Flash Time Out Error\n", __func__); @@ -324,7 +324,7 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) int sector_end = sector + chip->ecc.steps - 1;
for (i = sector / 4; i <= sector_end / 4; i++) - eccstat[i] = in_be32(&ifc->ifc_nand.nand_eccstat[i]); + eccstat[i] = ifc_in32(&ifc->ifc_nand.nand_eccstat[i]);
for (i = sector; i <= sector_end; i++) { errors = check_read_ecc(mtd, ctrl, eccstat, i); @@ -364,30 +364,30 @@ static void fsl_ifc_do_read(struct nand_chip *chip,
/* Program FIR/IFC_NAND_FCR0 for Small/Large page */ if (mtd->writesize > 512) { - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | - (IFC_FIR_OP_RBCD << IFC_NAND_FIR0_OP4_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fir1, 0x0); - - out_be32(&ifc->ifc_nand.nand_fcr0, - (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | - (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_RBCD << IFC_NAND_FIR0_OP4_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir1, 0x0); + + ifc_out32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | + (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); } else { - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_RBCD << IFC_NAND_FIR0_OP3_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_RBCD << IFC_NAND_FIR0_OP3_SHIFT));
if (oob) - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_READOOB << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READOOB << IFC_NAND_FCR0_CMD0_SHIFT); else - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); } }
@@ -408,7 +408,7 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, switch (command) { /* READ0 read the entire buffer to use hardware ECC. */ case NAND_CMD_READ0: { - out_be32(&ifc->ifc_nand.nand_fbcr, 0); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 0); set_addr(mtd, 0, page_addr, 0);
ctrl->read_bytes = mtd->writesize + mtd->oobsize; @@ -424,7 +424,7 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command,
/* READOOB reads only the OOB because no ECC is performed. */ case NAND_CMD_READOOB: - out_be32(&ifc->ifc_nand.nand_fbcr, mtd->oobsize - column); + ifc_out32(&ifc->ifc_nand.nand_fbcr, mtd->oobsize - column); set_addr(mtd, column, page_addr, 1);
ctrl->read_bytes = mtd->writesize + mtd->oobsize; @@ -441,19 +441,19 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, if (command == NAND_CMD_PARAM) timing = IFC_FIR_OP_RBCD;
- out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_UA << IFC_NAND_FIR0_OP1_SHIFT) | - (timing << IFC_NAND_FIR0_OP2_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fcr0, - command << IFC_NAND_FCR0_CMD0_SHIFT); - out_be32(&ifc->ifc_nand.row3, column); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_UA << IFC_NAND_FIR0_OP1_SHIFT) | + (timing << IFC_NAND_FIR0_OP2_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + command << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.row3, column);
/* * although currently it's 8 bytes for READID, we always read * the maximum 256 bytes(for PARAM) */ - out_be32(&ifc->ifc_nand.nand_fbcr, 256); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 256); ctrl->read_bytes = 256;
set_addr(mtd, 0, 0, 0); @@ -468,16 +468,16 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command,
/* ERASE2 uses the block and page address from ERASE1 */ case NAND_CMD_ERASE2: - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP2_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP2_SHIFT));
- out_be32(&ifc->ifc_nand.nand_fcr0, - (NAND_CMD_ERASE1 << IFC_NAND_FCR0_CMD0_SHIFT) | - (NAND_CMD_ERASE2 << IFC_NAND_FCR0_CMD1_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_ERASE1 << IFC_NAND_FCR0_CMD0_SHIFT) | + (NAND_CMD_ERASE2 << IFC_NAND_FCR0_CMD1_SHIFT));
