[U-Boot-Users] "Uncompressing Kernel Image" failed
Hi allĀ !
I am trying to boot a Linux Kernel (uImage) which size is 1.1 MB. tftp 0x600000 uImage bootm 0x600000 => uboot stays inside uncompressing process, OK don't appear.
U-Boot 1.1.4 ( - Jun 22 2006 - 15:17:55) CPU: 8541, Version: 1.1, (0x807a0011) Core: E500, Version: 2.0, (0x80200020) Clock Configuration: CPU: 833 MHz, CCB: 333 MHz, DDR: 166 MHz, LBC: 83 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled BOARD: Version 0, EPLD 14 PCI1: 32 bit, 66 MHz (compiled) PCI2: 32 bit, 66 MHz (compiled) I2C: ready DRAM: Initializing DDR: 128 MB Testing DRAM from 0x00200000 to 0x00240000 DRAM test phase 3a: DRAM test passed. FLASH: 32 MB L2 cache 256KB: enabled In: serial Out: serial Err: serial Net: FCC1 ETHERNET
Tftp 0x600000 uImage Load address: 0x0600000 Loading: ################################################################# ################################################################# ################################################################# ################################ done Bytes transferred = 1157389 (11a90d hex)
## Booting image at 00600000 ... Image Name: Linux-2.6.13 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1157325 Bytes = 1.1 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ...
And that'a all. Reboot is needed. Any idea? Thanks a lot. Anne-Sophie.
Harnois Anne-Sophie
