[U-Boot-Users] [PATCH] cfi_flash: make the command u32 only
This got change by commit 93c56f212c [cfi_flash: support of long cmd in U-boot.]
Long is the wrong type because it will behave differently on 64bit machnines in a way that is probably not expected. u32 should be enough.
Cc: Alexey Korolev akorolev@infradead.org Cc: Vasiliy Leonenko vasiliy.leonenko@mail.ru Signed-off-by: Sebastian Siewior bigeasy@linutronix.de --- drivers/mtd/cfi_flash.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index c0ea97b..799db71 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -301,7 +301,7 @@ static inline void flash_unmap(flash_info_t *info, flash_sect_t sect, /*----------------------------------------------------------------------- * make a proper sized command based on the port and chip widths */ -static void flash_make_cmd (flash_info_t * info, ulong cmd, void *cmdbuf) +static void flash_make_cmd (flash_info_t * info, uint cmd, void *cmdbuf) { int i; int cword_offset; @@ -316,9 +316,9 @@ static void flash_make_cmd (flash_info_t * info, ulong cmd, void *cmdbuf) val = *((uchar*)&cmd + cword_offset); #else cp_offset = i - 1; - val = *((uchar*)&cmd + sizeof(ulong) - cword_offset - 1); + val = *((uchar*)&cmd + sizeof(uint) - cword_offset - 1); #endif - cp[cp_offset] = (cword_offset >= sizeof(ulong)) ? 0x00 : val; + cp[cp_offset] = (cword_offset >= sizeof(uint)) ? 0x00 : val; } }
@@ -329,7 +329,7 @@ static void flash_make_cmd (flash_info_t * info, ulong cmd, void *cmdbuf) static void print_longlong (char *str, unsigned long long data) { int i; - char *cp; + unsigned char *cp;
cp = (unsigned char *) &data; for (i = 0; i < 8; i++) @@ -433,7 +433,7 @@ static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, * Write a proper sized command to the correct address */ static void flash_write_cmd (flash_info_t * info, flash_sect_t sect, - uint offset, ulong cmd) + uint offset, uint cmd) {
void *addr;
Well, if you write "u32" in the commit message...
#endif
...you should also use "u32" (and not uint) in the patch.
Please fix.
Cc: Alexey Korolev akorolev@infradead.org Cc: Vasiliy Leonenko vasiliy.leonenko@mail.ru Signed-off-by: Sebastian Siewior bigeasy@linutronix.de --- drivers/mtd/cfi_flash.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index c0ea97b..4340b1b 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -301,7 +301,7 @@ static inline void flash_unmap(flash_info_t *info, flash_sect_t sect, /*----------------------------------------------------------------------- * make a proper sized command based on the port and chip widths */ -static void flash_make_cmd (flash_info_t * info, ulong cmd, void *cmdbuf) +static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) { int i; int cword_offset; @@ -316,9 +316,9 @@ static void flash_make_cmd (flash_info_t * info, ulong cmd, void *cmdbuf) val = *((uchar*)&cmd + cword_offset); #else cp_offset = i - 1; - val = *((uchar*)&cmd + sizeof(ulong) - cword_offset - 1); + val = *((uchar*)&cmd + sizeof(u32) - cword_offset - 1); #endif - cp[cp_offset] = (cword_offset >= sizeof(ulong)) ? 0x00 : val; + cp[cp_offset] = (cword_offset >= sizeof(u32)) ? 0x00 : val; } }
@@ -433,7 +433,7 @@ static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, * Write a proper sized command to the correct address */ static void flash_write_cmd (flash_info_t * info, flash_sect_t sect, - uint offset, ulong cmd) + uint offset, u32 cmd) {
void *addr;
Applied, thanks.
Sebastian Siewior