- out_be32(&ifc->ifc_nand.nand_fbcr, 0); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 0); ctrl->read_bytes = 0; fsl_ifc_run_command(mtd); return; @@ -494,17 +494,18 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, (NAND_CMD_STATUS << IFC_NAND_FCR0_CMD1_SHIFT) | (NAND_CMD_PAGEPROG << IFC_NAND_FCR0_CMD2_SHIFT);
- out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_WBCD << IFC_NAND_FIR0_OP3_SHIFT) | - (IFC_FIR_OP_CMD2 << IFC_NAND_FIR0_OP4_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fir1, - (IFC_FIR_OP_CW1 << IFC_NAND_FIR1_OP5_SHIFT) | - (IFC_FIR_OP_RDSTAT << + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_WBCD << + IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_CMD2 << IFC_NAND_FIR0_OP4_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir1, + (IFC_FIR_OP_CW1 << IFC_NAND_FIR1_OP5_SHIFT) | + (IFC_FIR_OP_RDSTAT << IFC_NAND_FIR1_OP6_SHIFT) | - (IFC_FIR_OP_NOP << IFC_NAND_FIR1_OP7_SHIFT)); + (IFC_FIR_OP_NOP << IFC_NAND_FIR1_OP7_SHIFT)); } else { nand_fcr0 = ((NAND_CMD_PAGEPROG << IFC_NAND_FCR0_CMD1_SHIFT) | @@ -513,18 +514,18 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, (NAND_CMD_STATUS << IFC_NAND_FCR0_CMD3_SHIFT));
- out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CMD2 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP3_SHIFT) | - (IFC_FIR_OP_WBCD << IFC_NAND_FIR0_OP4_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fir1, - (IFC_FIR_OP_CMD1 << IFC_NAND_FIR1_OP5_SHIFT) | - (IFC_FIR_OP_CW3 << IFC_NAND_FIR1_OP6_SHIFT) | - (IFC_FIR_OP_RDSTAT << + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CMD2 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_WBCD << IFC_NAND_FIR0_OP4_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir1, + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR1_OP5_SHIFT) | + (IFC_FIR_OP_CW3 << IFC_NAND_FIR1_OP6_SHIFT) | + (IFC_FIR_OP_RDSTAT << IFC_NAND_FIR1_OP7_SHIFT) | - (IFC_FIR_OP_NOP << IFC_NAND_FIR1_OP8_SHIFT)); + (IFC_FIR_OP_NOP << IFC_NAND_FIR1_OP8_SHIFT));
if (column >= mtd->writesize) nand_fcr0 |= @@ -539,7 +540,7 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, column -= mtd->writesize; ctrl->oob = 1; } - out_be32(&ifc->ifc_nand.nand_fcr0, nand_fcr0); + ifc_out32(&ifc->ifc_nand.nand_fcr0, nand_fcr0); set_addr(mtd, column, page_addr, ctrl->oob); return; } @@ -547,21 +548,21 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, /* PAGEPROG reuses all of the setup from SEQIN and adds the length */ case NAND_CMD_PAGEPROG: if (ctrl->oob) - out_be32(&ifc->ifc_nand.nand_fbcr, - ctrl->index - ctrl->column); + ifc_out32(&ifc->ifc_nand.nand_fbcr, + ctrl->index - ctrl->column); else - out_be32(&ifc->ifc_nand.nand_fbcr, 0); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 0);
case NAND_CMD_STATUS: - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_RB << IFC_NAND_FIR0_OP1_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_STATUS << IFC_NAND_FCR0_CMD0_SHIFT); - out_be32(&ifc->ifc_nand.nand_fbcr, 1); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_RB << IFC_NAND_FIR0_OP1_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_STATUS << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 1); set_addr(mtd, 0, 0, 0); ctrl->read_bytes = 1;
@@ -572,10 +573,10 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, return;
case NAND_CMD_RESET: - out_be32(&ifc->ifc_nand.nand_fir0, - IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT); - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_RESET << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fir0, + IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_RESET << IFC_NAND_FCR0_CMD0_SHIFT); fsl_ifc_run_command(mtd); return;
@@ -647,8 +648,8 @@ static uint8_t fsl_ifc_read_byte16(struct mtd_info *mtd) * next byte. */ if (ctrl->index < ctrl->read_bytes) { - data = in_be16((uint16_t *)&ctrl-> - addr[ctrl->index]); + data = ifc_in16((uint16_t *)&ctrl-> + addr[ctrl->index]); ctrl->index += 2; return (uint8_t)data; } @@ -727,12 +728,12 @@ static int fsl_ifc_wait(struct mtd_info *mtd, struct nand_chip *chip) return NAND_STATUS_FAIL;
