[U-Boot] [PATCH v3] MX28: use a clear name for DDR2 initialization
The mx28 prefix has been added to the initialization data and function so it is clear by which SoC it is used as i.MX233 will have a specific one. While on that, we also change it to static.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - use static for the allocation of memory initialization matrix
Changes in v3: - change short-description prefix
arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c index e17a4d7..cca1316 100644 --- a/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c +++ b/arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c @@ -31,7 +31,7 @@
#include "mx28_init.h"
-uint32_t dram_vals[] = { +static uint32_t mx28_dram_vals[] = { 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, @@ -88,14 +88,14 @@ void __mx28_adjust_memory_params(uint32_t *dram_vals) void mx28_adjust_memory_params(uint32_t *dram_vals) __attribute__((weak, alias("__mx28_adjust_memory_params")));
-void init_m28_200mhz_ddr2(void) +void init_mx28_200mhz_ddr2(void) { int i;
- mx28_adjust_memory_params(dram_vals); + mx28_adjust_memory_params(mx28_dram_vals);
- for (i = 0; i < ARRAY_SIZE(dram_vals); i++) - writel(dram_vals[i], MXS_DRAM_BASE + (4 * i)); + for (i = 0; i < ARRAY_SIZE(mx28_dram_vals); i++) + writel(mx28_dram_vals[i], MXS_DRAM_BASE + (4 * i)); }
void mx28_mem_init_clock(void) @@ -230,7 +230,7 @@ void mx28_mem_init(void) /* Clear START bit from DRAM_CTL16 */ clrbits_le32(MXS_DRAM_BASE + 0x40, 1);
- init_m28_200mhz_ddr2(); + init_mx28_200mhz_ddr2();
/* Clear SREFRESH bit from DRAM_CTL17 */ clrbits_le32(MXS_DRAM_BASE + 0x44, 1);
On Sat, Jul 28, 2012 at 6:44 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Changes in v2:
Changes in v3:
Ping?
Dear Otavio Salvador,
Changes in v2:
Changes in v3:
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Changes in v2:
Changes in v3:
- mx28_adjust_memory_params(mx28_dram_vals);
- for (i = 0; i < ARRAY_SIZE(mx28_dram_vals); i++)
Acked-by : Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Applied to u-boot-imx, thanks
Otavio Salvador
Stefano Babic