/* Use READ_STATUS command, but wait for the device to be ready */ - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_RDSTAT << IFC_NAND_FIR0_OP1_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fcr0, NAND_CMD_STATUS << - IFC_NAND_FCR0_CMD0_SHIFT); - out_be32(&ifc->ifc_nand.nand_fbcr, 1); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_RDSTAT << IFC_NAND_FIR0_OP1_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fcr0, NAND_CMD_STATUS << + IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 1); set_addr(mtd, 0, 0, 0); ctrl->read_bytes = 1;
@@ -741,7 +742,7 @@ static int fsl_ifc_wait(struct mtd_info *mtd, struct nand_chip *chip) if (ctrl->status != IFC_NAND_EVTER_STAT_OPC) return NAND_STATUS_FAIL;
- nand_fsr = in_be32(&ifc->ifc_nand.nand_fsr); + nand_fsr = ifc_in32(&ifc->ifc_nand.nand_fsr);
/* Chip sometimes reporting write protect even when it's not */ nand_fsr = nand_fsr | NAND_STATUS_WP; @@ -784,17 +785,17 @@ static void fsl_ifc_ctrl_init(void) ifc_ctrl->regs = IFC_BASE_ADDR;
/* clear event registers */ - out_be32(&ifc_ctrl->regs->ifc_nand.nand_evter_stat, ~0U); - out_be32(&ifc_ctrl->regs->ifc_nand.pgrdcmpl_evt_stat, ~0U); + ifc_out32(&ifc_ctrl->regs->ifc_nand.nand_evter_stat, ~0U); + ifc_out32(&ifc_ctrl->regs->ifc_nand.pgrdcmpl_evt_stat, ~0U);
/* Enable error and event for any detected errors */ - out_be32(&ifc_ctrl->regs->ifc_nand.nand_evter_en, - IFC_NAND_EVTER_EN_OPC_EN | - IFC_NAND_EVTER_EN_PGRDCMPL_EN | - IFC_NAND_EVTER_EN_FTOER_EN | - IFC_NAND_EVTER_EN_WPER_EN); + ifc_out32(&ifc_ctrl->regs->ifc_nand.nand_evter_en, + IFC_NAND_EVTER_EN_OPC_EN | + IFC_NAND_EVTER_EN_PGRDCMPL_EN | + IFC_NAND_EVTER_EN_FTOER_EN | + IFC_NAND_EVTER_EN_WPER_EN);
- out_be32(&ifc_ctrl->regs->ifc_nand.ncfgr, 0x0); + ifc_out32(&ifc_ctrl->regs->ifc_nand.ncfgr, 0x0); }
static void fsl_ifc_select_chip(struct mtd_info *mtd, int chip) @@ -810,50 +811,50 @@ static void fsl_ifc_sram_init(void) cs = ifc_ctrl->cs_nand >> IFC_NAND_CSEL_SHIFT;
/* Save CSOR and CSOR_ext */ - csor = in_be32(&ifc_ctrl->regs->csor_cs[cs].csor); - csor_ext = in_be32(&ifc_ctrl->regs->csor_cs[cs].csor_ext); + csor = ifc_in32(&ifc_ctrl->regs->csor_cs[cs].csor); + csor_ext = ifc_in32(&ifc_ctrl->regs->csor_cs[cs].csor_ext);
/* chage PageSize 8K and SpareSize 1K*/ csor_8k = (csor & ~(CSOR_NAND_PGS_MASK)) | 0x0018C000; - out_be32(&ifc_ctrl->regs->csor_cs[cs].csor, csor_8k); - out_be32(&ifc_ctrl->regs->csor_cs[cs].csor_ext, 0x0000400); + ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor, csor_8k); + ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor_ext, 0x0000400);
/* READID */ - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_UA << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RB << IFC_NAND_FIR0_OP2_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_READID << IFC_NAND_FCR0_CMD0_SHIFT); - out_be32(&ifc->ifc_nand.row3, 0x0); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_UA << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RB << IFC_NAND_FIR0_OP2_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READID << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.row3, 0x0);
- out_be32(&ifc->ifc_nand.nand_fbcr, 0x0); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 0x0);
/* Program ROW0/COL0 */ - out_be32(&ifc->ifc_nand.row0, 0x0); - out_be32(&ifc->ifc_nand.col0, 0x0); + ifc_out32(&ifc->ifc_nand.row0, 0x0); + ifc_out32(&ifc->ifc_nand.col0, 0x0);
/* start read seq */ - out_be32(&ifc->ifc_nand.nandseq_strt, IFC_NAND_SEQ_STRT_FIR_STRT); + ifc_out32(&ifc->ifc_nand.nandseq_strt, IFC_NAND_SEQ_STRT_FIR_STRT);
while (end_tick > get_ticks()) { - ifc_ctrl->status = in_be32(&ifc->ifc_nand.nand_evter_stat); + ifc_ctrl->status = ifc_in32(&ifc->ifc_nand.nand_evter_stat);
if (ifc_ctrl->status & IFC_NAND_EVTER_STAT_OPC) break; }
- out_be32(&ifc->ifc_nand.nand_evter_stat, ifc_ctrl->status); + ifc_out32(&ifc->ifc_nand.nand_evter_stat, ifc_ctrl->status);
/* Restore CSOR and CSOR_ext */ - out_be32(&ifc_ctrl->regs->csor_cs[cs].csor, csor); - out_be32(&ifc_ctrl->regs->csor_cs[cs].csor_ext, csor_ext); + ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor, csor); + ifc_out32(&ifc_ctrl->regs->csor_cs[cs].csor_ext, csor_ext); }
static int fsl_ifc_chip_init(int devnum, u8 *addr) @@ -883,8 +884,8 @@ static int fsl_ifc_chip_init(int devnum, u8 *addr) for (priv->bank = 0; priv->bank < MAX_BANKS; priv->bank++) { phys_addr_t phys_addr = virt_to_phys(addr);
- cspr = in_be32(&ifc_ctrl->regs->cspr_cs[priv->bank].cspr); - csor = in_be32(&ifc_ctrl->regs->csor_cs[priv->bank].csor); + cspr = ifc_in32(&ifc_ctrl->regs->cspr_cs[priv->bank].cspr); + csor = ifc_in32(&ifc_ctrl->regs->csor_cs[priv->bank].csor);
if ((cspr & CSPR_V) && (cspr & CSPR_MSEL) == CSPR_MSEL_NAND && (cspr & CSPR_BA) == CSPR_PHYS_ADDR(phys_addr)) { @@ -1004,7 +1005,7 @@ static int fsl_ifc_chip_init(int devnum, u8 *addr) nand->ecc.mode = NAND_ECC_SOFT; }
- ver = in_be32(&ifc_ctrl->regs->ifc_rev); + ver = ifc_in32(&ifc_ctrl->regs->ifc_rev); if (ver == FSL_IFC_V1_1_0) fsl_ifc_sram_init();
diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index 9de327b..d970369 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -60,7 +60,7 @@ static inline void nand_wait(uchar *buf, int bufnum, int page_size) bufnum_end = bufnum + bufperpage - 1;
do { - status = in_be32(&ifc->ifc_nand.nand_evter_stat); + status = ifc_in32(&ifc->ifc_nand.nand_evter_stat); } while (!(status & IFC_NAND_EVTER_STAT_OPC));
if (status & IFC_NAND_EVTER_STAT_FTOER) { @@ -70,14 +70,14 @@ static inline void nand_wait(uchar *buf, int bufnum, int page_size) }
for (i = bufnum / 4; i <= bufnum_end / 4; i++) - eccstat[i] = in_be32(&ifc->ifc_nand.nand_eccstat[i]); + eccstat[i] = ifc_in32(&ifc->ifc_nand.nand_eccstat[i]);
for (i = bufnum; i <= bufnum_end; i++) { if (check_read_ecc(buf, eccstat, i, page_size)) break; }
- out_be32(&ifc->ifc_nand.nand_evter_stat, status); + ifc_out32(&ifc->ifc_nand.nand_evter_stat, status); }
static inline int bad_block(uchar *marker, int port_size) @@ -135,38 +135,38 @@ static void nand_load(unsigned int offs, int uboot_size, uchar *dst) blk_size = pages_per_blk * page_size;
/* Open Full SRAM mapping for spare are access */ - out_be32(&ifc->ifc_nand.ncfgr, 0x0); + ifc_out32(&ifc->ifc_nand.ncfgr, 0x0);
/* Clear Boot events */ - out_be32(&ifc->ifc_nand.nand_evter_stat, 0xffffffff); + ifc_out32(&ifc->ifc_nand.nand_evter_stat, 0xffffffff);
/* Program FIR/FCR for Large/Small page */ if (page_size > 512) { - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | - (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP4_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fir1, 0x0); - - out_be32(&ifc->ifc_nand.nand_fcr0, - (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | - (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP4_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir1, 0x0); + + ifc_out32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | + (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); } else { - out_be32(&ifc->ifc_nand.nand_fir0, - (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | - (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | - (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | - (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP3_SHIFT)); - out_be32(&ifc->ifc_nand.nand_fir1, 0x0); - - out_be32(&ifc->ifc_nand.nand_fcr0, - NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP3_SHIFT)); + ifc_out32(&ifc->ifc_nand.nand_fir1, 0x0); + + ifc_out32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); }
/* Program FBCR = 0 for full page read */ - out_be32(&ifc->ifc_nand.nand_fbcr, 0); + ifc_out32(&ifc->ifc_nand.nand_fbcr, 0);
/* Read and copy u-boot on SDRAM from NAND device, In parallel * check for Bad block if found skip it and read continue to @@ -179,11 +179,11 @@ static void nand_load(unsigned int offs, int uboot_size, uchar *dst) bufnum = pg_no & bufnum_mask; sram_addr = bufnum * page_size * 2;
- out_be32(&ifc->ifc_nand.row0, pg_no); - out_be32(&ifc->ifc_nand.col0, 0); + ifc_out32(&ifc->ifc_nand.row0, pg_no); + ifc_out32(&ifc->ifc_nand.col0, 0); /* start read */ - out_be32(&ifc->ifc_nand.nandseq_strt, - IFC_NAND_SEQ_STRT_FIR_STRT); + ifc_out32(&ifc->ifc_nand.nandseq_strt, + IFC_NAND_SEQ_STRT_FIR_STRT);
/* wait for read to complete */ nand_wait(&buf[sram_addr], bufnum, page_size); diff --git a/include/fsl_ifc.h b/include/fsl_ifc.h index be6c107..1ff4728 100644 --- a/include/fsl_ifc.h +++ b/include/fsl_ifc.h @@ -12,6 +12,20 @@ #include <config.h> #include <common.h>
+ +#ifdef CONFIG_SYS_FSL_IFC_LE +#define ifc_in32(a) in_le32(a) +#define ifc_out32(a, v) out_le32(a, v) +#define ifc_in16(a) in_le16(a) +#elif defined(CONFIG_SYS_FSL_IFC_BE) +#define ifc_in32(a) in_be32(a) +#define ifc_out32(a, v) out_be32(a, v) +#define ifc_in16(a) in_be16(a) +#else +#error Neither CONFIG_IFC_REG_LE nor CONFIG_IFC_REG_BE is defined +#endif + + /* * CSPR - Chip Select Property Register */ @@ -773,20 +787,22 @@ extern void init_early_memctl_regs(void);
#define IFC_BASE_ADDR ((struct fsl_ifc *)CONFIG_SYS_IFC_ADDR)
-#define get_ifc_cspr_ext(i) (in_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext)) -#define get_ifc_cspr(i) (in_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr)) -#define get_ifc_csor_ext(i) (in_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext)) -#define get_ifc_csor(i) (in_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor)) -#define get_ifc_amask(i) (in_be32(&(IFC_BASE_ADDR)->amask_cs[i].amask)) -#define get_ifc_ftim(i, j) (in_be32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j])) - -#define set_ifc_cspr_ext(i, v) (out_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext, v)) -#define set_ifc_cspr(i, v) (out_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr, v)) -#define set_ifc_csor_ext(i, v) (out_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext, v)) -#define set_ifc_csor(i, v) (out_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor, v)) -#define set_ifc_amask(i, v) (out_be32(&(IFC_BASE_ADDR)->amask_cs[i].amask, v)) +#define get_ifc_cspr_ext(i) (ifc_in32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext)) +#define get_ifc_cspr(i) (ifc_in32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr)) +#define get_ifc_csor_ext(i) (ifc_in32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext)) +#define get_ifc_csor(i) (ifc_in32(&(IFC_BASE_ADDR)->csor_cs[i].csor)) +#define get_ifc_amask(i) (ifc_in32(&(IFC_BASE_ADDR)->amask_cs[i].amask)) +#define get_ifc_ftim(i, j) (ifc_in32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j])) + +#define set_ifc_cspr_ext(i, v) \ + (ifc_out32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext, v)) +#define set_ifc_cspr(i, v) (ifc_out32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr, v)) +#define set_ifc_csor_ext(i, v) \ + (ifc_out32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext, v)) +#define set_ifc_csor(i, v) (ifc_out32(&(IFC_BASE_ADDR)->csor_cs[i].csor, v)) +#define set_ifc_amask(i, v) (ifc_out32(&(IFC_BASE_ADDR)->amask_cs[i].amask, v)) #define set_ifc_ftim(i, j, v) \ - (out_be32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j], v)) + (ifc_out32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j], v))
enum ifc_chip_sel { IFC_CS0,
Prabhakar Kushwaha
